    BLtouch & duet wifi issues
    My Duet controlled machine
    1.4k
    • polbofreeundefined
      polbofree
      Hello everybody.
      I have some issues with Bltouch. I mounted a duet wifi in my Hypercuve evo printer.
      I wiring my Bltouch like that:
      red wire –>+ 5v (1st pin in the expansion slot)
      brown wire –> GND (2nd pin in the expansion slot)
      yellow wire –> heater 7 (31th pin in the expansion slot)
      white wire –> "E0 stop" pin in duet wifi board
      black wire --> "E0 GND" pin in duet wifi board
      when I turn on the printer, the BLtouch goes out fot two times (it's all ok), but when I goes Z axis to home, bltouch don't work.
      What's the problem?
      Here my fw configuration:
      ; Configuration file for Duet WiFi (firmware version 1.17 to 1.19)
      ; generated by RepRapFirmware Configuration Tool on Sat Dec 16 2017 10:42:32 GMT+0100 (ora solare Europa occidentale)
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M555 P1 ; Set firmware compatibility to look like RepRapFirmare
      M553 S1
      M667 S1 ; Select CoreXY mode
      M208 X400 Y400 Z400 S0 ; Set axis maxima
      M574 Z0 S0 ; Set active low endstops
      M574 X1 Y2 S1 ; Set active high endstops
      M307 H7 A-1 C-1 D-1 ;
      M558 P5 X0 Y0 Z1 H5 F120 T6000 ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
      G31 P25 X9 Y10 Z1.5 ; Set Z probe trigger value, offset and trigger height
      M557 X15:215 Y15:195 S20 ; Define mesh grid
      M569 P0 S0 ; Drive 0 goes backwards
      M569 P1 S0 ; Drive 1 goes backwards
      M350 X16 Y16 Z16 E16:16 I0 ; Configure microstepping without interpolation
      M92 X80 Y80 Z800 E420:420 ; Set steps per mm
      M566 X900 Y900 Z12 E120:120 ; Set maximum instantaneous speed changes (mm/min)
      M203 X6000 Y6000 Z180 E1200:1200 ; Set maximum speeds (mm/min)
      M201 X500 Y20 Z250 E250:250 ; Set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800:800 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
      M305 P2 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 2
      M143 H2 S280 ; Set temperature limit for heater 2 to 280C
      M563 P0 D0 H1 ; Define tool 0
      G10 P0 R0 S0
      my deployprobe.g file contens:
      M280 P7 S120 I1
      and retractproble.g conteins
      M280 P7 S160 I1
      anyone can help me?
      cheers
      Diego
      • JRDMundefined
        JRDM
        For one, I think output P7 is incompatible with bltouch for not having the right kind of hardware PWM. Going back in the wiki, I might be wrong about that but I think P6 would work. I ended up going back to P3 because that was a known working config.
        I think your "S" parameters are wrong. I recall S120 and S160 turn on self test and reset, respectively.
        so shouldn't deployprobe.g be:
        M280 P3 S10 I1
        retract probe.g:
        M280 P3 S90 I1
        Substitute Px for the heater (PWM) pin you want to use.
          polbofree
          ok,
          I put the yellow wire in the 8th pin into the expansion slot.
          I modify the fw like that:
          M307 H3 A-1 C-1 D-1 ;
          M558 P5 X0 Y0 Z1 H5F120 T6000 ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
          and modify the deplyprobe and retractprobe files.
          it don't work
            polbofree
            I try to wiring BLtouch white wire and black wire into Z proble slot, bat it dosn't work.
              polbofree
              ok…. it work: when it's triggered, webpanel show Z-probe value:1000. when it is estract, show 0.... but it don't stop Z homing
              sorry for my english...I'm italian guy
                Here's how to test a Z probe. Position the nozzle high above the bed, then send G30. The probe should deploy and start moving towards the bed. Trigger the probe by holding something under it. That should stop the movement. If it doesn't, turn the power off before the nozzle reaches the bed.
                • DunstonUKundefined
                  DunstonUK
                  Hi
                  Looks like I have the same issue as you. 😞 just posted mine as well. Hopefully, we can get it sorted.
                  Life’s bucket list is never ending. Remember someone else is always better than you.
