I used the config from config tool and I can't reach the DWC now
Firmware installation
    siladeniz
    hey,
    I have duet 2 ethernet I am using reprap 3.4.5
    I wanted the use both hotend heater pins. firstly to check if the new cables are working or not I used the previously used pin which is e0. the hotend worked properly, so no problem with the cable. later I put the same cables to the other pin(e1) and leave e0 free. I changed the pin and heater number from config, but it didn't worked I could see the new created heater from DWC dashboard but the temprature was -273 C. so I went to config tool and add 1 more heater and create the new config. But unfortunately I didn't add the new part to my config I upload the new created system files via DWC. And I think it changed the config too, later I couldn't reach the DWC anymore. I checked the IP address from pronter face it was 0.0.0.0 and set the IP address to my previous one by m552 s0 p... and it settled but I still couldnt reach DWC. I took out the sd card and put it to my computer and delete the config and add the previous config but it doesn't work still. this is the previous config
    ; Configuration file for Duet Ethernet (firmware version 3)
    ; generated by Julian Zettl Feb 2022
    ; edited by Deniz and Tillman July 2023
    ; ================= General preferences ===================
    M550 P"BLV" ; set printer name
    M669 K1 ; Select CoreXY mode
    ;=================== Calling Macro =====================
    ;M98 P/macros/print_start.g
    ; ====================== Network ===========================
    M552 S1 ; enable network
    M552 P192.168.1.254 ; set IP Address
    M553 P255.255.255.0 ; set Netmask
    M554 P192.168.1.0 ; Set default Gateway
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    ; ======================= Drives ===========================
    M569 P0 S0 ; physical drive 0 goes backwards (A motor)
    M569 P1 S0 ; physical drive 1 goes backwards (B motor)
    M569 P2 S1 ; physical drive 2 goes forwards (alpha)
    M569 P5 S0 ; physical drive 4 goes forwards (beta)
    M569 P6 S0 ; physical drive 6 goes forwards (gamma)
    M569 P3 S1 ; physical drive 3 goes forwards (E0 motor)
    ;M569 P5 S1 ; physical drive 5 goes forwards (E1 motor)
    M584 X0 Y1 Z2:5:6 E3:4 ; set drive mapping
    ; ===================== Drive Settings =====================
    M350 X128 Y128 Z128:128:128 E128:128 I1 ; configure microstepping with interpolation
    M92 X1600 Y1600 Z12800:12800:12800 E3936:6400 ; steps per mm E1:800 E2:837
    M566 X540 Y540 Z56:56:56 E480:480 ; maximum instantaneous speed changes mm/min
    M203 X10000 Y10000 Z1800:1800:1800 E15000:15000 ; maximum speeds (mm/s)
    M201 X2000 Y2000 Z100:100:100 E1000:3000 ; set accelerations (mm/s^2)
    M906 X1000 Y1000 Z800 E800 I50 ; set motor currents (mA) and idle %
    M84 S120 ; Set idle timeout
    ; ================ Independent Z Leveleing =================
    M671 X-170.24:170.24:0 Y-128.815:-128.815:130.75 S20 ; leadscrew pivot point:
    ; ===================== Axis Limits ========================
    M208 X-45 Y-36 Z0 S1 ; set axis min
    M208 X270 Y270 Z200 S0 ; set axis max
    ;originally with 0,0 centered on bed:
    ;M208 X-152:150 Y-144:172
    ; ======================= Endstops =========================
    M574 X1 S1 P"x_stop" ; X min active high endstop switch
    M574 Y2 S1 P"y_stop" ; Y max active high endstop switch
    ; ======================== Z-Probe =========================
    ;M950
    M558 P9 C"zprobe.in" H5 F120 T6000 ; Duet 2 WiFi/Ethernet, DueX2/5
    M950 S0 C"duex.pwm1" ; Duet 2 WiFi/Ethernet + DueX2/5
    ;M307 H3 A-1 C-1 D-1 ; Disable heater 3 to free up PWM channel 1 on the Duex board.
