no dropdowns after update
I've updated my Duet2 from RRF3.4 to 3.5.2. After the update the temp dropdowns in DWC are empty...
I've already cleared the browsers cache. -
@cosmowave It may just be a slight change in the way the DWC settings are stored, or a corrupt settings file. Try renaming sys/dwc-settings.json to something different (eg .old on the end), refresh the browser, then check. Edit something, eg add another temperature in Settings > Machine-specific > Tool temperatures to create a new dwc-settings.json.
@droftarts Ok... that could be the problem. I will try it today evening.
Thanks in advance for your answer! -
@droftarts That has solved the problem. Thanks for your help!
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
