Configs for PCB PnP for Duet3D 6XD and 3 x 3HC expansion boards
i have built DIY PnP Machine with following :
Below is what i have on the PnP machine so far
Motors and Corresponding External Drivers
Closed Loop Motors:
(48V DC recommended for Nema 34 & 36V DC for Nema 23 )
- 3 x Nema 34 Closed Loop Motor ( 86HSE8N-BC38 ) each with HSS86 Hybrid Servo Driver ( X & Y-axis)
- 2 x Nema 23 Closed Loop Motor ( 57HSE76-2N-D25) each with 2HSS57 Hybrid Servo Driver
Open Loop Motors: ( Will be used for Conveyor later not yet implemented )
( 24V DC recommended for Nema 11 & 17 )
9 x Stepper Motors directly connected to 3 x 3HC expansion boards
- 3 x Nema 17 Open Loop Stepper Motor (Benzhi BD4248 ) for driving the 6 heads/Nozzles along the Z-axis ( 1 Stepper motor drives 2 Nozzles along Z-axis)
- 6 x Nema 11 Open Loop Stepper Motor (Benzhi BT12811 ) for the Nozzles/Heads
Duets:
- 1 x Duet 3 6XD Main Board ( All Closed Loop Motors & Drivers will connect to this 6XD board)
- 3 x Duet 3 3HC Expansion Boards ( All Open loop Motors will directly connect to 3 x 3HC expansion boards therefore avoiding external drivers and using 3HC in-built Drivers)
Endstops:
Several endstops (20+) for the various Axes as required-
X-axis (Nema 34)
Y-Axis (Nema 34)
Z1, Z2, Z3 , Z4, Z5,Z6 ( 3 motors driving 6 Nozzles up/down along the Z-axis )
6 Nozzles that rotate ( do i need a rotational axis for each Nozzle ?? )-- Optical switch Endstop Panasonic PM25U & PM25L
- One Endstop for X-Axis
- One Endstop for Y-Axis
- 6 Endstops for Z1, Z2, Z3 , Z4, Z5,Z6 for Z-Axes for each nozzle
- 6 Endstops for AB1, AB2, AB3 , AB4, AB5, AB6 for Rotational axes of the nozzles
Is it also possible to use 2 endstops on each of the X and Y-axis ( One at the Lowend and another at the High End on each axis ) ?
Any help in quickly setting this up correctly using config tool ?
From a Duet Example config for OpenPnP Duet3D-Openpnp-Example, here are the parameters that i can figure out :
5 Main Axis machine; linear X, Y, Z( Z1,Z2,Z3,Z4,Z5,Z6 for 6 nozzles moving along Z-axis), rotational AB (A1,A2,A3,A4,A5,A6, B1,B2,B3,B4,B5,B6)
Single head, 3 x CAM driven dual nozzle with -180+180 rotation = 6 Nozzles
XYZ & AB Limit switches (Endstops) using Panasonic Micro Photoelectric Sensor PM25U & PM25L
6 x Analog inputs for nozzle pressure
As per the example as reference , Not sure what to do here :
1 x Digital input for drag pin state detection
x7 PWM Outputs @20k to drive; x2 LED array, 6 x pumps, 6 x pneumatic valves and x1 drag pin solenoid.
RRF does not currently support two endstops for a given axis.
You can by issuing commands "on the fly" connect the board to one endstop or the other - but that is not likely going to prove very satisfactory.
You can use "endstops" as inputs to "triggers" - see M581.
My memory is not what it once was but I seem to recall that triggers 2 and up would not be processed until the moves in the queue were completed.
I need to test that to be sure.
@developeralgo222
Hi, an exciting project, worth watching...I was wondering why you use 3x 3HC boards for NEMA17 & NEMA11 motors?
AFAIK you can config the Duet-mini5+ as toolboard too. You'd need only two and the mini5+ is even cheaper...Using 3(6) independent Z-axes is another thing, I'm curious to see how that can be configured...
