    issues installing on PI 3 B+
    Third-party software
    2.6k
    • sankafolaundefined
      sankafola @stuartofmt
      @stuartofmt said in issues installing on PI 3 B+:
      Are you trying to install on a Pi that is used in SBC mode with a Duet3d board?
      What version of Duet are you using?
      What Duet3d board ?
      What version of Raspberry Pi are you using?
      hi , here are the answers
      Are you trying to install on a Pi that is used in SBC mode with a Duet3d board? not SBC mode am trying to do a standalone on pi 3 b+
      What version of Duet are you using? 3.5.0-rc.1+102
      What Duet3d board ? am using SKR PRO on a predator
      What version of Raspberry Pi are you using? PI 3 B+
      and i just noticed the file i copied was from the plugin 3.5 do i need to copy the one under 3.4 release instead ?
      when i do that i get this
      But the interface don’t open at 10.0.1.126:8082 it says refused connection
      stuartofmtundefined 1 Reply Last reply Reply Quote 0
      • stuartofmtundefined
        stuartofmt @sankafola
        @sankafola
        Hi -
        A couple of things.
        1- I have not released a standalone version for 3.5.0-rc.1 yet only the plug-in for SBC. The reason is because (a) it’s still a beta release and (b) I don’t have a standalone version to test with.
        Having said that, the 3.5.0-Rc.1 version should work.
        As you saw - the 3.4 version fails a version comparison test (this is expected).
        I’m happy to work with you but you need to only use the 3.5.0-rc.1 version.
        Please install that version, set -verbose in the config file and post a complete log file. That way we can see what’s happening in detail.
        As an aside - I see that you have a low voltage warning. This is common for raspberry pi’s with a power supply that is not adequate. It’s best to fix that as it can cause all sorts of strange behavior.
        sankafolaundefined 1 Reply Last reply Reply Quote 0
          @stuartofmt
          hi , yes i will fix that issue , in the sametime i want to show you what i have now
          the printer is running but no video maybe at the end ?
          here is the other screens
          you notice in this one it says connected and down it says printer not connected !!
          startup log
          2023-12-18 21:36:32,175 - MainThread - DuetLapse3 Version --- 5.2.3
          2023-12-18 21:36:32,176 - MainThread - Process Id --- 3529
          2023-12-18 21:36:32,177 - MainThread - -------------------------------------------------------------------------------
          2023-12-18 21:36:32,179 - MainThread - dontwait has been changed to True
          2023-12-18 21:36:32,180 - MainThread - ################### Options at start of this print job #####################
          2023-12-18 21:36:32,182 - MainThread - # Environment
          2023-12-18 21:36:32,183 - MainThread - -duet = 10.0.1.126
          2023-12-18 21:36:32,184 - MainThread - -basedir = /home/pi/DuetLapse
          2023-12-18 21:36:32,185 - MainThread - -poll = 10
          2023-12-18 21:36:32,186 - MainThread - -instances = single
          2023-12-18 21:36:32,187 - MainThread - -logtype = both
          2023-12-18 21:36:32,188 - MainThread - -nolog = False
          2023-12-18 21:36:32,188 - MainThread - -verbose = False
          2023-12-18 21:36:32,189 - MainThread - -host = 0.0.0.0
          2023-12-18 21:36:32,190 - MainThread - -port = 8082
          2023-12-18 21:36:32,190 - MainThread - -keeplogs = False
          2023-12-18 21:36:32,191 - MainThread - -novideo = False
          2023-12-18 21:36:32,192 - MainThread - -deletepics = False
          2023-12-18 21:36:32,192 - MainThread - -maxffmpeg = 2
          2023-12-18 21:36:32,193 - MainThread - -keepfiles = False
          2023-12-18 21:36:32,194 - MainThread - # Execution
          2023-12-18 21:36:32,195 - MainThread - -dontwait = True
          2023-12-18 21:36:32,195 - MainThread - -seconds = 30
          2023-12-18 21:36:32,196 - MainThread - -detect = none
          2023-12-18 21:36:32,197 - MainThread - -pause = no
          2023-12-18 21:36:32,198 - MainThread - -movehead = [0, 0]
          2023-12-18 21:36:32,199 - MainThread - -rest = 1
          2023-12-18 21:36:32,200 - MainThread - -standby = False
          2023-12-18 21:36:32,201 - MainThread - -restart = False
          2023-12-18 21:36:32,201 - MainThread - # Camera
          2023-12-18 21:36:32,202 - MainThread - -camera1 = stream
          2023-12-18 21:36:32,203 - MainThread - -camera2
          2023-12-18 21:36:32,203 - MainThread - -weburl1 = http://10.0.1.110/stream
          2023-12-18 21:36:32,204 - MainThread - -weburl2
          2023-12-18 21:36:32,205 - MainThread - # Video
          2023-12-18 21:36:32,206 - MainThread - -extratime = 0
          2023-12-18 21:36:32,207 - MainThread - -fps = 10
          2023-12-18 21:36:32,208 - MainThread - -minvideo = 5
          2023-12-18 21:36:32,209 - MainThread - -maxvideo = 0
          2023-12-18 21:36:32,211 - MainThread - # Overrides
          2023-12-18 21:36:32,212 - MainThread - -camparam1
          2023-12-18 21:36:32,213 - MainThread - -camparam2
          2023-12-18 21:36:32,214 - MainThread - -vidparam1
          2023-12-18 21:36:32,215 - MainThread - -vidparam2
          2023-12-18 21:36:32,216 - MainThread - # UI
          2023-12-18 21:36:32,218 - MainThread - -hidebuttons = False
          2023-12-18 21:36:32,219 - MainThread - # Special Functions
          2023-12-18 21:36:32,220 - MainThread - -execkey
          2023-12-18 21:36:32,221 - MainThread - -----------------------------------------------------------------------
          2023-12-18 21:36:32,223 - MainThread - ************************************************************************************
          2023-12-18 21:36:32,224 - MainThread - Warning: -seconds 30 and -detect none
          2023-12-18 21:36:32,225 - MainThread - This combination implies -dontwait and will be set automatically
          2023-12-18 21:36:32,226 - MainThread - ************************************************************************************
          2023-12-18 21:36:32,229 - MainThread - ##########################################################
          2023-12-18 21:36:32,230 - MainThread - Will start capturing images immediately
          2023-12-18 21:36:32,231 - MainThread - ##########################################################
          2023-12-18 21:36:32,232 - MainThread - ##########################################################
          2023-12-18 21:36:32,233 - MainThread - Video will be created when printing ends
          2023-12-18 21:36:32,233 - MainThread - or if requested from the UI or M291 "DuetLapse3.completed" S2
          2023-12-18 21:36:32,234 - MainThread - ##########################################################
          2023-12-18 21:36:32,235 - MainThread - ##########################################################
          2023-12-18 21:36:32,236 - MainThread - If running from a console using the command line
          2023-12-18 21:36:32,236 - MainThread - Press Ctrl+C one time to stop the program and create a video.
          2023-12-18 21:36:32,237 - MainThread - ##########################################################
          2023-12-18 21:36:32,240 - MainThread - ##########################################################
          2023-12-18 21:36:32,242 - MainThread - ***** Started http listener *****
          2023-12-18 21:36:32,243 - MainThread - ##########################################################
          2023-12-18 21:36:32,245 - MainThread - Logging in to Printer
          2023-12-18 21:36:32,470 - MainThread - !!!!! Checking for firmware version 3.4 !!!!!
          2023-12-18 21:36:32,525 - MainThread - ###############################################################
          2023-12-18 21:36:32,527 - MainThread - The printer at 10.0.1.126 needs to be at version 3.4
          2023-12-18 21:36:32,528 - MainThread - The version on this printer is 3.5.0-rc.1+102
          2023-12-18 21:36:32,529 - MainThread - ###############################################################
          i just saw that you want me to use the ver 3.5 do you mean the DuetLapse3.py under the folder plugin 3.5 ? which was giving me errors before ? so now i did and i added the -vebrose here is the log file
          2023-12-19 06:44:19,549 - MainThread - DuetLapse3 Version --- 5.3.3
          2023-12-19 06:44:19,549 - MainThread - Requires Duet3d Version --- 3.5.0-rc.1
          2023-12-19 06:44:19,550 - MainThread - Process Id --- 3042
          2023-12-19 06:44:19,551 - MainThread - -------------------------------------------------------------------------------
          2023-12-19 06:44:19,552 - MainThread - seconds has been changed to 30
          2023-12-19 06:44:19,553 - MainThread - poll has been changed to 10
          2023-12-19 06:44:19,554 - MainThread - dontwait has been changed to True
          2023-12-19 06:44:19,556 - MainThread - ################### Options at start of this print job #####################
          2023-12-19 06:44:19,557 - MainThread - # Simulate
          2023-12-19 06:44:19,557 - MainThread - -simulate = off
          2023-12-19 06:44:19,558 - MainThread - # Environment
          2023-12-19 06:44:19,558 - MainThread - -duet = 10.0.1.126
          2023-12-19 06:44:19,559 - MainThread - -password = reprap
          2023-12-19 06:44:19,559 - MainThread - -basedir = /home/pi/DuetLapse
          2023-12-19 06:44:19,560 - MainThread - -poll = 10
          2023-12-19 06:44:19,561 - MainThread - -instances = single
          2023-12-19 06:44:19,561 - MainThread - -logtype = both
          2023-12-19 06:44:19,562 - MainThread - -nolog = False
          2023-12-19 06:44:19,562 - MainThread - -verbose = True
          2023-12-19 06:44:19,563 - MainThread - -host = 0.0.0.0
          2023-12-19 06:44:19,563 - MainThread - -port = 8082
          2023-12-19 06:44:19,564 - MainThread - -keeplogs = False
          2023-12-19 06:44:19,564 - MainThread - -novideo = False
          2023-12-19 06:44:19,565 - MainThread - -deletepics = False
          2023-12-19 06:44:19,566 - MainThread - -maxffmpeg = 2
          2023-12-19 06:44:19,566 - MainThread - -keepfiles = False
          2023-12-19 06:44:19,567 - MainThread - # Execution
          2023-12-19 06:44:19,567 - MainThread - -dontwait = True
          2023-12-19 06:44:19,568 - MainThread - -seconds = 30
          2023-12-19 06:44:19,569 - MainThread - -detect = none
          2023-12-19 06:44:19,569 - MainThread - -pause = no
          2023-12-19 06:44:19,570 - MainThread - -numlayers = 1
          2023-12-19 06:44:19,570 - MainThread - -movehead = [0, 0]
          2023-12-19 06:44:19,571 - MainThread - -rest = 1
          2023-12-19 06:44:19,572 - MainThread - -standby = False
          2023-12-19 06:44:19,572 - MainThread - -restart = False
          2023-12-19 06:44:19,573 - MainThread - # Camera
          2023-12-19 06:44:19,574 - MainThread - -camera1 = stream
          2023-12-19 06:44:19,574 - MainThread - -camera2
          2023-12-19 06:44:19,575 - MainThread - -weburl1 = http://10.0.1.110/stream
          2023-12-19 06:44:19,575 - MainThread - -weburl2
          2023-12-19 06:44:19,576 - MainThread - # Video
          2023-12-19 06:44:19,577 - MainThread - -extratime = 0
          2023-12-19 06:44:19,577 - MainThread - -fps = 10
          2023-12-19 06:44:19,578 - MainThread - -minvideo = 5
          2023-12-19 06:44:19,578 - MainThread - -maxvideo = 0
          2023-12-19 06:44:19,579 - MainThread - # Overrides
          2023-12-19 06:44:19,579 - MainThread - -camparam1
          2023-12-19 06:44:19,580 - MainThread - -camparam2
          2023-12-19 06:44:19,580 - MainThread - -vidparam1
          2023-12-19 06:44:19,581 - MainThread - -vidparam2
          2023-12-19 06:44:19,581 - MainThread - # UI
          2023-12-19 06:44:19,582 - MainThread - -hidebuttons = False
          2023-12-19 06:44:19,583 - MainThread - # Special Functions
          2023-12-19 06:44:19,583 - MainThread - -execkey
          2023-12-19 06:44:19,584 - MainThread - -M3291 = M3291
          2023-12-19 06:44:19,584 - MainThread - -----------------------------------------------------------------------
          2023-12-19 06:44:19,585 - MainThread - ************************************************************************************
          2023-12-19 06:44:19,586 - MainThread - Warning: -seconds 30 and -detect none
          2023-12-19 06:44:19,586 - MainThread - This combination implies -dontwait and will be set automatically
          2023-12-19 06:44:19,587 - MainThread - ************************************************************************************
          2023-12-19 06:44:19,589 - MainThread - ##########################################################
          2023-12-19 06:44:19,590 - MainThread - Will start capturing images immediately
          2023-12-19 06:44:19,591 - MainThread - ##########################################################
          2023-12-19 06:44:19,592 - MainThread - ##########################################################
          2023-12-19 06:44:19,593 - MainThread - Video will be created when printing ends
          2023-12-19 06:44:19,593 - MainThread - or if requested from the UI or M3291 P"DuetLapse3.completed"
          2023-12-19 06:44:19,594 - MainThread - ##########################################################
          2023-12-19 06:44:19,596 - MainThread - ##########################################################
          2023-12-19 06:44:19,597 - MainThread - If running from a console using the command line
          2023-12-19 06:44:19,597 - MainThread - Press Ctrl+C one time to stop the program and create a video.
          2023-12-19 06:44:19,598 - MainThread - ##########################################################
          2023-12-19 06:44:19,599 - MainThread - ***** Initializing state and counters *****
          2023-12-19 06:44:19,602 - MainThread - ##########################################################
          2023-12-19 06:44:19,603 - MainThread - ***** Started http listener *****
          2023-12-19 06:44:19,604 - MainThread - ##########################################################
          2023-12-19 06:44:19,604 - MainThread - Logging in to Printer
          2023-12-19 06:44:19,605 - MainThread - 0 url: http://10.0.1.126/rr_disconnect post: False
          2023-12-19 06:44:19,931 - MainThread - 0 url: http://10.0.1.126/rr_connect?password=reprap post: False
          2023-12-19 06:44:20,289 - MainThread - !!!!! Connected to printer Standalone !!!!!
          2023-12-19 06:44:20,290 - MainThread - !!!!! Checking for firmware version 3.5.0-rc.1 !!!!!
