    [3.5.0-rc.3+5] [bug] nested while job Illegal para letter '.'
    DSF Development
    475
    • chrishammundefined
      chrishamm administrators @timschneider
      @timschneider I've got another bug fix ready in case you want to try it.
      Duet software engineer
      timschneiderundefined 1 Reply Last reply Reply Quote 0
      • timschneiderundefined
        timschneider @chrishamm
        @chrishamm
        thank you for the fix !
        the main problem is fixed now, but idk if there is another one.
        If started as a job file it will never terminate, even with an explicit M0 at the end of the .gcode file.
        Mar 06 11:38:42 X: [debug] HTTP: Finished code M23 "0:/macros/test-sbc-3.gcode" => File 0:/macros/test-sbc-3.gcode selected for printing
        Mar 06 11:38:42 X: [debug] IPC#14: Connection closed
        Mar 06 11:38:42 X: [debug] Requesting update of key job, seq 1 -> 3
        Mar 06 11:38:42 X: [debug] Updated key job
        Mar 06 11:38:44 X: [debug] Requesting update of key inputs, seq 30 -> 31
        Mar 06 11:38:44 X: [debug] Updated key inputs
        Mar 06 11:38:44 X: [debug] Requesting update of key inputs, seq 31 -> 32
        Mar 06 11:38:52 X: [debug] Got new UNIX connection via IPC#15, checking permissions...
        Mar 06 11:38:52 X: [debug] IPC#15: Granting full DSF permissions to external plugin
        Mar 06 11:38:52 X: [debug] Command processor added for IPC#15
        Mar 06 11:38:52 X: [debug] IPC#15: Received command SimpleCode
        Mar 06 11:38:52 X: [debug] HTTP: Starting code M24
        Mar 06 11:38:52 X: [debug] Processing M24
        Mar 06 11:38:52 X: [debug] HTTP: Sent M24, remaining space 1512, needed 24
        Mar 06 11:38:52 X: [info] Starting macro file start.g on channel File
        Mar 06 11:38:52 X: [debug] File: Starting code ; start.g  (macro code)
        Mar 06 11:38:52 X: [debug] File: Starting code ; is run when you start a print from SD card. Runs immediately before any slicer created gcode (macro code)
        Mar 06 11:38:52 X: [debug] Processing ; start.g
        Mar 06 11:38:52 X: [debug] File: Starting code M98 P"0:/sys/meltingplot/check_doors_closed" (macro code)
        Mar 06 11:38:52 X: [debug] Processing ; is run when you start a print from SD card. Runs immediately before any slicer created gcode
        Mar 06 11:38:52 X: [debug] Processing M98 P"0:/sys/meltingplot/check_doors_closed"
        Mar 06 11:38:52 X: [debug] File: Finished code ; start.g
        Mar 06 11:38:52 X: [debug] File: Finished code ; is run when you start a print from SD card. Runs immediately before any slicer created gcode
        Mar 06 11:38:52 X: [debug] File: Sent M98 P"0:/sys/meltingplot/check_doors_closed", remaining space 1464, needed 72
        Mar 06 11:38:52 X: [info] Starting macro file start.g on channel File2
        Mar 06 11:38:52 X: [debug] File2: Starting code ; start.g  (macro code)
        Mar 06 11:38:52 X: [debug] File2: Starting code ; is run when you start a print from SD card. Runs immediately before any slicer created gcode (macro code)
        Mar 06 11:38:52 X: [debug] File2: Finished code ; start.g
        Mar 06 11:38:52 X: [debug] File2: Finished code ; is run when you start a print from SD card. Runs immediately before any slicer created gcode
        Mar 06 11:38:52 X: [debug] File2: Starting code M98 P"0:/sys/meltingplot/check_doors_closed" (macro code)
        Mar 06 11:38:52 X: [debug] File2: Sent M98 P"0:/sys/meltingplot/check_doors_closed", remaining space 1464, needed 72
        Mar 06 11:38:52 X: [info] Starting macro file 0:/sys/meltingplot/check_doors_closed on channel File
        Mar 06 11:38:52 X: [debug] File: ==> Starting code M98 P"0:/sys/meltingplot/check_doors_closed"
