    Confused about recent 12864 Display Fix (3.5.0 rc 2)
    Third-party add-ons
    • Yukikazeundefined
      Yukikaze
      I have a duet 5 Mini with a SBC and a 12864 Display.
      Since SD card access doesn't work with a SBC i made a button for every Macro:
      button R26 C40 F0 W64 V0 T"Lights OFF" A"M98 P#0" L"/macros/LightOFF"
      This worked flawlessly until some Time last year (can't say exactly which update broke it. I assumed it would be fixed someday so i just ignored it.
      Now i updated to 3.5.0 Release Candidate 3 and saw that in rc2 there was a fix that should solve my issue:
      "In menu files for a 12864 display it was not possible to include a double-quote character in the command string for an A parameter (issue 909). This made it impossible to use the M98 command in such a parameter because the P argument of the M98 command must now be enclosed in double quotes."
      https://github.com/Duet3D/RepRapFirmware/issues/909
      Sadly, I'm confused how i have to change my code to get it to work. I tried a few things, but none of them worked.
      It would be great if someone could modify my code for me.
      X-Dron created this issue in Duet3D/RepRapFirmware
      closed [Bug]: RepRapFirmware 3.5.0-rc.1 and Screens 12864 #909
      • chrishammundefined
        chrishamm administrators @Yukikaze
        @Yukikaze You are missing double-quotes in your M98 command. Does this work?
        button R26 C40 F0 W64 V0 T"Lights OFF" A"M98 P""#0""" L"/macros/LightOFF"
        Duet software engineer
        Yukikazeundefined 1 Reply Last reply Reply Quote 0
        • Yukikazeundefined
          Yukikaze @chrishamm
          @chrishamm No, i tried that already.
            @Yukikaze What about
            button R26 C40 F0 W64 V0 T"Lights OFF" A"M98 P""/macros/LightOFF"""
            • Yukikazeundefined
              Yukikaze @chrishamm
              @chrishamm Yes, that worked. Thanks a lot.
              dc42undefined 2 Replies Last reply Reply Quote 0
                dc42 administrators @Yukikaze
                @Yukikaze interesting, last time I looked at the code it appeared that the #0 parameter in the M98 command should get double quotes surrounding it automatically. I'll take another look.
                  @Yukikaze I confirm that this was not working in rc3. I have corrected the 3.5 source code and tested the fix. Thank you for reporting it.