    ;M558 P1 C"ZPROBE.IN" H5 F500 T1000 ; Z Probe type=analog, pin, dive height+rate, travelspeed
    ;M280 P0 S90
    G31 X27 Y58 Z1 P25
    ;G31 X0 Y0 Z0.2 P500 ; Z Probe offset and trigger value
    M557 X15:215 Y15:195 S60 ; define mesh grid
    ; ======================== Heaters =========================
    ;M305 P1 T100000 B4267 R4700 ; old RRF2.x
    M301 H1 P21.1 I0.816 D59.6 ;PID settings hotend from old config
    M308 S1 P"e0temp" Y"thermistor" A"Hotend" T100000 B4267 R4700 ; extruder thermistor
    M950 H1 C"e0heat" T1 ; link heater to sensor
    M143 H1 S285 ; temperature limit
    M104 S0 ; turn off nozzle heater
    M308 S0 P"bedtemp" Y"thermistor" A"Bed" T100000 B4267 R4700 ; configure sensor 0 as thermistor on pin bedtemp
    M950 H0 Q10 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0
    M307 H0 A284.0 C843.8 D11.0 B0 ; Heatbed PID
    M140 H0 S0 ; map heated bed to heater 0
    M143 H0 S100 ; set temperature limit for heater 0 to 120C
    M308 S2 P"mcu-temp" Y"mcu-temp" A"Duet Board" ; Configure MCU sensor
    ; ========================= Fans ===========================
    M106 P0 S0.1 I0 F500 T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M950 F0 C"fan0" Q250 ; create fan 1 on pin fan0 and set its frequency
    M106 P0 C"hotend fan" T60 H1 ; P"fan1" C"displayname" T"triggervalue" H"heater1"
    M950 F1 C"fan1"
    M106 P1 S100
    ; ======================== Tools ===========================
    M563 P0 S"FDM" D0 H1 ; P"tool0" S"displayname" D"e0motor" H"heater1"
    ; ===================== Custom settings ====================
    M564 H0 ; Let the Jog buttons work blv: added to allow jog buttons
    ; ====================== Miscellaneous =====================
    ;M575 P1 S1 B57600 ; enable support for PanelDue
    ;M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
    ;Duet 2 pinout-*=inverted
    ;bedheat * Bedheater
    ;e0heat * Hotend
    ;e1heat * NC
    ;exp.heater3 BLTouch S
    ;Duet 2 temperature inputs
    ;bedtemp Bed thermistor
    ;e0temp HE thermistor
    ;e1temp NC
    ;Duet 2 fan outputs
    ;fan0 MB Fan GND
    ;fan1 LY Fan GND
    ;fan2 HE Fan GND
    ;Endstop inputs
    ;xstop X Endstop C
    ;ystop Y Endstop C
    ;zstop NC
    ;e0stop Filament runout sensor C
    ;e1stop Off button C pin
    ;zprobe.in Z-
    ;zprobe.mod NC
    this is the config generated by config tool
    ; Configuration file for Duet WiFi (firmware version 3.3)
    ; generated by RepRapFirmware Configuration Tool v3.3.16 on Thu Aug 31 2023 10:46:37 GMT+0200 (Central European Summer Time)
    M550 P"BLV Cube" ; set printer name
    M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
    M84 S30 ; Set idle timeout
    M208 X230 Y210 Z200 S0 ; set axis maxima
    M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
    M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
    M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
    M308 S1 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e1temp
    M950 H1 C"e1heat" T1 ; create nozzle heater output on e1heat and map it to sensor 1
      @siladeniz said in I used the config from config tool and I can't reach the DWC now:
      Did you try adding those lines from your old config to your new config?
      undefined 2 Replies Last reply 1 Sept 2023, 07:36 Reply Quote 0
        siladeniz @Phaedrux
        @Phaedrux no because I don't want to use new config I just want to take the second heater lines from there and add to my config. Also while I am trying to update the documents which I got from config tool, I deleted www, firmware and sys files in sd card. and add the config tool generated www,firmware and sys files. later as I said previously it didn't work and I turned back to old files. I think I might delete something wrong I'll share the files with you can you check please?
        or there is another option I can delete all the files in the sd card, I'll copy my config and macros. and I will download the latest firmware version and put it to the sd card. Does it work? I don't know if the other files can be arranged by user or just copy paste from the downloads thats why I don't know if I arranged them in some way.
        here is the files:
        www sys macros gcodes firmware
        undefined 1 Reply Last reply 1 Sept 2023, 08:01 Reply Quote 0
          siladeniz @siladeniz
          @siladeniz I noticed that in the files config.g and config.json don't have same content. Is it should be like that?
            siladeniz @Phaedrux
            @Phaedrux okay I found the problem the gateway number was changed and I set it with m554
            • Phaedruxundefined Phaedrux marked this topic as a question 1 Sept 2023, 16:58
            • Phaedruxundefined Phaedrux has marked this topic as solved 1 Sept 2023, 16:58
            1 out of 5
