    New experimental DuetPi Bookworm builds available
    Beta Firmware
    8
    34
    2.5k
    • chrishammundefined
      chrishamm administrators @fractalengineer
      @fractalengineer said in New experimental DuetPi Bookworm builds available:
      My HDMI display shows a black, unresponsive screen after bootup despite showing the Duet bg and boot sequence just fine. Display manager service checked and active
      My DSI and HDMI screens came up straight without any problems. Maybe you need to configure your HDMI settings manually via config.txt? See here.
      Likewise, VNC is not connecting despite the service being turned on
      RaspPi OS based on Bookworm does not use RealVNC any more by default, instead it uses WayVNC. To get RealVNC working again, you need to turn off Wayland support via raspi-config in the advanced settings. However, that will probably make the display a bit slower than it needs to be (Wayland is faster than X11).
      I have full access through SSH though, through which I performed a git init, remote add and fetch origin in /sd to get my backup from my github backup; all is well, however...
      It appears the file permissions are all bonked out; config refuses to load with this message: Error in start-up file config.g line 29: Access to the path '/opt/dsf/sd/sys/eventlog.txt' is denied. >>> This is a know issue I previously sorted out by doing sudo chmod 777 -R /opt/dsf/sd but there has to be a better way right
      It sounds like neither the dsf user or group can access your files in /opt/dsf/sd. If you cloned your repo as root, that's likely to happen. Instead of messing with chmod, it's better to call sudo chown -R dsf:dsf /opt/dsf/sd to fix the ownership permissions if needed.
      Duet software engineer
      • printerguy3dundefined
        printerguy3d
        I have both HDMI and DSI connected, neither work. DSI shows just black screen. HDMI shows desktop background like extended monitor. This is with a 3b+, does this only work with a 4?image1.jpeg image0.jpeg
        chrishammundefined printerguy3dundefined 2 Replies Last reply Reply Quote 1
          chrishamm administrators @printerguy3d
          @printerguy3d It should work as well with a 3B+. Does your display work with the official RPi Bookworm image as expected? I don't think the new DuetPi image should be too different from it.
          fractalengineerundefined 1 Reply Last reply Reply Quote 0
            printerguy3d @printerguy3d
            @printerguy3d also of note, if i unplug the DSI monitor, the HDMI screen is also blank after boot.
              printerguy3d
              this makes the dsi screen work...
              placing the directive in boot/confix.txt
              dtoverlay=vc4-kms-dsi-7inch,invx,invy
              and disabling the entry:
              display_auto_detect=1
              putting the hash sign # at the beginning
              #display_auto_detect=1
                printerguy3d
                OK. so now bookworm loads and I have the board connected. When the Duet2 board runs 3.4.6 it gives an error that the versions are incompatible. When I update the board with Bossa to 3.5r3, it says it can't find the host. What can I do to get you access to take a look....
                • fractalengineerundefined
                  fractalengineer @chrishamm
                  @chrishamm interesting; just flashed latest vanila raspios bookworm and the screen works out of the box (but not the touchscreen?)
                  Meanwhile I'm unable to access VNC, neither through Tiger or RealVNC with both wayland and X11, even while confirmed running hmm
                  Railcore II ZL
                  • jay_s_ukundefined jay_s_uk referenced this topic
                    @fractalengineer I just checked and with the Wayland desktop it's possible to enable wayvnc (sudo systemctl enable --now wayvnc) and to connect using the TigerVNC client (other VNC clients may work as well).
