Wifi No longer Connecting to Duet2
Hi All,
We have a brand new Modex180 in-house and got the wifi to connect briefly this morning but now it is no longer pingable or visible from our wifi controllers.
This is a wpa2 network, in an Aruba environment and running on AP 535's
The signal strength is excellent.I'm wondering if this community can share any troubleshooting steps with us to make the system usable.
Note: Please do not recommend restarting our router(s) - We (the IT department) will not consider this a viable troubleshooting step.
@ConnectIT For general WiFi troubleshooting, see https://docs.duet3d.com/en/User_manual/Troubleshooting/WiFi_troubleshooting
If you can connect to the Duet via USB serial using YAT (or another serial terminal), then send M122 to get a status report, and copy that into your reply, that would be useful. The WiFi diagnostics are at the end, so please try to post the whole M122 output.
Additional Info: I tested connecting to an iPhone hotspot but the duet2 fails to connect to that network as well.
M122 Output: === Diagnostics ===
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.5 (2022-11-30 19:36:12) running on Duet WiFi 1.02 or later + DueX5v0.11
Board ID: 0JD0M-9P6M2-NW4SD-6JTD8-3SN6R-9UQMK
Used output buffers: 1 of 26 (4 max)
Static ram: 23836
Dynamic ram: 77256 of which 12 recycled
Never used RAM 8120, free system stack 176 words
Tasks: NETWORK(ready,8.2%,331) HEAT(notifyWait,0.0%,333) Move(notifyWait,0.0%,363) DUEX(notifyWait,0.0%,24) MAIN(running,91.2%,461) IDLE(ready,0.5%,30), total 100.0%
Owned mutexes: USB(MAIN)
Last reset 00:02:39 ago, cause: power up
Last software reset time unknown, reason: User, GCodes spinning, available RAM 8120, slot 0
Error status: 0x00
Aux0 errors 0,0,0
Step timer max interval 0
MCU temperature: min 27.1, current 30.9, max 31.2
Supply voltage: min 1.3, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
Heap OK, handles allocated/used 99/14, heap memory allocated/used/recyclable 2048/212/8, gc cycles 0
Events: 0 queued, 0 completed
Driver 0: standstill, SG min n/a
Driver 1: standstill, SG min n/a
Driver 2: standstill, SG min n/a
Driver 3: standstill, SG min n/a
Driver 4: standstill, SG min n/a
Driver 5: standstill, SG min n/a
Driver 6: standstill, SG min n/a
Driver 7: standstill, SG min n/a
Driver 8: standstill, SG min n/a
Driver 9: standstill, SG min n/a
Driver 10:
Driver 11:
Slowest loop: 500.26ms; fastest: 0.15ms
=== Storage ===
Free file entries: 10
SD card longest read time 10.6ms, write time 0.0ms, max retries 0
DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
=== AuxDDARing ===
Bed heaters -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is ready with “M122” in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty
=== Filament sensors ===
Extruder 0 sensor: no data received
Extruder 1 sensor: no data received
=== DueX ===
Read count 1, 0.38 reads/min
=== Network ===
Slowest loop: 11.17ms; fastest: 0.00ms
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
HTTP sessions: 0 of 8
= WiFi =
Network state is changingMode
WiFi module is idle
Failed messages: pending 0, notready 0, noresp 3
Failed to get WiFi status
Socket states: 0 0 0 0 0 0 0 0 -
I'm not sure if this may be of use also...
M552 S0
ok
WiFi module started
M587
Remembered networks: none
ok
M587 S"BA-Devices" P"********""
M587
Remembered networks: none -
Can you confirm that you have a 2.4ghz network to connect to? The Duet cannot connect to a 5ghz network.
Occasionally we've seen dual 2.4/5ghz networks try and use band steering to erroneously force the Duet onto the 5ghz network.
A good method for testing the wifi module that eliminates the local area network entirely is to use Access Point mode on the Duet where it create it's own SSID that you connect your computer to. If that works successfully we know the module itself is working.
https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m589-configure-access-point-parameters
Thank you for your help Droftarts and Phaedrux,
We do have 2.4 available and bandsteering is not aggressive in our environment.
I cannot see the unit referenced anywhere in our systems, so it never reaches our Wi-Fi controllers, DHCP server, etc.
It does not appear to be successfully storing networks (it was able to briefly a couple of days ago)
Output:
WiFi module stopped
ok
M552
WiFi module is disabled
ok
M552 S0
ok
WiFi module started
M552
WiFi module is idle
ok
M587 S"BA-Devices" P"******"
M587
okNotes:
Board ID: 0JD0M-9P6M2-NW4SD-6JTD8-3SN6R-***** -
@ConnectIT You don't seem to be getting an 'ok' from the M587 command that sets the SSID and password, which you should. Are you using a Apple Mac to connect to it via USB? This is quite common if using a Mac and SerialTools, see my reply here: https://forum.duet3d.com/post/323711
Good call - We are using Apple/USB
I will definitely explore the thread you linked and reply after testing (and lunch)
This is a wonderful forum!
You can also use a macro to add a network. This bypasses the need to use a terminal.
; Add default wifi network ; M291 R"Add default WIFI network? Y/N" P"This will add duetwifi access point." S3 T10 M552 S0 ; Disable network module G4 S5 ; wait 5 seconds M587 S"duetwifi" P"password" ; Add duetwifi SSID to remembered networks list G4 S5 ; wait 5 seconds M552 S1 ; reenable wifi module M291 R"duetwifi SSID added." P"Check console to verify IP address."
We are up!
You guys nailed it with our terminal input.
Our initial connection to the device was via Terminal (explains brief connectivity before we began over-writing) but we quickly switched to SerialTools to mitigate the "creep" to the right and lack of echo.
We shifted back to Terminal and were able to successfully configure our new Printer--- You guys were tremendously helpful ---
