    Pellet extruder on delta WIP
    • edo_drumundefined
      edo_drum
      hi, I have to mount a pellet extruder on my delta, I have a question, on e0 or e1 can I put a 10A resistance? or should I use the heated bed slot?
      • DjDemonDundefined
        DjDemonD
        I'd say 5-6A is probably the most you want to put through e0 or e1. Heated bed is around 18A,or consider some external device like mosfet, relay or ssr.
        www.precisionpiezo.co.uk
          I agree. The mosfets can take 10A, but the terminal blocks and PCB traces can't.
          • edo_drumundefined
            edo_drum
            thanks for the answer, then I prefer to put a mosfet, do you know if this mosfet is okay or do I need something else?
            https://www.amazon.co.uk/Hrph-Printer-Heated-Current-upgrade/dp/B06ZYQN6VQ/ref=sr_1_1?ie=UTF8&qid=1514405067&sr=8-1&keywords=mosfet
