    Endstop help
    • rs4raceundefined
      rs4race
      Im using a LJ12A3-4-Z/BX inductive sensor for my z max endstop. I have it wired to an always on fan pin, and the signal thru a diode to the z endstop connector. It lights up when triggered and the light by the z axis driver lights up as well. Theres no change when m119 is sent.
      Am I missing something? I've tried setting m574 z2 s1 and s0 but there is no change when the sensor is triggered.
        What type of diode are you using? Others have found that an ordinary silicon diode doesn't pull the endstop pin low enough and you need to use a Schottky diode.
        • rs4raceundefined
          rs4race
          I am using "FAIRCHILD SEMICONDUCTOR 1N4148TA DIODE, ULTRAFAST RECOVERY, 300mA, 100V, DO-204AH"
          I beleive I bought this based off info here but it was a long time ago. I read somewhere else last night to hook sensor ground and signal to the endstop pins. I currently have ground and power hooked to an always on fan channel. Could this be it?
          • darkorbzundefined
            darkorbz
            I'm using a LJ12A3-4-Z/BY (PNP with a diode similar to yours), on my printer:
            M574 X1 Y1 S0 ; Set active low endstops
            M574 Z1 S0 ; Set endstops controlled by probe
            M558 P3 H5 F120 T6000 ; Set Z probe type to modulated and the dive height + speeds
            G31 P250 X16 Y30 Z0.5 ; Set Z probe trigger value, offset and trigger height
              @rs4race:
              Try a Schottky diode instead as recommended at https://duet3d.com/wiki/Connecting_a_Z_probe#NPN_output_normally-open_inductive_or_capacitive_sensor.
              • rs4raceundefined
                rs4race
                Thanks again! The Schottky diode works.
                To sum things up. The 1N4148TA diode didnt work.
                I Wired the LJ12A3-4-Z/BX inductive sensor as follows:
                Power wires to always on fan channel (24V)
                Blue is Ground
                Brown is 24V
                Signal wire to Z stop pin of Z stop Connector
                Black - (Cathode) Schottky Diode - Z stop pin
                In config I set
                M574 Z2 S0 ; z axis homes in positive direction active low
                And my Z home file
                G91 ; Relative positioning
                G1 Z200 F420 S1 ; Move quickly to endstop
                G1 Z-2 ; Back off of endstop
                G1 Z3 F60 S1 ; Move slowly to endstop
                G92 Z186.5 ; Set Z axis position
                G90 ; Absolute positioning
                I hope this will help anyone with the same question.
