    Firmware 1.20 released
    Firmware installation
    20
    89
    14.2k
      If you run M122 from USB, how much free memory does it report?
      • Captain_squndefined
        Captain_sq
        I'm not sure wich number you're after so I copied the entire response:
        [c]17:34:17.138 : serial: M122
        17:34:17.143 : LINK
        17:34:17.145 : xmit: 0
        17:34:17.145 : recv: 0
        17:34:17.145 : fw: 0
        17:34:17.145 : drop: 0
        17:34:17.145 : chkerr: 0
        17:34:17.145 : lenerr: 0
        17:34:17.145 : memerr: 0
        17:34:17.145 : rterr: 0
        17:34:17.145 : proterr: 0
        17:34:17.145 : opterr: 0
        17:34:17.145 : err: 0
        17:34:17.145 : cachehit: 0
        17:34:17.145 : ETHARP
        17:34:17.146 : proterr: 0
        17:34:17.146 : opterr: 0
        17:34:17.146 : err: 0
        17:34:17.146 : cachehit: 0
        17:34:17.146 : IP_FRAG
        17:34:17.146 : xmit: 0
        17:34:17.146 : recv: 0
        17:34:17.146 : fw: 0
        17:34:17.146 : drop: 0
        17:34:17.146 : chkerr: 0
        17:34:17.146 : lenerr: 0
        17:34:17.146 : memerr: 0
        17:34:17.146 : rterr: 0
        17:34:17.146 : IP
        17:34:17.147 : memerr: 0
        17:34:17.147 : rterr: 0
        17:34:17.147 : proterr: 0
        17:34:17.147 : opterr: 0
        17:34:17.147 : err: 0
        17:34:17.147 : cachehit: 0
        17:34:17.147 : IGMP
        17:34:17.147 : xmit: 0
        17:34:17.147 : recv: 0
        17:34:17.147 : drop: 0
        17:34:17.147 : chkerr: 0
        17:34:17.147 : lenerr: 0
        17:34:17.147 : rx_v1: 0
        17:34:17.147 : rx_group: 0
        17:34:17.147 : rx_general: 0
        17:34:17.147 : rx_report: 0
        17:34:17.147 : tx_join: 0
        17:34:17.148 : tx_leave: 0
        17:34:17.148 : tx_report: 0
        17:34:17.148 :
        17:34:17.148 : ICMP
        17:34:17.148 : xmit: 0
        17:34:17.148 : recv: 0
        17:34:17.148 : fw: 0
        17:34:17.148 : drop: 0
        17:34:17.148 : chkerr: 0
        17:34:17.148 : lenerr: 0
        17:34:17.148 : memerr: 0
        17:34:17.148 : rterr: 0
        17:34:17.148 : proterr: 0
        17:34:17.148 : opterr: 0
        17:34:17.148 : err: 0
        17:34:17.148 : cachehit: 0
        17:34:17.148 : UDP
        17:34:17.149 : rterr: 0
        17:34:17.149 : proterr: 0
        17:34:17.149 : opterr: 0
        17:34:17.149 : err: 0
        17:34:17.149 : cachehit: 0
        17:34:17.149 : TCP
        17:34:17.149 : xmit: 0
        17:34:17.149 : recv: 0
        17:34:17.149 : fw: 0
        17:34:17.149 : drop: 0
        17:34:17.149 : chkerr: 0
        17:34:17.149 : lenerr: 0
        17:34:17.149 : memerr: 0
        17:34:17.149 : MEM HEAP
        17:34:17.149 : avail: 1024
        17:34:17.150 : used: 0
        17:34:17.150 : max: 0
        17:34:17.150 : err: 0
        17:34:17.150 : MEM UDP_PCB
        17:34:17.150 : avail: 5
        17:34:17.150 : used: 2
        17:34:17.150 : max: 2
        17:34:17.150 : MEM TCP_PCB
        17:34:17.150 : avail: 16
        17:34:17.150 : MEM TCP_PCB_LISTEN
        17:34:17.151 : avail: 4
        17:34:17.151 : used: 0
        17:34:17.151 : max: 0
        17:34:17.151 : err: 0