@o_lampe
Not sure how but i believe a couple of users have done it . -
@developeralgo222 See https://docs.duet3d.com/User_manual/Machine_configuration/CAN_connection#mainboard-used-as-expansion-board
The Duet 3 Mini 5+ can take the Duet 3 Expansion Mini 2+ for a total of 7 drives. Also, if you need more inputs, you can use io[#].out pins for inputs, and vice versa, with some caveats. See https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Mini_5+_Hardware_Overview#io-headers
IO output pins can be used as inputs, but are only 3.3V tolerant. IO input pins can be used as outputs, but have 10K protection resistors in series with them, so you would need to bypass these to use them as outputs. On board revision v1.01 and later only, jumpers allow the 10K resistors on IO2.in and IO3.in to be bypassed with 470R resistors.
@droftarts
i am using Duet 3 6XD plus 3 x 3HC expansion boards. Not sure what Duet 3 Mini 5+ plus Duet 3 Expansion Mini 2+ will do that i can't accomplish with what i already have in hand ? -
@developeralgo222 said in Configs for PCB PnP for Duet3D 6XD and 3 x 3HC expansion boards:
I was just explaining how, and making you aware of other options, should the need arise. Perhaps you'll build another one!
@developeralgo222 here's an outline of what you need in your config.g file. You can use the only configuration tool to generate a basic config.g file, then edit it (which you can do in Duet Web Control) to make the necessary changes.
Near the start of config.g you should have A G4 S4 command. This is to give the expansion boards time to start up. Recent versions of the configuration tool generate this automatically.
You should have a M569 command for each motor you use, to define in which direction it moves. The configuration tool with generate this for the X, Y and (single) Z motors.
You will need to use M584 to allocate a linear axis for each of your "Z" axes and a rotational axis for each. Assuming that you need to drive them all independently, you can't call them Z1 Z1 A1 A2 etc. because each one needs a unique letter. You can start by using letters Z U V W A B C D. After that you can use lowercase letters a b c ... but because GCode is defined as being case-insensitive, in the GCode commands sent by OpenPnP they have to be called 'a 'b 'c etc. or equivalently 'A 'B 'C etc.
The M584 command allows you to create both linear and rotary axes. By default Z U V W are linear and A B C D are rotary; but you can change that using the R parameter. See https://docs.duet3d.com/User_manual/Reference/Gcodes#m584-set-drive-mapping. You can create multiple axes using one M584 command, and you can also use multiple M584 commands. You will most likely want to use one M584 command to create the additional linear axes and another to create the rotary axes.
You will need to use M83 commands to define the steps/mm or steps/degree for each axis. The configuration tool will generate this for the X Y and (single) Z axes.
The motors will default to x16 microstepping interpolated to x256. If this is not satisfactory then you will need to add M350 commands to change it.
You will need to add M906 commands to set the motor current for your additional axis motors.
You will need to add M574 commands to define how you have connected the additional homing switches, and which end of the axis they are on.
For each axis there needs to be a homing file called home#.g where # is the axis letter. This command should use the G1 H1 command to move the axis towards the homing switch until it triggers.
Normally you should also have a homeall.g file. In its simplest form this can calls each of the other homing files in turn using the M98 command. If you want faster homing then you can use commands in this file to home several axes concurrently.
