    RepRapFirmware 3.6.0-alpha.2 for Duet main boards available
    Beta Firmware
    14
    83
    7.0k
    • ProteanReverieundefined
      ProteanReverie
      @ProteanReverie said in RepRapFirmware 3.6.0-alpha.2 for Duet main boards available:
      These tests were done with a Hemera Revo 0.4HF nozzle and PETG material. I am also starting tests with a 1.0 nozzle but do not have that data yet.
      Here is data from my 1.0 nozzle tests.
      Duet 2
      accel test
      3.5.2 = Never used RAM 11736, free system stack 112 words
      3.6A2+3 = Never used RAM 22616, free system stack 116 words
      benchy
      3.5.2 = Never used RAM 11664, free system stack 122 words
      3.6A2+3 = Never used RAM 18992, free system stack 116 words
      ghost text
      3.5.2 = Never used RAM 11808, free system stack 114 words
      3.6A2+3 = Never used RAM 22112, free system stack 114 words
      Duet 3
      accel test
      3.5.2 = Never used RAM 12068, free system stack 130 words
      3.6A2+3 = Never used RAM 40076, free system stack 130 words
      benchy
      3.5.2 = Never used RAM 11972, free system stack 128 words
      3.6A2+3 = Never used RAM 36236, free system stack 130 words
      ghost text
      3.5.2 = Never used RAM 12092, free system stack 128 words
      3.6A2+3 = Never used RAM 39788, free system stack 130 words
      additionally, here is data from the duet 3 using a 0.4 nozzle for the accel test model, since that data wasn't ready for my prior post
      3.5.2 = Never used RAM 11876, free system stack 128 words
      3.6A2+3 = Never used RAM 39884, free system stack 130 words
      I have still not encountered any noticeable issues on either the Duet 2 Wi-Fi or Duet 3 Mini 5+ setups when using 3.6A2+3.
      • DonStaufferundefined
        DonStauffer @dc42
        @dc42 I've been having major problems with bed leveling. One Z stepper either adjusts the wrong direction, or doesn't move at all. I had been doing extensive work on bed.g a few weeks ago and got it working perfectly. This problem doesn't correspond with that, but it gives a time frame which indicates to me there's something with this alpha version since that's the only major change since then. At that time I had probably run the routine 100 times in a row, working on LED issues. The actual leveling worked well.
        balajiramaniundefined 1 Reply Last reply Reply Quote 0
        • balajiramaniundefined
          balajiramani @DonStauffer
          @DonStauffer I too am having a similar problem with bed levelling. Printing with 3.6.0-alpha2+3 works fine and the input shaping is absolutely awesome! BTW, the printer I have is a delta.
          The input shaping is so good that I am able to increase the accleration and jerk, without any artefacts. I was also able to drop the pressure advance value. I went from 0.21 to 0.14.
          DonStaufferundefined 1 Reply Last reply Reply Quote 1
            DonStauffer @balajiramani
            @balajiramani I need to look into input shaping. The pics I've seen a really awesome.
              dc42 administrators @DonStauffer
              I've put new 3.6.0 alpha RRF builds at https://www.dropbox.com/scl/fo/yc7mnauicu5vqw6yegeq7/AKnV4j8k1MCADG4VE4EIG6Y?rlkey=skjxh23i9c953yvxm2tb8qr36&dl=0. Some notes:
              • The issue with bed tramming might be fixed. I don't have a suitable machine to test it on.
              • Scanning Z probes are fixed (they didn't work in previous 3.6.0 alpha releases)
              • Also included are 3.6.0 alpha versions of some expansion board firmware (not EXP1HCL or M23CL). You can revert to 3.5.2 versions if you have any issues with them.
              See https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x-Beta#reprapfirmware-360-beta1-in-preparation for more details.
              Notepadundefined 1 Reply Last reply Reply Quote 3
              • Notepadundefined
                Notepad @dc42
                @dc42 Im just about to start deploying and testing 3.6.A2+4. and in a few weeks I should have a handful of Duet3 equipped machines ready for testing the firmware on.
                Regarding the bed tramming bug on A2+3 I have not been able to repeat this bug using Duet2 hardware on a 2 z-motor setup. I have not tried this on my 3 z-motor setup yet.
