    Filament monitoring attached to U axis on
    Filament Monitor
    481
      droftarts administrators @Duet_lover
      @India See https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m563-define-or-remove-a-tool, particularly the description of the D, H and F parameters.
      Example:
      M563 P2 D0:1 H1:2 F0:2 ; create a tool using extruder drives 0 and 1, heaters 1 and 2,  and fan mapped to fans 0 and 2
      Duet_loverundefined 1 Reply Last reply Reply Quote 0
      • Duet_loverundefined
        Duet_lover @droftarts
        @droftarts thanks for your help.
        As per your suggestion, I am able to configure two extruder E0 and E1 .1.PNG .
        M563 P0 D0:1
        G10 P0 R0 S0
        T0:1 ; tool
        After this I tried to monitor the filament runout using sensor BIGTREETECH by inserting the code in config.g as
        M591 D1 P7 C"e1stop" L7 R50:200 E5 S1 ;configure BTT smart filament sensor
        M591 D1 ; display filament sensor parameters for extruder drive
        where i have attached it to "e1stop" and run a two line g-code from SD card as
        G1 E0:50 F180
        G1 E0:-50 F180
        i found error shown in figure.
        M591 D0 shows that there is no sensor (here I don't want to monitor the filament as it used for extruding liquid)
        M591 D1- shows the sensor attached to it and where I want to monitor the filament.
        so based on above can some one guide me
          @India What firmware version are you running? Send M115 in the console, and post the response.
            please find the response of M115
              @India Please update to 3.4.6 and test again.
                @droftarts Thanks, I have updated the firmware to 3.4.6. Now it is not showing the problem as I was facing in old version.
                Now filament sensor showing no calibrated data only as shown below
                I have tried printing two line code from SD card (G1 E0:200; G1E0:-200) but it is not able to calibrate.
                The code I have used to configure the sensor is
                M591 D1 P7 C"e1stop" L7 R50:200 E22 S1
                I am little confused about the R and E value , can u please suggest me how to get these value
                  Duet_lover @Duet_lover
                  @India said in Filament monitoring attached to U axis on:
                  @droftarts please help me out.
                    @India I don't have a BigTreeTech filament monitor to test, it isn't manufactured by us, and I don't know if the way you have set it up is correct. Please refer to the BigTreeTech documentation, or at very least provide a link to it so I know which version you have: BTT have produced two, V1 and V2, which do you have?
                    According to the documentation here, the configuration should be:
                    V1 (which appears to be what you have, and have set)
                    M591 D1 P7 C"e1stop" L7 R75:125 E22 S1
                    V2
                    M591 D1 P7 C"e1stop" L2.88 R75:125 E9 S1
                    If your configuration is correct, I don't know how many points counts as calibrated, but I doubt just extruding and retracting 200mm is enough to calibrate it. It really needs to start a print, so enough data can be collected, particularly if you are using a V1, which has larger distance between points sampled. Use the E parameter suggested; the R parameter is just for how sensitive you want the monitor to be.
                      @droftarts thank you sir.
                        @India Did you get it working? If so, please let us know, and what steps you took, so the information is here for other people, and so I can mark the thread as solved.
