    DWC rr_status different than DWC UI percentage printed
    • kazolarundefined
      kazolar
      http://10.1.1.108/rr_status?type=3 reports a different fractionPrinted than the percentage shown in the DWC UI. Where do I get that percentage?
      • totalitarianundefined
        totalitarian
        I found the same issue.
        The one on the DWC UI seems to be based on filament printed. Not sure where the rr_status one get's it from….
          The fractionPrinted variable in the rr_status result is the fraction of the GCode file that has been processed. I presume that DWC is calculating the fraction of total filament consumed instead, based on the filament needed from the file info and the reported total extrusion.
