RepRapFirmware 3.6.0-alpha.2 for Duet main boards available
Beta Firmware
14
83
6.0k
    ProteanReverie
    I have begun testing on two machines that are nearly identical, but one with a Duet 2 controlling it and one with a Duet 3 controlling it. I am very excited about the results I am seeing in print quality improvement. I have not yet encountered any noticeable issues with 3.6A2+3. Prints have run largely unattended, so if there was anything unusual that happened mid-print I could have missed it. Results off of the Duet 2 setup and Duet 3 setup look the same for the tests I have run.
    Gcode was identical across both machines and both firmware versions. Input shaping is configured as ZVDD F15 on both machines. Pressure advance is enabled with a value of 0.04 on both machines.
    These tests were done with a Hemera Revo 0.4HF nozzle and PETG material. I am also starting tests with a 1.0 nozzle but do not have that data yet.
    Duet 2 setup:
    Duet 2 Wi-Fi external antenna
    Duex 5
    Ghost text:
    3.5.2 = Never used RAM 11712, free system stack 112 words
    3.6A2+3 = Never used RAM 21704, free system stack 120 words
    Benchy:
    3.5.2 = Never used RAM 11544, free system stack 110 words
    3.6A2+3 = Never used RAM 18512, free system stack 116 words
    Accel test:
    3.5.2 = Never used RAM 11568, free system stack 114 words
    3.6A2+3 = Never used RAM 21656, free system stack 122 words
    Duet 3 setup:
    Duet 3 Mini 5+ WiFi main board in standalone mode
    Duet 3 Mini 5+ CAN expansion board
    Ghost text:
    3.5.2 = Never used RAM 12068, free system stack 128 words
    3.6A2+3 = Never used RAM 39644, free system stack 130 words
    Benchy:
    3.5.2 = Never used RAM 11900, free system stack 122 words
    3.6A2+3 = Never used RAM 37052, free system stack 130 words
    Here is an example of the difference in ringing/ghosting from the Ghost Text model. 3.5.2 is on bottom, 3.6A2+3 on top.
    Please let me know if there is any other information I can provide that would be beneficial.
    undefined 1 Reply Last reply 2 Aug 2024, 04:30 Reply Quote 0
      DonStauffer @ProteanReverie
      @ProteanReverie Sorry I'm not up to speed on the latest features, but is there some particular feature that has to be enabled or configured to get that improvement in the ringing, or is it just improvements to the RFF code?
      undefined 1 Reply Last reply 2 Aug 2024, 15:08 Reply Quote 0
        balajiramani @Notepad
        @Notepad thank you for your guidance. I was able to reproduce the issue and here are the output files.
        Here is the output of M122 right after booting up with 3.6.0-alpha2+3
        M122
        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.6.0-alpha.2+3 (2024-07-17 20:03:21) running on Duet WiFi 1.0 or 1.01
        Board ID: 08DAM-999TL-MQ4SD-6JTDL-3SS6N-968BX
        Used output buffers: 15 of 26 (22 max)
        Static ram: 23368
        Dynamic ram: 66320 of which 0 recycled
        Never used RAM 28388, free system stack 178 words
        Tasks: NETWORK(2,nWait 6,17.5%,222) HEAT(3,nWait 5,0.1%,328) Move(4,nWait 5,0.0%,359) MAIN(1,running,81.2%,748) IDLE(0,ready,1.3%,29), total 100.0%
        Owned mutexes: WiFi(NETWORK)
        Last reset 00:04:04 ago, cause: software
        Last software reset at 2024-07-22 19:58, reason: User, Gcodes spinning, available RAM 12348, slot 0
        Error status: 0x00
        Aux0 errors 0,0,0
        MCU temperature: min 31.2, current 33.3, max 34.5
        Supply voltage: min 24.1, current 24.3, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
        Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/24/0, gc cycles 0
        Events: 0 queued, 0 completed
        Date/time: 2024-08-02 11:27:17
        Slowest loop: 150.13ms; fastest: 0.19ms
        === Storage ===
        Free file entries: 9
        SD card longest read time 1.2ms, write time 15.6ms, max retries 0
        Segments created 0, maxWait 0ms, bed comp in use: none, height map offset 0.000, hiccups added 0 (0.00ms), max steps late 0, ebfmin 0.00, ebfmax 0.00, mcet 0.000
        Pos req/act/dcf: 114452.00/114452/0.00 114452.00/114452/0.00 114452.00/114452/0.00
        no step interrupt scheduled
        === DDARing 0 ===
        Scheduled moves 0, completed 0, LaErrors 0, Underruns [0, 0, 0]
        Driver 0: standstill, SG min n/a
        Driver 1: standstill, SG min n/a
