    5bar scara Problem configuring z probe using fsr switch
    4.2k
    • gnmrc_undefined
      gnmrc_ @fcwilt
      @fcwilt no it’s the opposite it overshoots the target.
      • fcwiltundefined
        fcwilt @gnmrc_
        @gnmrc_ said in Problem configuring z probe using fsr switch:
        Does it home correctly to each axis?
        gnmrc_undefined 1 Reply Last reply Reply Quote 0
        • gnmrc_undefined
          gnmrc_ @fcwilt
          @fcwilt yes it homes the left and right actuator, than want to home z positioning the arm at the center of the bed using G1 x0 y0 s2, but it completely overshoots the position
          • fcwiltundefined
            fcwilt @gnmrc_
            How do things behave if you use the axes "jog" buttons of the Dashboard on the Duet web interface?
            • gnmrc_undefined
              gnmrc_ @fcwilt
              @fcwilt I cannot jog the machine due to insufficient axis homed. But I can say that the machine knows its homed position relative to bed 0,0
              • fcwiltundefined
                fcwilt @gnmrc_
                You can execute G92 Z## where ## is some position that the Z could reach in the real world.
                Once you did that Z would be considered homed.
                Or you can execute M564 H0 S0. The H0 means "ignore the homed state". The S0 means "ignore the axes limits". H1 means "respect the homed state". S1 means "respect the axes limits". You can use H or S alone or together. And all axes are affected.
                So you could home X and Y and then use G92 or M564 to allow Z to be jogged.
                • gnmrc_undefined
                  gnmrc_ @fcwilt
                  @fcwilt so I tried to position the arm to the home position and input the offsets manually with g92, now if I move the arm to the 0,0 position it works as it should.
                  If in the homing file I add a g92 x0 y0 than move the arm it should work, for sure is not the cleanest solution but seems reasonable.
                  Tell me what you think.
                  Gianmarco
                  gnmrc_undefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                  • gnmrc_undefined
                    gnmrc_ @gnmrc_
                    Gianmarco
                    Gianmarco
                    I tried this solution using first s2 and that h0 but it does not work.
                    with h0 it does not work and with s2 it overshoots as before.
                    • fcwiltundefined
                      fcwilt @gnmrc_
                      Gianmarco
                      I only use G92 during testing and in my homing files.
                      For example:
                      Let's say my bed is 300 x 300. But I like to have X=0, Y=0 at the center of that area. So the printable limits of the X axis are specified in M208 as -150 and 150.
                      But my endstop is actually at -175.
                      So when doing a typical homing move...
                      G91              ; relative moves
                      G1 H1 X-399 F600 ; move toward the endstop
                      ...when the endstop is activated the behavior of the H1 move is to set the logical X axis position to Xmin as specified in the M208, which as mentioned above is -150.
                      But the physical position is -175 because that is where movement stops when the endstop was triggered.
                      We now have a situation where the logical position of -150 is out of sync with the physical position of -175.
                      So to get them in sync I do something like:
                      M564 S0      ; ignore axis limits
                      G90          ; absolute move
                      G1 X175 F600 ; move to physical position X=0
                      G92 X0       ; set logical position to X=0
                      M564 s1      ; respect axis limits
                      Now things are in sync. I usually find that the X175 is a bit off and needs repeated testing to tweak the value so X=0 is just where I want it.
                      There are other ways to do this but this is how I do it.
                      • gnmrc_undefined
                        gnmrc_ @fcwilt
                        @fcwilt I will give it a try but if I understood correctly it's not our case of error, because my movement limits are min:-250,-250 max:250,250 when the arm is homed I'm inside those limits.
                        I really can't understand what I'm doing wrong.
                        We also should open another forum discussion because we are talking a lot about a completely different topic that maybe could help others.
                        Gianmarco
                        • gnmrc_undefined
                          gnmrc_ @gnmrc_
                          Gianmarco
                          Gianmarco
                          I'm still testing while changing some parts of the homing procedure, when the arm overshoots it does it in a way that looks like the arm is moving to 0,0 as if the Zero position was in the front left corner of the bed that has an area 200x200
                          • fcwiltundefined
                            fcwilt @gnmrc_
                            Gianmarco
                            I see in the config.g file that both X and Y range from -250 to +250.