                    With X11 it's a bit more difficult and apparently VNC doesn't work out of the box (yet?). This seems to be an issue in RaspiOS, too, see https://github.com/raspberrypi/bookworm-feedback/issues/41 But I could get it working on my setup by:
                    • installing libraspberrypi0 (sudo apt install libraspberrypi0),
                    • downloading the missing .so files via wget as described later in the GitHub issue,
                    • enabling VNC via raspi-config
                    gitbls created this issue in raspberrypi/bookworm-feedback
                    closed RealVNC on 32-bit RasPiOS issue #41
                    fractalengineerundefined oozeBotundefined 2 Replies Last reply Reply Quote 0
                      @chrishamm Ok great that definitely did something;
                      Now I can connect on both RealVNC and TigerVNC... But all I get is a grey screen in both cases 😅
                      Such is the case on both duetpi and the official pi release, both updated to latest (I have them both on separate SD cards now to cross test)
                      HDMI display still shows on official release (still no touchscreen) and black on Duetpi
                      The search continues
                      Railcore II ZL
                      • oozeBotundefined
                        oozeBot @chrishamm
                        @chrishamm will you be releasing instructions on how to "roll your own" copy of DuetPi for bookworm? We have a custom version but I've not been able to get it to connect with the old instruction set as I'm receiving:
                        Setting up reprapfirmware (3.4.6-3) ...
                        [fatal] Could not connect to Duet: Timeout while waiting for transfer ready pin
                        In the meantime, I'm flashing one of your builds onto an SD for testing now.
                        Thanks!
                          chrishamm administrators @oozeBot
                          @oozeBot No, I don't plan to provide more documentation than there already is on GitHub but Duet3D can provide extra consultancy under certain conditions. If you're interested, feel free to contact info@duet3d.com.
                          oozeBotundefined 1 Reply Last reply Reply Quote 0
                          • oozeBotundefined
                            oozeBot @chrishamm
                            @chrishamm - I was able to get past my issue. The documentation ( https://docs.duet3d.com/User_manual/Machine_configuration/DSF_Other#gpio-transfer-ready-pin ) states The following steps can be skipped if a Raspberry Pi is used. That does not appear to be valid for the Raspberry Pi 5 as I had to switch to gpiochip4 instead of the default gpiochip0. Thanks
                            chrishammundefined IndeX4Dundefined 2 Replies Last reply Reply Quote 1
                              @oozeBot Right, the Bookworm build uses a startup script to determine if it's running on a Pi 5. If it is, it makes those adjustments automatically. I'll update the documentation.
                              • oozeBotundefined
                                oozeBot @chrishamm
                                @chrishamm said in New experimental DuetPi Bookworm builds available:
                                Thanks. I just added something similar within duetcontrolserver's postinst script to do the same.
                                • p8blrundefined
                                  p8blr
                                  Any ideas what might be causing this "incompatible software versions error?"
                                  Also I'm running this on a Raspberry Pi 5 8GB with an NVMe hat and noticed that I'm getting freezing every few seconds. Any ideas there?
                                    chrishamm administrators @p8blr
                                    @p8blr Either you don't have all three RRF/DSF/DWC versions in sync (ideally only all updated by apt) or your browser is still using a cached DWC version. Try pressing Ctrl+Shift+R in your browser and check if that helps.
                                    I haven't noticed any occasional freezes on my setups.
                                    p8blrundefined 1 Reply Last reply Reply Quote 0
                                    • p8blrundefined
                                      p8blr @chrishamm
                                      @chrishamm I just installed a fresh image, and ran sudo apt update & sudo apt dist-upgrade, also ctrl+shift+r and am getting the same message. I updated the eeprom on the raspberry pi so hopefully that'll resolve the freezing issue.
                                      running M997 S2 gives "Error: M997: Failed to perform update: Upgrade process return non-zero exit code"
                                      Update: the issue seems to be that the sudo apt update/upgrade commands aren't doing anything regarding the duet board firmware. I confirmed this by connecting a Raspberry Pi 4 and running the commands again, and it was able to upgrade
                                      However, after upgrading I still get this "incompatible software versions" popup no matter how many times I ctrl+F5. Note, this is on the raspberry pi itself with a monitor attached.
                                      Also for the life of me, I can't get M997 S2 to work.
                                      Edit: Just an update for anybody with a similar issue, I went back to a raspbery pi 4 with a SD card and updated to the latest firmware, then copy/pasted my sys and macros over to a newly imaged NVMe and that did the trick. My best guess is that it was the drive I was using. TeamGroup MP33 stalled but a Patriot P310 seems to work fine.