        Driver 2: standstill, SG min n/a
        Driver 3: standstill, SG min n/a
        Driver 4: standstill, SG min n/a
        Driver 5:
        Driver 6:
        Driver 7:
        Driver 8:
        Driver 9:
        Driver 10:
        Driver 11:
        Heater 1 is on, I-accum = 0.0
        Movement locks held by null
        HTTP is idle in state(s) 0
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        Daemon is idle in state(s) 0
        Q0 segments left 0
        Code queue 0 is empty
        === Network ===
        Slowest loop: 190.46ms; fastest: 0.00ms
        Responder states: HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
        HTTP sessions: 1 of 8
        === WiFi ===
        Interface state: active
        Module is connected to access point
        Failed messages: pending 0, notrdy 0, noresp 0
        Firmware version 2.1.0
        MAC address 5c:cf:7f:2c:25:00
        Module reset reason: Turned on by main processor, Vcc 3.40, flash size 4194304, free heap 41332
        WiFi IP address 192.168.1.61
        Signal strength -39dBm, channel 6, mode 802.11n, reconnections 0
        Clock register 00002002
        Then I ran M111, here is the output:
        M111 P4 D1 B2048
        Debugging enabled for modules: Move(4 - 0x1)
        Debugging disabled for modules: Platform(0) Network(1) Webserver(2) Gcodes(3) Heat(5) Kinematics(6) InputShaping(7) unused(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) WiFi(14) Display(15) SbcInterface(16) CAN(17) Expansion(18)
        Next, I ran G32 and here is the output. Note that before it gave up, the nozzle crashed into the bed, as shown in the previous video.
        G32
        Error: G30: Probe was not triggered during probing move
        Too many auto calibration attempts
        Here is the output of M122 after the failure:
        M122
        Static ram: 23368
        Error status: 0x00
        Aux0 errors 0,0,0
        === Storage ===
        === DDARing 0 ===
        Driver 5:
        Driver 6:
        Driver 7:
        Driver 8:
        Driver 9:
        Driver 10:
        Driver 11:
        Q0 segments left 0
        === Network ===
        === WiFi ===
        Here is the relevant section from eventlog.txt:
        power up + 00:00:00 [info] Event logging started at level warn
        power up + 00:00:00 [info] Running: Duet WiFi 1.0 or 1.01: 3.6.0-alpha.2+3 (2024-07-17 20:03:21)
        power up + 00:00:00 [warn] Warning: Heater 1 predicted maximum temperature at full power is 627°C
        power up + 00:00:01 [warn] WiFi module started
        power up + 00:00:08 [warn] WiFi module is connected to access point yablibli, IP address 192.168.1.61
        power up + 00:00:09 [warn] HTTP client 192.168.1.163 login succeeded (session key 304643682)
        2024-08-02 11:23:22 [warn] Date and time set at power up + 00:00:09
        2024-08-02 11:24:23 [warn] HTTP client 192.168.1.163 login succeeded (session key 545348926)
        2024-08-02 11:25:22 [warn] HTTP client 192.168.1.163 login succeeded (session key 219193886)
        2024-08-02 11:28:48 [warn] Error: G30: Probe was not triggered during probing move
        2024-08-02 11:30:01 [info] Event logging stopped
        power up + 00:00:09 [warn] HTTP client 192.168.1.163 login succeeded (session key 1182103538)
        2024-08-02 11:30:11 [warn] Date and time set at power up + 00:00:09
          ProteanReverie @DonStauffer
          @DonStauffer said in RepRapFirmware 3.6.0-alpha.2 for Duet main boards available:
          The difference between my pictures is only an update to the RFF code, but the difference in the code pertains to how input shaping is handled. So, if you are using input shaping the update should improve things. If not, you would likely need to configure input shaping as well as applying the update. You can learn more about Input Shaping for Duet here https://docs.duet3d.com/en/User_manual/Tuning/Input_shaping
            edsped
            Haven't used my RRF printer in a few months due to it not printing as well as the Qidi. I saw this post and decided to dust off the Jubilee and load up 3.6 alpha and give it a go. I only have a few prints in but see a big improvement in print quality over the 3.5 version it replaced. So far not having an issues but have only used a single tool. Will try to do a multi color this weekend.
