motors only vibrate
i have a clone duet2 i bought it in 2019 used for 3 years and needed to move and disarmed the printed and was in a box for 2 years now
i started working on it again and the first thing i do was to update it to 3.5 firmware version and that worked fine
now when i try to move the motors the motors vibrate but not move
im testing only with the motors without load and this very minimal config; General M550 P"corexy" ; set hostname M911 S19.8 R22 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss ; Network M552 S1 ; configure WiFi adapter M586 P0 S1 ; configure HTTP ; Drives M569 P0 S0 ; physical drive 0 goes forwards M569 P1 S0 ; physical drive 1 goes forwards M569 P2 S1 ; physical drive 2 goes forwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 ; set steps per mm M566 X1020.00 Y1020.00 Z1200.00 E40.00 ; set maximum instantaneous speed changes (mm/min) M203 X7000.00 Y7000.00 Z1800.00 ; set maximum speeds (mm/min) M201 X700.00 Y700.00 Z200.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Kinematics M669 K1 ; configure CoreXY kinematics ; Endstops M574 X1 P"xstop" S1 ; configure X axis endstop M574 Y1 P"ystop" S1 ; configure Y axis endstop i tried diferent cables diferent motors in diferent drivers even diferent motors and nothing
any ideas? -
Get a full config from the config tool and then send M98 P"config.g" and see if there are any errors reported. Also an M122 report.
Common cause for motors just vibrating is one of the phases is not connected due to a bad crimp or broken wire.
i re generated all configs and nothing changed
i keep searching for the issue and find that some motors have they coils inverted
almost all my motors have that and none of my cables is inverted to work like that
so start changing cables and find that works