HTH David
@dc42 said in Configs for PCB PnP for Duet3D 6XD and 3 x 3HC expansion boards:
i want to make sure my drive mapping and Axes are correct before i start doing anything. will this excerpt work . i will post a complete config.g once its correct
Updated Config.g :
; Configuration file for Duet 3 MB 6XD (firmware version 3.3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.16 on Tue Dec 05 2023 09:51:46 GMT-0500 (Eastern Standard Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"MYTEST PNP" ; set printer name ; Wait a moment for the CAN expansion boards to start G4 S2 ; Network if {network.interfaces[0].type = "ethernet"} M552 P10.0.0.200 S1 ; enable network and set IP address M553 P255.255.255.0 ; set netmask M554 P10.0.0.1 ; set gateway else M552 S1 M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ;The X axis to control the movement of the PnP head right and left. Right is positive. ;The Y axis to control the movement of the PnP head forward and back. Forward is positive. ;The Z axis to control raising and lowering of the PnP nozzle up and down. Up is positive. ;The V, U, W, A, B, C (for 6-Head nozzles) axes rotates clockwise and counter-clockwise. Counter-clockwise is positive. ;RepRapFirmware supports X, Y and Z axes as standard and allows you to create up to 7 additional axes depending on the firmware ;version and which Duet you are using. Axes are created and associated with ;stepper motors using the M584 command in config.g. ;You may use any of the following letters to refer to the new axes: U V W A B C D (letter D is not supported in older firmware versions) ; Drives ;Physical Drives CAN ID = 0 M569 P0.0 S1 R1 ; X-Axis physical drive 0.0 goes forwards on CAN ID = 0 - Duet 6XD Drive 0.0 M569 P0.1 S1 R1 ; Y-Axis physical drive 0.1 goes forwards on CAN ID = 0 - Duet 6XD Drive 0.1 ;Physical Drives CAN ID = 1 M569 P1.0 S1 ; Z & U Axis physical drive 1.0 goes forwards (moves down and up on z-axis) on CAN ID = 1 - Duet 3HC Drive 1.0 M569 P1.1 S1 ; V & W Axis physical drive 1.1 goes forwards (moves down and up on z-axis) on CAN ID = 1 - Duet 3HC Drive 1.1 M569 P1.2 S1 ; A & B Axis physical drive 1.2 goes forwards (moves down and up on z-axis) on CAN ID = 1 - Duet 3HC Drive 1.2 ;Physical Drives CAN ID = 2 M569 P2.0 S1 ; C-Axis physical drive 2.0 goes Rotates forwards and backwards (+180 and -180 ) on CAN ID = 2 - Duet 3HC Drive 2.0 M569 P2.1 S1 ; D-Axis physical drive 2.1 goes Rotates forwards and backwards (+180 and -180 ) on CAN ID = 2 - Duet 3HC Drive 2.1 M569 P2.2 S1 ; 'A-Axis physical drive 2.2 goes Rotates forwards and backwards (+180 and -180 ) on CAN ID = 2 - Duet 3HC Drive 2.2 ;Physical Drives CAN ID = 3 M569 P3.0 S1 ; 'B-Axis physical drive 3.0 goes Rotates forwards and backwards (+180 and -180 ) on CAN ID = 3 - Duet 3HC Drive 3.0 M569 P3.1 S1 ; 'A-Axis physical drive 3.1 goes Rotates forwards and backwards (+180 and -180 ) on CAN ID = 3 - Duet 3HC Drive 3.1 M569 P3.2 S1 ; 'B-Axis physical drive 3.2 goes Rotates forwards and backwards (+180 and -180 ) on CAN ID = 3 - Duet 3HC Drive 3.2 ;By default Z U V W are linear and A B C D are rotary; but you can change that using the R ; set visible drive mapping ; X-Axis , Y-Axis (2 x Nema 34 Closed Loop Motors) and Z-Axes (Z,U,V,W,A,B) mapping to 3 Stepper motors ; directly connected to 3HC (CAN ID = 1) (which moves the nozzles up and down along Z-axis) M584 