    firmware build
    Firmware developers
    1.7k
    • jokeundefined
      joke
      Re: Firmware building
      I use the msy2 to build firmware.But when I re-downloaded using the above steps, I'm not sure where the problem occurred.
      cd8b8a40-fd6c-4e9a-b123-3e471487611c-image.png be446c28-e026-42df-8c7a-1db5f642329d-image.png bad597fc-55af-404f-bbaa-a4ea48991c0c-image.png
        dc42 administrators @joke
        @joke you haven't defined where the ARM gcc compiler is. See step 10 at https://github.com/Duet3D/RepRapFirmware/wiki/Building-RepRapFirmware#instructions-for-building-under-windows.
        jokeundefined 1 Reply Last reply Reply Quote 0
        • jokeundefined
          joke @dc42
          @dc42 d51cdcf9-6c5b-46d7-9caf-b72c9bef716f-image.png Is that so? Or can you give me a screenshot? Step 10 I don't see too clearly, thank you very much.
            @joke mine looks like this:
            The first one ArmGccPath is needed for all the RRF projects. The remaining three are needed only to build DuetWiFiSocketServer, which you don't need to do.
            • jokeundefined
              joke @dc42
              @dc42 78da4dde-48f7-4be2-8ee4-ff8a96ec2b36-image.png 2700e6a3-bf61-4029-9989-92a1c3c27d86-image.png 56e350e0-7511-4a13-9cdd-a50cf74297bc-image.png d382ac98-4356-4010-b8c7-294b2d300ed4-image.png I set it up this way, but there are still these errors, can you help me see what's going on.
              • JoergS5undefined
                JoergS5 @joke
                @joke your ArmGccPath looks wrong, David's and my are ...eabi/12.2 mpacbti-rel1/bin, but your setting is ...eabi/bin, so there is missing a subdir. I expcect you extracted somehow only the exe file subdir, but the compiler needs the include subdir and maybe other subdirs also which are parallel to it.
                If I remember correctly, I had a similar situation unpacking a zip file version which didn't include all subdirs, and solved it by using the installer version. This installed all which is needed.
                • jokeundefined
                  joke @JoergS5
                  @JoergS5 0278981d-e73f-43df-b7a3-9595157ba75e-image.png Thank you, I re-decompressed arm, and after recompiling, there was a new problem, is this set wrong
                  dc42undefined JoergS5undefined 2 Replies Last reply Reply Quote 0
                    @joke 'make' is not part of the ARM compiler bundle. It is an optional component of msys2 that has to be installed separately.
                    • jokeundefined
                      joke @dc42
                      @dc42 I have installed msys2.Follow the steps you gave.Do I still need to add it to Eclipse?38032ade-b3a9-475c-a68d-2c23438d0591-image.png
                        @joke add C:\msys64\usr\bin to your PATH in windows. Then exit and reload Eclipse (otherwise it won't pick up changes to the Windows path).
                        jokeundefined 2 Replies Last reply Reply Quote 0
                        • jokeundefined
                          joke @dc42
                          @dc42 6c2d7401-b9e3-4c53-a81f-9e8eafd31bd3-image.png I made these changes, but I still have this error.
                          • jokeundefined
                            joke @dc42
                            @dc42 cc5b0be8-2ec3-45f0-816b-757cbef74864-image.png 3dd70e33-55f1-43aa-b337-76f9ccf57b70-image.png I tried to do this and could find make, but these new errors appear.
                            • JoergS5undefined
                              JoergS5 @joke
                              This post is deleted!
                              • JoergS5undefined
                                JoergS5 @joke
                                @joke said in firmware build:
                                I didn't recompile it, but used the ready compiled files. Did you check that there are include subdirectories parallel to your bin directory?
                                The include files are necessary for the compiler to find uint32_t, which is included in stdlib.h
                                • jokeundefined
                                  joke @JoergS5
                                  @JoergS5 D:\arm-gnu-toolchain-12.2.mpacbti-rel1-mingw-w64-i686-arm-none-eabi\arm-none-eabi\include\c++\12.2.1\stdlib.hd352b85a-d96e-4f2e-9218-78cbc59418c2-image.png I can find it, so the compiler path I set is D:\arm-gnu-toolchain-12.2.mpacbti-rel1-mingw-w64-i686-arm-none-eabi\arm-none-eabi\bin.5e5d01bf-31d0-4c62-bb11-4d8e16a524c4-image.png These errors still occur after compiling.Thank you.
                                  JoergS5undefined dc42undefined 4 Replies Last reply Reply Quote 0
                                  • JoergS5undefined
                                    JoergS5 @joke
                                    @joke if you have still the msys2 part in ArmGccPath setting, this may confuse the compiler. You should remove it.
                                    • JoergS5undefined
                                      JoergS5 @joke
                                      @joke an my path is different from your:
                                      C:\Program Files (x86)\Arm GNU Toolchain arm-none-eabi\12.2 mpacbti-rel1\bin\
                                      don't know why they are different, we both use 12.2 (independent from the beginning of course).
                                        @joke which version of each project have you loaded into your Eclipse workspace?
                                          @joke I think the issue may be that you are building an older version of the firmware with a compiler and library version more recent than we used with that version. In this case I think you can work around the issue by adding the line #include <stdint.c> before the line extern void vAssertCalled(uint32_t line, const char *file) noexcept; near the start of file nano-mallocr.c.
                                          jokeundefined 4 Replies Last reply Reply Quote 0
                                          • jokeundefined
                                            joke @dc42
                                            @dc42 I downloaded the 3.5 version in the picture above on the website, but after downloading the suffix of the software is 3.4, I don't know how many versions I own, is there no update 3.5 series in github now?16e12fd0-5df7-40b3-8dfa-9a9b431f3fc1-image.png
