    Firmware 1.20 released
    Firmware installation
    20
    89
    14.2k
    • Captain_squndefined
      Captain_sq
      Great! Thanks.
      Custom made Kossel Mini - Duet WiFi / Modded Tronxy X5S - Duet WiFi / Prusa i3 MKIII
      Embedded systems designer, RC Pilot, maker and Gadget-o-holic
        Captain_sq
        I'm still having problems I'm afraid. Cannot connect to my Duet 0.6 after upgrade to 1.20.1 (RepRapFirmware.bin). I can see that it boots up and runs for about 25 secs, then both ethernet connecor LEDs go out for 3-4 seconds and pattern repeats over an over.
        I've installed manually the DuetWebControl associated with this firmware release.
        Any ideas?
        Regards /Thom
          I tested 1.20 on a Duet 0.8.5 but not on a 0.6. You could try putting a minimal config.g file on the SD card, with the network parameters and not much else in it.
          Version 1.19.2 was tested on a Duet 0.6.
            Captain_sq
            This is my current config.g
            [c]
            ; Configuration file for Duet 0.6 (firmware version 1.17 to 1.19)
            ; generated by RepRapFirmware Configuration Tool on Fri Nov 17 2017 18:51:38 GMT+0100 (Västeuropa, normaltid)
            M111 S0 ; Debugging off
            G21 ; Work in millimetres
            G90 ; Send absolute coordinates…
            M555 P1 ; Set firmware compatibility to look like RepRapFirmare
            ;Delta parameters
            M665 L190.000 R90 H236.8 B72.0 ; Set delta radius, diagonal rod length, printable radius and homed height
            M666 X0 Y0 Z0 ; Endstops
            M208 Z-0.5 S1 ; Set minimum Z
            M574 X2 Y2 Z2 S1 ; Set active high endstops
            M558 P4 X0 Y0 Z0 H4 F120 T8000 ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
            G31 P600 X0 Y0 Z-0.10 ; Set Z probe trigger value, offset and trigger height
            M557 R78 S20 ; Bed mesh
            M92 X100 Y100 Z100 E141.8 ; Set steps per mm
            M566 X1200 Y1200 Z1200 E1500 ; Set maximum instantaneous speed changes (mm/min)
            M203 X18000 Y18000 Z18000 E12000 ; Set maximum speeds (mm/min)
            M201 X2200 Y2200 Z2200 E2000 ; Set accelerations (mm/s^2)
            M906 X960 Y960 Z960 E1600 I60 ; Set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
            M305 P0 T100000 B3950 C0 R1000 H10 ; Set thermistor + ADC parameters for heater 0
            M143 H0 S130 ; Set temperature limit for heater 0 (bed) to 130C
            M305 P1 T100000 B4267 C0 R1000 H10 ; Set thermistor + ADC parameters for heater 1
            M563 P0 D0 H1 ; Define tool 0
            M550 PMy Mini Kossel ; Set machine name
            M540 PBE:EF:DE:AD:FE:ED ; Set MAC address
            M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
            M586 P0 S1 ; Enable HTTP
            M586 P1 S0 ; Disable FTP
            M586 P2 S0 ; Disable Telnet
            M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency.
            ; thermostatic control is turned off
            ; Read in calibration override settings
            M501
            G29 S1 ; Read in bed height correction map
            T0 ; Select first tool
            [/c]
            I'm going to try the network parameters only and then if I manage to connect to it, I'll uncomment paragraphs
            step by step.
            /Thom
            • Teilchenundefined
              Teilchen
              @Captain_sq:
              Any ideas?
              Regards /Thom
              This sounds exactly like my problem with 0.85 too.
              I did not think about simplifying the config.g, since this is not an option to my opinion, but I am curious to see the results. I am still on 1.18.1 because of that. The 1.19 does run, but it is very unstable, and the 1.20 will not start up at all with my config.
                Captain_sq
                I'm able to make connection via the USB port using Repetier-Host V2.05. A short clip from the serial log:
                [c]22:27:09.813 : RepRapFirmware for Duet is up and running.