        Mar 06 11:38:52 X: [debug] HTTP: Finished code M24 =>
        Mar 06 11:38:52 X: [info] Starting file print
        Mar 06 11:38:52 X: [debug] IPC#15: Connection closed
        Mar 06 11:38:52 X: [info] Starting macro file 0:/sys/meltingplot/check_doors_closed on channel File2
        Mar 06 11:38:52 X: [debug] File2: ==> Starting code M98 P"0:/sys/meltingplot/check_doors_closed"
        Mar 06 11:38:52 X: [debug] Evaluating While block
        Mar 06 11:38:52 X: [debug] Evaluating (sensors.gpIn[2].value == 0 || sensors.gpIn[3].value == 0 ) on channel File
        Mar 06 11:38:52 X: [debug] Evaluating (sensors.gpIn[2].value == 0 || sensors.gpIn[3].value == 0 ) on channel File2
        Mar 06 11:38:52 X: [debug] Evaluation result: ((sensors.gpIn[2].value == 0 || sensors.gpIn[3].value == 0 )) = False
        Mar 06 11:38:52 X: [debug] End of While block
        Mar 06 11:38:52 X: [debug] Finished codes from macro file 0:/sys/meltingplot/check_doors_closed
        Mar 06 11:38:52 X: [info] Finished macro file 0:/sys/meltingplot/check_doors_closed
        Mar 06 11:38:52 X: [debug] File: ==> Unfinished starting code: M98 P"0:/sys/meltingplot/check_doors_closed"
        Mar 06 11:38:52 X: [debug] File: Finished code M98 P"0:/sys/meltingplot/check_doors_closed"
        Mar 06 11:38:52 X: [debug] Requesting update of key inputs, seq 32 -> 36
        Mar 06 11:38:52 X: [debug] Finished codes from macro file start.g
        Mar 06 11:38:52 X: [info] Finished macro file start.g
        Mar 06 11:38:52 X: [debug] File: Disposing macro file 0:/sys/meltingplot/check_doors_closed
        Mar 06 11:38:52 X: [debug] File2: ==> Unfinished starting code: M98 P"0:/sys/meltingplot/check_doors_closed"
        Mar 06 11:38:52 X: [debug] File2: Disposing macro file 0:/sys/meltingplot/check_doors_closed
        Mar 06 11:38:52 X: [debug] File2: Finished code M98 P"0:/sys/meltingplot/check_doors_closed"
        Mar 06 11:38:52 X: [debug] File: Disposing macro file start.g
        Mar 06 11:38:52 X: [debug] Evaluating If block
        Mar 06 11:38:52 X: [debug] Evaluating !inputs[state.thisInput].active on channel File
        Mar 06 11:38:52 X: [debug] Updated key inputs
        Mar 06 11:38:52 X: [debug] Requesting update of key job, seq 3 -> 4
        Mar 06 11:38:52 X: [debug] File2: Disposing macro file start.g
        Mar 06 11:38:52 X: [debug] Evaluating !inputs[state.thisInput].active on channel File2
        Mar 06 11:38:52 X: [debug] Evaluation result: (!inputs[state.thisInput].active) = False
        Mar 06 11:38:52 X: [debug] Updated key job
        Mar 06 11:38:52 X: [debug] End of If block
        Mar 06 11:38:52 X: [debug] File: Starting code var x = 0
        Mar 06 11:38:52 X: [debug] File: Starting code var y = 1
        Mar 06 11:38:52 X: [debug] File: Starting code var N = 5
        Mar 06 11:38:52 X: [debug] Processing var x = 0
        Mar 06 11:38:52 X: [debug] Setting variable var.x to 0 on channel File
        Mar 06 11:38:52 X: [debug] Evaluation result: (!inputs[state.thisInput].active) = True
        Mar 06 11:38:52 X: [debug] File2: Starting code M0
        Mar 06 11:38:52 X: [debug] Processing M0
        Mar 06 11:38:52 X: [debug] File2: Starting code var x = 0
        Mar 06 11:38:52 X: [debug] File2: Starting code var y = 1
        Mar 06 11:38:52 X: [debug] File2: Starting code var N = 5
        Mar 06 11:38:52 X: [debug] Set variable var.x to 0
        Mar 06 11:38:52 X: [debug] Processing var y = 1
        Mar 06 11:38:52 X: [debug] Setting variable var.y to 1 on channel File
        Mar 06 11:38:52 X: [debug] File: Finished code var x = 0 =>
        Mar 06 11:38:52 X: [debug] Set variable var.y to 1
        Mar 06 11:38:52 X: [debug] Processing var N = 5
        Mar 06 11:38:52 X: [debug] File: Finished code var y = 1 =>