          2023-12-19 06:44:20,291 - MainThread - 0 url: http://10.0.1.126/rr_model?key=boards post: False
          2023-12-19 06:44:20,326 - MainThread - ###############################################################
          2023-12-19 06:44:20,327 - MainThread - Connected to printer at 10.0.1.126
          2023-12-19 06:44:20,328 - MainThread - Using Duet version 3.5.0-rc.1+102
          2023-12-19 06:44:20,328 - MainThread - Using API interface rr_model
          2023-12-19 06:44:20,329 - MainThread - ###############################################################
          2023-12-19 06:44:20,330 - MainThread - isPlugin ignored - only valid for SBC
          2023-12-19 06:44:20,331 - MainThread - Initializing DL3msg queue
          2023-12-19 06:44:20,332 - MainThread - 0 url: http://10.0.1.126/rr_gcode?gcode=M3291 B"Clear" post: False
          2023-12-19 06:44:20,386 - mainLoop - ###########################
          2023-12-19 06:44:20,387 - MainThread - Initiating with action set to start
          2023-12-19 06:44:20,387 - mainLoop - Starting mainLoop
          2023-12-19 06:44:20,388 - MainThread - Calling nextaction start from main --> startup --> nextAction
          2023-12-19 06:44:20,389 - mainLoop - ###########################
          2023-12-19 06:44:20,390 - MainThread - ++++++ start state requested ++++++
          2023-12-19 06:44:20,390 - mainLoop - Calling Status from run --> mainLoop --> getDuet
          2023-12-19 06:44:20,391 - MainThread - nextAction requested stopCaptureLoop
          2023-12-19 06:44:20,392 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=state post: False
          2023-12-19 06:44:20,392 - MainThread - captureLoop is not running
          2023-12-19 06:44:20,400 - MainThread - nextAction satisfied waitforCaptureLoop
          2023-12-19 06:44:20,409 - MainThread - ++++++ Determining next logical action ++++++
          2023-12-19 06:44:20,411 - MainThread - ++++++ Entering start state ++++++
          2023-12-19 06:44:20,412 - MainThread - nextAction exiting normally
          2023-12-19 06:44:20,435 - mainLoop - Status is idle
          2023-12-19 06:44:20,437 - mainLoop - !!!!! UNRECOVERABLE ERROR ENCOUNTERED IN MAIN LOOP -- 'global'
          2023-12-19 06:44:20,437 - mainLoop - !!!!! Forced Termination !!!!!
            sankafola @sankafola
            @sankafola said in issues installing on PI 3 B+:
            @stuartofmt
            @stuartofmt now am running the 5.3 file which i found in the plugin dir 5.3 see the log below
            2023-12-19 10:37:31,784 - MainThread - DuetLapse3 Version --- 5.3.3
            2023-12-19 10:37:31,785 - MainThread - Requires Duet3d Version --- 3.5.0-rc.1
            2023-12-19 10:37:31,786 - MainThread - Process Id --- 2323
            2023-12-19 10:37:31,786 - MainThread - -------------------------------------------------------------------------------
            2023-12-19 10:37:31,787 - MainThread - seconds has been changed to 30
            2023-12-19 10:37:31,788 - MainThread - poll has been changed to 10
            2023-12-19 10:37:31,790 - MainThread - dontwait has been changed to True
            2023-12-19 10:37:31,791 - MainThread - ################### Options at start of this print job #####################
            2023-12-19 10:37:31,791 - MainThread - # Simulate
            2023-12-19 10:37:31,791 - MainThread - -simulate = off
            2023-12-19 10:37:31,792 - MainThread - # Environment
            2023-12-19 10:37:31,792 - MainThread - -duet = 10.0.1.126
            2023-12-19 10:37:31,792 - MainThread - -password = reprap
            2023-12-19 10:37:31,792 - MainThread - -basedir = /home/pi/DuetLapse
            2023-12-19 10:37:31,793 - MainThread - -poll = 10
            2023-12-19 10:37:31,793 - MainThread - -instances = single
            2023-12-19 10:37:31,793 - MainThread - -logtype = both
            2023-12-19 10:37:31,793 - MainThread - -nolog = False
            2023-12-19 10:37:31,794 - MainThread - -verbose = True
            2023-12-19 10:37:31,794 - MainThread - -host = 10.0.1.110
            2023-12-19 10:37:31,794 - MainThread - -port = 8082
            2023-12-19 10:37:31,794 - MainThread - -keeplogs = False
            2023-12-19 10:37:31,795 - MainThread - -novideo = False
            2023-12-19 10:37:31,795 - MainThread - -deletepics = False
            2023-12-19 10:37:31,795 - MainThread - -maxffmpeg = 2
            2023-12-19 10:37:31,795 - MainThread - -keepfiles = False
            2023-12-19 10:37:31,796 - MainThread - # Execution
            2023-12-19 10:37:31,796 - MainThread - -dontwait = True
            2023-12-19 10:37:31,796 - MainThread - -seconds = 30
            2023-12-19 10:37:31,797 - MainThread - -detect = none
            2023-12-19 10:37:31,797 - MainThread - -pause = no
            2023-12-19 10:37:31,797 - MainThread - -numlayers = 1
            2023-12-19 10:37:31,797 - MainThread - -movehead = [0, 0]
            2023-12-19 10:37:31,798 - MainThread - -rest = 1
            2023-12-19 10:37:31,798 - MainThread - -standby = False
            2023-12-19 10:37:31,798 - MainThread - -restart = False
            2023-12-19 10:37:31,798 - MainThread - # Camera
            2023-12-19 10:37:31,799 - MainThread - -camera1 = stream
            2023-12-19 10:37:31,799 - MainThread - -camera2
            2023-12-19 10:37:31,799 - MainThread - -weburl1 = http://10.0.1.110:8081
            2023-12-19 10:37:31,800 - MainThread - -weburl2
            2023-12-19 10:37:31,800 - MainThread - # Video
            2023-12-19 10:37:31,800 - MainThread - -extratime = 0
            2023-12-19 10:37:31,801 - MainThread - -fps = 10
            2023-12-19 10:37:31,801 - MainThread - -minvideo = 5
            2023-12-19 10:37:31,802 - MainThread - -maxvideo = 0
            2023-12-19 10:37:31,802 - MainThread - # Overrides
            2023-12-19 10:37:31,803 - MainThread - -camparam1
            2023-12-19 10:37:31,803 - MainThread - -camparam2
            2023-12-19 10:37:31,804 - MainThread - -vidparam1
            2023-12-19 10:37:31,804 - MainThread - -vidparam2
            2023-12-19 10:37:31,805 - MainThread - # UI
            2023-12-19 10:37:31,805 - MainThread - -hidebuttons = False
            2023-12-19 10:37:31,806 - MainThread - # Special Functions
            2023-12-19 10:37:31,806 - MainThread - -execkey
            2023-12-19 10:37:31,806 - MainThread - -M3291 = M3291
            2023-12-19 10:37:31,807 - MainThread - -----------------------------------------------------------------------
            2023-12-19 10:37:31,807 - MainThread - ************************************************************************************
            2023-12-19 10:37:31,808 - MainThread - Warning: -seconds 30 and -detect none
            2023-12-19 10:37:31,809 - MainThread - This combination implies -dontwait and will be set automatically
            2023-12-19 10:37:31,810 - MainThread - ************************************************************************************
            2023-12-19 10:37:31,815 - MainThread - ##########################################################
            2023-12-19 10:37:31,817 - MainThread - Will start capturing images immediately
            2023-12-19 10:37:31,819 - MainThread - ##########################################################
            2023-12-19 10:37:31,820 - MainThread - Video will be created when printing ends
            2023-12-19 10:37:31,820 - MainThread - or if requested from the UI or M3291 P"DuetLapse3.completed"
            2023-12-19 10:37:31,821 - MainThread - ##########################################################
            2023-12-19 10:37:31,821 - MainThread - If running from a console using the command line
            2023-12-19 10:37:31,822 - MainThread - Press Ctrl+C one time to stop the program and create a video.
            2023-12-19 10:37:31,822 - MainThread - ##########################################################
            2023-12-19 10:37:31,822 - MainThread - ***** Initializing state and counters *****
            2023-12-19 10:37:31,853 - MainThread - ##########################################################
            2023-12-19 10:37:31,854 - MainThread - ***** Started http listener *****
            2023-12-19 10:37:31,854 - MainThread - ##########################################################
            2023-12-19 10:37:31,854 - MainThread - Logging in to Printer
            2023-12-19 10:37:31,855 - MainThread - 0 url: http://10.0.1.126/rr_disconnect post: False
            2023-12-19 10:37:35,005 - MainThread - Cannot connect to the printer
            2023-12-19 10:37:35,006 - MainThread - HTTPConnectionPool(host='10.0.1.126', port=80): Max retries exceeded with url: /rr_disconnect (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x75c87538>: Failed to establish a new connection: [Errno 113] No route to host'))
            2023-12-19 10:37:35,007 - MainThread - !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
            2023-12-19 10:37:36,008 - MainThread - 1 url: http://10.0.1.126/rr_disconnect post: False
            2023-12-19 10:37:37,761 - MainThread - Terminating because of Ctl + C (SIGINT)
            2023-12-19 10:37:37,762 - MainThread - !!!!! Forced Termination !!!!!
            and here is my config
            -basedir /home/pi/DuetLapse
            -duet 10.0.1.126
            -port 8082
            -seconds 30
            -detect none
            -weburl1 http://10.0.1.110:8081
            -verbose
            -camera1 stream
            -host 10.0.1.110
            my printer is 10.0.1.126 and my pi is on 10.0.1.110
              @stuartofmt
              -duet 10.0.1.126
              -port 8082
              -seconds 30
              -detect none
              -verbose
              -camera1 stream
              -host 10.0.1.110
              i tried to stop the printer and start it while the DuetPalse is running so it was running a bet no video
              here is the log
              2023-12-19 10:45:42,698 - MainThread - DuetLapse3 Version --- 5.3.3
              2023-12-19 10:45:42,699 - MainThread - Requires Duet3d Version --- 3.5.0-rc.1
              2023-12-19 10:45:42,699 - MainThread - Process Id --- 2856
              2023-12-19 10:45:42,700 - MainThread - -------------------------------------------------------------------------------
              2023-12-19 10:45:42,701 - MainThread - seconds has been changed to 30
              2023-12-19 10:45:42,702 - MainThread - poll has been changed to 10
              2023-12-19 10:45:42,703 - MainThread - dontwait has been changed to True
              2023-12-19 10:45:42,704 - MainThread - ################### Options at start of this print job #####################
              2023-12-19 10:45:42,705 - MainThread - # Simulate
              2023-12-19 10:45:42,705 - MainThread - -simulate = off
              2023-12-19 10:45:42,705 - MainThread - # Environment
              2023-12-19 10:45:42,705 - MainThread - -duet = 10.0.1.126
              2023-12-19 10:45:42,706 - MainThread - -password = reprap
              2023-12-19 10:45:42,706 - MainThread - -basedir = /home/pi/DuetLapse
              2023-12-19 10:45:42,706 - MainThread - -poll = 10
              2023-12-19 10:45:42,706 - MainThread - -instances = single
              2023-12-19 10:45:42,707 - MainThread - -logtype = both
              2023-12-19 10:45:42,707 - MainThread - -nolog = False
              2023-12-19 10:45:42,707 - MainThread - -verbose = True
              2023-12-19 10:45:42,707 - MainThread - -host = 0.0.0.0
              2023-12-19 10:45:42,708 - MainThread - -port = 8082
              2023-12-19 10:45:42,708 - MainThread - -keeplogs = False
              2023-12-19 10:45:42,708 - MainThread - -novideo = False
              2023-12-19 10:45:42,708 - MainThread - -deletepics = False
              2023-12-19 10:45:42,709 - MainThread - -maxffmpeg = 2
              2023-12-19 10:45:42,709 - MainThread - -keepfiles = False
              2023-12-19 10:45:42,709 - MainThread - # Execution
              2023-12-19 10:45:42,709 - MainThread - -dontwait = True
              2023-12-19 10:45:42,709 - MainThread - -seconds = 30
              2023-12-19 10:45:42,710 - MainThread - -detect = none
              2023-12-19 10:45:42,710 - MainThread - -pause = no
              2023-12-19 10:45:42,710 - MainThread - -numlayers = 1
              2023-12-19 10:45:42,710 - MainThread - -movehead = [0, 0]
              2023-12-19 10:45:42,711 - MainThread - -rest = 1
              2023-12-19 10:45:42,711 - MainThread - -standby = False
              2023-12-19 10:45:42,711 - MainThread - -restart = False
              2023-12-19 10:45:42,711 - MainThread - # Camera
              2023-12-19 10:45:42,712 - MainThread - -camera1 = stream
              2023-12-19 10:45:42,712 - MainThread - -camera2
              2023-12-19 10:45:42,712 - MainThread - -weburl1 = http://10.0.1.110/stream
              2023-12-19 10:45:42,712 - MainThread - -weburl2
              2023-12-19 10:45:42,713 - MainThread - # Video
              2023-12-19 10:45:42,713 - MainThread - -extratime = 0
              2023-12-19 10:45:42,713 - MainThread - -fps = 10
              2023-12-19 10:45:42,714 - MainThread - -minvideo = 5
              2023-12-19 10:45:42,714 - MainThread - -maxvideo = 0
              2023-12-19 10:45:42,714 - MainThread - # Overrides
              2023-12-19 10:45:42,714 - MainThread - -camparam1
              2023-12-19 10:45:42,715 - MainThread - -camparam2
              2023-12-19 10:45:42,715 - MainThread - -vidparam1
              2023-12-19 10:45:42,716 - MainThread - -vidparam2
              2023-12-19 10:45:42,716 - MainThread - # UI
              2023-12-19 10:45:42,716 - MainThread - -hidebuttons = False
              2023-12-19 10:45:42,717 - MainThread - # Special Functions
              2023-12-19 10:45:42,717 - MainThread - -execkey
              2023-12-19 10:45:42,717 - MainThread - -M3291 = M3291
              2023-12-19 10:45:42,717 - MainThread - -----------------------------------------------------------------------
              2023-12-19 10:45:42,718 - MainThread - ************************************************************************************
              2023-12-19 10:45:42,718 - MainThread - Warning: -seconds 30 and -detect none
              2023-12-19 10:45:42,718 - MainThread - This combination implies -dontwait and will be set automatically
              2023-12-19 10:45:42,720 - MainThread - ##########################################################
              2023-12-19 10:45:42,720 - MainThread - Will start capturing images immediately
              2023-12-19 10:45:42,721 - MainThread - ##########################################################
              2023-12-19 10:45:42,722 - MainThread - Video will be created when printing ends
              2023-12-19 10:45:42,722 - MainThread - or if requested from the UI or M3291 P"DuetLapse3.completed"
              2023-12-19 10:45:42,722 - MainThread - ##########################################################
              2023-12-19 10:45:42,723 - MainThread - ##########################################################
              2023-12-19 10:45:42,723 - MainThread - If running from a console using the command line
              2023-12-19 10:45:42,723 - MainThread - Press Ctrl+C one time to stop the program and create a video.
              2023-12-19 10:45:42,724 - MainThread - ##########################################################
              2023-12-19 10:45:42,724 - MainThread - ***** Initializing state and counters *****
              2023-12-19 10:45:42,727 - MainThread - ##########################################################
              2023-12-19 10:45:42,729 - MainThread - ***** Started http listener *****
              2023-12-19 10:45:42,731 - MainThread - ##########################################################
              2023-12-19 10:45:42,733 - MainThread - Logging in to Printer
              2023-12-19 10:45:42,736 - MainThread - 0 url: http://10.0.1.126/rr_disconnect post: False
              2023-12-19 10:45:47,756 - MainThread - Cannot connect to the printer
              2023-12-19 10:45:47,757 - MainThread - HTTPConnectionPool(host='10.0.1.126', port=80): Max retries exceeded with url: /rr_disconnect (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x75d364a8>, 'Connection to 10.0.1.126 timed out. (connect timeout=5)'))
              2023-12-19 10:45:47,758 - MainThread - !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
              2023-12-19 10:45:48,760 - MainThread - 1 url: http://10.0.1.126/rr_disconnect post: False
              2023-12-19 10:45:53,776 - MainThread - Cannot connect to the printer
              2023-12-19 10:45:53,777 - MainThread - HTTPConnectionPool(host='10.0.1.126', port=80): Max retries exceeded with url: /rr_disconnect (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x75d368c8>, 'Connection to 10.0.1.126 timed out. (connect timeout=5)'))
              2023-12-19 10:45:53,778 - MainThread - !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
              2023-12-19 10:45:54,780 - MainThread - 0 url: http://10.0.1.126/rr_connect?password=reprap post: False
              2023-12-19 10:45:59,794 - MainThread - Cannot connect to the printer
              2023-12-19 10:45:59,795 - MainThread - HTTPConnectionPool(host='10.0.1.126', port=80): Max retries exceeded with url: /rr_connect?password=reprap (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x75d36d60>, 'Connection to 10.0.1.126 timed out. (connect timeout=5)'))
              2023-12-19 10:45:59,795 - MainThread - !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
              2023-12-19 10:46:00,797 - MainThread - 1 url: http://10.0.1.126/rr_connect?password=reprap post: False
              2023-12-19 10:46:05,812 - MainThread - Cannot connect to the printer
              2023-12-19 10:46:05,813 - MainThread - HTTPConnectionPool(host='10.0.1.126', port=80): Max retries exceeded with url: /rr_connect?password=reprap (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x7549b1a8>, 'Connection to 10.0.1.126 timed out. (connect timeout=5)'))
              2023-12-19 10:46:05,814 - MainThread - !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
              2023-12-19 10:46:06,816 - MainThread - !!!!! Could not connect. code = 9999 reason = Connection Error !!!!!
              2023-12-19 10:46:06,816 - MainThread - 0 url: http://10.0.1.126/machine/disconnect post: False
              2023-12-19 10:46:11,832 - MainThread - Cannot connect to the printer
              2023-12-19 10:46:11,833 - MainThread - HTTPConnectionPool(host='10.0.1.126', port=80): Max retries exceeded with url: /machine/disconnect (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x7549b628>, 'Connection to 10.0.1.126 timed out. (connect timeout=5)'))
              2023-12-19 10:46:11,833 - MainThread - !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
              2023-12-19 10:46:12,836 - MainThread - 1 url: http://10.0.1.126/machine/disconnect post: False
              2023-12-19 10:46:17,854 - MainThread - Cannot connect to the printer
              2023-12-19 10:46:17,855 - MainThread - HTTPConnectionPool(host='10.0.1.126', port=80): Max retries exceeded with url: /machine/disconnect (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x75d36f88>, 'Connection to 10.0.1.126 timed out. (connect timeout=5)'))
              2023-12-19 10:46:17,855 - MainThread - !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
              2023-12-19 10:46:18,857 - MainThread - 0 url: http://10.0.1.126/machine/connect?password=reprap post: False
              2023-12-19 10:46:19,039 - MainThread - !!!!! Connected to SBC printer !!!!!
