Input Shaper Plugin will not install
Duet Web Control
255
    Trevor
    Hello Everyone,
    I am running DWC in SBC mode. Version 3.4.6
    I am trying to install the Input Shaper Plugin but nothing happens, at all. This is what i am doing.
    I go to the plugins tab ---> External Plugins --> Install Plugin
    Select the zipped folder - InputShapingPlugin-master
    Click Open, and then the window closes and nothing happens
    Any help would be greatly appreciated.
    Thanks
    Trevor
    undefined 1 Reply Last reply 26 Sept 2023, 23:27 Reply Quote 0
      tas @Trevor
      @Trevor After 3.4.2 I believe the Input Shaper Plugin became an Integrated Plugin.
      Look for it in the Integrated Plugins tab. If the external plugin version did install (ie. it shows up in the External Plugins list) then uninstall it from the External Plugins tab. That is no longer required.
      undefined 1 Reply Last reply 26 Sept 2023, 23:30 Reply Quote 0
        Trevor @tas
        @tas Is it the Accelerometer Plugin? when i run that it does nothing.
        undefined 1 Reply Last reply 26 Sept 2023, 23:38 Reply Quote 0
          tas @Trevor
          @Trevor I am running 3.5.0-rc.1. It is just called Input Shaping. I think that is what it was always called.
          undefined 1 Reply Last reply 26 Sept 2023, 23:42 Reply Quote 0
            Trevor @tas
            @tas and that is what the instructions show, but it is not there.
            undefined 1 Reply Last reply 26 Sept 2023, 23:53 Reply Quote 0
              tas @Trevor
              @Trevor For 3.5 there was an issue with the order the files are installed but I don't think it would be applicable to 3.4. I may be wrong.
              For now try reinstalling DWC 3.4.6 and see if that works.
              Here is the topic that discussed that issue:
              3-5-0-rc-1-dwc-integrated-plugins-still-stuck-at-3-5-0-beta-4
              undefined 1 Reply Last reply 27 Sept 2023, 00:06 Reply Quote 0
                Trevor @tas
                @tas So i found a different GitHub link with the shaper for 3.4.0, and it worked like it should.
                It was under the SBC setup page.
                Thanks for the help trying to get this sorted out for me.
                Now to beat my head against the desk learning how the shaper stuff works. lol
                undefined 1 Reply Last reply 27 Sept 2023, 00:22 Reply Quote 0
                  tas @Trevor
                  @Trevor No need to beat your head against the desk. Just search this forum for articles on using Input Shaping.
                  7 out of 8