        Mar 06 11:38:52 X: [debug] Setting variable var.N to 5 on channel File
        Mar 06 11:38:52 X: [debug] Set variable var.N to 5
        Mar 06 11:38:52 X: [debug] Evaluating var.x < var.y on channel File
        Mar 06 11:38:52 X: [debug] File: Finished code var N = 5 =>
        Mar 06 11:38:52 X: [debug] Evaluation result: (var.x < var.y) = True
        Mar 06 11:38:52 X: [debug] File: Starting code var i = 0
        Mar 06 11:38:52 X: [debug] Processing var i = 0
        Mar 06 11:38:52 X: [debug] Setting variable var.i to 0 on channel File
        Mar 06 11:38:52 X: [debug] Set variable var.i to 0
        Mar 06 11:38:52 X: [debug] File: Finished code var i = 0 =>
        Mar 06 11:38:52 X: [debug] Evaluating var.i < var.N on channel File
        Mar 06 11:38:52 X: [debug] Requesting update of key inputs, seq 36 -> 44
        Mar 06 11:38:52 X: [debug] Evaluation result: (var.i < var.N) = True
        Mar 06 11:38:52 X: [debug] File: Starting code echo "var.i = " ^ var.i
        Mar 06 11:38:52 X: [debug] Processing echo "var.i = " ^ var.i
        Mar 06 11:38:52 X: [debug] Evaluating "var.i = " ^ var.i on channel File
        Mar 06 11:38:52 X: [debug] File: Starting code echo "var.N = " ^ var.N
        Mar 06 11:38:52 X: [debug] Processing echo "var.N = " ^ var.N
        Mar 06 11:38:52 X: [debug] Evaluating "var.N = " ^ var.N on channel File
        Mar 06 11:38:52 X: [info] var.i = 0
        Mar 06 11:38:52 X: [debug] File: Finished code echo "var.i = " ^ var.i => var.i = 0
        Mar 06 11:38:52 X: [info] var.N = 5
        Mar 06 11:38:52 X: [debug] Evaluating var.i > 2 on channel File
        Mar 06 11:38:52 X: [debug] File: Finished code echo "var.N = " ^ var.N => var.N = 5
        Mar 06 11:38:52 X: [debug] Evaluation result: (var.i > 2) = False
        Mar 06 11:38:52 X: [debug] Evaluating var.i > 5 on channel File
        Mar 06 11:38:53 X: [debug] Evaluation result: (var.i > 5) = False
        Mar 06 11:38:53 X: [debug] End of If block
        Mar 06 11:38:53 X: [debug] File: Starting code set var.i = var.i + 1
        Mar 06 11:38:53 X: [debug] Processing set var.i = var.i + 1
        Mar 06 11:38:53 X: [debug] Setting variable var.i to var.i + 1 on channel File
        Mar 06 11:38:53 X: [debug] Set variable var.i to 1
        Mar 06 11:38:53 X: [debug] File: Finished code set var.i = var.i + 1 =>
        Mar 06 11:38:53 X: [debug] Restarting While block, iterations = 1
        Mar 06 11:38:53 X: [debug] Evaluating While block
        Mar 06 11:38:53 X: [debug] Evaluating var.i < var.N on channel File
        Mar 06 11:38:53 X: [debug] Evaluation result: (var.i < var.N) = True
        Mar 06 11:38:53 X: [debug] File: Starting code echo "var.i = " ^ var.i
        Mar 06 11:38:53 X: [debug] File: Starting code echo "var.N = " ^ var.N
        Mar 06 11:38:53 X: [debug] Processing echo "var.i = " ^ var.i
        Mar 06 11:38:53 X: [debug] Evaluating "var.i = " ^ var.i on channel File
        Mar 06 11:38:53 X: [debug] Processing echo "var.N = " ^ var.N
        Mar 06 11:38:53 X: [info] var.i = 1
        Mar 06 11:38:53 X: [debug] Evaluating "var.N = " ^ var.N on channel File
        Mar 06 11:38:53 X: [debug] File: Finished code echo "var.i = " ^ var.i => var.i = 1
        Mar 06 11:38:53 X: [info] var.N = 5
        Mar 06 11:38:53 X: [debug] Evaluating If block
        Mar 06 11:38:53 X: [debug] File: Finished code echo "var.N = " ^ var.N => var.N = 5
        Mar 06 11:38:53 X: [debug] Evaluating var.i > 2 on channel File
        Mar 06 11:38:53 X: [debug] Evaluation result: (var.i > 2) = False
        Mar 06 11:38:53 X: [debug] Evaluating var.i > 5 on channel File
        Mar 06 11:38:53 X: [debug] Set variable var.i to 2
        Mar 06 11:38:53 X: [debug] Restarting While block, iterations = 2
