    Slicers and Tools with multiple heaters
    Gcode meta commands
    • Makergal3Dundefined
      Makergal3D
      So I was looking for the forum but I couldn't find information related to this.
      I had a machine with a Pulsar from dyze, that has 3 heaters for 1 extruder. When I send something to print all the heaters use the same temperature. But if I want to select one temperature for each section of the extruder, I was doing it manually deleting the M104 from the start gcode manually, because I can find a way to do it automatically in the slicer.
      There is any Mcode I can use in the start gcode to do this??
      Or should I set the slicer like is has 3 extruders. And create diferent filament profiles for each heater??
      Best
      Alvaro
        T3P3Tony administrators @Makergal3D
        @Makergal3D If you want to set the heaters individually, then ideally using M568 in your start gcode in place of M104 is the way to do this. I understand that support for this is not yet implemented in slicers, let alone a way to capture that a material ("filament") profile has more than one temperature specified.
        Creating three extruders in the slicer, with a different profile for each heater and then basing the conditional start gcode around this:
        https://forum.prusa3d.com/forum/prusaslicer/starting-gcode-for-multiple-extruders/#post-404908
        might help? For example:
        M568 R{first_layer_temperature[0] -50}:{first_layer_temperature[1] -50}:{first_layer_temperature[2] -50} S{first_layer_temperature[0]}:{first_layer_temperature[1]}:{first_layer_temperature[2]}
        (note this is untested!)
        Alternatively there may be a way to handle this using the built in "filaments" system in RRF:
        https://docs.duet3d.com/en/User_manual/Reference/DWC_filaments