              ProteanReverie
              @ProteanReverie said in RepRapFirmware 3.6.0-alpha.2 for Duet main boards available:
              Here is data from my 1.0 nozzle tests.
              Duet 2
              accel test
              3.5.2 = Never used RAM 11736, free system stack 112 words
              3.6A2+3 = Never used RAM 22616, free system stack 116 words
              benchy
              3.5.2 = Never used RAM 11664, free system stack 122 words
              3.6A2+3 = Never used RAM 18992, free system stack 116 words
              ghost text
              3.5.2 = Never used RAM 11808, free system stack 114 words
              3.6A2+3 = Never used RAM 22112, free system stack 114 words
              Duet 3
              accel test
              3.5.2 = Never used RAM 12068, free system stack 130 words
              3.6A2+3 = Never used RAM 40076, free system stack 130 words
              benchy
              3.5.2 = Never used RAM 11972, free system stack 128 words
              3.6A2+3 = Never used RAM 36236, free system stack 130 words
              ghost text
              3.5.2 = Never used RAM 12092, free system stack 128 words
              3.6A2+3 = Never used RAM 39788, free system stack 130 words
              additionally, here is data from the duet 3 using a 0.4 nozzle for the accel test model, since that data wasn't ready for my prior post
              3.5.2 = Never used RAM 11876, free system stack 128 words
              3.6A2+3 = Never used RAM 39884, free system stack 130 words
              I have still not encountered any noticeable issues on either the Duet 2 Wi-Fi or Duet 3 Mini 5+ setups when using 3.6A2+3.
                DonStauffer @dc42
                @dc42 I've been having major problems with bed leveling. One Z stepper either adjusts the wrong direction, or doesn't move at all. I had been doing extensive work on bed.g a few weeks ago and got it working perfectly. This problem doesn't correspond with that, but it gives a time frame which indicates to me there's something with this alpha version since that's the only major change since then. At that time I had probably run the routine 100 times in a row, working on LED issues. The actual leveling worked well.
                undefined 1 Reply Last reply 3 Aug 2024, 07:21 Reply Quote 0
                  balajiramani @DonStauffer
                  @DonStauffer I too am having a similar problem with bed levelling. Printing with 3.6.0-alpha2+3 works fine and the input shaping is absolutely awesome! BTW, the printer I have is a delta.
                  The input shaping is so good that I am able to increase the accleration and jerk, without any artefacts. I was also able to drop the pressure advance value. I went from 0.21 to 0.14.
                  undefined 1 Reply Last reply 3 Aug 2024, 15:25 Reply Quote 1
                    DonStauffer @balajiramani
                    @balajiramani I need to look into input shaping. The pics I've seen a really awesome.
                    dc42undefined 1 Reply Last reply 10 Aug 2024, 18:42 Reply Quote 0
                      dc42 administrators @DonStauffer
                      I've put new 3.6.0 alpha RRF builds at https://www.dropbox.com/scl/fo/yc7mnauicu5vqw6yegeq7/AKnV4j8k1MCADG4VE4EIG6Y?rlkey=skjxh23i9c953yvxm2tb8qr36&dl=0. Some notes:
                      • The issue with bed tramming might be fixed. I don't have a suitable machine to test it on.
                      • Scanning Z probes are fixed (they didn't work in previous 3.6.0 alpha releases)
                      • Also included are 3.6.0 alpha versions of some expansion board firmware (not EXP1HCL or M23CL). You can revert to 3.5.2 versions if you have any issues with them.