        Mar 06 11:38:53 X: [info] var.i = 2
        Mar 06 11:38:53 X: [debug] File: Finished code echo "var.i = " ^ var.i => var.i = 2
        Mar 06 11:38:53 X: [debug] Set variable var.i to 3
        Mar 06 11:38:53 X: [debug] Restarting While block, iterations = 3
        Mar 06 11:38:54 X: [info] var.i = 3
        Mar 06 11:38:54 X: [debug] File: Finished code echo "var.i = " ^ var.i => var.i = 3
        Mar 06 11:38:54 X: [debug] Processing echo "var.N = " ^ var.N
        Mar 06 11:38:54 X: [debug] Evaluating "var.N = " ^ var.N on channel File
        Mar 06 11:38:54 X: [info] var.N = 5
        Mar 06 11:38:54 X: [debug] Evaluating If block
        Mar 06 11:38:54 X: [debug] File: Finished code echo "var.N = " ^ var.N => var.N = 5
        Mar 06 11:38:54 X: [debug] Evaluating var.i > 2 on channel File
        Mar 06 11:38:54 X: [debug] Evaluation result: (var.i > 2) = True
        Mar 06 11:38:54 X: [debug] File: Starting code set var.N = var.i
        Mar 06 11:38:54 X: [debug] Processing set var.N = var.i
        Mar 06 11:38:54 X: [debug] Setting variable var.N to var.i on channel File
        Mar 06 11:38:54 X: [debug] End of If block
        Mar 06 11:38:54 X: [debug] Set variable var.N to 3
        Mar 06 11:38:54 X: [debug] Evaluating var.i > 5 on channel File
        Mar 06 11:38:54 X: [debug] File: Finished code set var.N = var.i =>
        Mar 06 11:38:54 X: [debug] Evaluation result: (var.i > 5) = False
        Mar 06 11:38:54 X: [debug] File: Starting code set var.i = var.i + 1
        Mar 06 11:38:54 X: [debug] Processing set var.i = var.i + 1
        Mar 06 11:38:54 X: [debug] Setting variable var.i to var.i + 1 on channel File
        Mar 06 11:38:54 X: [debug] Set variable var.i to 4
        Mar 06 11:38:54 X: [debug] File: Finished code set var.i = var.i + 1 =>
        Mar 06 11:38:54 X: [debug] Restarting While block, iterations = 4
        Mar 06 11:38:54 X: [debug] Evaluating While block
        Mar 06 11:38:54 X: [debug] Evaluating var.i < var.N on channel File
        Mar 06 11:38:54 X: [debug] Evaluation result: (var.i < var.N) = False
        Mar 06 11:38:54 X: [debug] End of While block
        Mar 06 11:38:54 X: [debug] File: Starting code set var.x = var.x + 1
        Mar 06 11:38:54 X: [debug] Processing set var.x = var.x + 1
        Mar 06 11:38:54 X: [debug] Setting variable var.x to var.x + 1 on channel File
        Mar 06 11:38:54 X: [debug] Set variable var.x to 1
        Mar 06 11:38:54 X: [debug] End of generic block
        Mar 06 11:38:54 X: [debug] File: Finished code set var.x = var.x + 1 =>
        Mar 06 11:38:54 X: [debug] Deleting local variable i on channel File
        Mar 06 11:38:54 X: [debug] Restarting While block, iterations = 1
        Mar 06 11:38:54 X: [debug] Evaluating var.x < var.y on channel File
        Mar 06 11:38:54 X: [debug] Evaluation result: (var.x < var.y) = False
        Mar 06 11:38:54 X: [debug] File: Starting code M0
        Mar 06 11:38:54 X: [debug] Processing M0
        Mar 06 11:38:54 X: [debug] Requesting update of key inputs, seq 44 -> 46
        Mar 06 11:38:54 X: [debug] Updated key inputs
        Mar 06 11:39:00 X: [debug] Requesting update of key boards, seq 166 -> 167
        Mar 06 11:39:00 X: [debug] Updated key boards
        Mar 06 11:39:04 X: [debug] Requesting update of key inputs, seq 46 -> 48
        Mar 06 11:39:04 X: [debug] Updated key inputs
        Mar 06 11:39:14 X: [debug] Requesting update of key inputs, seq 48 -> 50
        Mar 06 11:39:14 X: [debug] Updated key inputs
          timschneider @timschneider
          @timschneider
          and when I pause and cancle the printjob, it appears that the printjob is not cancled - I'm not able to re-run a printjob without a restart of DCS.