X0.0 Y0.1 Z1.0 U1.0 V1.1 W1.1 A1.2 B1.2 R0 ; LIN R0 = LINEAR, R1 = ROTATION ; Rotational Axes mapping to 6 motors directly connected to 3HC (CAN ID 2 and 3) (which rotates the nozzles +180 / -180 along Rotational axis) M584 C2.0 D2.1 'A2.2 'B3.0 'C3.1 'D3.2 R1 ; LIN R0 = LINEAR, R1 = ROTATION M350 X16 Y16 Z16 U16 V16 W16 A16 B16 C16 D16 'A16 'B16 'C16 'D16 I1 ; configure microstepping with interpolation M92 X40.00 Y40.00 Z8.888 U8.888 V8.888 W8.888 A8.888 B8.888 C8.888 D8.888 'A8.888 'B8.888 'C8.888 'D8.888 ; set steps per mm 50mm/rev M566 X900.0 Y900.0 Z900.0 U900.0 V900.0 W900.0 A900.0 B900.0 C100.0 D100.0 'A100.0 'B100.0 'C100.0 'D100.0 ; set maximum instantaneous speed changes (mm/min) M203 X126000.00 Y126000.00 Z24000.00 U24000.00 V24000.00 W24000.00 A24000.00 B24000.00 C24000.00 D24000.00 'A24000.00 'B24000.00 'C24000.00 'D24000.00 ; set maximum speeds (mm/min) M201 X50000.00 Y50000.00 Z500.00 U500.00 V500.00 W500.00 A500.00 B500.00 C5000.00 D5000.00 'A5000.00 'B5000.00 'C5000.00 'D5000.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z600.0 U600.0 V600.0 W600.0 A600.0 B600.0 C500.0 D500.0 'A500.0 'B500.0 'C500.0 'D500.0 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout M564 H0 ; Sets homing, H0 allows mvmnt wo homing ; Axis Limits M208 X0 Y0 Z-50 U-50 V-50 W-50 A-50 B-50 C-180 D-180 'A-180 'B-180 'C-180 'D-180 S1 ; Set axis minima M208 X450 Y500 Z50 U50 V50 W50 A50 B50 C180 D180 'A180 'B180 'C180 'D180 S0 ; Set axis maxima ; Endstops ; For X and Y Axis M574 X1 S1 P"!io0.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io0.in M574 Y1 S1 P"!io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io1.in ; For Z-Axis (Z,U,V,W,A,B) - Up/down) M574 Z1 S1 P"!1.io0.in" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin 1.io0.in M574 U1 S1 P"!1.io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on U via pin 1.io1.in M574 V1 S1 P"!1.io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on V via pin 1.io2.in M574 W1 S1 P"!1.io3.in" ; configure switch-type (e.g. microswitch) endstop for low end on W via pin 1.io3.in M574 A1 S1 P"!1.io4.in" ; configure switch-type (e.g. microswitch) endstop for low end on A via pin 1.io4.in M574 B1 S1 P"!1.io5.in" ; configure switch-type (e.g. microswitch) endstop for low end on B via pin 1.io5.in ; For Rotational Axes (C,D,'A,'B,'C,'D) +180 / - 180 ) M574 C1 S1 P"!2.io0.in" ; configure switch-type (e.g. microswitch) endstop for low end on C via pin 2.io0.in M574 D1 S1 P"!2.io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on D via pin 2.io1.in M574 'A1 S1 P"!2.io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on 'A via pin 2.io2.in M574 'B1 S1 P"!3.io0.in" ; configure switch-type (e.g. microswitch) endstop for low end on 'B via pin 3.io0.in M574 'C1 S1 P"!3.io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on 'C via pin 3.io1.in M574 'D1 S1 P"!3.io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on 'D via pin 3.io2.in ; Z-Probe ; Heaters ; Fans ; Tools ; Custom settings are not defined Updated homeall.g . All the corresponding homing files for each axis are in sys folder
