Duex 5 Hardware - SMD component specifications
i need the some information about 2 SMD componebts mounted on the DueX 5 Board.In more detail do i need the manufacturer, model and the parameters / specifications from the diodes D7 and D18, listed in the BOM as
- "DB2W40300L", "D_SOD-123F"
and - "DO-219AB", "DO-219AB"
of the Duet3D DueX 5.
Are there any replacement variants for these components, if the original parts are not available to order or too expensive?
Thank you in advance..
undefined Phaedrux marked this topic as a question
@wildblue DB2W40300L is a part number so you can look it up, basically a 3A 40V Schottky diode. D18 is a 1A fast recovery silicon diode rated 40V or greater.