                The real bamboo printer manufacturer
                  dc42 administrators @Notepad
                  @Notepad the latest build is 3.6.0-alpha.4 which you can find at https://www.dropbox.com/scl/fo/cckwiq91gn16hvl1zdjnp/AF0SMEtkVfiArSPeYaBDGPY?rlkey=kqkknk9q1kiq684u4s55ce8d4&dl=0. Release notes are at https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x-Beta#reprapfirmware-360-alpha4-in-preparation,
                  DonStaufferundefined balajiramaniundefined 2 Replies Last reply Reply Quote 1
                    DonStauffer @dc42
                    @dc42 M260 lines in my initialization macro called by config.g in alpha 4 generate a message "Error: Command is not supported"
                    ;	InitNeoPix
                    ;   To disable NeoPixel LEDs, in config.g comment out the call to this macro.
                    ;   You must restart afterward (don't just run config.g).
                    ;   Defines global data, initializes NeoDriver and turns off LEDs. Preventing
                    ;	this macro from running at machine startup should effectively disable all
                    ;	NeoPixel=related macros.
                    ;	Parameters:
                    ;		A	I2C Address (default: 0x60)
                    ;		N	Number of LEDs (default: 28)
                    ;	Don Stauffer									August, 2024
                    if global.DebugLevel >= 1200
                    	echo "InitNeoPix"
                    ;   Enumeration Constants
                    var FUNC_REG_PIN = 0x01
                    var FUNC_REG_SPEED = 0x02
                    var FUNC_REG_BUF_LENGTH = 0x03
                    var NEO_DRIVER_PIN_NUM = 0x0F
                    var SPEED400khz = 0
                    var SPEED800khz = 1
                    ;   Other Constants
                    var ADDR_BASE = 0x0E
                    ;   Parameters
                    var AddrI2C = (exists(param.A) ? param. A : 0x60)
                    var LEDCount = (exists(param.N) ? param.N : 28)
                    ;	Define global NeoPixel array
                    if exists(global.NeoPix)
                    	set global.NeoPix = vector(2, vector(var.LEDCount, null))
                    else
                    	global NeoPix = vector(2, vector(var.LEDCount, null))
                    ;   Initialize NeoDriver card settings
                    M260 A{var.AddrI2C} B{var.ADDR_BASE, var.FUNC_REG_PIN, var.NEO_DRIVER_PIN_NUM}
                    M260 A{var.AddrI2C} B{var.ADDR_BASE, var.FUNC_REG_SPEED, var.SPEED800khz}
                    M260 A{var.AddrI2C} B{var.ADDR_BASE, var.FUNC_REG_BUF_LENGTH, 3 *var.LEDCount,0}
                    ;   Turn all LEDs off
                    G4 P500
                    echo "5"
                    M98 P"/macros/Lights/NeoPixel/TurnOffAll" A{var.AddrI2C}
                    	echo "Leaving InitNeoPix"
                      balajiramani @dc42
                      @dc42 I am still seeing failures and head crashing into the bed on running G32 calibration on a delta. Is this a known issue?
                        dc42 administrators @balajiramani
                        @balajiramani are you definitely running the 3.6.0-alpha.4 build? There was a minor bug in G32 calibration on deltas in early 3.6.0 alpha builds but I fixed that some time ago.
                          @DonStauffer does that same macro work if you invoke it from the DWC command line using M98?
                          DonStaufferundefined 1 Reply Last reply Reply Quote 0
                            balajiramani @dc42
                            @dc42 Yes, I downloaded it from the latest link you posted. Here is a screenshot.
                              @balajiramani my delta is working perfectly with alpha.4. Please post your bed.g file and provide more details about when the probing sequence goes wrong.
                                balajiramani @dc42
                                @dc42 Here is a video that shows the crash - https://forum.duet3d.com/assets/uploads/files/1721977512327-pxl_20240726_065615215-2.mp4. The motion from from one probe point to the other is more of a 'U' shaped travel, instead of a straight line.
                                Let me know if you need any other information.
                                Here is bed.g file.
