    changing the default gcodes directory
    Firmware installation
    • Boxyundefined
      Boxy
      Is it possible to set the default "gcodes" directory to be on SD1(the secondary SD card) at SD1:/ - or even SD1:/GCODES/.
        dc42 administrators @Boxy
        @Boxy in what context do you want to change the default GCodes directory? Do you mean for use by GCode commands that don't specify a path, such as M32 and M20? Or do you mean for user interfaces that list job files e.g. DWC and PanelDue? Or something else?
        Boxyundefined 1 Reply Last reply Reply Quote 0
        • Boxyundefined
          Boxy
          @dc42 HI Thank you for the useful questions :
          I will be more exact!.
          What I need it to be able to access VIA a USB cable a front mounted Accessible SD card ( SD 1) ( or better USB memory stick)
          I need to be able to a) load files b) run files, c) stop the printer, d)Home etc.
          Unfortunately for this particular situation I cannot use Ehternet nor Wi-Fi.
          It is important that I don't leave files on SD0 card - which should be inaccessible.
          ** Ideally I would also like to be able to run your excellent DWC from the USB cable. **
          Yes using SD1:/ for the default .gcode directory would also be great -
          I am currently using DUET 2 boards which I think are pretty good.
          I have made significant changes to the PANELDUE interface.
          I believe that I spoke briefly with you at TCT (5/6 years ago) - as I had the stand behind you. - sorry - I was probably a bit standoffish (no pun intended).
          visited Duet and spoke with Sarah a few months ago - would love to chatto you with purpose!
          • Boxyundefined
            Boxy @dc42
            @dc42 Hi again,
            I realise that I am asking a lot. and some of the requests might not be possible or even sensible! Also I am very appreciative of any help at all. On the other side I am also very happy to contribute as you might think fit!
              T3P3Tony administrators @Boxy
              @Boxy I will drop you an email - this looks like quite a specific and potentially far reaching set of changes.