        17:34:17.151 : MEM TCP_SEG
        17:34:17.151 : avail: 16
        17:34:17.151 : MEM REASSDATA
        17:34:17.151 : avail: 2
        17:34:17.151 : MEM FRAG_PBUF
        17:34:17.151 : avail: 8
        17:34:17.151 : MEM IGMP_GROUP
        17:34:17.152 : avail: 8
        17:34:17.152 : used: 0
        17:34:17.152 : max: 0
        17:34:17.152 : err: 0
        17:34:17.152 : MEM SYS_TIMEOUT
        17:34:17.152 : used: 6
        17:34:17.152 : max: 6
        17:34:17.152 : MEM PBUF_REF/ROM
        17:34:17.152 : avail: 4
        17:34:17.152 : MEM PBUF_POOL
        17:34:17.152 : avail: 5
        17:34:17.152 : === Diagnostics ===
        17:34:17.153 : Used output buffers: 1 of 32 (15 max)
        17:34:17.153 : === Platform ===
        17:34:17.153 : RepRapFirmware for Duet version 1.20.1RC2 running on Duet 0.6
        17:34:17.153 : Static ram used: 44836
        17:34:17.153 : Dynamic ram used: 40508
        17:34:17.153 : Recycled dynamic ram: 672
        17:34:17.153 : Stack ram used: 3520 current, 5528 maximum
        17:34:17.153 : Never used ram: 6760
        17:34:17.154 : Last reset 00:07:46 ago, cause: power up
        17:34:17.154 : Last software reset time unknown, reason: Stuck in spin loop, spinning module Network, available RAM 8620 bytes (slot 2)
        17:34:17.154 : Software reset code 0x2041 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0440f80f, BFAR 0xe000ed38, SP 0x20087e6c
        17:34:17.155 : Stack: 000bfb1f 01c8a8c0 fffffff9 00ffffff 20087ebc 20070fe8 01c8a8c0 20087ebc 000a6221 000a6220 21000000 20087ea0 2007a938 00000000 2007376c 200737a8 20087ebc 0000012c 2007aea8 75207369 01c8a8c0 2007376c 000a5b1d 2001376c
        17:34:17.155 : Error status: 0
        17:34:17.155 : Free file entries: 10
        17:34:17.155 : SD card 0 detected, interface speed: 21.0MBytes/sec
        17:34:17.155 : SD card longest block write time: 0.0ms
        17:34:17.155 : MCU temperature: min 26.2, current 27.3, max 27.8
        17:34:17.156 : Date/time: 1970-01-01 00:00:00
        17:34:17.156 : Slowest main loop (seconds): 0.009165; fastest: 0.000104
        17:34:17.156 : === Move ===
        17:34:17.156 : MaxReps: 0, StepErrors: 0, LaErrors: 0, FreeDm: 100, MinFreeDm 100, MaxWait: 0ms, Underruns: 0, 0
        17:34:17.156 : Scheduled moves: 0, completed moves: 0
        17:34:17.156 : Bed compensation in use: none
        17:34:17.157 : Bed probe heights: 0.000 0.000 0.000 0.000 0.000
        17:34:17.157 : === Heat ===
        17:34:17.157 : Bed heaters = 0, chamberHeaters = -1 -1
        17:34:17.157 : === GCodes ===
        17:34:17.157 : Segments left: 0
        17:34:17.157 : Stack records: 1 allocated, 0 in use
        17:34:17.157 : Movement lock held by null
        17:34:17.157 : http is idle in state(s) 0
        17:34:17.157 : telnet is idle in state(s) 0
        17:34:17.157 : file is idle in state(s) 0
        17:34:17.157 : serial is ready with "M122" in state(s) 0
        17:34:17.158 : aux is idle in state(s) 0
        17:34:17.158 : daemon is idle in state(s) 0
        17:34:17.158 : queue is idle in state(s) 0
        17:34:17.158 : autopause is idle in state(s) 0
        17:34:17.158 : Code queue is empty.