              2023-12-19 10:46:44,088 - Thread-1 - !!!!! http call: {} !!!!!
              2023-12-19 10:46:44,422 - Thread-2 - !!!!! http call: {'displayStatus': ['true']} !!!!!
              2023-12-19 10:46:54,357 - Thread-4 - !!!!! http call: {'displayStatus': ['true']} !!!!!
              2023-12-19 10:46:54,417 - Thread-5 - !!!!! http call: {'displayStatus': ['true']} !!!!!
              2023-12-19 10:46:56,365 - Thread-6 - !!!!! http call: {'displayControls': ['true']} !!!!!
              2023-12-19 10:46:58,255 - Thread-7 - !!!!! http call: {'displayVideo': ['true']} !!!!!
              2023-12-19 10:46:59,793 - Thread-8 - !!!!! http call: {'displayFiles': ['true']} !!!!!
              2023-12-19 10:46:59,794 - Thread-8 - list_dir called with path = /home/pi/DuetLapse/raspberrypi/10-0-1-126
              2023-12-19 10:46:59,795 - Thread-8 - Finished parsing the files directory
              2023-12-19 10:47:01,597 - Thread-9 - !!!!! http call: {'displayInfo': ['true']} !!!!!
              2023-12-19 10:47:11,116 - Thread-10 - !!!!! http call: {'displayStatus': ['true']} !!!!!
              2023-12-19 10:47:21,119 - Thread-11 - !!!!! http call: {'displayStatus': ['true']} !!!!!
              2023-12-19 10:47:29,449 - Thread-12 - !!!!! http call: {'displayFiles': ['true']} !!!!!
              2023-12-19 10:47:29,450 - Thread-12 - list_dir called with path = /home/pi/DuetLapse/raspberrypi/10-0-1-126
              2023-12-19 10:47:29,452 - Thread-12 - Finished parsing the files directory
              2023-12-19 10:47:30,556 - Thread-13 - !!!!! http call: {'displayInfo': ['true']} !!!!!
              2023-12-19 10:47:31,976 - Thread-14 - !!!!! http call: {'displayVideo': ['true']} !!!!!
              2023-12-19 10:47:33,620 - Thread-15 - !!!!! http call: {'displayControls': ['true']} !!!!!
              2023-12-19 10:47:36,322 - Thread-16 - !!!!! http call: {'command': ['restart']} !!!!!
              2023-12-19 10:47:36,323 - Thread-16 - nextAction is available
              2023-12-19 10:47:36,324 - nextAction - Calling nextaction restart from _bootstrap_inner --> run --> nextAction
              2023-12-19 10:47:36,325 - nextAction - ++++++ restart state requested ++++++
              2023-12-19 10:47:36,326 - nextAction - nextAction requested stopCaptureLoop
              2023-12-19 10:47:36,327 - nextAction - captureLoop is not running
              2023-12-19 10:47:36,327 - nextAction - nextAction satisfied waitforCaptureLoop
              2023-12-19 10:47:36,328 - nextAction - nextaction aborted because connectionState is False
              2023-12-19 10:47:38,880 - Thread-17 - !!!!! http call: {'displayStatus': ['true']} !!!!!
              2023-12-19 10:47:48,866 - Thread-18 - !!!!! http call: {'displayStatus': ['true']} !!!!!
              2023-12-19 10:47:49,996 - Thread-19 - !!!!! http call: {'displayControls': ['true']} !!!!!
              2023-12-19 10:47:51,311 - Thread-20 - !!!!! http call: {'displayStatus': ['true']} !!!!!
              2023-12-19 10:48:01,378 - Thread-21 - !!!!! http call: {'displayStatus': ['true']} !!!!!
              2023-12-19 10:48:11,376 - Thread-22 - !!!!! http call: {'displayStatus': ['true']} !!!!!
              2023-12-19 10:48:21,374 - Thread-23 - !!!!! http call: {'displayStatus': ['true']} !!!!!
              2023-12-19 10:48:31,376 - Thread-24 - !!!!! http call: {'displayStatus': ['true']} !!!!!
              2023-12-19 10:48:41,373 - Thread-25 - !!!!! http call: {'displayStatus': ['true']} !!!!!
              2023-12-19 10:48:51,375 - Thread-26 - !!!!! http call: {'displayStatus': ['true']} !!!!!
              2023-12-19 10:49:50,376 - Thread-27 - !!!!! http call: {'displayStatus': ['true']} !!!!!
              2023-12-19 10:50:37,430 - Thread-28 - !!!!! http call: {'displayStatus': ['true']} !!!!!
              2023-12-19 10:50:38,026 - Thread-29 - !!!!! http call: {} !!!!!
              2023-12-19 10:50:38,203 - Thread-30 - !!!!! http call: {'displayStatus': ['true']} !!!!!
              2023-12-19 10:50:41,892 - Thread-32 - !!!!! http call: {'displayControls': ['true']} !!!!!
              2023-12-19 10:50:43,290 - Thread-33 - !!!!! http call: {'displayVideo': ['true']} !!!!!
              2023-12-19 10:50:45,193 - Thread-34 - !!!!! http call: {'snapshot': ['true']} !!!!!
              2023-12-19 10:50:47,790 - Thread-35 - !!!!! http call: {'displayVideo': ['true']} !!!!!
              2023-12-19 10:50:49,861 - Thread-36 - !!!!! http call: {'displayFiles': ['true']} !!!!!
              2023-12-19 10:50:49,862 - Thread-36 - list_dir called with path = /home/pi/DuetLapse/raspberrypi/10-0-1-126
              2023-12-19 10:50:49,862 - Thread-36 - Finished parsing the files directory
              2023-12-19 10:50:54,814 - Thread-37 - !!!!! http call: {'getfile': ['/home/pi/DuetLapse/raspberrypi/10-0-1-126/startup.log']} !!!!!
              2023-12-19 10:50:54,815 - Thread-37 - Trying to get file /home/pi/DuetLapse/raspberrypi/10-0-1-126/startup.log
              2023-12-19 10:50:54,874 - Thread-37 - application/octet-stream
              2023-12-19-105430_493x322_scrot.png 2023-12-19-105416_541x280_scrot.png 2023-12-19-105402_388x314_scrot.png
              bare in mind the following :
              1-i dont have a password on the printer not sure why it says password is reprap
              2-that was taking while the printer is printing
              3-noticed this too in the log "SBC "
              4-do i need to install motion ? i have ffmpeg installed
              after it run 5 min then it give me same error again forced terminated
              so basicly the DuetLapse runs while the printer is OFF when the printer comes online the !!! forced Termination !!! comes on
                @sankafola
                For clarity - we will be using Version 5.3.3 of DuetLapse3.py found here:
                https://github.com/stuartofmt/DuetLapse3/blob/main/plugin 3.5.0-rc.1/dsf/DuetLapse3.py
                This is what you have in the last logfile. So that part is good.
                The default password is reprap - so that part is fine.
                The printer should be on when DuetLapse starts. The Log indicates that this was not the case because it could not connect to the printer with:
                I'm not sure why it reported success with the SBC connection. I will need to look into that (This is a symptom, not the problem).
                The main problem is that it is not actually connecting to the printer.2023-12-19 10:47:36,328 - nextAction - nextaction aborted because connectionState is False
                From a browser, with the printer on (it does not need to be printing) What output do you get from this url
                http://10.0.1.126//rr_model?key=boards (this is just to check connectivity).
                Are you successfully streaming the video from http://10.0.1.110/stream?
                If you enter that url into a browser - do you see the video? If not then you need to resolve that issue.
                Unfortunately - the screenshot of the log output when the error occured did not use -verbose
                  @stuartofmt
                  when i open http://10.0.1.126//rr_model?key=boards i get this
                  for the camera i dont get stream do i need to install , fswebcam and ffmpeg and motion and set it to 8081 ?
                    @sankafola
                    A couple of things I just noticed.
                    1. You are using an SKF PRO - not a Duet Board - correct ?.
                      Can you show me a screen shot of the object model with the following object:
                      boards
                    Does the Duet3d firmware support the SKF board ?
                    From a browser - what output do you get from:
                    http://10.0.1.126//machine/status
                    To stream video you need something to stream it. If you have not set up a streaming service, you can use something like motion or videostream
                    https://github.com/stuartofmt/videostream
                      @stuartofmt
                      1-am using the SKR PRO and yes running rerap
                      not sure about the object model but i do have a file under the system called boards.txt
                      // Board Hardware configuration file for SKR Pro
                      // generated by RepRapFirmware Configuration Tool (LPC Version) v3.1.10+1-LPC
                      // on Tue Dec 22 2020 13:55:26 GMT-0500 (Eastern Standard Time)
                      //Note: Each line should be less than 120 characters.
                      // : Unwanted options can be commented out or set to NoPin. Lines commented out will get default values
                      // : for pins the default is NoPin.
                      // : Values for Arrays need to be contained within { and }
                      // : Comments can be defined with // or # (comments are not supported inside arrays)
                      // : Each config entry must be all on a single line.
                      lpc.board = biquskrpro_1.1;
                      //LED blinks to indicate Platform is spinning or other diagnostic
                      //Comment out or set to NoPin if not wanted.
                      leds.diagnostic = NoPin;
                      //Internal SDCard SPI Frequency.
                      lpc.internalSDCard.spiFrequencyHz = 25000000;
                      //Only supports 1 External SDCard
                      //externalSDCard.csPin = NoPin;
                      //externalSDCard.cardDetectPin = NoPin;
                      //lpc.externalSDCard.spiFrequencyHz = 4000000;
                      //lpc.externalSDCard.spiChannel = 0;
                      heat.tempSensePins = {bedtemp, e0temp}; //Max of 3 entries
                      //heat.spiTempSensorCSPins = { }; //Max of 2 entries
                      //Analogue to Digital prefilter
                      adc.prefilter.enable = true
                      //ESP Settings
                      //8266wifi.espDataReadyPin = A.8;
                      //8266wifi.lpcTfrReadyPin = G.4;
                      //8266wifi.espResetPin = F.12;
                      //ESP RX/TX Settings
                      //8266wifi.serialRxTxPins = { C.7, C.6 } ;
                      //serial.aux.rxTxPins = {NoPin, NoPin};
                      //serial.aux.rxTxPins = {PA.10, PA.9}
                      //WiFi pins
                      8266wifi.espDataReadyPin = PG_10
                      8266wifi.TfrReadyPin = PF_11
                      8266wifi.espResetPin = PF_12
                      //ESP32 RX/TX Settings
                      8266wifi.serialRxTxPins = { PD_9, PD_8 }
                      serial.aux.rxTxPins = { PA_10, PA_9 }
                      heat.tempSensePins = { PF_6, PF_3, PF_4, PF_5 }
                      			//TMC Smart Drivers
                      stepper.numSmartDrivers = 4;
                      accelerometer.spiChannel = 2
                      //heat.spiTempSensorCSPins = {NoPin, NoPin, NoPin, NoPin, NoPin, NoPin, NoPin, NoPin}
                      as for the http://10.0.1.126//machine/status i get the same results as before which is above when i open the rr...
                        @stuartofmt
                        hi , some update
                        1-i fixed the video stream so i do have now http://10.0.1.110/stream giving a pic
                        the DuetLapse running a bet more now here is the log
                        2023-12-19 17:03:20,353 - MainThread - DuetLapse3 Version --- 5.3.3
                        2023-12-19 17:03:20,354 - MainThread - Requires Duet3d Version --- 3.5.0-rc.1
                        2023-12-19 17:03:20,354 - MainThread - Process Id --- 2393
                        2023-12-19 17:03:20,355 - MainThread - -------------------------------------------------------------------------------
                        2023-12-19 17:03:20,357 - MainThread - seconds has been changed to 30
                        2023-12-19 17:03:20,358 - MainThread - poll has been changed to 10
                        2023-12-19 17:03:20,360 - MainThread - dontwait has been changed to True
                        2023-12-19 17:03:20,361 - MainThread - ################### Options at start of this print job #####################
                        2023-12-19 17:03:20,361 - MainThread - # Simulate
                        2023-12-19 17:03:20,362 - MainThread - -simulate = off
                        2023-12-19 17:03:20,363 - MainThread - # Environment
                        2023-12-19 17:03:20,363 - MainThread - -duet = 10.0.1.126
                        2023-12-19 17:03:20,364 - MainThread - -password = reprap
                        2023-12-19 17:03:20,364 - MainThread - -basedir = /home/pi/DuetLapse
                        2023-12-19 17:03:20,364 - MainThread - -poll = 10
                        2023-12-19 17:03:20,364 - MainThread - -instances = single
                        2023-12-19 17:03:20,365 - MainThread - -logtype = both
                        2023-12-19 17:03:20,365 - MainThread - -nolog = False
                        2023-12-19 17:03:20,365 - MainThread - -verbose = True
                        2023-12-19 17:03:20,366 - MainThread - -host = 0.0.0.0
                        2023-12-19 17:03:20,366 - MainThread - -port = 8081
                        2023-12-19 17:03:20,366 - MainThread - -keeplogs = False
                        2023-12-19 17:03:20,366 - MainThread - -novideo = False
                        2023-12-19 17:03:20,367 - MainThread - -deletepics = False
                        2023-12-19 17:03:20,367 - MainThread - -maxffmpeg = 2
                        2023-12-19 17:03:20,367 - MainThread - -keepfiles = False
                        2023-12-19 17:03:20,367 - MainThread - # Execution
                        2023-12-19 17:03:20,368 - MainThread - -dontwait = True
                        2023-12-19 17:03:20,368 - MainThread - -seconds = 30
                        2023-12-19 17:03:20,368 - MainThread - -detect = none
                        2023-12-19 17:03:20,369 - MainThread - -pause = no
                        2023-12-19 17:03:20,369 - MainThread - -numlayers = 1
                        2023-12-19 17:03:20,369 - MainThread - -movehead = [0, 0]
                        2023-12-19 17:03:20,369 - MainThread - -rest = 1
                        2023-12-19 17:03:20,370 - MainThread - -standby = False
                        2023-12-19 17:03:20,370 - MainThread - -restart = False
                        2023-12-19 17:03:20,370 - MainThread - # Camera
                        2023-12-19 17:03:20,371 - MainThread - -camera1 = web
                        2023-12-19 17:03:20,371 - MainThread - -camera2
                        2023-12-19 17:03:20,371 - MainThread - -weburl1 = http://10.0.1.110/stream
                        2023-12-19 17:03:20,371 - MainThread - -weburl2
                        2023-12-19 17:03:20,372 - MainThread - # Video
                        2023-12-19 17:03:20,372 - MainThread - -extratime = 0
                        2023-12-19 17:03:20,372 - MainThread - -fps = 10
                        2023-12-19 17:03:20,373 - MainThread - -minvideo = 5
                        2023-12-19 17:03:20,374 - MainThread - -maxvideo = 0
                        2023-12-19 17:03:20,374 - MainThread - # Overrides
                        2023-12-19 17:03:20,374 - MainThread - -camparam1
                        2023-12-19 17:03:20,374 - MainThread - -camparam2
                        2023-12-19 17:03:20,375 - MainThread - -vidparam1
                        2023-12-19 17:03:20,375 - MainThread - -vidparam2
                        2023-12-19 17:03:20,375 - MainThread - # UI
                        2023-12-19 17:03:20,376 - MainThread - -hidebuttons = False
                        2023-12-19 17:03:20,376 - MainThread - # Special Functions
                        2023-12-19 17:03:20,376 - MainThread - -execkey
                        2023-12-19 17:03:20,377 - MainThread - -M3291 = M3291
                        2023-12-19 17:03:20,377 - MainThread - -----------------------------------------------------------------------
                        2023-12-19 17:03:20,378 - MainThread - ************************************************************************************
                        2023-12-19 17:03:20,378 - MainThread - Warning: -seconds 30 and -detect none
                        2023-12-19 17:03:20,379 - MainThread - This combination implies -dontwait and will be set automatically
                        2023-12-19 17:03:20,379 - MainThread - ************************************************************************************
                        2023-12-19 17:03:20,381 - MainThread - ##########################################################
                        2023-12-19 17:03:20,381 - MainThread - Will start capturing images immediately
                        2023-12-19 17:03:20,382 - MainThread - ##########################################################
                        2023-12-19 17:03:20,383 - MainThread - Video will be created when printing ends
                        2023-12-19 17:03:20,383 - MainThread - or if requested from the UI or M3291 P"DuetLapse3.completed"
                        2023-12-19 17:03:20,384 - MainThread - ##########################################################
                        2023-12-19 17:03:20,384 - MainThread - If running from a console using the command line
                        2023-12-19 17:03:20,385 - MainThread - Press Ctrl+C one time to stop the program and create a video.