                                M561						; clear any bed transform, otherwise homing may be at the wrong height
                                M290 R0 S0			; Remove any baby stepping
                                ; bed.g file for RepRapFirmware, generated by Escher3D calculator
                                ; 16 points, 4 factors, probing radius: 150, probe offset (0, 0)
                                ; If the printer hasn't been homed, home it
                                if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
                                  G28
                                ; Probe the bed and do auto calibration
                                G1 X0 Y0 Z10 F10000        ; go to just above the first probe point
                                while true
                                  if iterations = 5
                                    abort "Too many auto calibration attempts"
                                  G30 P0 X0.00 Y150.00 Z-99999 H0
                                  if result != 0
                                    continue
                                  G30 P1 X96.42 Y114.91 Z-99999 H0
                                  if result != 0
                                    continue
                                  G30 P2 X147.72 Y26.05 Z-99999 H0
                                  if result != 0
                                    continue
                                  G30 P3 X129.90 Y-75.00 Z-99999 H0
                                  if result != 0
                                    continue
                                  G30 P4 X51.30 Y-140.95 Z-99999 H0
                                  if result != 0
                                    continue
                                  G30 P5 X-51.30 Y-140.95 Z-99999 H0
                                  if result != 0
                                    continue
                                  G30 P6 X-129.90 Y-75.00 Z-99999 H0
                                  if result != 0
                                    continue
                                  G30 P7 X-147.72 Y26.05 Z-99999 H0
                                  if result != 0
                                    continue
                                  G30 P8 X-96.42 Y114.91 Z-99999 H0
                                  if result != 0
                                    continue
                                  G30 P9 X0.00 Y75.00 Z-99999 H0
                                  if result != 0
                                    continue
                                  G30 P10 X64.95 Y37.50 Z-99999 H0
                                  if result != 0
                                    continue
                                  G30 P11 X64.95 Y-37.50 Z-99999 H0
                                  if result != 0
                                    continue
                                  G30 P12 X0.00 Y-75.00 Z-99999 H0
                                  if result != 0
                                    continue
                                  G30 P13 X-64.95 Y-37.50 Z-99999 H0
                                  if result != 0
                                    continue
                                  G30 P14 X-64.95 Y37.50 Z-99999 H0
                                  if result != 0
                                    continue
                                  G30 P15 X0 Y0 Z-99999 S6
                                  if result != 0
                                    continue
                                  if move.calibration.initial.deviation <= 0.03
                                    break
                                  echo "Repeating calibration because deviation is too high (" ^ move.calibration.initial.deviation ^ "mm)"
                                ; end loop
                                echo "Auto calibration successful, deviation", move.calibration.final.deviation ^ "mm"
                                  @balajiramani it sounds to me that segmentation is not working on those moves. If you send M669 without parameters, what does it report?
                                    balajiramani @dc42
                                    @dc42 Here is what I see:
                                    M669
                                    Kinematics is Linear delta, 100 segments/sec, min. segment length 0.20mm
                                    Exerqtorundefined 1 Reply Last reply Reply Quote 0
                                    • Exerqtorundefined
                                      Exerqtor @balajiramani
                                      @dc42 Just had time to TRY a print with the alpha.4 binaries you uploaded the other day (on both the D3 Mini & the 1LC), and the bed leveling seems to be working.
                                      BUT now the extruder won't extrude (or retract for that matter), either through G-code or if I to use the "extrude buttons" in DWC & PD.
                                      When I canceled the print on PD i got these error messages:
                                      CAN response timeout: board 121, req type 6044, RID 220.
                                      Error: at column 2: G10: hA
                                      CAN response timeout: board 121, req type 6029, RID 222
                                      CAN response timeout: board 121, req type 6044, RID 223
                                      Which is new behaviour from alpha.2+3.
                                      AND the hotend heater (connected to the 1LC) won't turn off. Both DWC & PD show active/standby heat to be 0, but the heater is still at working temp (255c).
                                      If i manually try to input 0 in active on DWC and push enter i get this error:
                                      M568 P0 S0
                                      Error:  at column 2: M568: P
                                      The only way I've found to actually make it turn off/adjust the temp down is to power toggle or restart the printer.
                                      gloomyandyundefined Exerqtorundefined 2 Replies Last reply Reply Quote 0
                                      • gloomyandyundefined
                                        gloomyandy @Exerqtor
                                        @Exerqtor What version of the firmware do you have installed on the 1LC?