                22:27:09.816 : N10 M111 S686
                22:27:09.816 : FIRMWARE_NAME: RepRapFirmware for Duet FIRMWARE_VERSION: 1.20.1RC2 ELECTRONICS: Duet 0.6 FIRMWARE_DATE: 2018-01-01
                22:27:09.816 : N11 T0
                10
                22:27:09.847 : X:0.000 Y:0.000 Z:0.000 E0:0.0 E1:0.0 E2:0.0 E3:0.0 E4:0.0 E5:0.0 Count 0 0 0 User 0.0 0.0 0.0
                22:27:09.847 : serial: T0
                22:27:09.847 : serial: M20
                22:27:09.847 : Begin file list
                22:27:09.849 : Enclosures
                22:27:09.849 : Kossel
                22:27:09.849 : Art
                22:27:09.849 : Supports and mounts
                22:27:09.849 : X5S
                22:27:09.849 : Couplings
                22:27:09.849 : MK PLA L015 N035 (Noraft) PrtAlignmentModel.gcode
                22:27:09.849 : Diverse
                22:27:09.849 : Gee(i3)
                22:27:09.849 : Alu profile 20x20
                22:27:09.852 : End file list
                22:27:09.852 : serial: M80
                22:27:09.852 : serial: M105
                22:27:09.853 : serial: M111 S6
                22:27:09.853 : serial: T0
                22:27:12.803 : N12 M10520
                22:27:12.805 : serial: M105
                22:27:15.863 : N13 M105
                21
                22:27:15.864 : serial: M105
                22:27:18.929 : N14 M10518
                22:27:18.930 : serial: M105
                22:27:21.989 : N15 M105
                19
                22:27:21.990 : serial: M105
                22:27:25.048 : N16 M10516
                22:27:25.049 : serial: M105
                22:27:28.114 : N17 M105
                17
                22:27:28.114 : serial: M105
                22:27:31.174 : N18 M10530
                22:27:31.175 : serial: M105
                22:27:34.240 : N19 M105
                31
                22:27:34.241 : serial: M105
                22:27:37.300 : N20 M10521
                22:27:37.301 : serial: M105
                22:27:40.367 : N21 M105
                20
                22:27:40.368 : serial: M105
                22:27:43.426 : N22 M10523
                22:27:43.428 : serial: M105
                22:27:46.492 : N23 M105
                22
                22:27:46.493 : serial: M105
                22:27:49.552 : N24 M105*17
                22:27:49.553 : serial: M105
                [/c]
                However, if I connect the Ethernet cable, Repetier-Host gets disconnected and the Reboot pattern starts to run again. The current config.g:
                [c]
                ;M111 S0 ; Debugging off
                ;M83 ; ...but relative extruder moves
                ;M555 P1 ; Set firmware compatibility to look like RepRapFirmare
                ;Delta parameters
                ;M665 L190.000 R90 H236.8 B72.0 ; Set delta radius, diagonal rod length, printable radius and homed height
                ;M666 X0 Y0 Z0 ; Endstops
                ;M208 Z-0.5 S1 ; Set minimum Z
                ;M574 X2 Y2 Z2 S1 ; Set active high endstops
                ;M558 P4 X0 Y0 Z0 H4 F120 T8000 ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
                ;G31 P600 X0 Y0 Z-0.10 ; Set Z probe trigger value, offset and trigger height
                ;M557 R78 S20 ; Bed mesh
                ;569 P0 S1 ; Drive 0 goes forwards
                ;569 P1 S1 ; Drive 1 goes forwards
                ;M569 P2 S1 ; Drive 2 goes forwards
                ;M569 P3 S1 ; Drive 3 goes forwards
                ;M92 X100 Y100 Z100 E141.8 ; Set steps per mm
                ;M566 X1200 Y1200 Z1200 E1500 ; Set maximum instantaneous speed changes (mm/min)
                ;M203 X18000 Y18000 Z18000 E12000 ; Set maximum speeds (mm/min)
                ;M201 X2200 Y2200 Z2200 E2000 ; Set accelerations (mm/s^2)
                ;M906 X960 Y960 Z960 E1600 I60 ; Set motor currents (mA) and motor idle factor in per cent
                ;M84 S30 ; Set idle timeout
                ;M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
                ;M305 P0 T100000 B3950 C0 R1000 H10 ; Set thermistor + ADC parameters for heater 0
                ;M143 H0 S130 ; Set temperature limit for heater 0 (bed) to 130C
                ;M305 P1 T100000 B4267 C0 R1000 H10 ; Set thermistor + ADC parameters for heater 1
                ;M143 H1 S280 ; Set temperature limit for heater 1 to 280C
                ;M563 P0 D0 H1 ; Define tool 0
                ;G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets
                ;G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C
                ;M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency.