; homeall.g ; called to home all axes ; Home X-Axis and Y-Axis second M98 P"homex.g" M98 P"homey.g" ; Home Z-Axes (Z, U, V, W, A, B ) M98 P"homez.g" M98 P"homeu.g" M98 P"homev.g" M98 P"homew.g" M98 P"homea.g" M98 P"homeb.g" ; Home Rotational axes (C, D, 'A, 'B, 'C, 'D ) = ( C, D, a, b, c, d) M98 P"homec.g" M98 P"homed.g" M98 P"home'a.g" M98 P"home'b.g" M98 P"home'c.g" M98 P"home'd.g" ;G91 ; relative positioning ;G1 H2 Z5 F6000 ; lift Z relative to current position ;G1 H1 X235 Y215 F1800 ; move quickly to X and Y axis endstops and stop there (first pass) ;G1 H2 X-5 Y-5 F6000 ; go back a few mm ;G1 H1 X235 Y215 F360 ; move slowly to X and Y axis endstops once more (second pass) ;G1 H1 Z205 F360 ; move Z up stopping at the endstop ;G90 ; absolute positioning ;G92 Z200 ; set Z position to axis maximum (you may want to adjust this) ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z5 F100 ; lift Z relative to current position ;G90 ; absolute positioning Below is a sample (one of the Z-axes) file
Z Axes ( Z, U, V, W, A, B )
Updated homez.g
; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v3.3.16 on Tue Dec 05 2023 09:51:47 GMT-0500 (Eastern Standard Time) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 Z205 F1800 ; move Z up until the endstop is triggered G92 Z200 ; set Z position to axis maximum (you may want to adjust this) ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z5 F100 ; lift Z relative to current position ;G90 ; absolute positioning Below is a sample (one of the Rotational Axes) file
Rotational Axes ( C, D, 'A, 'B, 'C, 'D )
Updated homec.g (one of the Rotational axes) file
; homec.g ; called to home the C axis ; ; generated by RepRapFirmware Configuration Tool v3.3.16 on Tue Dec 05 2023 09:51:47 GMT-0500 (Eastern Standard Time) G91 ; relative positioning G0 H2 C180 F6000 ; Rotate C relative to current position G0 H1 C-180 F1800 ; Rotate C up until the endstop is triggered G92 C200 ; set C position to axis maximum (you may want to adjust this) ; Uncomment the following lines to lift C after probing ;G91 ; relative positioning ;G0 C180 F100 ; Rotate C relative to current position ;G90 ; absolute positioning is this correct mapping of Drives and Axes? was having issues before this update and used recommendations from @droftarts to update my pervious files . Any issues you can see
i tried homing with the above config file and it failed on X-axis & Y-axis with
G28: failed homing
and other axes did not home correctly
@developeralgo222 I'm not sure these M584 lines are correct:
M584 X0.0 Y0.1 Z1.0 U1.0 V1.1 W1.1 A1.2 B1.2 R0 ; LIN R0 = LINEAR, R1 = ROTATION --- NOT SURE HOW TO MAP Z-axes to Drives here M584 'Z2.0 'U2.1 'V2.2 'W3.0 'A3.1 'B3.2 R1 ; LIN R0 = LINEAR, R1 = ROTATION According to the M584 documentation, only XYZUVWABCDabcdef axis names are available, ie not zuvw. Rename those.
Post your homeall.g file so we can see what it is doing.
A quick config.g test is to send
M98 P"config.g"
which will run the config, and report any errors found.Ian
@droftarts
updated the original post above as per earlier recommedation and posted config.g , homeall.g, homez.g and homec.g . Any issues with the updated version ? -
i have following Axes as shown above in the config.g and homeall.g
Basically it is PnP Machine with 6 nozzles (Nema 11 stepper motors - open loop- CAM driven Dual Nozzles) driven by 3 x Nema 17 stepper motors-open loop. i.e 1 motor drives 2 nozzles on z-axes ( All 9 stepper Motors are connected to 3 x 3HC expansion boards)
While The X and Y Axis driven by 2 x Nema 34 Closed Loop Motors with External Closed Loop Driver (HSE86) Driver connected to Duet 3 6XD Main Board.
