    Multizone heater bed
    • Anon1337undefined
      Anon1337
      Is there an easy-ish way to run a heater bed with multiple heating elements and then just turn on whatever part of the bed is needed?
      Like what the Prusa XL does?
      Would be neat for big printers.
      • Anon1337undefined
        Anon1337
        I mean this was made by you (Duet3D).
        Screenshot 2023-10-25 at 14-11-21 Huge 3D Printer Case Study - Duet3D Distributed Control example - YouTube.png
        Any documentation to go with it?
        How were the 3HC board connected to the beds? I mean each 3HC only has 3 high amps outputs but that bad has 9 segments?
        Screenshot 2023-10-25 at 14-11-29 Huge 3D Printer Case Study - Duet3D Distributed Control example - YouTube.png
          dc42 administrators @Anon1337
          @Anon1337 I believe the bed heaters were all AC mains voltage, so controlled by SSRs.
          Anon1337undefined 1 Reply Last reply Reply Quote 0
          • Anon1337undefined
            Anon1337 @dc42
            @dc42 So AC SSRs connected to the 3HC PWM outputs? How were the segments controlled? Was it automatic or do you have to manually choose what segments to heat?