                ;M501
                ;G29 S1 ; Read in bed height correction map
                ;T0 ; Select first tool
                [/c]
                  Captain_sq
                  As I work with embedded systems myself I see the typical symptoms of a stack crash. While watching the output from the serial line I could observe some kind of "hartbeat" messages from classes running inside the Duet. All seems normal until I plug the ethernet cable in. Then everything just stops.
                    If you run M122 from USB, how much free memory does it report?
                      Captain_sq
                      I'm not sure wich number you're after so I copied the entire response:
                      [c]17:34:17.138 : serial: M122
                      17:34:17.143 : LINK
                      17:34:17.145 : xmit: 0
                      17:34:17.145 : recv: 0
                      17:34:17.145 : fw: 0
                      17:34:17.145 : drop: 0
                      17:34:17.145 : chkerr: 0
                      17:34:17.145 : lenerr: 0
                      17:34:17.145 : memerr: 0
                      17:34:17.145 : rterr: 0
                      17:34:17.145 : proterr: 0
                      17:34:17.145 : opterr: 0
                      17:34:17.145 : err: 0
                      17:34:17.145 : cachehit: 0
                      17:34:17.145 : ETHARP
                      17:34:17.146 : proterr: 0
                      17:34:17.146 : opterr: 0
                      17:34:17.146 : err: 0
                      17:34:17.146 : cachehit: 0
                      17:34:17.146 : IP_FRAG
                      17:34:17.146 : xmit: 0
                      17:34:17.146 : recv: 0
                      17:34:17.146 : fw: 0
                      17:34:17.146 : drop: 0
                      17:34:17.146 : chkerr: 0
                      17:34:17.146 : lenerr: 0
                      17:34:17.146 : memerr: 0
                      17:34:17.146 : rterr: 0
                      17:34:17.146 : IP
                      17:34:17.147 : memerr: 0
                      17:34:17.147 : rterr: 0
                      17:34:17.147 : proterr: 0
                      17:34:17.147 : opterr: 0
                      17:34:17.147 : err: 0
                      17:34:17.147 : cachehit: 0
                      17:34:17.147 : IGMP
                      17:34:17.147 : xmit: 0
                      17:34:17.147 : recv: 0
                      17:34:17.147 : drop: 0
                      17:34:17.147 : chkerr: 0
                      17:34:17.147 : lenerr: 0
                      17:34:17.147 : rx_v1: 0
                      17:34:17.147 : rx_group: 0
                      17:34:17.147 : rx_general: 0
                      17:34:17.147 : rx_report: 0
                      17:34:17.147 : tx_join: 0
                      17:34:17.148 : tx_leave: 0
                      17:34:17.148 : tx_report: 0
                      17:34:17.148 :
                      17:34:17.148 : ICMP
                      17:34:17.148 : xmit: 0
                      17:34:17.148 : recv: 0
                      17:34:17.148 : fw: 0
                      17:34:17.148 : drop: 0
                      17:34:17.148 : chkerr: 0
                      17:34:17.148 : lenerr: 0
                      17:34:17.148 : memerr: 0
                      17:34:17.148 : rterr: 0
                      17:34:17.148 : proterr: 0
                      17:34:17.148 : opterr: 0
                      17:34:17.148 : err: 0
                      17:34:17.148 : cachehit: 0
                      17:34:17.148 : UDP
                      17:34:17.149 : rterr: 0
                      17:34:17.149 : proterr: 0
                      17:34:17.149 : opterr: 0
                      17:34:17.149 : err: 0
                      17:34:17.149 : cachehit: 0
                      17:34:17.149 : TCP
                      17:34:17.149 : xmit: 0
                      17:34:17.149 : recv: 0
                      17:34:17.149 : fw: 0
                      17:34:17.149 : drop: 0
                      17:34:17.149 : chkerr: 0
                      17:34:17.149 : lenerr: 0
                      17:34:17.149 : memerr: 0
                      17:34:17.149 : MEM HEAP
                      17:34:17.149 : avail: 1024
                      17:34:17.150 : used: 0
                      17:34:17.150 : max: 0
                      17:34:17.150 : err: 0
                      17:34:17.150 : MEM UDP_PCB