In Summary
X and Y-axis each connected to an External Driver (HSE86) and NEMA 34 Closed Loop Servo Motor(with encoder) and then to Duet 6XD main board (CAN ID = 0 )
Z-Axes ( Z, U, V, W, A, B ) with 3 x Nema 17 Stepper motors directly connected to 3HC in-built Drivers (CAN ID = 1) . Each Stepper motor drives 2 (Dual) nozzles up & down the Z-axes (CAM driven dual nozzle with -180 , +180 rotation )
Stepper Motor 1 ---> Driver 1.0 ---> Drives/share Z and U axis Stepper Motor 2 ---> Driver 1.1 --> Drives/share V and W axis Stepper Motor 3 ---> Driver 1.2 --> Drives/share A and B axis -
Rotational Axes ( C , D, 'A, 'B, 'C, 'D ) = ( C, D, a, b, c, d) with 6 x Nema 11 Stepper motors directly connected to 2 x 3HC in-built Drivers (CAN ID = 2 and CAN ID = 3) . Each Stepper motor drives 1 nozzle and Rotates that single Nozzle Clockwise and anticlockwise.
i can't seem to be able to Home X and Y at all. Also the Z-Axes are not homing correctly . Rotational axes seem to be able to home fine
i am getting the error
G28 X Error: Failed to home axes X G28 Y Error: Failed to home axes Y -
@developeralgo222 @dc42 @droftarts @fcwilt @o_lampe
i really need help on this configuration setup for a PNP machine. i am new to Duet 3 board but it was highly recommended. Not sure is there is any true support for Duet 3 6XD and 3HC Products.
There is a ton of documentation and help on how to setup 3D printers but almost non-existent support or help on how to correctly setup PnP machine using Duet 6XD and 3HC boards apart from very few users in the forum who are trying similar setups.
This is very frustrating for Duet board users
Well the 6HC and the 6XD are the same board except for how they connect to steppers.
The 6HC connect directly to steppers using standard A+ A- B+ B- high current connections.
The 6XD is designed to connect to standard external stepper drivers and servo drivers using STEP DIR ENA & ERR connections.
The 3HC provides the same kind of connections to steppers that the 6HC does.
You can easily use two 6xx boards in the same system as long as one board is at the start of the CAN bus and the other at the end, as the boards only have one CAN connector and built-in terminators, so they are not designed for easy daisy-chaining.
I assume you have read all of this:
@developeralgo222 please post your homex.g and homey.g. Do all the other axes home correctly? If you run homex.g on its own, does the axis move at all? Is there any more messages in the console while or after homex.g has run?
@droftarts said in Configs for PCB PnP for Duet3D 6XD and 3 x 3HC expansion boards:
X and Y Axis do not home at all
Z-Axes ( Z, U, V, W, A, B ) homes but not correctly
Only Rotational Axes ( C , D, 'A, 'B, 'C, 'D ) = ( C, D, a, b, c, d) home correctly
Below are my current homex.g and homey.g
homex.g
; homex.g ; called to home the X axis ; ; generated by RepRapFirmware Configuration Tool v3.3.16 on Tue Dec 05 2023 09:51:46 GMT-0500 (Eastern Standard Time) G91 ; relative positioning G1 H2 Z50 F6000 ; Rotate Nema 17 Motor 1 by 50 Degrees to move up Z relative to current position G1 H2 U-100 F6000 ; Rotate Nema 17 Motor 1 by -100 Degrees to move up U relative to current position G1 H2 V50 F6000 ; Rotate Nema 17 Motor 2 by 50 Degrees to move up V relative to current position G1 H2 W-100 F6000 ; Rotate Nema 17 Motor 2 by -100 Degrees to move up W relative to current position G1 H2 A50 F6000 ; Rotate Nema 17 Motor 3 by 50 Degrees to move up A relative to current position G1 H2 B-100 F6000 ; Rotate Nema 17 Motor 3 by -100 Degrees to move up B relative to current position G1 H1 X235 F1800 ; move quickly to X axis endstop and stop there (first pass) G1 H2 X-5 F6000 ; go back a few mm G1 H1 X235 F360 ; move slowly to X axis endstop once more (second pass) G1 H2 Z-50 F6000 ; Rotate Nema 17 Motor 1 by -50 Degrees to move down Z again G1 H2 U100 F6000 ; Rotate Nema 17 Motor 1 by 100 Degrees to move down U again G1 H2 V-50 F6000 ; Rotate Nema 17 Motor 2 by -50 Degrees to move down V again G1 H2 W100 F6000 ; Rotate Nema 17 Motor 2 by 100 Degrees to move down W again G1 H2 A-50 F6000 ; Rotate Nema 17 Motor 3 by -50 Degrees to move down A again G1 H2 B100 F6000 ; Rotate Nema 17 Motor 3 by 100 Degrees to move down B again G90 ; absolute positioning homey.g
; homey.g ; called to home the Y axis ; ; generated by RepRapFirmware Configuration Tool v3.3.16 on Tue Dec 05 2023 09:51:46 GMT-0500 (Eastern Standard Time) G91 ; relative positioning G1 H2 Z50 F6000 ; Rotate Nema 17 Motor 1 by 50 Degrees to move up Z relative to current position G1 H2 U-100 F6000 ; Rotate Nema 17 Motor 1 by -100 Degrees to move up U relative to current position G1 H2 V50 F6000 ; Rotate Nema 17 Motor 2 by 50 Degrees to move up V relative to current position G1 H2 W-100 F6000 ; Rotate Nema 17 Motor 2 by -100 Degrees to move up W relative to current position G1 H2 A50 F6000 ; Rotate Nema 17 Motor 3 by 50 Degrees to move up A relative to current position G1 H2 B-100 F6000 ; Rotate Nema 17 Motor 3 by -100 Degrees to move up B relative to current position G1 H1 Y215 F1800 ; move quickly to Y axis endstop and stop there (first pass) G1 H2 Y-5 F6000 ; go back a few mm G1 H1 Y215 F360 ; move slowly to Y axis endstop once more (second pass) G1 H2 Z-50 F6000 ; Rotate Nema 17 Motor 1 by -50 Degrees to move down Z again G1 H2 U100 F6000 ; Rotate Nema 17 Motor 1 by 100 Degrees to move down U again G1 H2 V-50 F6000 ; Rotate Nema 17 Motor 2 by -50 Degrees to move down V again G1 H2 W100 F6000 ; Rotate Nema 17 Motor 2 by 100 Degrees to move down W again G1 H2 A-50 F6000 ; Rotate Nema 17 Motor 3 by -50 Degrees to move down A again G1 H2 B100 F6000 ; Rotate Nema 17 Motor 3 by 100 Degrees to move down B again G90 ; absolute positioning -
@developeralgo222 Your X and Y endstops are set as axis low end (ie where X=0) endstops:
M574 X1 S1 P"!io0.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io0.in M574 Y1 S1 P"!io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io1.in Whether the endstop is at the minimum or maximum end is defined by the number after the axis label, ie X or Y, in M574
Xnnn Position of X endstop: 0 = none, 1 = low end, 2 = high end.
However, your homing script tries to home the X axis to the high end (Y is the same):
G1 H1 X235 F1800 ; move quickly to X axis endstop and stop there (first pass) G1 H2 X-5 F6000 ; go back a few mm G1 H1 X235 F360 ; move slowly to X axis endstop once more (second pass) Where is each endstop actually located, low or high end? Check the other linear axes for the same issue.
Edit: when the endstop is triggered, the axis position is set to the low or high number (depending on whether it's a low or high endstop) in the M208 commands:
; Axis Limits M208 X0 Y0 Z-50 U-50 V-50 W-50 A-50 B-50 C-180 D-180 'A-180 'B-180 'C-180 'D-180 S1 ; Set axis minima M208 X450 Y500 Z50 U50 V50 W50 A50 B50 C180 D180 'A180 'B180 'C180 'D180 S0 ; Set axis maxima Edit 2: You also need to move the axis far enough to actually trigger the endstop. Your X and Y axis moves are X235 and Y215, but the axis length is X450 and Y500.