                                        • Exerqtorundefined
                                          Exerqtor @Exerqtor
                                          @gloomyandy said in RepRapFirmware 3.6.0-alpha.2 for Duet main boards available:
                                          @Exerqtor said in RepRapFirmware 3.6.0-alpha.2 for Duet main boards available:
                                          To be more specific:
                                          M122 B121
                                          Diagnostics for board 121:
                                          Duet TOOL1LC rev 1.1 or later firmware version 3.6.0-alpha.4 (2024-08-13 12:30:07)
                                          Bootloader ID: SAMC21 bootloader version 2.8 (2023-07-25)
                                          I just tested if the extrusion works while idle, which it does. I'm about to start a new test print (same job g-code as earlier) and see what happens.
                                          Here is a couple M122's from BEFORE starting the print:
                                          M122
                                          RepRapFirmware for Duet 3 Mini 5+ version 3.6.0-alpha.4 (2024-08-13 15:11:57) running on Duet 3 Mini5plus WiFi (standalone mode)
                                          Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ
                                          Used output buffers: 16 of 40 (37 max)
                                          Static ram: 92296
                                          Dynamic ram: 94544 of which 0 recycled
                                          Never used RAM 50316, free system stack 142 words
                                          Tasks: NETWORK(2,nWait 7,16.7%,211) HEAT(3,nWait 6,0.0%,350) Move(4,nWait 6,0.0%,247) TMC(4,nWait 6,0.9%,65) CanReceiv(6,nWait 1,0.1%,792) CanSender(5,nWait 7,0.0%,336) CanClock(7,delaying,0.0%,339) MAIN(1,running,80.5%,665) IDLE(0,ready,1.1%,29) AIN(4,delaying,0.8%,259), total 100.0%
                                          Owned mutexes: WiFi(NETWORK)
                                          Last reset 00:17:06 ago, cause: software
                                          Last software reset at 2024-08-14 18:13, reason: User, Gcodes spinning, available RAM 52872, slot 2
                                          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                                          Error status: 0x00
                                          Aux0 errors 0,1,0
                                          MCU temperature: min 41.0, current 44.0, max 46.0
                                          Supply voltage: min 2.8, current 24.2, max 24.8, under voltage events: 0, over voltage events: 0, power good: yes
                                          Heap OK, handles allocated/used 99/34, heap memory allocated/used/recyclable 2048/696/252, gc cycles 232
                                          Events: 0 queued, 0 completed
                                          Date/time: 2024-08-14 18:30:13
                                          Slowest loop: 49.66ms; fastest: 0.11ms
                                          === Storage ===
                                          Free file entries: 18
                                          SD card longest read time 8.0ms, write time 9.5ms, max retries 0
                                          Segments created 33, maxWait 232923ms, bed comp in use: none, height map offset 0.000, hiccups added 0 (0.00ms), max steps late 0, ebfmin 0.00, ebfmax 0.00, mcet 0.012
                                          Pos req/act/dcf: 10.00/10/0.00 -27991.00/-27991/0.00 4000.00/4000/0.00
                                          no step interrupt scheduled
                                          Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 38, reads 53987, writes 38, timeouts 0, DMA errors 0, CC errors 0
                                          Driver 1: standstill, SG min 0, read errors 0, write errors 0, ifcnt 38, reads 53987, writes 38, timeouts 0, DMA errors 0, CC errors 0
                                          Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 24, reads 54001, writes 24, timeouts 0, DMA errors 0, CC errors 0
                                          Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 23, reads 54001, writes 23, timeouts 0, DMA errors 0, CC errors 0
                                          Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 23, reads 54002, writes 23, timeouts 0, DMA errors 0, CC errors 0
                                          Driver 5: not present
                                          Driver 6: not present
                                          === DDARing 0 ===
                                          Scheduled moves 63, completed 63, LaErrors 0, Underruns [0, 0, 0]
                                          === DDARing 1 ===
                                          Scheduled moves 0, completed 0, LaErrors 0, Underruns [0, 0, 0]
                                          Heater 0 is on, I-accum = 0.5
                                          Heater 1 is on, I-accum = 0.0
                                          HTTP is idle in state(s) 0
                                          Telnet is idle in state(s) 0
                                          File is idle in state(s) 0
                                          USB is idle in state(s) 0
                                          Aux is idle in state(s) 0
                                          Trigger is idle in state(s) 0
                                          Queue is idle in state(s) 0