                                      • chrishammundefined chrishamm referenced this topic
                                      • kiendeleoundefined
                                        kiendeleo
                                        With Duet 3.5.0 being released, I decided I would run
                                        apt update && apt upgrade
                                        on my RPI5. I am getting the following errors.
                                        rr:1 https://pkg.duet3d.com stable/armv7 arm64 duetpimanagementplugin arm64 3.5.0~rc.4+2
                                          404  Not Found [IP: 134.209.94.168 443]
                                        Err:2 https://pkg.duet3d.com stable/armv7 arm64 duetpluginservice arm64 3.5.0~rc.4+2
                                        Err:3 https://pkg.duet3d.com stable/armv7 arm64 duetsoftwareframework arm64 3.5.0~rc.4+2
                                        Err:4 https://pkg.duet3d.com stable/armv7 arm64 duettools arm64 3.5.0~rc.4+2
                                        Err:5 https://pkg.duet3d.com stable/armv7 arm64 duetcontrolserver arm64 3.5.0~rc.4+2
                                        Err:6 https://pkg.duet3d.com stable/armv7 arm64 duetruntime arm64 3.5.0~rc.4+2
                                        Err:7 https://pkg.duet3d.com stable/armv7 arm64 duetwebserver arm64 3.5.0~rc.4+2
                                        Ign:8 https://pkg.duet3d.com stable/armv7 arm64 reprapfirmware all 3.5.0~rc.4+2-1
                                        Err:8 https://pkg.duet3d.com stable/armv7 arm64 reprapfirmware all 3.5.0~rc.4+2-1
                                        E: Failed to fetch https://pkg.duet3d.com/dists/stable/armv7/binary-arm64/duetpimanagementplugin_3.5.0%7erc.4%2b2_arm64.deb  404  Not Found [IP: 134.209.94.168 443]
                                        E: Failed to fetch https://pkg.duet3d.com/dists/stable/armv7/binary-arm64/duetpluginservice_3.5.0%7erc.4%2b2_arm64.deb  404  Not Found [IP: 134.209.94.168 443]
                                        E: Failed to fetch https://pkg.duet3d.com/dists/stable/armv7/binary-arm64/duetsoftwareframework_3.5.0%7erc.4%2b2_arm64.deb  404  Not Found [IP: 134.209.94.168 443]
                                        E: Failed to fetch https://pkg.duet3d.com/dists/stable/armv7/binary-arm64/duettools_3.5.0%7erc.4%2b2_arm64.deb  404  Not Found [IP: 134.209.94.168 443]
                                        E: Failed to fetch https://pkg.duet3d.com/dists/stable/armv7/binary-arm64/duetcontrolserver_3.5.0%7erc.4%2b2_arm64.deb  404  Not Found [IP: 134.209.94.168 443]
                                        E: Failed to fetch https://pkg.duet3d.com/dists/stable/armv7/binary-arm64/duetruntime_3.5.0%7erc.4%2b2_arm64.deb  404  Not Found [IP: 134.209.94.168 443]
                                        E: Failed to fetch https://pkg.duet3d.com/dists/stable/armv7/binary-arm64/duetwebserver_3.5.0%7erc.4%2b2_arm64.deb  404  Not Found [IP: 134.209.94.168 443]
                                        E: Failed to fetch https://pkg.duet3d.com/dists/stable/armv7/binary-armhf/reprapfirmware_3.5.0%7erc.4%2b2-1_all.deb  404  Not Found [IP: 134.209.94.168 443]
                                        E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
                                        Is this something wrong on my end?
                                          chrishamm administrators @kiendeleo
                                          @kiendeleo It's WIP. I will announce 3.5.0 when everything is ready.
                                          kiendeleoundefined 1 Reply Last reply Reply Quote 0
                                            kiendeleo @chrishamm
                                            @chrishamm okay, I just wanted to submit the bug