Also, check you motors are actually going the way you expect. The origin (X0 Y0) usually in the front left corner, a +X move should move to the right, a +Y move should move the tool towards the back, relative to the 'bed'. If you have a moving bed (which I don't think you do), the bed would move forward. If the axis moving the wrong way, change it with the M569 S parameter. All yours are S1; some may need to be S0, to change the direction.Ian
Regarding your setup of the 6 nozzles, you say they are set up as:
Nozzle Pair, Shared Z Axis, Cam
A nozzle pair share a Z axis motor. The two nozzles are pushed down by a rotational cam, pulled up with a springIs this how they are actually set up? I would think this means you only need 3 Z axes, and a way to actuate the cam; this is usually done by going to the end of the axis and hitting a bump stop that flips the cam. Does yours do something different? With the option you have selected, the gcode openPNP produces likely only contains commands for 3 Z axes.
This is very frustrating for Duet board usersThe forum is the way we offer support; you bought Duet hardware, not a support contract. You are building a very complicated machine, which you haven't fully described (position of endstops, how the nozzles are activated/switched). You are on a learning curve to implement this with Duet and RRF, and you are jumping in at the deep end. It takes us time to go through your posts, to understand the layout of your machine, and what you are trying to achieve. OpenPNP users are a small fraction of our users, and we don't have an OpenPNP test setup to be able to try out the options, just like we don't have every kind of 3D printer, or CNC machine. For some areas, you would be better served by asking on the OpenPNP forums/Discord/wherever for advice. So, please, be patient, we're learning as well.
Yes that's how it's setup. On Each each CAM pair there is an end stop on each axis (2 Nozzles , 2 Endstops on the shared Z-axis )
@developeralgo222 thanks. Please let is know what issues remain when you have corrected the issues identified by Ian 3 posts up from here.
You may find https://docs.duet3d.com/en/User_manual/Machine_configuration/Configuration_cartesian useful because it describes how config.g should be set up to control the axis motors and how the homing files should be set up.
Here is an illustration to capture the PnP machine build so that anyone willing to help can visualize my build
@dc42 Is there anyone who can work with me to come up with a working configuration for this PnP Machine. It will also help those who want to take the dive with Duet 3 6XD, 6HC and expansion boards in building PnP Machines to at least have sample config.g and homeall.g that they can use and play around with. I will buy him/her coffee or beer for a week !!!!!
@developeralgo222 please read the page I linked to in my previous post and the advice from Ian. That should give you enough information to get X and Y homing properly. Further advice:
- Test motor movement like this:
- Send G91 to put the machine into relative movement mode
- Use G1 H2 commands to command individual motors regardless of their homed status. For example, G1 H2 X10 should move the X axis by +10mm, and G1 H2 X-10 should move it by -10mm.
- Read the endstop states, either by using M119, or in Duet Web Control start the Object Model Browser and expand sensors/endstops. Check that the state changes as expected when you operate the endstop.
In trying to troubleshoot the homing Failure for X and Y axis, I noticed that when NEMA 34 Closed Loop Motors ( 86HSE8N-BC38 8.0N.m ) with External Driver (HSS86) are energized(48V Power is applied ) it locks, as it should, but does not move when i try to home it even after changes . Without Power applied i can move it manually and moves fine as expectedi have double checked all Wiring from Motor <---> Driver <--> Duet 3 6XD and seems correct as expected, No error light on the Driver or Duet 6XD
I am thinking that one of Motor Power (A+, A-, B+, B-) internal wires might be crossed or swapped or
PSU Output supply 48V DC @ 12.5A Max . is this an undervoltage issue ?
Looking at the Datasheets of both the Driver and Closed Loop Motor, it seems to suggest that the recommended DC is 60V while some documents say 48V . i am perplexed on this. Any one with an idea about this motors or drivers?
