    Tool Distribution Board 2 Wire CAN Information
    Documentation
    • PCRundefined
      PCR
      I installed 3 Roto Toolboards 🙂
      Took some time to get it working
      • With 2 Wire the Tool Bypass Jumper has to be always in
      • I used always the Can L and Can H from pin 4 and 3 on toolboard output
      droftartsundefined 1 Reply Last reply Reply Quote 1
        droftarts administrators @PCR
        @PCR Thanks, I'm getting around to documenting the complexities of the Tool Distribution board. I just realised the other day that it's possible to support eight toolboards (and maybe even nine if you use the CAN_OUT RJ11 port) wired as stubs, on a single TDB! You can use either pair of pins on each Tool output for a stub, and have a separate stub connected to each pair. Then, of course, you could have more than one toolboard per stub...
        And yes, the tool bypass jumper needs to be on for stubs to work.