                        2023-12-19 17:03:20,386 - MainThread - ##########################################################
                        2023-12-19 17:03:20,386 - MainThread - ***** Initializing state and counters *****
                        2023-12-19 17:03:20,402 - MainThread - ##########################################################
                        2023-12-19 17:03:20,403 - MainThread - ***** Started http listener *****
                        2023-12-19 17:03:20,404 - MainThread - ##########################################################
                        2023-12-19 17:03:20,405 - MainThread - Logging in to Printer
                        2023-12-19 17:03:20,405 - MainThread - 0 url: http://10.0.1.126/rr_disconnect post: False
                        2023-12-19 17:03:23,554 - MainThread - Cannot connect to the printer
                        2023-12-19 17:03:23,555 - MainThread - HTTPConnectionPool(host='10.0.1.126', port=80): Max retries exceeded with url: /rr_disconnect (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x75cd3988>: Failed to establish a new connection: [Errno 113] No route to host'))
                        2023-12-19 17:03:23,555 - MainThread - !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                        2023-12-19 17:03:24,557 - MainThread - 1 url: http://10.0.1.126/rr_disconnect post: False
                        2023-12-19 17:03:26,675 - MainThread - Cannot connect to the printer
                        2023-12-19 17:03:26,676 - MainThread - HTTPConnectionPool(host='10.0.1.126', port=80): Max retries exceeded with url: /rr_disconnect (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x75cd3da8>: Failed to establish a new connection: [Errno 113] No route to host'))
                        2023-12-19 17:03:26,677 - MainThread - !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                        2023-12-19 17:03:27,680 - MainThread - 0 url: http://10.0.1.126/rr_connect?password=reprap post: False
                        2023-12-19 17:03:28,415 - MainThread - Terminating because of Ctl + C (SIGINT)
                        2023-12-19 17:03:28,416 - MainThread - !!!!! Forced Termination !!!!!
                          @sankafola
                          I think you are out of luck.
                          Duetlapse3 was developed to run with duet hardware and firmware. Part of this means that it needs to support the DWC/ DSF api framework.
                          I’m away from my printer and test-bed. But it’s failing to log on and likely unable to resolve basic information from the object model.
                          If all is as it should be - you should have an object model menu item (left hand pane) in DWC and be able to get object model information.
                          There is not much I can do if this is not the case.
                          Maybe the SKF pro is fully supported. I do not know. Perhaps @T3P3Tony can clarify.
                          sankafolaundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                            @stuartofmt
                            no no dont give up i found it here it is i had to start a plugin to see it on the left
                            now what i need to do ,
                              @sankafola
                              Great ! I can see now see that it should be returning a vaild version. The question is why it is not?
                              Try this version. Its just got a bit more error checking in it.
                              For this check:
                              Make sure the printer is on but not printing.
                              Start DuetLapse3 Make sure you are running with -verbose .
                              Send me the log file.
                              Something strange is happening with the connection to the printer. I need to understand what is happening.
                              DuetLapse3.py
                                @stuartofmt
                                hi , the printer is on not printing , the 10.0.1.110:8082 not opening
                                2023-12-20 07:53:33,364 - MainThread - DuetLapse3 Version --- 5.3.4
                                2023-12-20 07:53:33,365 - MainThread - Requires Duet3d Version --- 3.5.0-rc.1
                                2023-12-20 07:53:33,366 - MainThread - Process Id --- 3438
                                2023-12-20 07:53:33,366 - MainThread - -------------------------------------------------------------------------------
                                2023-12-20 07:53:33,368 - MainThread - seconds has been changed to 30
                                2023-12-20 07:53:33,369 - MainThread - poll has been changed to 10
                                2023-12-20 07:53:33,370 - MainThread - dontwait has been changed to True
                                2023-12-20 07:53:33,371 - MainThread - ################### Options at start of this print job #####################
                                2023-12-20 07:53:33,372 - MainThread - # Simulate
                                2023-12-20 07:53:33,373 - MainThread - -simulate = off
                                2023-12-20 07:53:33,373 - MainThread - # Environment
                                2023-12-20 07:53:33,374 - MainThread - -duet = 10.0.1.126
                                2023-12-20 07:53:33,375 - MainThread - -password = reprap
                                2023-12-20 07:53:33,375 - MainThread - -basedir = /home/pi/DuetLapse
                                2023-12-20 07:53:33,376 - MainThread - -poll = 10
                                2023-12-20 07:53:33,377 - MainThread - -instances = single
                                2023-12-20 07:53:33,377 - MainThread - -logtype = both
                                2023-12-20 07:53:33,378 - MainThread - -nolog = False
                                2023-12-20 07:53:33,379 - MainThread - -verbose = True
                                2023-12-20 07:53:33,379 - MainThread - -host = 0.0.0.0
                                2023-12-20 07:53:33,380 - MainThread - -port = 8082
                                2023-12-20 07:53:33,381 - MainThread - -keeplogs = False
                                2023-12-20 07:53:33,382 - MainThread - -novideo = False
                                2023-12-20 07:53:33,383 - MainThread - -deletepics = False
                                2023-12-20 07:53:33,383 - MainThread - -maxffmpeg = 2
                                2023-12-20 07:53:33,384 - MainThread - -keepfiles = False
                                2023-12-20 07:53:33,384 - MainThread - # Execution
                                2023-12-20 07:53:33,385 - MainThread - -dontwait = True
                                2023-12-20 07:53:33,386 - MainThread - -seconds = 30
                                2023-12-20 07:53:33,386 - MainThread - -detect = none
                                2023-12-20 07:53:33,387 - MainThread - -pause = no
                                2023-12-20 07:53:33,387 - MainThread - -numlayers = 1
                                2023-12-20 07:53:33,388 - MainThread - -movehead = [0, 0]
                                2023-12-20 07:53:33,389 - MainThread - -rest = 1
                                2023-12-20 07:53:33,389 - MainThread - -standby = False
                                2023-12-20 07:53:33,390 - MainThread - -restart = False
                                2023-12-20 07:53:33,391 - MainThread - # Camera
                                2023-12-20 07:53:33,391 - MainThread - -camera1 = stream
                                2023-12-20 07:53:33,393 - MainThread - -camera2
                                2023-12-20 07:53:33,393 - MainThread - -weburl1 = http://10.0.1.110/stream
                                2023-12-20 07:53:33,394 - MainThread - -weburl2
                                2023-12-20 07:53:33,395 - MainThread - # Video
                                2023-12-20 07:53:33,395 - MainThread - -extratime = 0
                                2023-12-20 07:53:33,396 - MainThread - -fps = 10
                                2023-12-20 07:53:33,396 - MainThread - -minvideo = 5
                                2023-12-20 07:53:33,397 - MainThread - -maxvideo = 0
                                2023-12-20 07:53:33,398 - MainThread - # Overrides
                                2023-12-20 07:53:33,398 - MainThread - -camparam1
                                2023-12-20 07:53:33,399 - MainThread - -camparam2
                                2023-12-20 07:53:33,399 - MainThread - -vidparam1
                                2023-12-20 07:53:33,401 - MainThread - -vidparam2
                                2023-12-20 07:53:33,402 - MainThread - # UI
                                2023-12-20 07:53:33,403 - MainThread - -hidebuttons = False
                                2023-12-20 07:53:33,404 - MainThread - # Special Functions
                                2023-12-20 07:53:33,405 - MainThread - -execkey
                                2023-12-20 07:53:33,407 - MainThread - -M3291 = M3291
                                2023-12-20 07:53:33,408 - MainThread - -----------------------------------------------------------------------
                                2023-12-20 07:53:33,409 - MainThread - ************************************************************************************
                                2023-12-20 07:53:33,410 - MainThread - Warning: -seconds 30 and -detect none
                                2023-12-20 07:53:33,411 - MainThread - This combination implies -dontwait and will be set automatically
                                2023-12-20 07:53:33,412 - MainThread - ************************************************************************************
                                2023-12-20 07:53:33,416 - MainThread - ##########################################################
                                2023-12-20 07:53:33,417 - MainThread - Will start capturing images immediately
                                2023-12-20 07:53:33,418 - MainThread - ##########################################################
                                2023-12-20 07:53:33,419 - MainThread - ##########################################################
                                2023-12-20 07:53:33,419 - MainThread - Video will be created when printing ends
                                2023-12-20 07:53:33,421 - MainThread - or if requested from the UI or M3291 P"DuetLapse3.completed"
                                2023-12-20 07:53:33,422 - MainThread - ##########################################################
                                2023-12-20 07:53:33,422 - MainThread - If running from a console using the command line
                                2023-12-20 07:53:33,423 - MainThread - Press Ctrl+C one time to stop the program and create a video.
                                2023-12-20 07:53:33,423 - MainThread - ##########################################################
                                2023-12-20 07:53:33,423 - MainThread - ***** Initializing state and counters *****
                                2023-12-20 07:53:33,425 - MainThread - ##########################################################
                                2023-12-20 07:53:33,426 - MainThread - ***** Started http listener *****
                                2023-12-20 07:53:33,426 - MainThread - ##########################################################
                                2023-12-20 07:53:33,427 - MainThread - Logging in to Printer
                                2023-12-20 07:53:33,427 - MainThread - 0 url: http://10.0.1.126/rr_disconnect post: False
                                2023-12-20 07:53:33,486 - MainThread - 0 url: http://10.0.1.126/rr_connect?password=reprap post: False
                                2023-12-20 07:53:33,522 - MainThread - !!!!! Connected to printer Standalone !!!!!
                                2023-12-20 07:53:33,523 - MainThread - !!!!! Checking for firmware version 3.5.0-rc.1 !!!!!
                                2023-12-20 07:53:33,524 - MainThread - 0 url: http://10.0.1.126/rr_model?key=boards post: False
                                2023-12-20 07:53:33,545 - MainThread - Version Check returned --> 3.5.0-rc.1+102
                                2023-12-20 07:53:33,545 - MainThread - ###############################################################
                                2023-12-20 07:53:33,546 - MainThread - Connected to printer at 10.0.1.126
                                2023-12-20 07:53:33,546 - MainThread - Using Duet version 3.5.0-rc.1+102
                                2023-12-20 07:53:33,546 - MainThread - Using API interface rr_model
                                2023-12-20 07:53:33,547 - MainThread - ###############################################################
                                2023-12-20 07:53:33,547 - MainThread - isPlugin ignored - only valid for SBC
                                2023-12-20 07:53:33,547 - MainThread - Initializing DL3msg queue
                                2023-12-20 07:53:33,547 - MainThread - 0 url: http://10.0.1.126/rr_gcode?gcode=M3291 B"Clear" post: False
                                2023-12-20 07:53:33,578 - mainLoop - ###########################
                                2023-12-20 07:53:33,579 - mainLoop - Starting mainLoop
                                2023-12-20 07:53:33,579 - MainThread - Initiating with action set to start
                                2023-12-20 07:53:33,579 - mainLoop - ###########################
                                2023-12-20 07:53:33,580 - MainThread - Calling nextaction start from main --> startup --> nextAction
                                2023-12-20 07:53:33,580 - mainLoop - Calling Status from run --> mainLoop --> getDuet
                                2023-12-20 07:53:33,581 - MainThread - ++++++ start state requested ++++++
                                2023-12-20 07:53:33,581 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=state post: False
                                2023-12-20 07:53:33,581 - MainThread - nextAction requested stopCaptureLoop
                                2023-12-20 07:53:33,583 - MainThread - captureLoop is not running
                                2023-12-20 07:53:33,589 - MainThread - nextAction satisfied waitforCaptureLoop
                                2023-12-20 07:53:33,592 - MainThread - ++++++ Determining next logical action ++++++
                                2023-12-20 07:53:33,593 - MainThread - ++++++ Entering start state ++++++
                                2023-12-20 07:53:33,593 - MainThread - nextAction exiting normally
                                2023-12-20 07:53:33,617 - mainLoop - Standalone Status is idle
                                2023-12-20 07:53:33,618 - mainLoop - Error Processing message queue
                                2023-12-20 07:53:33,618 - mainLoop - 'global'
                                2023-12-20 07:53:38,624 - mainLoop - Calling Status from run --> mainLoop --> getDuet
                                2023-12-20 07:53:38,625 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=state post: False
                                2023-12-20 07:53:38,720 - mainLoop - Standalone Status is idle
                                2023-12-20 07:53:38,721 - mainLoop - Error Processing message queue
                                2023-12-20 07:53:38,721 - mainLoop - 'global'
                                2023-12-20 07:53:43,727 - mainLoop - Calling Status from run --> mainLoop --> getDuet
                                2023-12-20 07:53:43,728 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=state post: False
                                2023-12-20 07:53:43,823 - mainLoop - Standalone Status is idle
                                2023-12-20 07:53:43,824 - mainLoop - Error Processing message queue
                                2023-12-20 07:53:43,824 - mainLoop - 'global'
                                2023-12-20 07:53:43,825 - mainLoop - ****** Duet status changed to: idle from unknown *****
                                2023-12-20 07:53:43,826 - mainLoop - ****** stateMachine:
                                2023-12-20 07:53:43,827 - mainLoop - newstate = Capturing
                                2023-12-20 07:53:43,827 - mainLoop - currentState = Waiting
                                2023-12-20 07:53:43,827 - mainLoop - duetStatus = idle
                                2023-12-20 07:53:43,828 - mainLoop - lastDuetStatus = unknown
                                2023-12-20 07:53:43,828 - mainLoop - dontwait = True
                                2023-12-20 07:53:43,829 - mainLoop - detect = none
                                2023-12-20 07:53:43,829 - mainLoop - terminateState = -1
                                2023-12-20 07:53:43,830 - mainLoop - ******
                                2023-12-20 07:53:43,831 - mainLoop - ****** Print State changed to: Capturing from Waiting*****
                                2023-12-20 07:53:43,831 - mainLoop - Calling oneInterval for Camera 1
                                2023-12-20 07:53:43,832 - mainLoop - Calling Layer from captureLoop --> oneInterval --> getDuet
                                2023-12-20 07:53:43,832 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=job.layer post: False
                                2023-12-20 07:53:43,855 - mainLoop - Current Layer is -1
                                2023-12-20 07:53:43,856 - mainLoop - elapsed: 10.432576417922974
                                2023-12-20 07:53:43,857 - mainLoop - ****** stateMachine:
                                2023-12-20 07:53:43,858 - mainLoop - newstate = Waiting
                                2023-12-20 07:53:43,858 - mainLoop - currentState = Capturing
                                2023-12-20 07:53:43,859 - mainLoop - duetStatus = idle
                                2023-12-20 07:53:43,859 - mainLoop - lastDuetStatus = unknown
                                2023-12-20 07:53:43,859 - mainLoop - dontwait = True
                                2023-12-20 07:53:43,860 - mainLoop - detect = none
                                2023-12-20 07:53:43,861 - mainLoop - terminateState = -1
                                2023-12-20 07:53:43,861 - mainLoop - ******
                                2023-12-20 07:53:43,861 - mainLoop - ****** Print State changed to: Waiting from Capturing*****
                                2023-12-20 07:53:48,868 - mainLoop - Calling Status from run --> mainLoop --> getDuet
                                2023-12-20 07:53:48,869 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=state post: False
                                2023-12-20 07:53:48,944 - mainLoop - Standalone Status is idle
                                2023-12-20 07:53:48,945 - mainLoop - Error Processing message queue
                                2023-12-20 07:53:48,945 - mainLoop - 'global'
                                2023-12-20 07:53:53,951 - mainLoop - Calling Status from run --> mainLoop --> getDuet
                                2023-12-20 07:53:53,952 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=state post: False
                                2023-12-20 07:53:54,074 - mainLoop - Standalone Status is idle
                                2023-12-20 07:53:54,075 - mainLoop - Error Processing message queue
                                2023-12-20 07:53:54,075 - mainLoop - 'global'
                                2023-12-20 07:53:54,075 - mainLoop - ****** stateMachine:
                                2023-12-20 07:53:54,076 - mainLoop - newstate = Capturing
                                2023-12-20 07:53:54,076 - mainLoop - currentState = Waiting
                                2023-12-20 07:53:54,076 - mainLoop - duetStatus = idle
                                2023-12-20 07:53:54,077 - mainLoop - lastDuetStatus = idle
                                2023-12-20 07:53:54,077 - mainLoop - dontwait = True
                                2023-12-20 07:53:54,077 - mainLoop - detect = none
                                2023-12-20 07:53:54,077 - mainLoop - terminateState = -1
                                2023-12-20 07:53:54,078 - mainLoop - ******
                                2023-12-20 07:53:54,078 - mainLoop - ****** Print State changed to: Capturing from Waiting*****
                                2023-12-20 07:53:54,079 - mainLoop - Calling oneInterval for Camera 1
                                2023-12-20 07:53:54,079 - mainLoop - Calling Layer from captureLoop --> oneInterval --> getDuet
                                2023-12-20 07:53:54,080 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=job.layer post: False
                                2023-12-20 07:53:54,107 - mainLoop - Current Layer is -1
                                2023-12-20 07:53:54,108 - mainLoop - elapsed: 20.684492111206055
                                2023-12-20 07:53:54,110 - mainLoop - ****** stateMachine:
                                2023-12-20 07:53:54,110 - mainLoop - newstate = Waiting
                                2023-12-20 07:53:54,111 - mainLoop - currentState = Capturing
                                2023-12-20 07:53:54,111 - mainLoop - duetStatus = idle
                                2023-12-20 07:53:54,112 - mainLoop - lastDuetStatus = idle
                                2023-12-20 07:53:54,112 - mainLoop - dontwait = True
                                2023-12-20 07:53:54,113 - mainLoop - detect = none
                                2023-12-20 07:53:54,113 - mainLoop - terminateState = -1
                                2023-12-20 07:53:54,114 - mainLoop - ******
                                2023-12-20 07:53:54,114 - mainLoop - ****** Print State changed to: Waiting from Capturing*****
                                2023-12-20 07:53:59,120 - mainLoop - Calling Status from run --> mainLoop --> getDuet
                                2023-12-20 07:53:59,121 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=state post: False
                                2023-12-20 07:53:59,184 - mainLoop - Standalone Status is idle
                                2023-12-20 07:53:59,185 - mainLoop - Error Processing message queue
                                2023-12-20 07:53:59,185 - mainLoop - 'global'
                                2023-12-20 07:54:04,191 - mainLoop - Calling Status from run --> mainLoop --> getDuet
                                2023-12-20 07:54:04,192 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=state post: False
                                2023-12-20 07:54:04,311 - mainLoop - Standalone Status is idle
                                2023-12-20 07:54:04,311 - mainLoop - Error Processing message queue
                                2023-12-20 07:54:04,312 - mainLoop - 'global'
                                2023-12-20 07:54:04,312 - mainLoop - ****** stateMachine:
                                2023-12-20 07:54:04,312 - mainLoop - newstate = Capturing
                                2023-12-20 07:54:04,313 - mainLoop - currentState = Waiting
                                2023-12-20 07:54:04,313 - mainLoop - duetStatus = idle
                                2023-12-20 07:54:04,313 - mainLoop - lastDuetStatus = idle
                                2023-12-20 07:54:04,314 - mainLoop - dontwait = True
                                2023-12-20 07:54:04,314 - mainLoop - detect = none
                                2023-12-20 07:54:04,314 - mainLoop - terminateState = -1
                                2023-12-20 07:54:04,314 - mainLoop - ******
                                2023-12-20 07:54:04,314 - mainLoop - ****** Print State changed to: Capturing from Waiting*****
                                2023-12-20 07:54:04,315 - mainLoop - Calling oneInterval for Camera 1
                                2023-12-20 07:54:04,315 - mainLoop - Calling Layer from captureLoop --> oneInterval --> getDuet
                                2023-12-20 07:54:04,315 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=job.layer post: False
                                2023-12-20 07:54:04,332 - mainLoop - Current Layer is -1
                                2023-12-20 07:54:04,333 - mainLoop - elapsed: 30.909065008163452
                                2023-12-20 07:54:04,333 - mainLoop - Time - Camera1: capturing frame 1 at layer None after 30 seconds
                                2023-12-20 07:54:04,333 - mainLoop - Calling stack oneInterval --> onePhoto --> createworkingDir
                                2023-12-20 07:54:04,334 - mainLoop - Created working directory: /home/pi/DuetLapse/raspberrypi/10-0-1-126/3438_1
                                2023-12-20 07:54:04,334 - mainLoop - Calling stack onePhoto --> createworkingDir --> renamelogfile
                                2023-12-20 07:54:04,336 - mainLoop - Calling Jobname from onePhoto --> renameworkingDir --> getDuet
                                2023-12-20 07:54:04,336 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=job.file.fileName post: False
                                2023-12-20 07:54:04,360 - mainLoop - jobname was not available
                                2023-12-20 07:54:06,054 - mainLoop - Command Exception: ffmpeg -threads 1 -loglevel quiet -y -i http://10.0.1.110/stream -vframes 1 -threads 1 /home/pi/DuetLapse/raspberrypi/10-0-1-126/3438_1/Camera1_00000001.jpeg
                                2023-12-20 07:54:06,055 - mainLoop - Exception = Command 'ffmpeg -threads 1 -loglevel quiet -y -i http://10.0.1.110/stream -vframes 1 -threads 1 /home/pi/DuetLapse/raspberrypi/10-0-1-126/3438_1/Camera1_00000001.jpeg' returned non-zero exit status 1.