          Mar 06 11:44:45 X: [debug] HTTP: Starting code M25
          Mar 06 11:44:45 X: [debug] Processing M25
          Mar 06 11:44:45 X: [debug] HTTP: Sent M25, remaining space 1512, needed 24
          Mar 06 11:44:45 X: [debug] Opening 0:/sys/resurrect.g for writing (not appending), prealloc 0
          Mar 06 11:44:45 X: [debug] File 0:/sys/resurrect.g opened with handle #2
          Mar 06 11:44:45 X: [debug] Closing file #2
          Mar 06 11:44:45 X: [info] Resume state saved
          Mar 06 11:44:45 X: [debug] HTTP: Finished code M25 => Printing paused at X0.0 Y0.0 Z0.0
          Mar 06 11:44:45 X: [debug] IPC#16: Connection closed
          Mar 06 11:44:45 X: [debug] Received print pause notification for file position 0, reason User
          Mar 06 11:44:45 X: [debug] Requesting update of key inputs, seq 114 -> 115
          Mar 06 11:44:46 X: [debug] Updated key inputs
          Mar 06 11:44:46 X: [debug] Requesting update of key state, seq 5 -> 6
          Mar 06 11:44:46 X: [debug] Updated key state
          Mar 06 11:44:46 X: [debug] Requesting update of key volumes, seq 1 -> 2
          Mar 06 11:44:46 X: [debug] Updated key volumes
          Mar 06 11:44:46 X: [debug] Requesting update of key inputs, seq 115 -> 116
          Mar 06 11:44:49 X: [debug] Got new UNIX connection via IPC#17, checking permissions...
          Mar 06 11:44:49 X: [debug] IPC#17: Granting full DSF permissions to external plugin
          Mar 06 11:44:49 X: [debug] Command processor added for IPC#17
          Mar 06 11:44:49 X: [debug] IPC#17: Received command SimpleCode
          Mar 06 11:44:49 X: [debug] HTTP: Starting code M0
          Mar 06 11:44:49 X: [debug] Processing M0
          Mar 06 11:44:49 X: [debug] HTTP: Sent M0, remaining space 1512, needed 24
          Mar 06 11:44:49 X: [info] Cancelled printing file 0:/macros/test-sbc-3.gcode, print time was 0h 5m
          Mar 06 11:44:49 X: [info] Starting macro file cancel.g on channel HTTP
          Mar 06 11:44:49 X: [debug] HTTP: ==> Starting code M0
          Mar 06 11:44:49 X: [debug] HTTP: Starting code ; cancel.g (macro code)
          Mar 06 11:44:49 X: [debug] HTTP: Starting code ; called when a print is cancelled after a pause. (macro code)
          Mar 06 11:44:49 X: [debug] Processing ; cancel.g
          Mar 06 11:44:49 X: [debug] HTTP: Finished code ; cancel.g
          Mar 06 11:44:49 X: [debug] Processing ; called when a print is cancelled after a pause.
          Mar 06 11:44:49 X: [debug] HTTP: Finished code ; called when a print is cancelled after a pause.
