Macro to stop printing, run some code and then resume print
I'm looking to mace a macro on my printer pause the current print, run a set of gcode commands that pulse a pin and delay, and then return to the print as if nothing has happened. The machine is a DuetWifi and DueX5
I have created "Trigger2.g" in the "sys" folder and have added "M581 T2 S1 E2 C0" in config.g that will invoke trigger 2 on rising edge on E2 endstop regardless of print status. I have attached a switch to the E2 endstop connector on the dueX5 and when i have the "Trigger2.g" contain just
M42 P100 S255 G4 P10 M42 P100 S0 ```the pin is pulsed, however after adding more commands to the file the commands seem to be interlaced with the print commands and the print doesnt stop. [[language]]
;Switch to relative, lift Z 10 mm and return to absolute.
G90
G1 Z10
G91G1 X100 Y300 F4800; Move to purge location
;Pulse to open the valve
M42 P100 S255
G4 P10
M42 P100 S0G4 S60; Delay for 60 seconds
;Pulse to close the valve
M42 P100 S255
G4 P10
M42 P100 S0G4 S5; Delay for pressure build up
I'm stuck on how to proceed with pausing the print, running commands and then resuming the print properly.
Try to add a M400 command at the beginning of your macro…
Use M25 to pause the print, then do the M42 commands, then
M25M24 to resume the print. -
Resume with M25 or M24?
M24.