                                2023-12-20 07:54:06,056 - mainLoop - !!!!! There was a problem capturing an image !!!!!
                                2023-12-20 07:54:06,057 - mainLoop - ****** stateMachine:
                                2023-12-20 07:54:06,058 - mainLoop - newstate = Waiting
                                2023-12-20 07:54:06,059 - mainLoop - currentState = Capturing
                                2023-12-20 07:54:06,061 - mainLoop - duetStatus = idle
                                2023-12-20 07:54:06,062 - mainLoop - lastDuetStatus = idle
                                2023-12-20 07:54:06,063 - mainLoop - dontwait = True
                                2023-12-20 07:54:06,064 - mainLoop - detect = none
                                2023-12-20 07:54:06,065 - mainLoop - terminateState = -1
                                2023-12-20 07:54:06,065 - mainLoop - ******
                                2023-12-20 07:54:06,066 - mainLoop - ****** Print State changed to: Waiting from Capturing*****
                                2023-12-20 07:54:08,702 - MainThread - Terminating because of Ctl + C (SIGINT)
                                2023-12-20 07:54:08,704 - MainThread - !!!!! Forced Termination !!!!!
                                and when i open manualy that address i get this
                                stuartofmtundefined 1 Reply Last reply Reply Quote 0
                                • stuartofmtundefined
                                  stuartofmt @sankafola
                                  @sankafola
                                  Broadly speaking. It's working ... up to a point. Note that I did not change anything other than some additional debugging.
                                  Notwithstanding the error calling the M3291 macro (which we will tackle last) - tha main error is that ffmpeg is unable to get an image from your image stream.
                                  This could be a problem with your version of ffmpeg or the stream.
                                  Can you repeat the test with this version (just some more instrumentation).
                                  Can you verify that http://10.0.1.110/stream displays a video stream in your browser?
                                  what is the output from ffmpeg -version
                                  DuetLapse3.py
                                  sankafolaundefined 1 Reply Last reply Reply Quote 0
                                  • sankafolaundefined
                                    sankafola @stuartofmt
                                    @stuartofmt
                                    the ffmpeg is as follow
                                    as for the stream i have a real hard time to make the videostream works because of the failing link
                                    sudo pip3 install opencv-contrib-python==3.4.4.19
                                    i used the last file you gave me and here are the results seem to be working and connecting now but the main issue now maybe the videostream here are the screen shots and the log file
                                    2023-12-20 11:58:45,832 - MainThread - DuetLapse3 Version --- 5.3.5
                                    2023-12-20 11:58:45,833 - MainThread - Requires Duet3d Version --- 3.5.0-rc.1
                                    2023-12-20 11:58:45,834 - MainThread - Process Id --- 2368
                                    2023-12-20 11:58:45,834 - MainThread - -------------------------------------------------------------------------------
                                    2023-12-20 11:58:45,835 - MainThread - seconds has been changed to 30
                                    2023-12-20 11:58:45,836 - MainThread - poll has been changed to 10
                                    2023-12-20 11:58:45,838 - MainThread - dontwait has been changed to True
                                    2023-12-20 11:58:45,839 - MainThread - ################### Options at start of this print job #####################
                                    2023-12-20 11:58:45,840 - MainThread - # Simulate
                                    2023-12-20 11:58:45,840 - MainThread - -simulate = off
                                    2023-12-20 11:58:45,841 - MainThread - # Environment
                                    2023-12-20 11:58:45,841 - MainThread - -duet = 10.0.1.126
                                    2023-12-20 11:58:45,842 - MainThread - -password = reprap
                                    2023-12-20 11:58:45,842 - MainThread - -basedir = /home/pi/DuetLapse
                                    2023-12-20 11:58:45,843 - MainThread - -poll = 10
                                    2023-12-20 11:58:45,843 - MainThread - -instances = single
                                    2023-12-20 11:58:45,843 - MainThread - -logtype = both
                                    2023-12-20 11:58:45,843 - MainThread - -nolog = False
                                    2023-12-20 11:58:45,844 - MainThread - -verbose = True
                                    2023-12-20 11:58:45,844 - MainThread - -host = 0.0.0.0
                                    2023-12-20 11:58:45,844 - MainThread - -port = 8082
                                    2023-12-20 11:58:45,844 - MainThread - -keeplogs = False
                                    2023-12-20 11:58:45,845 - MainThread - -novideo = False
                                    2023-12-20 11:58:45,845 - MainThread - -deletepics = False
                                    2023-12-20 11:58:45,845 - MainThread - -maxffmpeg = 2
                                    2023-12-20 11:58:45,846 - MainThread - -keepfiles = False
                                    2023-12-20 11:58:45,846 - MainThread - # Execution
                                    2023-12-20 11:58:45,846 - MainThread - -dontwait = True
                                    2023-12-20 11:58:45,846 - MainThread - -seconds = 30
                                    2023-12-20 11:58:45,847 - MainThread - -detect = none
                                    2023-12-20 11:58:45,847 - MainThread - -pause = no
                                    2023-12-20 11:58:45,848 - MainThread - -numlayers = 1
                                    2023-12-20 11:58:45,849 - MainThread - -movehead = [0, 0]
                                    2023-12-20 11:58:45,850 - MainThread - -rest = 1
                                    2023-12-20 11:58:45,850 - MainThread - -standby = False
                                    2023-12-20 11:58:45,851 - MainThread - -restart = False
                                    2023-12-20 11:58:45,851 - MainThread - # Camera
                                    2023-12-20 11:58:45,852 - MainThread - -camera1 = stream
                                    2023-12-20 11:58:45,852 - MainThread - -camera2
                                    2023-12-20 11:58:45,853 - MainThread - -weburl1 = http://10.0.1.110/stream
                                    2023-12-20 11:58:45,853 - MainThread - -weburl2
                                    2023-12-20 11:58:45,854 - MainThread - # Video
                                    2023-12-20 11:58:45,854 - MainThread - -extratime = 0
                                    2023-12-20 11:58:45,855 - MainThread - -fps = 10
                                    2023-12-20 11:58:45,855 - MainThread - -minvideo = 5
                                    2023-12-20 11:58:45,855 - MainThread - -maxvideo = 0
                                    2023-12-20 11:58:45,856 - MainThread - # Overrides
                                    2023-12-20 11:58:45,856 - MainThread - -camparam1
                                    2023-12-20 11:58:45,857 - MainThread - -camparam2
                                    2023-12-20 11:58:45,857 - MainThread - -vidparam1
                                    2023-12-20 11:58:45,858 - MainThread - -vidparam2
                                    2023-12-20 11:58:45,859 - MainThread - # UI
                                    2023-12-20 11:58:45,859 - MainThread - -hidebuttons = False
                                    2023-12-20 11:58:45,860 - MainThread - # Special Functions
                                    2023-12-20 11:58:45,860 - MainThread - -execkey
                                    2023-12-20 11:58:45,861 - MainThread - -M3291 = M3291
                                    2023-12-20 11:58:45,861 - MainThread - -----------------------------------------------------------------------
                                    2023-12-20 11:58:45,862 - MainThread - ************************************************************************************
                                    2023-12-20 11:58:45,862 - MainThread - Warning: -seconds 30 and -detect none
                                    2023-12-20 11:58:45,863 - MainThread - This combination implies -dontwait and will be set automatically
                                    2023-12-20 11:58:45,863 - MainThread - ************************************************************************************
                                    2023-12-20 11:58:45,865 - MainThread - ##########################################################
                                    2023-12-20 11:58:45,866 - MainThread - Will start capturing images immediately
                                    2023-12-20 11:58:45,867 - MainThread - ##########################################################
                                    2023-12-20 11:58:45,868 - MainThread - ##########################################################
                                    2023-12-20 11:58:45,869 - MainThread - Video will be created when printing ends
                                    2023-12-20 11:58:45,870 - MainThread - or if requested from the UI or M3291 P"DuetLapse3.completed"
                                    2023-12-20 11:58:45,871 - MainThread - ##########################################################
                                    2023-12-20 11:58:45,873 - MainThread - ##########################################################
                                    2023-12-20 11:58:45,874 - MainThread - If running from a console using the command line
                                    2023-12-20 11:58:45,874 - MainThread - Press Ctrl+C one time to stop the program and create a video.
                                    2023-12-20 11:58:45,875 - MainThread - ##########################################################
                                    2023-12-20 11:58:45,877 - MainThread - ***** Initializing state and counters *****
                                    2023-12-20 11:58:45,880 - MainThread - ##########################################################
                                    2023-12-20 11:58:45,880 - MainThread - ***** Started http listener on port 8082*****
                                    2023-12-20 11:58:45,881 - MainThread - ##########################################################
                                    2023-12-20 11:58:45,882 - MainThread - Logging in to Printer
                                    2023-12-20 11:58:45,882 - MainThread - 0 url: http://10.0.1.126/rr_disconnect post: False
                                    2023-12-20 11:58:46,036 - MainThread - 0 url: http://10.0.1.126/rr_connect?password=reprap post: False
                                    2023-12-20 11:58:46,086 - MainThread - !!!!! Connected to printer Standalone !!!!!
                                    2023-12-20 11:58:46,087 - MainThread - !!!!! Checking for firmware version 3.5.0-rc.1 !!!!!