                      17:34:17.150 : avail: 5
                      17:34:17.150 : used: 2
                      17:34:17.150 : max: 2
                      17:34:17.150 : MEM TCP_PCB
                      17:34:17.150 : avail: 16
                      17:34:17.150 : MEM TCP_PCB_LISTEN
                      17:34:17.151 : avail: 4
                      17:34:17.151 : used: 0
                      17:34:17.151 : max: 0
                      17:34:17.151 : err: 0
                      17:34:17.151 : MEM TCP_SEG
                      17:34:17.151 : avail: 16
                      17:34:17.151 : MEM REASSDATA
                      17:34:17.151 : avail: 2
                      17:34:17.151 : MEM FRAG_PBUF
                      17:34:17.151 : avail: 8
                      17:34:17.151 : MEM IGMP_GROUP
                      17:34:17.152 : avail: 8
                      17:34:17.152 : used: 0
                      17:34:17.152 : max: 0
                      17:34:17.152 : err: 0
                      17:34:17.152 : MEM SYS_TIMEOUT
                      17:34:17.152 : used: 6
                      17:34:17.152 : max: 6
                      17:34:17.152 : MEM PBUF_REF/ROM
                      17:34:17.152 : avail: 4
                      17:34:17.152 : MEM PBUF_POOL
                      17:34:17.152 : avail: 5
                      17:34:17.152 : === Diagnostics ===
                      17:34:17.153 : Used output buffers: 1 of 32 (15 max)
                      17:34:17.153 : === Platform ===
                      17:34:17.153 : RepRapFirmware for Duet version 1.20.1RC2 running on Duet 0.6
                      17:34:17.153 : Static ram used: 44836
                      17:34:17.153 : Dynamic ram used: 40508
                      17:34:17.153 : Recycled dynamic ram: 672
                      17:34:17.153 : Stack ram used: 3520 current, 5528 maximum
                      17:34:17.153 : Never used ram: 6760
                      17:34:17.154 : Last reset 00:07:46 ago, cause: power up
                      17:34:17.154 : Last software reset time unknown, reason: Stuck in spin loop, spinning module Network, available RAM 8620 bytes (slot 2)
                      17:34:17.154 : Software reset code 0x2041 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0440f80f, BFAR 0xe000ed38, SP 0x20087e6c
                      17:34:17.155 : Stack: 000bfb1f 01c8a8c0 fffffff9 00ffffff 20087ebc 20070fe8 01c8a8c0 20087ebc 000a6221 000a6220 21000000 20087ea0 2007a938 00000000 2007376c 200737a8 20087ebc 0000012c 2007aea8 75207369 01c8a8c0 2007376c 000a5b1d 2001376c
                      17:34:17.155 : Error status: 0
                      17:34:17.155 : Free file entries: 10
                      17:34:17.155 : SD card 0 detected, interface speed: 21.0MBytes/sec
                      17:34:17.155 : SD card longest block write time: 0.0ms
                      17:34:17.155 : MCU temperature: min 26.2, current 27.3, max 27.8
                      17:34:17.156 : Date/time: 1970-01-01 00:00:00
                      17:34:17.156 : Slowest main loop (seconds): 0.009165; fastest: 0.000104
                      17:34:17.156 : === Move ===
                      17:34:17.156 : MaxReps: 0, StepErrors: 0, LaErrors: 0, FreeDm: 100, MinFreeDm 100, MaxWait: 0ms, Underruns: 0, 0
                      17:34:17.156 : Scheduled moves: 0, completed moves: 0
                      17:34:17.156 : Bed compensation in use: none
                      17:34:17.157 : Bed probe heights: 0.000 0.000 0.000 0.000 0.000
                      17:34:17.157 : === Heat ===
                      17:34:17.157 : Bed heaters = 0, chamberHeaters = -1 -1
                      17:34:17.157 : === GCodes ===
                      17:34:17.157 : Segments left: 0
                      17:34:17.157 : Stack records: 1 allocated, 0 in use
                      17:34:17.157 : Movement lock held by null
                      17:34:17.157 : http is idle in state(s) 0
                      17:34:17.157 : telnet is idle in state(s) 0
                      17:34:17.157 : file is idle in state(s) 0
                      17:34:17.157 : serial is ready with "M122" in state(s) 0
                      17:34:17.158 : aux is idle in state(s) 0
                      17:34:17.158 : daemon is idle in state(s) 0
                      17:34:17.158 : queue is idle in state(s) 0
                      17:34:17.158 : autopause is idle in state(s) 0
                      17:34:17.158 : Code queue is empty.
