    Howto make the filament monitor more robust
    Filament Monitor
    1
    1
    203
    • timschneiderundefined
      timschneider
      we sometimes face the problem, that the filamentsensor is producing "false" errors. They are actually true from the MFM perspective resulting in 0% extrusion or even minus values, but only minor in nature e.g. due to friction or some sort of untangling of the filament spool and will not affect the print result at all.
      So the current range will not work on these kind of errors.
      In order to reduce these "false" alarms and resulting print pause, I came up with the idea of some kind of a backoff counter.
      It works the following:
      • count the filament errors
      • if the count will go above a threshold, pause the print.
      • reduce the count if there was no filament error within a relaxe duration e.g. 60s
      reduce the check distance in order not to loose resultion. e.g. from
      M591 D0 P3 C"e1stop" S1 R70:120 E6 L25.3
      to
      M591 D0 P3 C"e1stop" S1 R70:120 E2 L25.3
      with a counter of 3.
      the output looks like the following below the threshold:
      and above the threshold:
      The code 0:/sys/filament-error.g:
      ; Parameter P description
      ; 2 = noDataReceived
      ; 3 = noFilament
      ; 4 = tooLittleMovement
      ; 5 = tooMuchMovement
      ; 6 = SensorError
      ; 7 = Magnet to weak
      ; 8 = Magnet to strong
      if !exists(global.mfmbackoff)
        global mfmbackoff = 3
      if !exists(global.lastMFMBackoffCheck)
        global lastMFMBackoffCheck = state.upTime
      if param.P == 2 || param.P == 6
          echo "Filament Sensor Error: " ^ param.P ^ "  sensor : " ^ param.D ^ " - continue printing"
          M99
      if param.P == 4
          if exists(global.mfmcalibration) && global.mfmcalibration == true
              M92 E{move.extruders[0].stepsPerMm+0.1}
              echo "E-Steps: " ^ {move.extruders[0].stepsPerMm} ^ ""
          else
              echo "Filament Sensor " ^ param.D ^ ": Too little Filament movement - Possible Reasons: Filament empty, grinding or clogged nozzle."
              set global.lastMFMBackoffCheck = state.upTime
              if global.mfmbackoff == 0
                  set global.mfmbackoff = 3
                  M291 P{"Filament Sensor " ^ param.D ^ ": Too little Filament movement - Possible Reasons: Filament empty, grinding or clogged nozzle."} S1 T0
                  M25 ; pause print
              else
                  set global.mfmbackoff = global.mfmbackoff - 1
                  echo "Filament Sensor Backoffcounter: " ^ global.mfmbackoff ^ ""
          M99 ; leave macro
      if param.P == 5
              M92 E{move.extruders[0].stepsPerMm-0.1}
          else
              echo "Filament Sensor " ^ param.D ^ ": Too much Filament movement - Possible Reasons: Spool skipped or Filament pushed into PTFE tube."
              M291 P{"Filament Sensor " ^ param.D ^ ": Too much Filament movement - Possible Reasons: Spool skipped or Filament pushed into PTFE tube."} S1 T0
              M25 ; pause print
          M99 ; leave macro
      echo "Filament error: " ^ param.P ^ " on sensor " ^ param.D ^ " - paused"
      M291 P{"Filament Sensor " ^ param.D ^ ": " ^ param.S ^ " - Paused"} S1 T0
      M25 ; pause
      0:/sys/daemon.g:
      if exists(global.mfmbackoff) && exists(global.lastMFMBackoffCheck) && global.mfmbackoff < 3 && ((global.lastMFMBackoffCheck + 60) < state.upTime)
          set global.mfmbackoff = global.mfmbackoff + 1
      1 Reply Last reply Reply Quote 4
      • timschneiderundefined timschneider referenced this topic