                                    2023-12-20 11:58:46,087 - MainThread - 0 url: http://10.0.1.126/rr_model?key=boards post: False
                                    2023-12-20 11:58:46,151 - MainThread - Version Check returned --> 3.5.0-rc.1+102
                                    2023-12-20 11:58:46,152 - MainThread - ###############################################################
                                    2023-12-20 11:58:46,152 - MainThread - Connected to printer at 10.0.1.126
                                    2023-12-20 11:58:46,152 - MainThread - Using Duet version 3.5.0-rc.1+102
                                    2023-12-20 11:58:46,152 - MainThread - Using API interface rr_model
                                    2023-12-20 11:58:46,153 - MainThread - ###############################################################
                                    2023-12-20 11:58:46,153 - MainThread - isPlugin ignored - only valid for SBC
                                    2023-12-20 11:58:46,153 - MainThread - Initializing DL3msg queue
                                    2023-12-20 11:58:46,153 - MainThread - 0 url: http://10.0.1.126/rr_gcode?gcode=M3291 B"Clear" post: False
                                    2023-12-20 11:58:46,198 - mainLoop - ###########################
                                    2023-12-20 11:58:46,199 - MainThread - Initiating with action set to start
                                    2023-12-20 11:58:46,199 - mainLoop - Starting mainLoop
                                    2023-12-20 11:58:46,199 - MainThread - Calling nextaction start from main --> startup --> nextAction
                                    2023-12-20 11:58:46,200 - mainLoop - ###########################
                                    2023-12-20 11:58:46,200 - MainThread - ++++++ start state requested ++++++
                                    2023-12-20 11:58:46,200 - mainLoop - Calling Status from run --> mainLoop --> getDuet
                                    2023-12-20 11:58:46,201 - MainThread - nextAction requested stopCaptureLoop
                                    2023-12-20 11:58:46,201 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=state post: False
                                    2023-12-20 11:58:46,201 - MainThread - captureLoop is not running
                                    2023-12-20 11:58:46,203 - MainThread - nextAction satisfied waitforCaptureLoop
                                    2023-12-20 11:58:46,209 - MainThread - ++++++ Determining next logical action ++++++
                                    2023-12-20 11:58:46,210 - MainThread - ++++++ Entering start state ++++++
                                    2023-12-20 11:58:46,210 - MainThread - nextAction exiting normally
                                    2023-12-20 11:58:46,227 - mainLoop - Standalone Status is busy
                                    2023-12-20 11:58:46,228 - mainLoop - Error Processing message queue
                                    2023-12-20 11:58:46,228 - mainLoop - 'global'
                                    2023-12-20 11:58:51,234 - mainLoop - Calling Status from run --> mainLoop --> getDuet
                                    2023-12-20 11:58:51,235 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=state post: False
                                    2023-12-20 11:58:51,267 - mainLoop - Standalone Status is idle
                                    2023-12-20 11:58:51,267 - mainLoop - Error Processing message queue
                                    2023-12-20 11:58:51,268 - mainLoop - 'global'
                                    2023-12-20 11:58:56,273 - mainLoop - Calling Status from run --> mainLoop --> getDuet
                                    2023-12-20 11:58:56,273 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=state post: False
                                    2023-12-20 11:58:56,529 - mainLoop - Standalone Status is idle
                                    2023-12-20 11:58:56,529 - mainLoop - Error Processing message queue
                                    2023-12-20 11:58:56,530 - mainLoop - 'global'
                                    2023-12-20 11:58:56,530 - mainLoop - ****** Duet status changed to: idle from unknown *****
                                    2023-12-20 11:58:56,530 - mainLoop - ****** stateMachine:
                                    2023-12-20 11:58:56,531 - mainLoop - newstate = Capturing
                                    2023-12-20 11:58:56,531 - mainLoop - currentState = Waiting
                                    2023-12-20 11:58:56,531 - mainLoop - duetStatus = idle
                                    2023-12-20 11:58:56,532 - mainLoop - lastDuetStatus = unknown
                                    2023-12-20 11:58:56,532 - mainLoop - dontwait = True
                                    2023-12-20 11:58:56,532 - mainLoop - detect = none
                                    2023-12-20 11:58:56,532 - mainLoop - terminateState = -1
                                    2023-12-20 11:58:56,533 - mainLoop - ******
                                    2023-12-20 11:58:56,533 - mainLoop - ****** Print State changed to: Capturing from Waiting*****
                                    2023-12-20 11:58:56,533 - mainLoop - Calling oneInterval for Camera 1
                                    2023-12-20 11:58:56,533 - mainLoop - Calling Layer from captureLoop --> oneInterval --> getDuet
                                    2023-12-20 11:58:56,534 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=job.layer post: False
                                    2023-12-20 11:58:56,612 - mainLoop - Current Layer is -1
                                    2023-12-20 11:58:56,613 - mainLoop - elapsed: 10.735199928283691
                                    2023-12-20 11:58:56,613 - mainLoop - ****** stateMachine:
                                    2023-12-20 11:58:56,613 - mainLoop - newstate = Waiting
                                    2023-12-20 11:58:56,614 - mainLoop - currentState = Capturing
                                    2023-12-20 11:58:56,614 - mainLoop - duetStatus = idle
                                    2023-12-20 11:58:56,614 - mainLoop - lastDuetStatus = unknown
                                    2023-12-20 11:58:56,614 - mainLoop - dontwait = True
                                    2023-12-20 11:58:56,615 - mainLoop - detect = none
                                    2023-12-20 11:58:56,615 - mainLoop - terminateState = -1
                                    2023-12-20 11:58:56,615 - mainLoop - ******
                                    2023-12-20 11:58:56,615 - mainLoop - ****** Print State changed to: Waiting from Capturing*****
                                    2023-12-20 11:59:01,621 - mainLoop - Calling Status from run --> mainLoop --> getDuet
                                    2023-12-20 11:59:01,622 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=state post: False
                                    2023-12-20 11:59:01,783 - mainLoop - Standalone Status is idle
                                    2023-12-20 11:59:01,785 - mainLoop - Error Processing message queue
                                    2023-12-20 11:59:01,785 - mainLoop - 'global'
                                    2023-12-20 11:59:06,792 - mainLoop - Calling Status from run --> mainLoop --> getDuet
                                    2023-12-20 11:59:06,793 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=state post: False
                                    2023-12-20 11:59:07,242 - mainLoop - Standalone Status is idle
                                    2023-12-20 11:59:07,243 - mainLoop - Error Processing message queue
                                    2023-12-20 11:59:07,244 - mainLoop - 'global'
                                    2023-12-20 11:59:07,245 - mainLoop - ****** stateMachine:
                                    2023-12-20 11:59:07,245 - mainLoop - newstate = Capturing
                                    2023-12-20 11:59:07,246 - mainLoop - currentState = Waiting
                                    2023-12-20 11:59:07,246 - mainLoop - duetStatus = idle
                                    2023-12-20 11:59:07,247 - mainLoop - lastDuetStatus = idle
                                    2023-12-20 11:59:07,247 - mainLoop - dontwait = True
                                    2023-12-20 11:59:07,248 - mainLoop - detect = none
                                    2023-12-20 11:59:07,249 - mainLoop - terminateState = -1
                                    2023-12-20 11:59:07,249 - mainLoop - ******
                                    2023-12-20 11:59:07,250 - mainLoop - ****** Print State changed to: Capturing from Waiting*****
                                    2023-12-20 11:59:07,250 - mainLoop - Calling oneInterval for Camera 1
                                    2023-12-20 11:59:07,251 - mainLoop - Calling Layer from captureLoop --> oneInterval --> getDuet
                                    2023-12-20 11:59:07,252 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=job.layer post: False
                                    2023-12-20 11:59:07,611 - mainLoop - Current Layer is -1
                                    2023-12-20 11:59:07,612 - mainLoop - elapsed: 21.73440194129944
                                    2023-12-20 11:59:07,613 - mainLoop - ****** stateMachine:
                                    2023-12-20 11:59:07,614 - mainLoop - newstate = Waiting
                                    2023-12-20 11:59:07,614 - mainLoop - currentState = Capturing
                                    2023-12-20 11:59:07,615 - mainLoop - duetStatus = idle
                                    2023-12-20 11:59:07,615 - mainLoop - lastDuetStatus = idle
                                    2023-12-20 11:59:07,616 - mainLoop - dontwait = True
                                    2023-12-20 11:59:07,616 - mainLoop - detect = none
                                    2023-12-20 11:59:07,617 - mainLoop - terminateState = -1
                                    2023-12-20 11:59:07,617 - mainLoop - ******
                                    2023-12-20 11:59:07,618 - mainLoop - ****** Print State changed to: Waiting from Capturing*****
                                    even though its giving this ( empty frame am using USB camera i have a ribbon camera too how to force videostream to use the ribbon camera ?
                                      @sankafola
                                      From memory - that version of ffmpeg is OK.
                                      As before, it looks like DuetLapse is working and the previous issues were installation / configuration.
                                      videostream uses opencv but that library is notorious for being difficult to install. Many of the guides simply do not work. That's not really the fault of the guides, mainly its to do with all the possible variations of operating systems etc that opencv has to deal with.
                                      There are several documents here that may help.
                                      https://github.com/stuartofmt/Pi-Notes
                                      but it all depends on the version if the pi operating system you are using.
                                      On my pi (using a pi camera and Debian Bullseye) I use a plugin that I've developed because it does not need to use opencv. It uses apis developed by the pi team BUT those do not support USB cameras.
                                      Having said all that - you might try Motion as that is a bit more self contained and may give you quicker success.
                                      What version of the pi operating system are you using?
                                        @stuartofmt
                                        see my PI os Ver below
                                        i will try motion but if videostream is better or a must i can try the plugin you mention if you dont mind
                                        i tried motion and now i have video in the http//:localhost:8081/stream not on 10.0.1.110:8081/stream even though it should be the same but on the DuetLapse still no video
                                        here is my config for DuetLapse see if i need to change anything there
                                        -duet 10.0.1.126
                                        -port 8082
                                        -seconds 30
                                        -detect none
                                        -weburl1 http://localhost:8081/stream
                                        -verbose
                                        -camera1 stream
                                        2023-12-20-150807_616x456_scrot.png 2023-12-20-150752_779x388_scrot.png 2023-12-20-150736_1204x884_scrot.png
                                        log file
                                        2023-12-20 15:10:07,155 - MainThread - DuetLapse3 Version --- 5.3.5
                                        2023-12-20 15:10:07,156 - MainThread - Requires Duet3d Version --- 3.5.0-rc.1
                                        2023-12-20 15:10:07,157 - MainThread - Process Id --- 3116
                                        2023-12-20 15:10:07,157 - MainThread - -------------------------------------------------------------------------------
                                        2023-12-20 15:10:07,159 - MainThread - seconds has been changed to 30
                                        2023-12-20 15:10:07,161 - MainThread - poll has been changed to 10
                                        2023-12-20 15:10:07,162 - MainThread - dontwait has been changed to True
                                        2023-12-20 15:10:07,163 - MainThread - ################### Options at start of this print job #####################
                                        2023-12-20 15:10:07,164 - MainThread - # Simulate
                                        2023-12-20 15:10:07,165 - MainThread - -simulate = off
                                        2023-12-20 15:10:07,166 - MainThread - # Environment
                                        2023-12-20 15:10:07,166 - MainThread - -duet = 10.0.1.126
                                        2023-12-20 15:10:07,167 - MainThread - -password = reprap
                                        2023-12-20 15:10:07,168 - MainThread - -basedir = /home/pi/DuetLapse
                                        2023-12-20 15:10:07,169 - MainThread - -poll = 10
                                        2023-12-20 15:10:07,170 - MainThread - -instances = single
                                        2023-12-20 15:10:07,171 - MainThread - -logtype = both
                                        2023-12-20 15:10:07,171 - MainThread - -nolog = False
                                        2023-12-20 15:10:07,172 - MainThread - -verbose = True
                                        2023-12-20 15:10:07,172 - MainThread - -host = 0.0.0.0
                                        2023-12-20 15:10:07,173 - MainThread - -port = 8082
                                        2023-12-20 15:10:07,174 - MainThread - -keeplogs = False
                                        2023-12-20 15:10:07,175 - MainThread - -novideo = False
                                        2023-12-20 15:10:07,176 - MainThread - -deletepics = False
                                        2023-12-20 15:10:07,177 - MainThread - -maxffmpeg = 2
                                        2023-12-20 15:10:07,178 - MainThread - -keepfiles = False
                                        2023-12-20 15:10:07,179 - MainThread - # Execution
                                        2023-12-20 15:10:07,180 - MainThread - -dontwait = True
                                        2023-12-20 15:10:07,180 - MainThread - -seconds = 30
                                        2023-12-20 15:10:07,181 - MainThread - -detect = none
                                        2023-12-20 15:10:07,181 - MainThread - -pause = no
                                        2023-12-20 15:10:07,181 - MainThread - -numlayers = 1
                                        2023-12-20 15:10:07,182 - MainThread - -movehead = [0, 0]
                                        2023-12-20 15:10:07,182 - MainThread - -rest = 1
                                        2023-12-20 15:10:07,182 - MainThread - -standby = False
                                        2023-12-20 15:10:07,183 - MainThread - -restart = False
                                        2023-12-20 15:10:07,183 - MainThread - # Camera
                                        2023-12-20 15:10:07,183 - MainThread - -camera1 = stream
                                        2023-12-20 15:10:07,184 - MainThread - -camera2
                                        2023-12-20 15:10:07,184 - MainThread - -weburl1 = http://localhost:8081/stream
                                        2023-12-20 15:10:07,184 - MainThread - -weburl2
                                        2023-12-20 15:10:07,185 - MainThread - # Video
                                        2023-12-20 15:10:07,185 - MainThread - -extratime = 0
                                        2023-12-20 15:10:07,185 - MainThread - -fps = 10
                                        2023-12-20 15:10:07,186 - MainThread - -minvideo = 5
                                        2023-12-20 15:10:07,186 - MainThread - -maxvideo = 0
                                        2023-12-20 15:10:07,186 - MainThread - # Overrides
                                        2023-12-20 15:10:07,187 - MainThread - -camparam1
                                        2023-12-20 15:10:07,187 - MainThread - -camparam2
                                        2023-12-20 15:10:07,188 - MainThread - -vidparam1
                                        2023-12-20 15:10:07,188 - MainThread - -vidparam2
                                        2023-12-20 15:10:07,188 - MainThread - # UI
                                        2023-12-20 15:10:07,189 - MainThread - -hidebuttons = False
                                        2023-12-20 15:10:07,190 - MainThread - # Special Functions
                                        2023-12-20 15:10:07,190 - MainThread - -execkey
                                        2023-12-20 15:10:07,191 - MainThread - -M3291 = M3291
                                        2023-12-20 15:10:07,191 - MainThread - -----------------------------------------------------------------------
                                        2023-12-20 15:10:07,192 - MainThread - ************************************************************************************
                                        2023-12-20 15:10:07,192 - MainThread - Warning: -seconds 30 and -detect none
                                        2023-12-20 15:10:07,193 - MainThread - This combination implies -dontwait and will be set automatically
                                        2023-12-20 15:10:07,194 - MainThread - ************************************************************************************
                                        2023-12-20 15:10:07,195 - MainThread - ##########################################################
                                        2023-12-20 15:10:07,196 - MainThread - Will start capturing images immediately
                                        2023-12-20 15:10:07,197 - MainThread - ##########################################################
                                        2023-12-20 15:10:07,198 - MainThread - ##########################################################
                                        2023-12-20 15:10:07,199 - MainThread - Video will be created when printing ends
                                        2023-12-20 15:10:07,200 - MainThread - or if requested from the UI or M3291 P"DuetLapse3.completed"
                                        2023-12-20 15:10:07,200 - MainThread - ##########################################################
                                        2023-12-20 15:10:07,201 - MainThread - ##########################################################
                                        2023-12-20 15:10:07,201 - MainThread - If running from a console using the command line
                                        2023-12-20 15:10:07,202 - MainThread - Press Ctrl+C one time to stop the program and create a video.
                                        2023-12-20 15:10:07,202 - MainThread - ##########################################################
                                        2023-12-20 15:10:07,202 - MainThread - ***** Initializing state and counters *****
                                        2023-12-20 15:10:07,205 - MainThread - ##########################################################
                                        2023-12-20 15:10:07,207 - MainThread - ***** Started http listener on port 8082*****
                                        2023-12-20 15:10:07,210 - MainThread - ##########################################################
                                        2023-12-20 15:10:07,211 - MainThread - Logging in to Printer
                                        2023-12-20 15:10:07,213 - MainThread - 0 url: http://10.0.1.126/rr_disconnect post: False
                                        2023-12-20 15:10:07,335 - MainThread - 0 url: http://10.0.1.126/rr_connect?password=reprap post: False
                                        2023-12-20 15:10:07,393 - MainThread - !!!!! Connected to printer Standalone !!!!!
                                        2023-12-20 15:10:07,394 - MainThread - !!!!! Checking for firmware version 3.5.0-rc.1 !!!!!
                                        2023-12-20 15:10:07,395 - MainThread - 0 url: http://10.0.1.126/rr_model?key=boards post: False
                                        2023-12-20 15:10:07,442 - MainThread - Version Check returned --> 3.5.0-rc.1+102
                                        2023-12-20 15:10:07,444 - MainThread - ###############################################################
                                        2023-12-20 15:10:07,445 - MainThread - Connected to printer at 10.0.1.126
                                        2023-12-20 15:10:07,447 - MainThread - Using Duet version 3.5.0-rc.1+102
                                        2023-12-20 15:10:07,448 - MainThread - Using API interface rr_model
                                        2023-12-20 15:10:07,450 - MainThread - ###############################################################
                                        2023-12-20 15:10:07,451 - MainThread - isPlugin ignored - only valid for SBC
                                        2023-12-20 15:10:07,453 - MainThread - Initializing DL3msg queue
                                        2023-12-20 15:10:07,454 - MainThread - 0 url: http://10.0.1.126/rr_gcode?gcode=M3291 B"Clear" post: False
                                        2023-12-20 15:10:07,539 - mainLoop - ###########################
                                        2023-12-20 15:10:07,539 - MainThread - Initiating with action set to start
                                        2023-12-20 15:10:07,541 - mainLoop - Starting mainLoop
                                        2023-12-20 15:10:07,542 - MainThread - Calling nextaction start from main --> startup --> nextAction
                                        2023-12-20 15:10:07,544 - mainLoop - ###########################
                                        2023-12-20 15:10:07,545 - MainThread - ++++++ start state requested ++++++
                                        2023-12-20 15:10:07,546 - mainLoop - Calling Status from run --> mainLoop --> getDuet
                                        2023-12-20 15:10:07,547 - MainThread - nextAction requested stopCaptureLoop
                                        2023-12-20 15:10:07,548 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=state post: False
                                        2023-12-20 15:10:07,549 - MainThread - captureLoop is not running
                                        2023-12-20 15:10:07,552 - MainThread - nextAction satisfied waitforCaptureLoop
                                        2023-12-20 15:10:07,553 - MainThread - ++++++ Determining next logical action ++++++
                                        2023-12-20 15:10:07,554 - MainThread - ++++++ Entering start state ++++++
                                        2023-12-20 15:10:07,555 - MainThread - nextAction exiting normally
                                        2023-12-20 15:10:07,614 - mainLoop - Standalone Status is processing
                                        2023-12-20 15:10:07,615 - mainLoop - Error Processing message queue
                                        2023-12-20 15:10:07,616 - mainLoop - 'global'
                                        2023-12-20 15:10:09,259 - Thread-1 - !!!!! http call: {'displayControls': ['true']} !!!!!
