    Endtops Low and High
    4.8k
    • Synapsisundefined
      Synapsis
      Tried G1 then G1 X10 the head moves from left to right G1 X-10 moves the head from right to left
      Same for G1 Y10 moves from front to back G1 X-10 back to front. Starting from the left bottom.
      back
      Y
      Top View
      0–-------------------- X
      front
      left motor was supposed to be Y while right X but had to switch them to get the correct movement when following the giude in
      Configuring RepRapFirmware for a CoreXY printer
        Good, your axes are moving in the correct directions. Now set up your M574 command to specify whether each endstop switch is at the low (minimum) end or the high (maximum) end, set up the M208 commands to specify the upper and lower limits of each axis, and set up the homing files as described at https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_Cartesian_printer#Homing_files and https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_CoreXY_printer#Homing_files. You can use the online configuration tool to generate these commands if you wish.
        • Synapsisundefined
          Synapsis
          Thanks David will do as soon as I get home. Wife made me take here to the beach wont be back until 02/01/18 ;(
          Well I can finally read up some documentation.
          • Synapsisundefined
            Synapsis
            Finally back home tried setting up starts to act almost correctly but I need to know in Web Control Head Moviment
            does a +1 = 1 mm? when I do home X and Y when I go back to zero I see the position is 120 x 120 and not 0 x 0.
            I do have a 400mm + bed. Does i8t have something to do with the steppers settings?
              Yes +1 should move the head 1mm in the +x direction, +10 should move it 10mm in the +X direction, and so on. If it moves the wrong amount, check the steps/mm settings, which are defined in the M92 command in config.g.
              • Synapsisundefined
                Synapsis
                Hi David thanks and Yes I was reading the M92 command but how do I calculate the steps, right now I have 200 for all three.
                So I know its wrong but rather than trial and error if I know how it would be better- 🙂
                I have 0.9 stepper motors.
                  1. How many teeth are there on the stepper motors pulleys? Are they GT2 pulleys and belts?
                  2. Is your G92 command before or after any M350 command that you have in config.g? if it is after, what M350 parameters are you using?
                  3. Are the motors 0.9deg or 1.8deg?
                  • Synapsisundefined
                    Synapsis
                    @dc42:
                    Yes have GT2 20 tooth pulleys and belts
                    I have a M92 X150 Y150 Z150 ; Set axis steps/mm was 200 I changed it to 150 but still not correct. I can not find a G92 command
                    M350 X16 Y16 Z16 E16 I1 ; Set 16x microstepping with interpolation
                    0.9deg stepper motors
                      Sorry, I meant M92 not G92. For 20 tooth GT2 pulleys and 0.9deg motors, steps/mm should be 160 on X and Y.
                      • Synapsisundefined
                        Synapsis
                        Thanks Davis will change now and try it-
