    [3.6.0.Beta.1] Halted due to step timing error
    Beta Firmware
    • Notepadundefined
      Notepad
      HI all,
      Simple error during a regular print about 20/25 minutes in
      Error: Movement halted because a step timing error occurred (code 3). Please reset the controller.
      Error: Existing: start=1789869067 length=8828, new: start=1789876874, overlap=1021 time now=1789871627
      M122 Report
      m122#
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.6.0-beta.1 (2024-09-24 10:07:04) running on Duet WiFi 1.02 or later
      Board ID: 0JD2M-9F8TA-GJ4TD-6J1D6-3SD6P-16PG6
      Used output buffers: 11 of 26 (24 max)
      Static ram: 23360
      Dynamic ram: 66884 of which 0 recycled
      Never used RAM 11944, free system stack 100 words
      Tasks: NETWORK(2,ready,14.7%,181) HEAT(3,nWait 5,0.1%,307) Move(4,invalid,0.5%,266) MAIN(2,running,84.7%,713) IDLE(0,ready,0.0%,29), total 100.0%
      Owned mutexes: HTTP(MAIN)
      Last reset 27:19:22 ago, cause: power up
      Last software reset at 2024-09-01 17:47, reason: User, Gcodes spinning, available RAM 30728, slot 0
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
      Error status: 0x00
      Aux0 errors 0,0,0
      MCU temperature: min 20.1, current 30.4, max 32.1
      Supply voltage: min 24.5, current 24.9, max 25.5, under voltage events: 0, over voltage events: 0, power good: yes
      Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/816/768, gc cycles 0
      Events: 0 queued, 0 completed
      Date/time: 2024-11-10 18:19:10
      Slowest loop: 376.85ms; fastest: 0.11ms
      === Storage ===
      Free file entries: 9
      SD card longest read time 44.5ms, write time 118.3ms, max retries 0
      Segments created 662, maxWait 60410311ms, bed comp in use: mesh, height map offset 0.000, hiccups added 42 (1.25ms), max steps late 1, ebfmin 0.00, ebfmax 0.00
      Pos req/act/dcf: 34135.00/33905/0.92 3194.00/2900/0.16 1881.00/1885/-0.81
      no step interrupt scheduled
      Driver 0: standstill, SG min 0
      Driver 1: standstill, SG min 0
      Driver 2: standstill, SG min 0
      Driver 3: standstill, SG min 0
      Driver 4: standstill, SG min 0
      Driver 5:
      Driver 6:
      Driver 7:
      Driver 8:
      Driver 9:
      Driver 10:
      Driver 11:
      === DDARing 0 ===
      Scheduled moves 18362, completed 18332, LaErrors 0, Underruns [5, 0, 0]
      Heater 0 is on, I-accum = 0.2
      Heater 1 is on, I-accum = 0.5
      Movement locks held by null
      HTTP is ready with "m122#" in state(s) 0
      Telnet is idle in state(s) 0
      File is doing "G1 X233.739 Y193.061" in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Q0 segments left 1
      Code queue 0 is empty
      === Network ===
      Slowest loop: 667.84ms; fastest: 0.00ms
      Responder states: HTTP(4) HTTP(0) HTTP(4) FTP(0) Telnet(0)
      HTTP sessions: 2 of 8
      === WiFi ===
      Interface state: active
      Module is connected to access point
      Failed messages: pending 0, notrdy 5, noresp 1
      Firmware version 2.1.0
      MAC address a4:e5:7c:03:da:81
      Module reset reason: Hardware watchdog, Vcc 3.40, flash size 2097152, free heap 42392
      WiFi IP address 192.168.1.197
      Signal strength -52dBm, channel 6, mode 802.11n, reconnections 0
      Clock register 00002002
      Socket states: 3 5 3 0 0 0 0 0
      config.g
      printfile_PETG_1h6m.gcode
      The real bamboo printer manufacturer
      droftartsundefined dc42undefined 2 Replies Last reply Reply Quote 0
        droftarts administrators @Notepad
        @Notepad One for @dc42.
        (Along with these ones: https://forum.duet3d.com/search?in=posts&term=Halted+due+to+step+timing+error&matchWords=all)
        Notepadundefined 1 Reply Last reply Reply Quote 0
        • Notepadundefined
          Notepad @droftarts
          @droftarts
          Not to worry, just logging incase and of the information is helpful.
            dc42 administrators @Notepad
            @Notepad thanks for your report. I fixed a cause of Code 3 halts in 3.6beta2. Please upgrade to that version if you haven't already. There are updated post-beta2 binaries for some boards at https://www.dropbox.com/scl/fo/kaxbpbsyq2lxbae4tmzpk/AAPVUAh6CO_FMO-cG9ttX6U?rlkey=f0aesppc8d2p7bzwwi2s1jayo&dl=0.
            Notepadundefined 1 Reply Last reply Reply Quote 1
            • Notepadundefined
              Notepad @dc42
              @dc42 Good to know, Ill deploy it to the farm and see if anything pings up an error!