                                        2023-12-20 15:10:10,087 - Thread-2 - !!!!! http call: {'displayStatus': ['true']} !!!!!
                                        2023-12-20 15:10:12,623 - mainLoop - Calling Status from run --> mainLoop --> getDuet
                                        2023-12-20 15:10:12,624 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=state post: False
                                        2023-12-20 15:10:12,654 - mainLoop - Standalone Status is processing
                                        2023-12-20 15:10:12,655 - mainLoop - Error Processing message queue
                                        2023-12-20 15:10:12,655 - mainLoop - 'global'
                                        2023-12-20 15:10:17,661 - mainLoop - Calling Status from run --> mainLoop --> getDuet
                                        2023-12-20 15:10:17,662 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=state post: False
                                        2023-12-20 15:10:17,710 - mainLoop - Standalone Status is processing
                                        2023-12-20 15:10:17,711 - mainLoop - Error Processing message queue
                                        2023-12-20 15:10:17,712 - mainLoop - 'global'
                                        2023-12-20 15:10:17,713 - mainLoop - ****** Duet status changed to: processing from unknown *****
                                        2023-12-20 15:10:17,713 - mainLoop - ****** stateMachine:
                                        2023-12-20 15:10:17,714 - mainLoop - newstate = Capturing
                                        2023-12-20 15:10:17,715 - mainLoop - currentState = Waiting
                                        2023-12-20 15:10:17,715 - mainLoop - duetStatus = processing
                                        2023-12-20 15:10:17,716 - mainLoop - lastDuetStatus = unknown
                                        2023-12-20 15:10:17,717 - mainLoop - dontwait = True
                                        2023-12-20 15:10:17,718 - mainLoop - detect = none
                                        2023-12-20 15:10:17,718 - mainLoop - terminateState = -1
                                        2023-12-20 15:10:17,719 - mainLoop - ******
                                        2023-12-20 15:10:17,720 - mainLoop - ****** Print State changed to: Capturing from Waiting*****
                                        2023-12-20 15:10:17,721 - mainLoop - Calling oneInterval for Camera 1
                                        2023-12-20 15:10:17,722 - mainLoop - Calling Layer from captureLoop --> oneInterval --> getDuet
                                        2023-12-20 15:10:17,723 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=job.layer post: False
                                        2023-12-20 15:10:17,812 - mainLoop - Current Layer is 1
                                        2023-12-20 15:10:17,813 - mainLoop - elapsed: 10.610595464706421
                                        2023-12-20 15:10:17,814 - mainLoop - ****** stateMachine:
                                        2023-12-20 15:10:17,815 - mainLoop - newstate = Capturing
                                        2023-12-20 15:10:17,816 - mainLoop - currentState = Capturing
                                        2023-12-20 15:10:17,816 - mainLoop - duetStatus = processing
                                        2023-12-20 15:10:17,817 - mainLoop - lastDuetStatus = unknown
                                        2023-12-20 15:10:17,817 - mainLoop - dontwait = True
                                        2023-12-20 15:10:17,818 - mainLoop - detect = none
                                        2023-12-20 15:10:17,819 - mainLoop - terminateState = -1
                                        2023-12-20 15:10:17,820 - mainLoop - ******
                                        2023-12-20 15:10:20,089 - Thread-3 - !!!!! http call: {'displayStatus': ['true']} !!!!!
                                          sankafola @sankafola
                                          @stuartofmt
                                          and this is the log while printing
                                          2023-12-20 15:50:25,955 - MainThread - DuetLapse3 Version --- 5.3.5
                                          2023-12-20 15:50:25,956 - MainThread - Requires Duet3d Version --- 3.5.0-rc.1
                                          2023-12-20 15:50:25,956 - MainThread - Process Id --- 9084
                                          2023-12-20 15:50:25,956 - MainThread - -------------------------------------------------------------------------------
                                          2023-12-20 15:50:25,957 - MainThread - seconds has been changed to 30
                                          2023-12-20 15:50:25,958 - MainThread - poll has been changed to 10
                                          2023-12-20 15:50:25,959 - MainThread - dontwait has been changed to True
                                          2023-12-20 15:50:25,960 - MainThread - ################### Options at start of this print job #####################
                                          2023-12-20 15:50:25,961 - MainThread - # Simulate
                                          2023-12-20 15:50:25,961 - MainThread - -simulate = off
                                          2023-12-20 15:50:25,962 - MainThread - # Environment
                                          2023-12-20 15:50:25,962 - MainThread - -duet = 10.0.1.126
                                          2023-12-20 15:50:25,963 - MainThread - -password = reprap
                                          2023-12-20 15:50:25,963 - MainThread - -basedir = /home/pi/DuetLapse
                                          2023-12-20 15:50:25,963 - MainThread - -poll = 10
                                          2023-12-20 15:50:25,964 - MainThread - -instances = single
                                          2023-12-20 15:50:25,964 - MainThread - -logtype = both
                                          2023-12-20 15:50:25,965 - MainThread - -nolog = False
                                          2023-12-20 15:50:25,965 - MainThread - -verbose = True
                                          2023-12-20 15:50:25,965 - MainThread - -host = 0.0.0.0
                                          2023-12-20 15:50:25,966 - MainThread - -port = 8082
                                          2023-12-20 15:50:25,966 - MainThread - -keeplogs = False
                                          2023-12-20 15:50:25,966 - MainThread - -novideo = False
                                          2023-12-20 15:50:25,967 - MainThread - -deletepics = False
                                          2023-12-20 15:50:25,967 - MainThread - -maxffmpeg = 2
                                          2023-12-20 15:50:25,968 - MainThread - -keepfiles = False
                                          2023-12-20 15:50:25,968 - MainThread - # Execution
                                          2023-12-20 15:50:25,968 - MainThread - -dontwait = True
                                          2023-12-20 15:50:25,979 - MainThread - -seconds = 30
                                          2023-12-20 15:50:25,980 - MainThread - -detect = none
                                          2023-12-20 15:50:25,980 - MainThread - -pause = no
                                          2023-12-20 15:50:25,981 - MainThread - -numlayers = 1
                                          2023-12-20 15:50:25,981 - MainThread - -movehead = [0, 0]
                                          2023-12-20 15:50:25,982 - MainThread - -rest = 1
                                          2023-12-20 15:50:25,982 - MainThread - -standby = False
                                          2023-12-20 15:50:25,983 - MainThread - -restart = False
                                          2023-12-20 15:50:25,983 - MainThread - # Camera
                                          2023-12-20 15:50:25,984 - MainThread - -camera1 = stream
                                          2023-12-20 15:50:25,984 - MainThread - -camera2
                                          2023-12-20 15:50:25,985 - MainThread - -weburl1 = http://localhost:8081/stream
                                          2023-12-20 15:50:25,985 - MainThread - -weburl2
                                          2023-12-20 15:50:25,985 - MainThread - # Video
                                          2023-12-20 15:50:25,986 - MainThread - -extratime = 0
                                          2023-12-20 15:50:25,986 - MainThread - -fps = 10
                                          2023-12-20 15:50:25,986 - MainThread - -minvideo = 5
                                          2023-12-20 15:50:25,987 - MainThread - -maxvideo = 0
                                          2023-12-20 15:50:25,987 - MainThread - # Overrides
                                          2023-12-20 15:50:25,987 - MainThread - -camparam1
                                          2023-12-20 15:50:25,988 - MainThread - -camparam2
                                          2023-12-20 15:50:25,988 - MainThread - -vidparam1
                                          2023-12-20 15:50:25,990 - MainThread - -vidparam2
                                          2023-12-20 15:50:25,991 - MainThread - # UI
                                          2023-12-20 15:50:25,991 - MainThread - -hidebuttons = False
                                          2023-12-20 15:50:25,992 - MainThread - # Special Functions
                                          2023-12-20 15:50:25,993 - MainThread - -execkey
                                          2023-12-20 15:50:25,994 - MainThread - -M3291 = M3291
                                          2023-12-20 15:50:25,994 - MainThread - -----------------------------------------------------------------------
                                          2023-12-20 15:50:25,995 - MainThread - ************************************************************************************
                                          2023-12-20 15:50:25,995 - MainThread - Warning: -seconds 30 and -detect none
                                          2023-12-20 15:50:25,996 - MainThread - This combination implies -dontwait and will be set automatically
                                          2023-12-20 15:50:25,996 - MainThread - ************************************************************************************
                                          2023-12-20 15:50:25,997 - MainThread - ##########################################################
                                          2023-12-20 15:50:25,998 - MainThread - Will start capturing images immediately
                                          2023-12-20 15:50:25,998 - MainThread - ##########################################################
                                          2023-12-20 15:50:25,999 - MainThread - ##########################################################
                                          2023-12-20 15:50:26,000 - MainThread - Video will be created when printing ends
                                          2023-12-20 15:50:26,001 - MainThread - or if requested from the UI or M3291 P"DuetLapse3.completed"
                                          2023-12-20 15:50:26,002 - MainThread - ##########################################################
                                          2023-12-20 15:50:26,003 - MainThread - ##########################################################
                                          2023-12-20 15:50:26,004 - MainThread - If running from a console using the command line
                                          2023-12-20 15:50:26,005 - MainThread - Press Ctrl+C one time to stop the program and create a video.
                                          2023-12-20 15:50:26,006 - MainThread - ##########################################################
                                          2023-12-20 15:50:26,009 - MainThread - ***** Initializing state and counters *****
                                          2023-12-20 15:50:26,018 - MainThread - ##########################################################
                                          2023-12-20 15:50:26,020 - MainThread - ***** Started http listener on port 8082*****
                                          2023-12-20 15:50:26,022 - MainThread - ##########################################################
                                          2023-12-20 15:50:26,023 - MainThread - Logging in to Printer
                                          2023-12-20 15:50:26,025 - MainThread - 0 url: http://10.0.1.126/rr_disconnect post: False
                                          2023-12-20 15:50:26,120 - MainThread - 0 url: http://10.0.1.126/rr_connect?password=reprap post: False
                                          2023-12-20 15:50:26,164 - MainThread - !!!!! Connected to printer Standalone !!!!!
                                          2023-12-20 15:50:26,166 - MainThread - !!!!! Checking for firmware version 3.5.0-rc.1 !!!!!
                                          2023-12-20 15:50:26,169 - MainThread - 0 url: http://10.0.1.126/rr_model?key=boards post: False
                                          2023-12-20 15:50:26,211 - MainThread - Version Check returned --> 3.5.0-rc.1+102
                                          2023-12-20 15:50:26,216 - MainThread - ###############################################################
                                          2023-12-20 15:50:26,217 - MainThread - Connected to printer at 10.0.1.126
                                          2023-12-20 15:50:26,218 - MainThread - Using Duet version 3.5.0-rc.1+102
                                          2023-12-20 15:50:26,219 - MainThread - Using API interface rr_model
                                          2023-12-20 15:50:26,220 - MainThread - ###############################################################
                                          2023-12-20 15:50:26,221 - MainThread - isPlugin ignored - only valid for SBC
                                          2023-12-20 15:50:26,222 - MainThread - Initializing DL3msg queue
                                          2023-12-20 15:50:26,222 - MainThread - 0 url: http://10.0.1.126/rr_gcode?gcode=M3291 B"Clear" post: False
                                          2023-12-20 15:50:26,365 - mainLoop - ###########################
                                          2023-12-20 15:50:26,367 - mainLoop - Starting mainLoop
                                          2023-12-20 15:50:26,368 - mainLoop - ###########################
                                          2023-12-20 15:50:26,368 - mainLoop - Calling Status from run --> mainLoop --> getDuet
                                          2023-12-20 15:50:26,369 - MainThread - Initiating with action set to start
                                          2023-12-20 15:50:26,379 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=state post: False
                                          2023-12-20 15:50:26,380 - MainThread - Calling nextaction start from main --> startup --> nextAction
                                          2023-12-20 15:50:26,393 - MainThread - ++++++ start state requested ++++++
                                          2023-12-20 15:50:26,397 - MainThread - nextAction requested stopCaptureLoop
                                          2023-12-20 15:50:26,398 - MainThread - captureLoop is not running
                                          2023-12-20 15:50:26,399 - MainThread - nextAction satisfied waitforCaptureLoop
                                          2023-12-20 15:50:26,400 - MainThread - ++++++ Determining next logical action ++++++
                                          2023-12-20 15:50:26,401 - MainThread - ++++++ Entering start state ++++++
                                          2023-12-20 15:50:26,401 - MainThread - nextAction exiting normally
                                          2023-12-20 15:50:26,451 - mainLoop - Standalone Status is processing
                                          2023-12-20 15:50:26,452 - mainLoop - Error Processing message queue
                                          2023-12-20 15:50:26,452 - mainLoop - 'global'
                                          2023-12-20 15:50:29,336 - Thread-1 - !!!!! http call: {'displayStatus': ['true']} !!!!!
                                          2023-12-20 15:50:31,459 - mainLoop - Calling Status from run --> mainLoop --> getDuet
                                          2023-12-20 15:50:31,461 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=state post: False
                                          2023-12-20 15:50:31,689 - mainLoop - Standalone Status is processing
                                          2023-12-20 15:50:31,690 - mainLoop - Error Processing message queue
                                          2023-12-20 15:50:31,690 - mainLoop - 'global'
                                          2023-12-20 15:50:36,696 - mainLoop - Calling Status from run --> mainLoop --> getDuet
                                          2023-12-20 15:50:36,703 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=state post: False
                                          2023-12-20 15:50:36,812 - mainLoop - Standalone Status is processing
                                          2023-12-20 15:50:36,813 - mainLoop - Error Processing message queue
                                          2023-12-20 15:50:36,815 - mainLoop - 'global'
                                          2023-12-20 15:50:36,816 - mainLoop - ****** Duet status changed to: processing from unknown *****
                                          2023-12-20 15:50:36,818 - mainLoop - ****** stateMachine:
                                          2023-12-20 15:50:36,820 - mainLoop - newstate = Capturing
                                          2023-12-20 15:50:36,823 - mainLoop - currentState = Waiting
                                          2023-12-20 15:50:36,826 - mainLoop - duetStatus = processing
                                          2023-12-20 15:50:36,828 - mainLoop - lastDuetStatus = unknown
                                          2023-12-20 15:50:36,829 - mainLoop - dontwait = True
                                          2023-12-20 15:50:36,830 - mainLoop - detect = none
                                          2023-12-20 15:50:36,835 - mainLoop - terminateState = -1
                                          2023-12-20 15:50:36,837 - mainLoop - ******
                                          2023-12-20 15:50:36,839 - mainLoop - ****** Print State changed to: Capturing from Waiting*****
                                          2023-12-20 15:50:36,841 - mainLoop - Calling oneInterval for Camera 1
                                          2023-12-20 15:50:36,843 - mainLoop - Calling Layer from captureLoop --> oneInterval --> getDuet
                                          2023-12-20 15:50:36,845 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=job.layer post: False
                                          2023-12-20 15:50:36,927 - mainLoop - Current Layer is 124
                                          2023-12-20 15:50:36,929 - mainLoop - elapsed: 10.918282985687256
                                          2023-12-20 15:50:36,932 - mainLoop - ****** stateMachine:
                                          2023-12-20 15:50:36,934 - mainLoop - newstate = Capturing
                                          2023-12-20 15:50:36,937 - mainLoop - currentState = Capturing
                                          2023-12-20 15:50:36,944 - mainLoop - duetStatus = processing
                                          2023-12-20 15:50:36,946 - mainLoop - lastDuetStatus = unknown
                                          2023-12-20 15:50:36,948 - mainLoop - dontwait = True
                                          2023-12-20 15:50:36,949 - mainLoop - detect = none
                                          2023-12-20 15:50:36,951 - mainLoop - terminateState = -1
                                          2023-12-20 15:50:36,952 - mainLoop - ******
                                          2023-12-20 15:50:39,334 - Thread-2 - !!!!! http call: {'displayStatus': ['true']} !!!!!