                            But where do the endstops trigger on each axis? Are they exactly at 250?
                            gnmrc_undefined 2 Replies Last reply Reply Quote 0
                            • gnmrc_undefined
                              gnmrc_ @fcwilt
                              @fcwilt no well you have to consider that being a scara they work on the axis rotation, but the position is inside the reachable area. The home position is aroung x-168 y-98 (I give you rough number because I’m not home right now), so no they do not trigger precisely in that position.
                              Gianmarco
                              • infiniteloopundefined infiniteloop referenced this topic
                              • gnmrc_undefined
                                gnmrc_ @fcwilt
                                @fcwilt said in Problem configuring z probe using fsr switch:
                                Gianmarco
                                So I didn’t understood this, no the arm position at home does not correspond to the are limits.
                                • fcwiltundefined
                                  fcwilt @gnmrc_
                                  Gianmarco
                                  When you say "home position" what do you mean. Maybe what you think of as "home" is different than what I think of as "home".
                                  And how did you determine the values in your M669 command?
                                  • gnmrc_undefined
                                    gnmrc_ @fcwilt
                                    @fcwilt so for me the home is the position in which the machine reach the endstops(this position is outside the are of printing) and it was determined in the design process. The value for m669 are taken by measures of the arm lenght and for the degrees by the design than I put the data in a geometry calculation program and found the other informations that i needed for the configuration.
                                    I made a simple sketch to explain me better
                                    Gianmarco
                                    • droftartsundefined droftarts referenced this topic
                                    • fcwiltundefined
                                      fcwilt @gnmrc_
                                      @gnmrc_
                                      That sketch helped a lot.
                                      I would suggest you try this:
                                      Execute...
                                      M564 H0 S0	                ; H0 = ignore axis homed state, S0 = ignore axes limits
                                      ...then carefully jog X and Y to see if the physical position seems correct for various values of X and Y.
                                      Once that seems to be working:
                                      • carefully jog to where you want X=0 Y=0 to be
                                      • execute a G92 X0 Y0 to set the logical positions of X and Y
                                      • carefully jog X and Y until the endstop switches are activated (there is a command that would do this but at this point jogging is probably safer)
                                      • make note of the X and Y values at that position
                                      Then post the results.
                                      • gnmrc_undefined
                                        gnmrc_ @fcwilt
                                        @fcwilt I tried your suggestion, I jogged the machine from a known position that would make the arm move theoretically in the right way, and the arm moved accordingly to my command so -y moved the arm only left +x forward and so on without having noticeable diagonal moves or incorrect ones. Then I started moving the arm until it reached its endstops, the position that I found was x: -161.1 y: -108.53, while the one that I had calculated using theoretical values was x: -162.67 y: -108.53.
                                        Thank you for all the help that you are giving me!
                                        Gianmarco
                                        • fcwiltundefined
                                          fcwilt @gnmrc_
                                          @gnmrc_
                                          Did you do the set of steps to establish X=0 Y=0 at the center of the bed?
                                          From that position can you reach an endstop switch moving on just one axis or does it require movement on both?
                                          Homing usually involves a G1 H1 move where the H1 causes the movement to stop when the endstop is triggered and set the current position to the min/max value for that axis.
                                          I suppose it is possible to have a G1 H1 Xnnn Ynnn move as long as it ends up triggering one of the endstop switches. It could still set the current position of the axis associated with the endstop switch that was activated. I guess it just ignore the other axis.
                                          • gnmrc_undefined
                                            gnmrc_ @fcwilt
                                            @fcwilt Yes, If I move first the left actuator than the right I can reach the zero position from the home position using only one actuator at the time with no problem.
                                            If I understand correctly you are suggesting that after I reached the home position I rotate only one motor at the time to reach the zero position, right?
                                            In this case I could also only move the arm using angular position.
                                            Tell me if I understood everything correctly.
                                            Thanks for the help,
                                            Gianmarco
