    optical end stop for duet wifi (3.3v)
    • morisundefined
      moris
      Hi all,
      I am trying to connect this optical end stop (see attached picture),
      but it won't working led state not change on the controller
      the wiring is fine, I can see the state change in the optical end stop PCB
      on the seller site it was operate on 2.7 - 5 v as I remember
      I am sure it something about resistors
      but I don't have clue how to solve it
      thanks,
      I need your help WhatsApp Image 2023-09-12 at 09.27.16.jpeg WhatsApp Image 2023-09-17 at 21.48.37.jpeg
        dc42 administrators @moris
        @moris can you get a schematic of that endstop?
        morisundefined 1 Reply Last reply Reply Quote 0
        • morisundefined
          moris @dc42
          @dc42 nope but I have a multimeter i can check the resistance or the volt circuit
          (plugged to dc batteries or something like that )
            @moris does the LED next to the Duet endstop connector change between off and on (or vice versa) when you trigger the endstop?
            • morisundefined
              moris @dc42
              @dc42 the default state is on , when I trigger the sensor only the let on the "End Stop" board is changed ; on the duet board the LED not changing state
              also on the board itself it not changing state
              how much volt trigger the IO on the board maybe it insufficient volt
              I use 1[m] cable lenght
                @moris I suspect that the wiring between the endstop and the Duet is incorrect. Please provide photographs showing how you have connected both ends of the cable.
