    Can't connect Duet 3 6HC v1.0 after updating to RRF 3.5.2
    Firmware installation
    904
    • Mr Yodundefined
      Mr Yod
      After more than an hour: still 0%
      Mr Yodundefined 1 Reply Last reply Reply Quote 0
      • Mr Yodundefined
        Mr Yod @Mr Yod
        YAY!
        I managed to flash the firmware!
        I had to buy a 75cm long micro-USB cable graded for 480Mb/s to be able to do it, but it worked!
        Then I tried something: I loaded again the firmware zip file ad told to update (it already was at 3.5.2) and it bricked again forcing me to re-flash the firmware...
          What version is/was your DWC running?
          Can you re-download 3.5.2 zip?
          • Mr Yodundefined
            Mr Yod @Phaedrux
            @Phaedrux said in Can't connect Duet 3 6HC v1.0 after updating to RRF 3.5.2:
            Now it's 3.5 (it was 3.4.5 on the first brick but it was 3.5 on the second)
            I have only the uncompressed version, but I don't see how it can be useful, since it contains the same file I flashed with BOSSA. 🤔
              You can only upload the zip file itself. DWC takes care of the rest. If you're uploading anything else that's probably the problem.
              • Mr Yodundefined
                Mr Yod @Phaedrux
                I always uploaded the zip.
                I used the single uncompressed file only when flashing with BOSSA.
                  What browser are you using?
                  • Mr Yodundefined
                    Mr Yod @Phaedrux
                    @Phaedrux Web interface via Orca Slicer
                      I'm not very familiar with Orca slicer. How does that work? It has a built in browser?
                      What browser are you using to upload the firmware zip file?
                      • Mr Yodundefined
                        Mr Yod @Phaedrux
                        So it seems. 🤔
                        I told you: Web interface via Orca Slicer
                          Phaedrux Moderator @Mr Yod
                          Can you try chrome?
                          • Mr Yodundefined
                            Mr Yod @Phaedrux
                            Can you try chrome?
                            I could, but I don't want to risk another brick + reflash, sorry... 😅
                            If I'll remember I'll do it in the next update.