                                          LCD is idle in state(s) 0
                                          SBC is idle in state(s) 0
                                          Daemon is doing "G4 P250" in state(s) 0 0, running macro
                                          Aux2 is idle in state(s) 0
                                          File2 is idle in state(s) 0
                                          Queue2 is idle in state(s) 0
                                          Q0 segments left 0, axes/extruders owned 0x0000803
                                          Code queue 0 is empty
                                          Code queue 1 is empty
                                          === Filament sensors ===
                                          check 0 clear 0
                                          Extruder 0 sensor: no filament
                                          === CAN ===
                                          Messages queued 9333, received 21187, lost 0, ignored 0, errs 1318, boc 0
                                          Longest wait 6ms for reply type 6024, peak Tx sync delay 10502, free buffers 26 (min 25), ts 5135/5133/0
                                          Tx timeouts 0,0,1,0,0,0 last cancelled message type 30 dest 127
                                          === Network ===
                                          Slowest loop: 19.26ms; fastest: 0.00ms
                                          Responder states: MQTT(0) HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                                          HTTP sessions: 1 of 8
                                          === WiFi ===
                                          Interface state: active
                                          Module is connected to access point
                                          Failed messages: pending 0, notrdy 0, noresp 0
                                          Firmware version 2.1.0
                                          MAC address c4:5b:be:ce:91:93
                                          Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 39620
                                          WiFi IP address 192.168.30.50
                                          Signal strength -48dBm, channel 6, mode 802.11n, reconnections 0
                                          Clock register 00002001
                                          M122 B121
                                          All averaging filters OK
                                          Never used RAM 7956, free system stack 92 words
                                          Tasks: Move(3,nWait 7,0.0%,100) TMC(2,delaying,3.6%,52) HEAT(2,nWait 6,0.4%,98) CanAsync(5,nWait 4,0.0%,54) CanRecv(3,nWait 1,0.0%,70) CanClock(5,nWait 1,0.0%,58) ACCEL(3,nWait 6,0.0%,52) MAIN(1,running,91.0%,318) IDLE(0,ready,0.0%,26) AIN(2,delaying,5.0%,112), total 100.0%
                                          Owned mutexes:
                                          Last reset 00:17:09 ago, cause: power up
                                          Last software reset at 2024-03-12 16:55, reason: StackOverflow, available RAM 2968, slot 0
                                          Software reset code 0x0100 ICSR 0x0042600e SP 0x20007f34 Task Move Freestk 3342 ok
                                          Stack: 20004a80 20004ab4 0001cf33 20004c98 20004938 00000000 0001c011 20003320 fffffffd a5a5a5a5 00000000 20007f8c 00000000 20007f8c 0001cc97 00000000 200017c4 20001748 0001c4d7 20001748 200017c4 00000032 454c4449 00022700 0001ac77 200018e0 200018e0
                                          Driver 0: pos 34130, 568.8 steps/mm, standstill, SG min 0, read errors 0, write errors 0, ifcnt 14, reads 37260, writes 3, timeouts 0, DMA errors 0, CC errors 0
                                          Moves scheduled 4, hiccups 0 (0.00ms), segs 3, step errors 0 (types 0x0), maxLate 0 maxPrep 96, ebfmin 0.00 max 0.00
                                          Peak sync jitter -2/9, peak Rx sync delay 222, resyncs 0/0, no timer interrupt scheduled, next step interrupt due in 3857541807 ticks, disabled
                                          VIN voltage: min 23.8, current 24.7, max 25.2
                                          MCU temperature: min 60.4C, current 64.1C, max 65.5C
                                          Last sensors broadcast 0x00000012 found 2 165 ticks ago, 0 ordering errs, loop time 0
                                          CAN messages queued 15059, send timeouts 0, received 6624, lost 0, ignored 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
                                          dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 294, adv 37049/37148
                                          Accelerometer: LIS3DH, status: 00
                                          I2C bus errors 0, naks 0, contentions 0, other errors 0
                                          Interrupt 5726621 to 0us, poll 5 to 1268us
                                          Driver 0: ok
                                          EDIT:
                                          I've got no idea what was going on earlier, because now it extrudes like it should 😶
                                          I'm letting the test print finish to see what's going to happen.
                                            DonStauffer @dc42
                                            @dc42 I didn't try it and I reverted to alpha 2. It's called from the last few lines in config.g so I didn't think it would be different.
                                            I reinstalled alpha 4 and yes, the error occurs on the M260 lines when the macro is invoked from the console using M98.
