    Duet connection
    626
    • fcwiltundefined
      fcwilt @Casugo
      @Casugo said in Duet connection:
      @fcwilt
      Okay, thanks!!
      Yes, I have a computer where I'm connecting the duet by at ethernet cable.
      Do you know how to open the Command Line window?
      Casugoundefined 1 Reply Last reply Reply Quote 0
      • Casugoundefined
        Casugo @fcwilt
        @fcwilt
        This one?
        And I already plug the SD card and the config all ready goen 😞
        fcwiltundefined 2 Replies Last reply Reply Quote 0
        • fcwiltundefined
          fcwilt @Casugo
          @Casugo
          Yes that is the command line window.
          Please enter:
          ipconfig
          and press the Enter key.
          You should see something like this:
          The lines
          IPv4
          Subnet Mask
          Default Gateway
          are the ones I am interested in.
          • fcwiltundefined
            fcwilt @Casugo
            @Casugo
            What do you think happened to the file?
            Do you have a backup?
            • Casugoundefined
              Casugo @fcwilt
              @fcwilt
              It sounds like the configuration might be resetting itself when attempting to re-establish the connection or set the IP through YAT. What's odd is that while the macros and configurations for components like the BLtouch remain intact, it's specifically the config/g that seems to be affected.
              • fcwiltundefined
                fcwilt @Casugo
                Fantastic.
                If you are directly connecting your computer to the Duet you need to set the Duet IP address to something that falls within the range of addresses your computer is expecting.
                Using the subnet mask you can compute the range which is:
                172.23.32.2 through 172.23.39.254 with the exception of the computers address of 172.23.36.34
                Now if I were faced with having lost the contents of the SD card I would resort to connecting the SD card to my computer using an SD-to-USB adapter.
                Then using a text editor, NotePad or the like, to create the bare minimum config.g file so I could then connect directly to the Duet from my computer.
                Something like this:
                ; config.g - just enough to get connected - beginning of file
                ; prologue
                M111 S0                ; debug off
                M550 P"FT5"            ; machine name (can be anything you like)
                M555 P1                ; firmware compatibility (P1=RepRap P2=Marlin P6=nanoDLP)
                M575 P0 B115200 S2     ; communication parameters for USB serial
                M575 P1 B115200 S1     ; communication parameters for PanelDue
                M552 P172.23.32.2 S1   ; set address (P) enable Ethernet (S1)
                M553 P255.255.248.0    ; set subnet mask (P)
                M554 P172.23.32.1      ; set gateway (P)
                M586 S1 P1 T0 R21      ; enable (S1) FTP    (P1) Disable TLS (T0) Port (R)
                M586 S1 P2 T0 R2323    ; enable (S1) Telnet (P2) Disable TLS (T0) Port (R)
                G21                    ; dimensions in mm
                G90                    ; for X,Y,Z     use absolute coordinate values
                M83                    ; for E0,E1,etc use relative coordinate values
                ; config.g - just enough to get connected - end of file
                • Casugoundefined
                  Casugo @fcwilt
                  @fcwilt
                  Hii!!!
                  By connecting the SD card to my computer and restoring the previous config.g file, I successfully established a connection to the DWC :D.However, I've noticed that I'm currently using the previous IP address instead of the ones you suggested.
                  Would it be advisable to change it to the recommended IP addresses, or should I leave it as is since the current setup is working fine?"
                  Thanks a lot!!!
                  • fcwiltundefined
                    fcwilt @Casugo
                    @Casugo
                    I see the issue.
                    When you took a screen shot from running Windows IPconfig you selected the WiFi connection, not the Ethernet connection - and I did not notice that - my mistake.
                    If you ran IPconfig again and looked for the Ethernet connection it would have a similar address to that one that is working for you.
                    • Casugoundefined
                      Casugo @fcwilt
                      @fcwilt
                      Oh yes, my bad sorry.
                      Do you have any idea of why that happened and why it restart the config?
                      Thank you so much for your help 😄
                      • fcwiltundefined
                        fcwilt @Casugo
                        @Casugo
                        From a distance, via this forum it's hard to tell what may have happened.
                        I make a point of keeping multiple backups of all the files on my SD card.
                        I guess you know that you can, from the DWC, select all the Gcode files in the SYSTEM folder and download them to your computer as a ZIP file.
                        I just name it something like PRINTER_NAME_SNAP_#.zip where # is a sequential number.
                        So I might have PRINTER_NAME_SNAP_1.zip, PRINTER_NAME_SNAP_2.zip and so on.
                        Is this your only printer?
                        • Casugoundefined
                          Casugo @fcwilt
                          @fcwilt
                          Okay!!
                          Yes, I used to regularly save the complete configuration by downloading it directly from the DWC.
                          Is the printer at work just that I upgraded with the duet and is the first time this happen to me.
                          Thank you so much 🙂
                          • fcwiltundefined
                            fcwilt @Casugo
                            @Casugo
                            Glad to help whenever I can.