                      See https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x-Beta#reprapfirmware-360-beta1-in-preparation for more details.
                      Notepadundefined 1 Reply Last reply 13 Aug 2024, 17:08 Reply Quote 3
                      • Notepadundefined
                        Notepad @dc42
                        @dc42 Im just about to start deploying and testing 3.6.A2+4. and in a few weeks I should have a handful of Duet3 equipped machines ready for testing the firmware on.
                        Regarding the bed tramming bug on A2+3 I have not been able to repeat this bug using Duet2 hardware on a 2 z-motor setup. I have not tried this on my 3 z-motor setup yet.
                        The real bamboo printer manufacturer
                        dc42undefined 1 Reply Last reply 13 Aug 2024, 19:45 Reply Quote 0
                          dc42 administrators @Notepad
                          @Notepad the latest build is 3.6.0-alpha.4 which you can find at https://www.dropbox.com/scl/fo/cckwiq91gn16hvl1zdjnp/AF0SMEtkVfiArSPeYaBDGPY?rlkey=kqkknk9q1kiq684u4s55ce8d4&dl=0. Release notes are at https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x-Beta#reprapfirmware-360-alpha4-in-preparation,
                          undefined undefined 2 Replies Last reply 13 Aug 2024, 22:14 Reply Quote 1
                            DonStauffer @dc42
                            @dc42 M260 lines in my initialization macro called by config.g in alpha 4 generate a message "Error: Command is not supported"
                            ;	InitNeoPix
                            ;   To disable NeoPixel LEDs, in config.g comment out the call to this macro.
                            ;   You must restart afterward (don't just run config.g).
                            ;   Defines global data, initializes NeoDriver and turns off LEDs. Preventing
                            ;	this macro from running at machine startup should effectively disable all
                            ;	NeoPixel=related macros.
                            ;	Parameters:
                            ;		A	I2C Address (default: 0x60)
                            ;		N	Number of LEDs (default: 28)
                            ;	Don Stauffer									August, 2024
                            if global.DebugLevel >= 1200
                            	echo "InitNeoPix"
                            ;   Enumeration Constants
                            var FUNC_REG_PIN = 0x01
                            var FUNC_REG_SPEED = 0x02
                            var FUNC_REG_BUF_LENGTH = 0x03
                            var NEO_DRIVER_PIN_NUM = 0x0F
                            var SPEED400khz = 0
                            var SPEED800khz = 1
                            ;   Other Constants
                            var ADDR_BASE = 0x0E
                            ;   Parameters
                            var AddrI2C = (exists(param.A) ? param. A : 0x60)
                            var LEDCount = (exists(param.N) ? param.N : 28)
                            ;	Define global NeoPixel array
                            if exists(global.NeoPix)
                            	set global.NeoPix = vector(2, vector(var.LEDCount, null))
                            else
                            	global NeoPix = vector(2, vector(var.LEDCount, null))
                            ;   Initialize NeoDriver card settings
                            M260 A{var.AddrI2C} B{var.ADDR_BASE, var.FUNC_REG_PIN, var.NEO_DRIVER_PIN_NUM}
                            M260 A{var.AddrI2C} B{var.ADDR_BASE, var.FUNC_REG_SPEED, var.SPEED800khz}
                            M260 A{var.AddrI2C} B{var.ADDR_BASE, var.FUNC_REG_BUF_LENGTH, 3 *var.LEDCount,0}
                            ;   Turn all LEDs off
                            G4 P500
                            echo "5"
                            M98 P"/macros/Lights/NeoPixel/TurnOffAll" A{var.AddrI2C}
                            	echo "Leaving InitNeoPix"
                            dc42undefined 1 Reply Last reply 14 Aug 2024, 06:54 Reply Quote 0
                              balajiramani @dc42
                              @dc42 I am still seeing failures and head crashing into the bed on running G32 calibration on a delta. Is this a known issue?
                              dc42undefined 1 Reply Last reply 14 Aug 2024, 06:52 Reply Quote 0
                                dc42 administrators @balajiramani
                                @balajiramani are you definitely running the 3.6.0-alpha.4 build? There was a minor bug in G32 calibration on deltas in early 3.6.0 alpha builds but I fixed that some time ago.
