    3.5.0-rc.1 has the working directory definition changed?
    Plugins for DWC and DSF
    • stuartofmtundefined
      stuartofmt
      @chrishamm
      I've recompiled DuetLapse3 against 3.5.0-rc.1 (no other changes).
      I get this error
      This is the output from journalctl
      Sep 19 11:02:49 srsender DuetPluginService[219029]:    System.ComponentModel.Win32Exception (2): An error occurred trying to start process '/opt/dsf/plugins/DuetLapse3/dsf/DuetLapse3.py' with working directory '/opt/dsf/plugins/DuetLapse3/dsf'. No such file or directory
      Sep 19 11:02:49 srsender DuetControlServer[219006]:    DuetAPI.InternalServerException: An error occurred trying to start process '/opt/dsf/plugins/DuetLapse3/dsf/DuetLapse3.py' with working directory '/opt/dsf/plugins/DuetLapse3/dsf'. No such file or directory
      Sep 19 11:02:49 srsender DuetWebServer[730]: DuetWebServer.Controllers.MachineController[0] [StartPlugin] Failed to start plugin DuetAPI.InternalServerException: An error occurred trying to start process '/opt/dsf/plugins/DuetLapse3/dsf/DuetLapse3.py' with working directory '/opt/dsf/plugins/DuetLapse3/dsf'. No such file or directory    at DuetAPIClient.BaseConnection.PerformCommand(BaseCommand command, CancellationToken cancellationToken) in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetAPIClient/BaseConnection.cs:line 156    at DuetWebServer.Controllers.MachineController.StartPlugin() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetWebServer/Controllers/MachineController.cs:line 1105
      The permissions look ok
      pi@srsender:/opt/dsf/plugins/DuetLapse3 $ ls -l
      total 8
      drwxrwxr-x 2 dsf dsf 4096 Sep 19 08:55 dsf
      drwxrwxr-x 4 dsf dsf 4096 Sep 19 08:55 dwc
      pi@srsender:/opt/dsf/plugins/DuetLapse3 $ ls -l ./dsf
      total 152
      -rwxrwx--- 1 dsf dsf 152930 Sep 19 08:55 DuetLapse3.py
      I presume (???) that the correct version of the dev environment for rc.1 is here https://github.com/Duet3D/DuetWebControl/tree/v3.5-dev
      If I run the plugin code manually - it works as expected:
      sudo python3 /opt/dsf/plugins/DuetLapse3/dsf/DuetLapse3.py -file /opt/dsf/sd/sys/DuetLapse3/DuetLapse3.config
      My plugin.json is below. The only change from 3.5.0-beta.4 (which worked fine) is the version requirements
          "id": "DuetLapse3",
          "name": "DuetLapse3",
          "author": "Stuartofmt",
          "version": "5.3.2",
          "license": "GPL-2.0-or-later",
          "homepage": "https://github.com/stuartofmt/DuetLapse3",
          "dwcVersion": "3.5.0-rc.1",
      	"sbcRequired": true,
      	"sbcDsfVersion": "3.5.0-rc.1",
      	"sbcExecutable": "DuetLapse3.py",
      	"sbcExecutableArguments": "-file /opt/dsf/sd/sys/DuetLapse3/DuetLapse3.config",
      	"sbcOutputRedirected": false,
      	"sbcPermissions": ["commandExecution", "objectModelReadWrite", "networkAccess", "webcamAccess", "readSystem", "writeSystem", "fileSystemAccess","launchProcesses", "managePlugins"],
      	"sbcPythonDependencies": ["requests", "psutil"]
      • chrishammundefined
        chrishamm administrators @stuartofmt
        @stuartofmt Can you please share the full plugin ZIP bundle so I can give it a try?
        Duet software engineer
          stuartofmt
          @chrishamm
          Here you go. It installs without error but throws the above as soon as Start is pressed.
          DuetLapse3-5.3.2.zip.txt
          stuartofmtundefined 1 Reply Last reply Reply Quote 0
            stuartofmt @stuartofmt
            @chrishamm
            I misreported. Something was changed!
            This is the first build of the plugin I am attempting on Bullseye 64K with DSF/DWC installed using the usual instructions. The installation was error free and I have full control over my printer using DWC. ALso, as reported above, I can successfully invoke the plugin code from the command line.
            About a year ago or so ago, I had the same error and ended up "downgrading" to the official Duet3d Buster release to get it working.
            Is it possible that there is something between the two versions of Debian that is causing the issue? Is there an official build Duet3d Bullseye version (I could not find one)?
            P.S. I also tried with "sbcExecutableArguments": "-file ../DuetLapse3/DuetLapse3.config",
            Same error.
              @stuartofmt Linux is quite strict when it comes to mode strings (first line in your script). If you encode Python scripts using CRLF line endings, Linux will attempt to start python3\r and not python3, so try to change the line ending to LF only. That should fix it.
                stuartofmt @chrishamm
                @chrishamm
                Thanks! I did not even look at line endings because its been fine up until this last round. Its the strangest thing - I have Visual Studio Code set to default to unix EOL . For some unknown reason, these files were reset to CRLF.
                Possibly during a file transfer (something I need to look into).
                Again - THANKS!
                chrishammundefined 1 Reply Last reply Reply Quote 1
                • stuartofmtundefined stuartofmt marked this topic as a question
                • stuartofmtundefined stuartofmt has marked this topic as solved
                  @stuartofmt Check your git settings, maybe that changed it on commit.