          Mar 06 11:44:49 X: [debug] HTTP: Starting code ;if move.axes[2].homed (macro code)
          Mar 06 11:44:49 X: [debug] HTTP: Starting code G10 ; retract filament (macro code)
          Mar 06 11:44:49 X: [debug] HTTP: Starting code G10 P0 R0 S0 ; disable heater (macro code)
          Mar 06 11:44:49 X: [debug] HTTP: Starting code M140 P0 S0 ; disable bed heater (macro code)
          Mar 06 11:44:49 X: [debug] HTTP: Starting code M107 ; disable fan (macro code)
          Mar 06 11:44:49 X: [debug] HTTP: Starting code G90 ; absolute position (macro code)
          Mar 06 11:44:49 X: [debug] Processing ;if move.axes[2].homed
          Mar 06 11:44:49 X: [debug] HTTP: Finished code ;if move.axes[2].homed
          Mar 06 11:44:49 X: [debug] Processing G10 ; retract filament
          Mar 06 11:44:49 X: [debug] Processing G10 P0 R0 S0 ; disable heater
          Mar 06 11:44:49 X: [debug] Processing M140 P0 S0 ; disable bed heater
          Mar 06 11:44:49 X: [debug] Processing M107 ; disable fan
          Mar 06 11:44:49 X: [debug] Processing G90 ; absolute position
          Mar 06 11:44:49 X: [debug] HTTP: Sent G10 ; retract filament, remaining space 1512, needed 24
          Mar 06 11:44:49 X: [debug] HTTP: Sent G10 P0 R0 S0 ; disable heater, remaining space 1464, needed 48
          Mar 06 11:44:49 X: [debug] HTTP: Sent M140 P0 S0 ; disable bed heater, remaining space 1424, needed 40
          Mar 06 11:44:49 X: [debug] HTTP: Sent M107 ; disable fan, remaining space 1400, needed 24
          Mar 06 11:44:49 X: [debug] HTTP: Sent G90 ; absolute position, remaining space 1376, needed 24
          Mar 06 11:44:49 X: [debug] HTTP: Finished code G10 ; retract filament
          Mar 06 11:44:49 X: [debug] HTTP: Finished code G10 P0 R0 S0 ; disable heater
          Mar 06 11:44:49 X: [debug] HTTP: Finished code M140 P0 S0 ; disable bed heater
          Mar 06 11:44:49 X: [debug] HTTP: Finished code M107 ; disable fan
          Mar 06 11:44:50 X: [debug] Evaluating If block
          Mar 06 11:44:50 X: [debug] Evaluating (sensors.gpIn[2].value == 1 && sensors.gpIn[3].value == 1 ) on channel HTTP
          Mar 06 11:44:50 X: [debug] HTTP: Finished code G90 ; absolute position
          Mar 06 11:44:50 X: [debug] Evaluation result: ((sensors.gpIn[2].value == 1 && sensors.gpIn[3].value == 1 )) = True
          Mar 06 11:44:50 X: [debug] HTTP: Starting code G91 ; relative (macro code)
          Mar 06 11:44:50 X: [debug] Processing G91 ; relative
          Mar 06 11:44:50 X: [debug] HTTP: Sent G91 ; relative, remaining space 1512, needed 24
          Mar 06 11:44:50 X: [debug] HTTP: Finished code G91 ; relative
          Mar 06 11:44:50 X: [debug] Evaluating move.axes[2].homed on channel HTTP
          Mar 06 11:44:50 X: [debug] Evaluation result: (move.axes[2].homed) = False
          Mar 06 11:44:50 X: [debug] End of If block
          Mar 06 11:44:50 X: [debug] Finished codes from macro file cancel.g
          Mar 06 11:44:50 X: [info] Finished macro file cancel.g
          Mar 06 11:44:50 X: [debug] Requesting update of key inputs, seq 116 -> 119
          Mar 06 11:44:50 X: [debug] HTTP: ==> Unfinished starting code: M0
          Mar 06 11:44:50 X: [debug] HTTP: Disposing macro file cancel.g
          Mar 06 11:44:50 X: [debug] HTTP: Finished code M0 =>
          Mar 06 11:44:50 X: [debug] IPC#17: Connection closed
          Mar 06 11:44:50 X: [debug] Updated key inputs
          Mar 06 11:44:50 X: [debug] Requesting update of key job, seq 4 -> 5
          Mar 06 12:05:28 Meltingplot-MBL-480-vaswsq DuetControlServer[16205]: [debug] HTTP: Starting code M23 "0:/macros/test-sbc-3.gcode"
          Mar 06 12:05:28 Meltingplot-MBL-480-vaswsq DuetControlServer[16205]: [debug] Processing M23 "0:/macros/test-sbc-3.gcode"
          Mar 06 12:05:28 Meltingplot-MBL-480-vaswsq DuetControlServer[16205]: [debug] HTTP: Finished code M23 "0:/macros/test-sbc-3.gcode" => Error: M23: Cannot set file to print, because a file is already being printed
            @timschneider I'm sorry but I cannot reproduce it here, print jobs complete/pause/cancel just as expected on my machine. Is it possible that you call M0 from channel File but not File2 e.g. from a macro file or other conditionals? That could indeed lead to problems. If not, please share the output of M122 when the machine appears to have finished but it doesn't let you start another print.