                                          2023-12-20 15:50:41,959 - mainLoop - Calling Status from run --> mainLoop --> getDuet
                                          2023-12-20 15:50:41,960 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=state post: False
                                          2023-12-20 15:50:42,060 - mainLoop - Standalone Status is processing
                                          2023-12-20 15:50:42,061 - mainLoop - Error Processing message queue
                                          2023-12-20 15:50:42,062 - mainLoop - 'global'
                                          2023-12-20 15:50:47,069 - mainLoop - Calling Status from run --> mainLoop --> getDuet
                                          2023-12-20 15:50:47,070 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=state post: False
                                          2023-12-20 15:50:47,131 - mainLoop - Standalone Status is processing
                                          2023-12-20 15:50:47,132 - mainLoop - Error Processing message queue
                                          2023-12-20 15:50:47,134 - mainLoop - 'global'
                                          2023-12-20 15:50:47,136 - mainLoop - ****** stateMachine:
                                          2023-12-20 15:50:47,137 - mainLoop - newstate = Capturing
                                          2023-12-20 15:50:47,139 - mainLoop - currentState = Capturing
                                          2023-12-20 15:50:47,140 - mainLoop - duetStatus = processing
                                          2023-12-20 15:50:47,140 - mainLoop - lastDuetStatus = processing
                                          2023-12-20 15:50:47,141 - mainLoop - dontwait = True
                                          2023-12-20 15:50:47,142 - mainLoop - detect = none
                                          2023-12-20 15:50:47,143 - mainLoop - terminateState = -1
                                          2023-12-20 15:50:47,143 - mainLoop - ******
                                          2023-12-20 15:50:47,146 - mainLoop - Calling oneInterval for Camera 1
                                          2023-12-20 15:50:47,149 - mainLoop - Calling Layer from captureLoop --> oneInterval --> getDuet
                                          2023-12-20 15:50:47,150 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=job.layer post: False
                                          2023-12-20 15:50:47,206 - mainLoop - Current Layer is 124
                                          2023-12-20 15:50:47,207 - mainLoop - elapsed: 21.196640968322754
                                          2023-12-20 15:50:47,208 - mainLoop - ****** stateMachine:
                                          2023-12-20 15:50:47,209 - mainLoop - newstate = Capturing
                                          2023-12-20 15:50:47,209 - mainLoop - currentState = Capturing
                                          2023-12-20 15:50:47,210 - mainLoop - duetStatus = processing
                                          2023-12-20 15:50:47,210 - mainLoop - lastDuetStatus = processing
                                          2023-12-20 15:50:47,214 - mainLoop - dontwait = True
                                          2023-12-20 15:50:47,216 - mainLoop - detect = none
                                          2023-12-20 15:50:47,218 - mainLoop - terminateState = -1
                                          2023-12-20 15:50:47,219 - mainLoop - ******
                                          2023-12-20 15:50:49,329 - Thread-3 - !!!!! http call: {'displayStatus': ['true']} !!!!!
                                          2023-12-20 15:50:52,226 - mainLoop - Calling Status from run --> mainLoop --> getDuet
                                          2023-12-20 15:50:52,228 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=state post: False
                                          2023-12-20 15:50:52,396 - mainLoop - Standalone Status is processing
                                          2023-12-20 15:50:52,397 - mainLoop - Error Processing message queue
                                          2023-12-20 15:50:52,397 - mainLoop - 'global'
                                          2023-12-20 15:50:57,403 - mainLoop - Calling Status from run --> mainLoop --> getDuet
                                          2023-12-20 15:50:57,405 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=state post: False
                                          2023-12-20 15:50:57,521 - mainLoop - Standalone Status is processing
                                          2023-12-20 15:50:57,527 - mainLoop - Error Processing message queue
                                          2023-12-20 15:50:57,528 - mainLoop - 'global'
                                          2023-12-20 15:50:57,531 - mainLoop - ****** stateMachine:
                                          2023-12-20 15:50:57,532 - mainLoop - newstate = Capturing
                                          2023-12-20 15:50:57,533 - mainLoop - currentState = Capturing
                                          2023-12-20 15:50:57,534 - mainLoop - duetStatus = processing
                                          2023-12-20 15:50:57,534 - mainLoop - lastDuetStatus = processing
                                          2023-12-20 15:50:57,559 - mainLoop - dontwait = True
                                          2023-12-20 15:50:57,560 - mainLoop - detect = none
                                          2023-12-20 15:50:57,560 - mainLoop - terminateState = -1
                                          2023-12-20 15:50:57,561 - mainLoop - ******
                                          2023-12-20 15:50:57,562 - mainLoop - Calling oneInterval for Camera 1
                                          2023-12-20 15:50:57,563 - mainLoop - Calling Layer from captureLoop --> oneInterval --> getDuet
                                          2023-12-20 15:50:57,564 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=job.layer post: False
                                          2023-12-20 15:50:57,613 - mainLoop - Current Layer is 125
                                          2023-12-20 15:50:57,616 - mainLoop - elapsed: 31.605782985687256
                                          2023-12-20 15:50:57,621 - mainLoop - Calling Status from oneInterval --> checkForPause --> getDuet
                                          2023-12-20 15:50:57,623 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=state post: False
                                          2023-12-20 15:50:57,681 - mainLoop - Standalone Status is processing
                                          2023-12-20 15:50:57,682 - mainLoop - Error Processing message queue
                                          2023-12-20 15:50:57,684 - mainLoop - 'global'
                                          2023-12-20 15:50:57,686 - mainLoop - Time - Camera1: capturing frame 1 at layer 125 after 30 seconds
                                          2023-12-20 15:50:57,689 - mainLoop - Calling stack oneInterval --> onePhoto --> createworkingDir
                                          2023-12-20 15:50:57,692 - mainLoop - Created working directory: /home/pi/DuetLapse/raspberrypi/10-0-1-126/9084_1
                                          2023-12-20 15:50:57,696 - mainLoop - Calling stack onePhoto --> createworkingDir --> renamelogfile
                                          2023-12-20 15:50:57,705 - mainLoop - Calling Jobname from onePhoto --> renameworkingDir --> getDuet
                                          2023-12-20 15:50:57,709 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=job.file.fileName post: False
                                          2023-12-20 15:50:57,768 - mainLoop - Renaming working directory: /home/pi/DuetLapse/raspberrypi/10-0-1-126/9084_1_Body1
                                          2023-12-20 15:50:57,770 - mainLoop - Calling stack onePhoto --> renameworkingDir --> renamelogfile
                                          2023-12-20 15:50:59,336 - Thread-4 - !!!!! http call: {'displayStatus': ['true']} !!!!!
                                          2023-12-20 15:51:00,941 - mainLoop - Command Failure: ffmpeg -threads 1 -y -i http://localhost:8081/stream -vframes 1 -threads 1 /home/pi/DuetLapse/raspberrypi/10-0-1-126/9084_1_Body1/Camera1_00000001.jpeg
                                          2023-12-20 15:51:00,944 - mainLoop - Error = ffmpeg version 4.3.6-0+deb11u1+rpt5 Copyright (c) 2000-2023 the FFmpeg developers
                                          built with gcc 10 (Raspbian 10.2.1-6+rpi1)
                                          configuration: --prefix=/usr --extra-version=0+deb11u1+rpt5 --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --
                                            @stuartofmt
                                            hi here are some updates
                                            1-i fixed the issue with the localhost and ip so now we are back to this config am using a ribbon pi cam
                                            -basedir /home/pi/DuetLapse
                                            -duet 10.0.1.126
                                            -port 8082
                                            -seconds 30
                                            -detect none
                                            -weburl1 http://10.0.1.110/stream
                                            -verbose
                                            -camera1 stream
                                            while printing here is the log
                                            2023-12-20 17:06:00,452 - mainLoop - Output =
                                            2023-12-20 17:06:00,454 - mainLoop - !!!!! There was a problem capturing an image !!!!!
                                            2023-12-20 17:06:00,455 - mainLoop - ****** stateMachine:
                                            2023-12-20 17:06:00,456 - mainLoop - newstate = Capturing
                                            2023-12-20 17:06:00,456 - mainLoop - currentState = Capturing
                                            2023-12-20 17:06:00,457 - mainLoop - duetStatus = processing
                                            2023-12-20 17:06:00,457 - mainLoop - lastDuetStatus = processing
                                            2023-12-20 17:06:00,458 - mainLoop - dontwait = True
                                            2023-12-20 17:06:00,458 - mainLoop - detect = none
                                            2023-12-20 17:06:00,458 - mainLoop - terminateState = -1
                                            2023-12-20 17:06:00,459 - mainLoop - ******
                                            2023-12-20 17:06:03,802 - mainLoop - Calling Status from run --> mainLoop --> getDuet
                                            2023-12-20 17:06:03,819 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=state post: False
                                            2023-12-20 17:06:03,861 - mainLoop - Standalone Status is processing
                                            2023-12-20 17:06:03,864 - mainLoop - Error Processing message queue
                                            2023-12-20 17:06:03,866 - mainLoop - 'global'
                                            2023-12-20 17:06:08,878 - mainLoop - Calling Status from run --> mainLoop --> getDuet
                                            2023-12-20 17:06:08,879 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=state post: False
                                            2023-12-20 17:06:09,063 - mainLoop - Standalone Status is processing
                                            2023-12-20 17:06:09,064 - mainLoop - Error Processing message queue
                                            2023-12-20 17:06:09,064 - mainLoop - 'global'
                                            2023-12-20 17:06:10,734 - mainLoop - ****** stateMachine:
                                            2023-12-20 17:06:10,735 - mainLoop - newstate = Capturing
                                            2023-12-20 17:06:10,735 - mainLoop - currentState = Capturing
                                            2023-12-20 17:06:10,736 - mainLoop - duetStatus = processing
                                            2023-12-20 17:06:10,736 - mainLoop - lastDuetStatus = processing
                                            2023-12-20 17:06:10,737 - mainLoop - dontwait = True
                                            2023-12-20 17:06:10,737 - mainLoop - detect = none
                                            2023-12-20 17:06:10,738 - mainLoop - terminateState = -1
                                            2023-12-20 17:06:10,738 - mainLoop - ******
                                            2023-12-20 17:06:10,738 - mainLoop - Calling oneInterval for Camera 1
                                            2023-12-20 17:06:10,739 - mainLoop - Calling Layer from captureLoop --> oneInterval --> getDuet
                                            2023-12-20 17:06:10,739 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=job.layer post: False
                                            2023-12-20 17:06:10,844 - mainLoop - Current Layer is 1
                                            2023-12-20 17:06:10,845 - mainLoop - elapsed: 403.8418319225311
                                            2023-12-20 17:06:10,846 - mainLoop - Calling Status from oneInterval --> checkForPause --> getDuet
                                            2023-12-20 17:06:10,846 - mainLoop - 0 url: http://10.0.1.126/rr_model?key=state post: False
                                            2023-12-20 17:06:10,876 - mainLoop - Standalone Status is processing
                                            2023-12-20 17:06:10,877 - mainLoop - Error Processing message queue
                                            2023-12-20 17:06:10,878 - mainLoop - 'global'
                                            2023-12-20 17:06:10,879 - mainLoop - Time - Camera1: capturing frame 1 at layer 1 after 30 seconds
                                            2023-12-20 17:06:12,984 - mainLoop - Command Failure: ffmpeg -threads 1 -y -i http://10.0.1.110/stream -vframes 1 -threads 1 /home/pi/DuetLapse/raspberrypi/10-0-1-126/1739_1_Body1/Camera1_00000001.jpeg
                                            2023-12-20 17:06:12,986 - mainLoop - Error = ffmpeg version 4.3.6-0+deb11u1+rpt5 Copyright (c) 2000-2023 the FFmpeg developers
                                            configuration: --prefix=/usr --extra-version=0+deb11u1+rpt5 --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-mmal --enable-neon --enable-rpi --enable-v4l2-request --enable-libudev --enable-epoxy --enable-pocketsphinx --enable-libdc1394 --enable-libdrm --enable-vout-drm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared --libdir=/usr/lib/arm-linux-gnueabihf --cpu=arm1176jzf-s --arch=arm
                                            WARNING: library configuration mismatch
                                            avutil configuration: --prefix=/usr --extra-version=0+deb11u1+rpt5 --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-mmal --enable-neon --enable-rpi --enable-v4l2-request --enable-libudev --enable-epoxy --enable-pocketsphinx --enable-libdc1394 --enable-libdrm --enable-vout-drm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs
                                            avcodec configuration: --prefix=/usr --extra-version=0+deb11u1+rpt5 --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-mmal --enable-neon --enable-rpi --enable-v4l2-request --enable-libudev --enable-epoxy --enable-pocketsphinx --enable-libdc1394 --enable-libdrm --enable-vout-drm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs
                                            avformat configuration: --prefix=/usr --extra-version=0+deb11u1+rpt5 --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-mmal --enable-neon --enable-rpi --enable-v4l2-request --enable-libudev --enable-epoxy --enable-pocketsphinx --enable-libdc1394 --enable-libdrm --enable-vout-drm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs
                                            avdevice configuration: --prefix=/usr --extra-version=0+deb11u1+rpt5 --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-mmal --enable-neon --enable-rpi --enable-v4l2-request --enable-libudev --enable-epoxy --enable-pocketsphinx --enable-libdc1394 --enable-libdrm --enable-vout-drm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs
                                            avfilter configuration: --prefix=/usr --extra-version=0+deb11u1+rpt5 --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-mmal --enable-neon --enable-rpi --enable-v4l2-request --enable-libudev --enable-epoxy --enable-pocketsphinx --enable-libdc1394 --enable-libdrm --enable-vout-drm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs
                                            avresample configuration: --prefix=/usr --extra-version=0+deb11u1+rpt5 --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-mmal --enable-neon --enable-rpi --enable-v4l2-request --enable-libudev --enable-epoxy --enable-pocketsphinx --enable-libdc1394 --enable-libdrm --enable-vout-drm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs
                                            swscale configuration: --prefix=/usr --extra-version=0+deb11u1+rpt5 --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-mmal --enable-neon --enable-rpi --enable-v4l2-request --enable-libudev --enable-epoxy --enable-pocketsphinx --enable-libdc1394 --enable-libdrm --enable-vout-drm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs
                                            swresample configuration: --prefix=/usr --extra-version=0+deb11u1+rpt5 --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-mmal --enable-neon --enable-rpi --enable-v4l2-request --enable-libudev --enable-epoxy --enable-pocketsphinx --enable-libdc1394 --enable-libdrm --enable-vout-drm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs
                                            postproc configuration: --prefix=/usr --extra-version=0+deb11u1+rpt5 --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-mmal --enable-neon --enable-rpi --enable-v4l2-request --enable-libudev --enable-epoxy --enable-pocketsphinx --enable-libdc1394 --enable-libdrm --enable-vout-drm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs
                                            libavutil 56. 51.100 / 56. 51.100
                                            libavcodec 58. 91.100 / 58. 91.100
                                            libavformat 58. 45.100 / 58. 45.100
                                            libavdevice 58. 10.100 / 58. 10.100
                                            libavfilter 7. 85.100 / 7. 85.100
                                            libavresample 4. 0. 0 / 4. 0. 0
                                            libswscale 5. 7.100 / 5. 7.100
                                            libswresample 3. 7.100 / 3. 7.100
                                            libpostproc 55. 7.100 / 55. 7.100
                                            Input #0, mpjpeg, from 'http://10.0.1.110/stream':
                                            Duration: N/A, bitrate: N/A
                                            Stream #0:0: Video: mjpeg (Baseline), yuvj420p(pc, bt470bg/unknown/unknown), 1280x720 [SAR 1:1 DAR 16:9], 25 tbr, 25 tbn, 25 tbc
                                            Stream mapping:
                                            Stream #0:0 -> #0:0 (mjpeg (native) -> mjpeg (native))
                                            Press [q] to stop, [?] for help
                                            Output #0, image2, to '/home/pi/DuetLapse/raspberrypi/10-0-1-126/1739_1_Body1/Camera1_00000001.jpeg':
                                            Metadata:
                                            encoder : Lavf58.45.100
                                            Stream #0:0: Video: mjpeg, yuvj420p(pc), 1280x720 [SAR 1:1 DAR 16:9], q=2-31, 200 kb/s, 25 fps, 25 tbn, 25 tbc
                                            Metadata:
                                            encoder : Lavc58.91.100 mjpeg
                                            Side data:
                                            cpb: bitrate max/min/avg: 0/0/200000 buffer size: 0 vbv_delay: N/A
                                            frame= 1 fps=0.0 q=5.2 Lsize=N/A time=00:00:00.04 bitrate=N/A speed=0.422x
                                            video:20kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown
                                            2023-12-20 17:06:12,988 - mainLoop - Output =
                                            2023-12-20 17:06:12,989 - mainLoop - !!!!! There was a problem capturing an image !!!!!
                                            2023-12-20 17:06:12,991 - mainLoop - ****** stateMachine:
                                            stuartofmtundefined 1 Reply Last reply Reply Quote 0
