    sensors.probes[].diveHeight
    Gcode meta commands
    • jhelmstetterjrundefined
      jhelmstetterjr
      I am running a macro that is using the object "sensors.probes[].diveHeight" I know that it has been replaced by sensors.probes[].diveHeights. I ried updating the macro, however, when I replace diveHeight with diveHeights, I get the error:
      M98 P"0:/macros/Maintenance/Calibrate Z Offset"
      Error: in file macro line 26 column 41: G1: expected numeric operand
      Line 26: G1 Z{sensors.probes[0].diveHeights} F360 ; if axes homed move to dive height
      If I change it back to diveHeight, I get the warning that the object is obsolete, but the macro works.
      OwenDundefined 1 Reply Last reply Reply Quote 0
      • OwenDundefined
        OwenD @jhelmstetterjr
        @jhelmstetterjr
        sensors.probes[].diveHeights[] is an array.
        It contains two dive heights as configured by M558 Hnn:nn
        So you need something like
        sensors.probes[0].diveHeights[1]
        jhelmstetterjrundefined 1 Reply Last reply Reply Quote 2
          jhelmstetterjr @OwenD
          @OwenD Ah, that makes sense. As I only have 1 Z probe, the first element in the array would be 0, correct?
            jhelmstetterjr
            By the way, that worked. Thanks
            • Phaedruxundefined Phaedrux has marked this topic as solved