              @chrishamm
              ok double checked it.
              the following will not work / will just stuck
              if !inputs[state.thisInput].active
                M0
              var x = 0
              var y = 1
              var N = 5
              while var.x < var.y
                var i = 0
                while var.i < var.N
                  if var.i > 2
                    set var.N = var.i
                  if var.i > 5
                    break
              G90
              G1 X100 F6000
              G1 Y100
              G1 X200 Y200
              M0
              and the following will work
                M99
              var x = 0
              var y = 1
              var N = 5
              while var.x < var.y
                var i = 0
                while var.i < var.N
                  if var.i > 2
                    set var.N = var.i
                  if var.i > 5
                    break
              G90
              G1 X100 F6000
              G1 Y100
              G1 X200 Y200
              M0
              see the M0 at the beginning for the inactive channel.
              ok another test revealed that is has something to do with the while code block, which is preventing it from cleaning the print job.
                M99
              M18 X
              G90
              G1 X10 ; not possible due to unhomed x axis
              M0
              and the following is not working / you will be unable to restart the print (it sometimes works / then just repeat)
              caution: even the E-Stop via DWC will stuck - be delayed!
                M99
              var x = 0
              var y = 1
              var N = 5
              while var.x < var.y
                var i = 0
                while var.i < var.N
                  if var.i > 2
                    set var.N = var.i
                  if var.i > 5
                    break
              M18 X
              G90
              M0
              sorry but I'm unable to get an M122 of the above code, due to the fact, that DCS is stuck.
              Error: Failed to connect to Duet, please check your connection (DCS is not started)
              Mar 06 14:14:56 Meltingplot-MBL-480-vaswsq DuetControlServer[26336]: [warn] Received SIGTERM, shutting down...
              Mar 06 14:15:00 Meltingplot-MBL-480-vaswsq DuetControlServer[26336]: [fatal] Regular shutdown failed, proceeding with unconditional program termination
              Mar 06 14:15:01 Meltingplot-MBL-480-vaswsq systemd[1]: duetcontrolserver.service: Main process exited, code=exited, status=70/SOFTWARE
              M122
              RepRapFirmware for Duet 3 MB6HC version 3.5.0-rc.3+6 (2024-03-01 12:32:32) running on Duet 3 MB6HC v1.02 or later (SBC mode)
              Board ID: 08DJM-9P63L-DJ3T8-6JKD4-3SJ6K-9A77A
              Used output buffers: 1 of 40 (17 max)
              Static ram: 155208
              Dynamic ram: 88404 of which 4328 recycled
              Never used RAM 95196, free system stack 204 words
              Tasks: SBC(2,ready,0.4%,414) HEAT(3,nWait 6,0.0%,323) Move(4,nWait 6,0.0%,336) CanReceiv(6,nWait 1,0.0%,940) CanSender(5,nWait 7,0.0%,334) CanClock(7,delaying,0.0%,336) TMC(4,nWait 6,8.4%,56) MAIN(2,running,91.0%,103) IDLE(0,ready,0.2%,30), total 100.0%
              Owned mutexes: HTTP(MAIN)
              Last reset 00:08:06 ago, cause: software
              Last software reset at 2024-03-06 14:00, reason: User, Gcodes spinning, available RAM 94716, slot 1
              Software reset code 0x6003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
              Error status: 0x00
              MCU temperature: min 32.6, current 32.9, max 34.8
              Supply voltage: min 24.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
              12V rail voltage: min 11.8, current 12.3, max 12.8, under voltage events: 0
              Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/440/440, gc cycles 0
              Events: 0 queued, 0 completed
              Driver 0: standstill, SG min n/a, mspos 296, reads 10168, writes 22 timeouts 0
              Driver 1: standstill, SG min n/a, mspos 248, reads 10168, writes 22 timeouts 0
              Driver 2: standstill, SG min n/a, mspos 168, reads 10169, writes 21 timeouts 0
              Driver 3: standstill, SG min n/a, mspos 936, reads 10169, writes 21 timeouts 0
              Driver 4: standstill, SG min n/a, mspos 680, reads 10169, writes 21 timeouts 0
              Driver 5: standstill, SG min n/a, mspos 804, reads 10171, writes 19 timeouts 0
              Date/time: 2024-03-06 14:08:31
              Slowest loop: 66.36ms; fastest: 0.06ms
              === Storage ===
              Free file entries: 20
              DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