                                undefined 1 Reply Last reply 14 Aug 2024, 07:04 Reply Quote 0
                                  @DonStauffer does that same macro work if you invoke it from the DWC command line using M98?
                                  undefined 1 Reply Last reply 16 Aug 2024, 01:47 Reply Quote 0
                                    balajiramani @dc42
                                    @dc42 Yes, I downloaded it from the latest link you posted. Here is a screenshot.
                                    dc42undefined 1 Reply Last reply 14 Aug 2024, 13:20 Reply Quote 0
                                      @balajiramani my delta is working perfectly with alpha.4. Please post your bed.g file and provide more details about when the probing sequence goes wrong.
                                      undefined 1 Reply Last reply 14 Aug 2024, 13:25 Reply Quote 0
                                        balajiramani @dc42
                                        @dc42 Here is a video that shows the crash - https://forum.duet3d.com/assets/uploads/files/1721977512327-pxl_20240726_065615215-2.mp4. The motion from from one probe point to the other is more of a 'U' shaped travel, instead of a straight line.
                                        Let me know if you need any other information.
                                        Here is bed.g file.
                                        M561						; clear any bed transform, otherwise homing may be at the wrong height
                                        M290 R0 S0			; Remove any baby stepping
                                        ; bed.g file for RepRapFirmware, generated by Escher3D calculator
                                        ; 16 points, 4 factors, probing radius: 150, probe offset (0, 0)
                                        ; If the printer hasn't been homed, home it
                                        if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
                                          G28
                                        ; Probe the bed and do auto calibration
                                        G1 X0 Y0 Z10 F10000        ; go to just above the first probe point
                                        while true
                                          if iterations = 5
                                            abort "Too many auto calibration attempts"
                                          G30 P0 X0.00 Y150.00 Z-99999 H0
                                          if result != 0
                                            continue
                                          G30 P1 X96.42 Y114.91 Z-99999 H0
                                          if result != 0
                                            continue
                                          G30 P2 X147.72 Y26.05 Z-99999 H0
                                          if result != 0
                                            continue
                                          G30 P3 X129.90 Y-75.00 Z-99999 H0
                                          if result != 0
                                            continue
                                          G30 P4 X51.30 Y-140.95 Z-99999 H0
                                          if result != 0
                                            continue
                                          G30 P5 X-51.30 Y-140.95 Z-99999 H0
                                          if result != 0
                                            continue
                                          G30 P6 X-129.90 Y-75.00 Z-99999 H0
                                          if result != 0
                                            continue
                                          G30 P7 X-147.72 Y26.05 Z-99999 H0
                                          if result != 0
                                            continue
                                          G30 P8 X-96.42 Y114.91 Z-99999 H0
                                          if result != 0
                                            continue
                                          G30 P9 X0.00 Y75.00 Z-99999 H0
                                          if result != 0
                                            continue
                                          G30 P10 X64.95 Y37.50 Z-99999 H0
                                          if result != 0
                                            continue
                                          G30 P11 X64.95 Y-37.50 Z-99999 H0
                                          if result != 0
                                            continue
                                          G30 P12 X0.00 Y-75.00 Z-99999 H0
                                          if result != 0
                                            continue
                                          G30 P13 X-64.95 Y-37.50 Z-99999 H0
                                          if result != 0
                                            continue
                                          G30 P14 X-64.95 Y37.50 Z-99999 H0
                                          if result != 0
                                            continue
                                          G30 P15 X0 Y0 Z-99999 S6
                                          if result != 0
                                            continue
                                          if move.calibration.initial.deviation <= 0.03
                                            break
                                          echo "Repeating calibration because deviation is too high (" ^ move.calibration.initial.deviation ^ "mm)"
                                        ; end loop
                                        echo "Auto calibration successful, deviation", move.calibration.final.deviation ^ "mm"
                                        dc42undefined 1 Reply Last reply 14 Aug 2024, 13:28 Reply Quote 0
                                          @balajiramani it sounds to me that segmentation is not working on those moves. If you send M669 without parameters, what does it report?
                                          undefined 1 Reply Last reply 14 Aug 2024, 14:12 Reply Quote 0
