    IDEX HOMING ISSUES
    Firmware installation
    657
      deckingman @Rollux
      @Rollux If all the individual homing files work, then you could call them individually for home all.
      e.g. homeall could be..........
      M98 P"homex.g"
      M98 P"homeu.g"
      M98 P "homey.g"
      M98 P"homez.g"
      Try that - if it works, then the problem is with your homeall.g, if it doesn't then the problem is elsewhere.
      Rolluxundefined 1 Reply Last reply Reply Quote 0
      • Rolluxundefined
        Rollux @deckingman
        @deckingman
        Success there on the first try. Then move everything around and try again. X and U axis home perfectly. . Y axis jumps and then does nothing and get the following error: Error: in file macro line 17: M98: expected a string expression.
        Going to have a look at the y axis endstop
        m119
        Endstops - X: at min stop, Y: at min stop, Z: no endstop, U: at max stop, Z probe: not stopped
        As it is one the "pcb board" style ones, wondering if it has failed but that doesnt explain why it works once or twice then nothing.
        • Rolluxundefined
          Rollux @Rollux
          Replaced the endstop with a pare makerbot pcb style. Same issue. Check wiring, all is good. Hard reset. All homed perfectly, repeatedly. Then back to the same issue of the y axis bumping in the opposite direction if the end stop and failing to home.
          • Rolluxundefined
            Rollux @Rollux
            "Home all" using individual axis works as expected. However, homing individual axis via dwc or panel due, Y axis does not want to work. Incredibly confusing.
            • Rolluxundefined
              Rollux @Rollux
              Current homeall.g
              This works somewhat, the U axis homes after x,y,z regardless of U axis position.
              Also when homing z, the z jumps up and down and the x and y jump around. Video Attached of whats happening.
              G91                               ; relative positioning
              G1 H2 Z5 F6000                    ; lift Z relative to current position
              G1 H1 X-450 F5000        ; move quickly to X Y and U axis endstops and stop there (first pass)
              G1 H1 U0 F5000
              G1 H1 Y-450 F5000
              G1 H2 X5 F6000             ; go back a few mm
              G1 H2 U-5 F6000
              G1 H2 Y5 F6000
              G1 H1 X-450 F360         ; move slowly to X Y and U axis endstops once more (second pass)
              G1 H1 U0 F360
              G1 H1 Y-450 F360
              G1 F6000 X243 Y200
              G30
              G90                               ; absolute positioning
              G29 S1                            ; this loads the contents of /sys/heightmap.csv
              [Home All.mp4](/assets/uploads/files/1717502002687-home-all.mp4)
              • Rolluxundefined
                Rollux @Rollux
                Home All.mp4
                Proschi3Dundefined 1 Reply Last reply Reply Quote 0
                • Proschi3Dundefined
                  Proschi3D @Rollux
                  @Rollux
                  It looks to me like the mesh bed compensation is going on a total roller coaster ride. Can you disable it before homing
                  Love my Duet 3 Mini.
                  https://www.instagram.com/proschi3d
                  https://youtube.com/@proschi3d
                  https://www.proschi3d.de
                    Proschi3D @Proschi3D
                    @Proschi78 said in IDEX HOMING ISSUES:
                    @Rollux
                    try this as homeall
                    Can you take over the code with copy paste for homeall that I posted here?
                    M561
                    G91
                    G1 H2 Z5 F6000               ; raise head 4mm to keep it clear of the bed
                    G1 H1 X-450 Y-450 U0 F3000 ; coarse home X, Y and U
                    G1 X5 Y5 U-5 F3000           ; move 4mm away from the homing switches
                    G1 H1 X-400 Y-430 U0 F600      ; fine home X, Y and U
                    ; Now home Z using the Z probe
                    G1 X243 Y200 F3000  ; move to bed centre for probing
                    G30 ; probe the bed and set Z height
                    G1 x-450 y-430 U0 F3000
                    G29 S1
                    Rolluxundefined 2 Replies Last reply Reply Quote 0
                    • Rolluxundefined
                      Rollux @Proschi3D
                      @Proschi78 Will give this a try tomorrow, unable to connect to the printer at the moment as having internet/router issues and pc vs printer location makes ethernet connection not viable.
                      • Rolluxundefined
                        Rollux @Proschi3D
                        @Proschi78
                        Tried the above and the movement behaviour became consistently erratic. Not sure as to why. Reverted back to the below and seems to be have "settled" to a somewhat normal behaviour. Potentially might reset the mbh6c and expansion board back to square one. Potentially the firmware updates may have left some things stuck which shouldnt be the case but never know as all the boards were still on 3.2 beta firmware when started up this time round.
                        M561
                        G1 H1 U0 F5000
                        G1 H1 Y-450 F5000
                        G1 H2 U-5 F6000
                        G1 H2 Y5 F6000
                        G1 H1 U0 F360
                        G1 H1 Y-450 F360
                        G1 F6000 X243 Y200
                        G30