              no step interrupt scheduled
              Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
              === DDARing 0 ===
              === DDARing 1 ===
              Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
              Telnet is idle in state(s) 0
              File* is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              SBC* is idle in state(s) 0
              Daemon is idle in state(s) 0
              Aux2 is idle in state(s) 0
              File2* is idle in state(s) 0
              Queue2 is idle in state(s) 0
              Q0 segments left 0, axes/extruders owned 0x0000001
              Code queue 0 is empty
              Code queue 1 is empty
              === Filament sensors ===
              check 31279 clear 4266391
              Extruder 0: pos 2160.00, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
              === CAN ===
              Messages queued 4333, received 0, lost 0, errs 2298737, boc 0
              Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 2435/0/0
              Tx timeouts 0,0,2434,0,0,1897 last cancelled message type 4514 dest 127
              === SBC interface ===
              Transfer state: 5, failed transfers: 0, checksum errors: 0
              RX/TX seq numbers: 4628/4628
              SPI underruns 0, overruns 0
              State: 5, disconnects: 1, timeouts: 1 total, 1 by SBC, IAP RAM available 0x255b4
              Buffer RX/TX: 0/0-0, open files: 0
              === Duet Control Server ===
              Duet Control Server version 3.5.0-rc.3+7 (2024-03-06 11:22:55, 32-bit)
              Failed to deserialize the following properties:
              - MoveSegmentation -> Int32 from 2.0
              Code buffer space: 4096
              Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
              Full transfers per second: 40.79, max time between full transfers: 54.2ms, max pin wait times: 37.8ms/3.0ms
              Codes per second: 0.02
              Maximum length of RX/TX data transfers: 4349/48
              https://streamable.com/u9d4i9
                @timschneider said in [3.5.0-rc.3+5] [bug] nested while job Illegal para letter '.':
                Hence my question from the previous post. M0 attempts to synchronize both file streams but since File2 never reaches it due to your check, it leads to a deadlock. I'm going to investigate why it might delay E-STOP, though.
                You should never call M0/M1/M2/M24/M25/M32 from a single file channel only.
                Even without your condition at the top the file should behave like a macro.
                  @chrishamm
                  ok, I missunderstood the concept of the two channels at all I guess - I thought if if tell channel File2 to leave/stop the file, it will just stop working as I do not utilize multiple motion systems, but in fact it turned out to do the opposit.
                  Anyhow the second example from above which will also fail is not using the conditional M0 as shown above.
                  Unfortunately, I cannot provide any further information from the journal this time, as there is no information / exceptions - it is just sitting in a dead lock 🙂
                  chrishammundefined 2 Replies Last reply Reply Quote 0
                    @timschneider If you do not use two motion systems you should not worry about File2 at all.
                    There was a recent bug which could lead to abort being executed even on an inactive file channel (aka File2) and the if-statement at the start of your files above (at least followed only by M99) was meant to work-around this particular case. But it won't be needed in the next versions either.
                    I could reproduce the deadlock that you managed to provoke and I am working on a fix. I'll keep you posted.
                      @timschneider This is now fixed as well.
                        @chrishamm
                        Thanks for the great patch! Your work is outstanding! It's impressive to see the passion and dedication you and the duet3d team put into the software and hardware!
                        Now that all the show-stoppers are out of the way, we are going to switch completely to duet3 in the sbc setup. Starting with 4 closed loop steppers with 4 1HCL and 4 open loop steppers directly on the 6HC. Also two filament monitors and two IR probes per machine. This will be followed at a later stage by two tool boards and a distribution board per machine. I am excited to see the results.
                        1 Reply Last reply Reply Quote 4
                        • droftartsundefined droftarts marked this topic as a question
                        • droftartsundefined droftarts has marked this topic as solved