                      17:34:17.158 : === Network ===
                      17:34:17.158 : Free connections: 16 of 16
                      17:34:17.158 : Free transactions: 24 of 24
                      17:34:17.158 : Locked: 0, state: 2, listening: 0x0, 0x0, 0x0
                      [/c]
                        Captain_sq
                        The "heartbeat" message
                        [c]17:36:25.475 : N151 M10534
                        17:36:25.476 : serial: M105
                        17:36:28.535 : N152 M105
                        33
                        17:36:28.537 : serial: M105
                        17:36:31.062 : Class GCodes spinning
                        17:36:31.062 : Class Move spinning
                        17:36:31.062 : Class Platform spinning
                        17:36:31.062 : Class Network spinning
                        17:36:31.064 : Class Heat spinning
                        17:36:31.064 : Class PrintMonitor spinning
                        17:36:31.601 : N153 M10532
                        17:36:31.602 : serial: M105
                        17:36:34.660 : N154 M105
                        39
                        17:36:34.661 : serial: M105
                        17:36:37.720 : N155 M10538
                        17:36:37.721 : serial: M105
                        17:36:40.786 : N156 M105
                        37
                        17:36:40.787 : serial: M105
                        [/c]
                        • RGN01undefined
                          RGN01
                          I upgraded my Duet WiFi firmware from 1.19 to 1.20 yesterday. All seems to be working but I'm getting strange error messages when I start a print. They start at layer 0 but I was slow to capture them - each layer gives an error like this:
                          [c]17:34:59Error: Bad command: // starting layer 19 at 2.47368mm
                          17:34:47Error: Bad command: // starting layer 18 at 2.4mm
                          17:34:35Error: Bad command: // starting layer 17 at 2.2mm
                          17:34:24Error: Bad command: // starting layer 16 at 2.18947mm
                          17:34:12Error: Bad command: // starting layer 15 at 2mm
                          17:34:01Error: Bad command: // starting layer 14 at 1.90526mm
                          17:33:49Error: Bad command: // starting layer 13 at 1.8mm
                          17:33:37Error: Bad command: // starting layer 12 at 1.62105mm
                          [/c]
                          The print worked OK but layer height was 0.2mm so I'm a little surprised by some of the layer heights.
                          What does this mean, please?
                          Richard
                          (edited to correct the starting layer from 1 to 0)
                          • RGN01undefined
                            RGN01
                            OK, I figured out what it is. The slicer was adding a comment to the beginning of each layer. This was in the format "// starting layer [layer_num] at [layer_z]mm"
                            The // was being interpreted as a comment but is no longer being interpreted so. I have changed the setting to "; starting layer [layer_num] at [layer_z]mm" and will try this as soon as I have finished the running print and can try another.
                            I'll report back once I confirm that this is the issue and is sorted.
                            • RGN01undefined
                              RGN01
                              This is confirmed - it was a slicer setting, nothing at all to do with the Duet firmware but a bit strange that the prior version didn't report errors with that format. Anyway, all sorted, thanks.
                              @RGN01:
                                @RGN01:
                                @RGN01:
                                It's because RRF now recognises lower case command letters, and also parses lines of gcode more thoroughly.
                                  @Captain_sq:
                                  Thanks, that should help me to track the problem down.
                                    Captain_sq
                                    I've gone back to 1.19 while your busy finding the rodent messing around in the Network task in the 0.6 hardware. I kept the newest DWC and found that this also works with 1.19 FW. Nice with some new functionality. I'm not sure wether all the new controls works for real with 1.19 but the extended system edit possibilities are welcome.
                                      I have it on my list to investigate your report before the 1.20.1 release, however I need to get the prototype laser filament sensors completed and shipped first to avoid additional delay to production of filament sensors.
                                      • Luca79undefined
                                        Luca79
                                        Just tried to upgrade from 1.19 to 1.20. I've uploaded DuetWifiFirmware.bin, but I cannot connect anymore to the printer via wireless. Any idea?
                                        • Luca79undefined
                                          Luca79
                                          Adding some bits. I also tried connecting through USB but the serial device is not recognized by my linux machine (before upgrading used to work).
                                          EDIT: i have tried the fallback procedure #2 described at https://duet3d.com/wiki/Updating_main_firmware but it still doesn't work.
                                            The USB interface code did not change between 1.19 and 1.20, so I don't understand why you can't access the Duet over USB any more. Do you have any evidence that the firmware update succeeded in other ways, e.g. because an attached PanelDue is working?
