[RRF 3.6.0-beta.2 Error code 7]
Hello everyone!
I got a strage issue with my printer, after an 8 hours print, i got this error:
Sadly I cannot get a M122 report for two reasons:
In DWC with 3.6.x I cannot get an M122 report even if other comands works as expected
Over USB, I needed to do an emergency stop wich cleared the relevant report..My board is a Duet 2 WiFi + Duex5 with MMU3
Anyway, I will upload my config files to google drive and update this post.
All that I have is the gcode and the aproximate layer height when the error occuredBy the way, with beta 1 for only one print I got the exact same error, the next day I do a simulation wich completed as expected, printed the exact same gcode without any problems. So, seems to be a random issue wich I can't reproduce myself twice. I started a slightly modified print now to see how it goes
Thank you in advance, and any help is welcomed!
Update:
This is the gcode in question: Jack Case_STEC7_0.2mm_PLA_5h24m.gcode
The error occured on layer 312 / Z height 62.40 most likely somewhere around line 117292 in that gcode