        17:34:17.158 : === Network ===
        17:34:17.158 : Free connections: 16 of 16
        17:34:17.158 : Free transactions: 24 of 24
        17:34:17.158 : Locked: 0, state: 2, listening: 0x0, 0x0, 0x0
        [/c]
        Custom made Kossel Mini - Duet WiFi / Modded Tronxy X5S - Duet WiFi / Prusa i3 MKIII
        Embedded systems designer, RC Pilot, maker and Gadget-o-holic
          Captain_sq
          The "heartbeat" message
          [c]17:36:25.475 : N151 M10534
          17:36:25.476 : serial: M105
          17:36:28.535 : N152 M105
          33
          17:36:28.537 : serial: M105
          17:36:31.062 : Class GCodes spinning
          17:36:31.062 : Class Move spinning
          17:36:31.062 : Class Platform spinning
          17:36:31.062 : Class Network spinning
          17:36:31.064 : Class Heat spinning
          17:36:31.064 : Class PrintMonitor spinning
          17:36:31.601 : N153 M10532
          17:36:31.602 : serial: M105
          17:36:34.660 : N154 M105
          39
          17:36:34.661 : serial: M105
          17:36:37.720 : N155 M10538
          17:36:37.721 : serial: M105
          17:36:40.786 : N156 M105
          37
          17:36:40.787 : serial: M105
          [/c]
          • RGN01undefined
            RGN01
            I upgraded my Duet WiFi firmware from 1.19 to 1.20 yesterday. All seems to be working but I'm getting strange error messages when I start a print. They start at layer 0 but I was slow to capture them - each layer gives an error like this:
            [c]17:34:59Error: Bad command: // starting layer 19 at 2.47368mm
            17:34:47Error: Bad command: // starting layer 18 at 2.4mm
            17:34:35Error: Bad command: // starting layer 17 at 2.2mm
            17:34:24Error: Bad command: // starting layer 16 at 2.18947mm
            17:34:12Error: Bad command: // starting layer 15 at 2mm
            17:34:01Error: Bad command: // starting layer 14 at 1.90526mm
            17:33:49Error: Bad command: // starting layer 13 at 1.8mm
            17:33:37Error: Bad command: // starting layer 12 at 1.62105mm
            [/c]
            The print worked OK but layer height was 0.2mm so I'm a little surprised by some of the layer heights.
            What does this mean, please?
            Richard
            (edited to correct the starting layer from 1 to 0)
            • RGN01undefined
              RGN01
              OK, I figured out what it is. The slicer was adding a comment to the beginning of each layer. This was in the format "// starting layer [layer_num] at [layer_z]mm"
              The // was being interpreted as a comment but is no longer being interpreted so. I have changed the setting to "; starting layer [layer_num] at [layer_z]mm" and will try this as soon as I have finished the running print and can try another.
              I'll report back once I confirm that this is the issue and is sorted.
              • RGN01undefined
                RGN01
                This is confirmed - it was a slicer setting, nothing at all to do with the Duet firmware but a bit strange that the prior version didn't report errors with that format. Anyway, all sorted, thanks.
                @RGN01:
                  @RGN01:
                  @RGN01:
                  It's because RRF now recognises lower case command letters, and also parses lines of gcode more thoroughly.
                    @Captain_sq:
                    Thanks, that should help me to track the problem down.
                      Captain_sq
                      I've gone back to 1.19 while your busy finding the rodent messing around in the Network task in the 0.6 hardware. I kept the newest DWC and found that this also works with 1.19 FW. Nice with some new functionality. I'm not sure wether all the new controls works for real with 1.19 but the extended system edit possibilities are welcome.
                        I have it on my list to investigate your report before the 1.20.1 release, however I need to get the prototype laser filament sensors completed and shipped first to avoid additional delay to production of filament sensors.
                        • Luca79undefined
                          Luca79
                          Just tried to upgrade from 1.19 to 1.20. I've uploaded DuetWifiFirmware.bin, but I cannot connect anymore to the printer via wireless. Any idea?
                          • Luca79undefined
                            Luca79
                            Adding some bits. I also tried connecting through USB but the serial device is not recognized by my linux machine (before upgrading used to work).
                            EDIT: i have tried the fallback procedure #2 described at https://duet3d.com/wiki/Updating_main_firmware but it still doesn't work.
                              The USB interface code did not change between 1.19 and 1.20, so I don't understand why you can't access the Duet over USB any more. Do you have any evidence that the firmware update succeeded in other ways, e.g. because an attached PanelDue is working?
                              • Luca79undefined
                                Luca79
                                I don't own a PanelDue. I don't know how to debug this.
                                  So as far as you know, the board isn't running at all. See https://duet3d.com/wiki/What_to_do_if_your_Duet_or_Duet_WiFi_won%27t_respond.
                                  • abitidiundefined
                                    abitidi
                                    I just want to report that the github link on this wiki page is broken. https://duet3d.com/wiki/Updating_main_firmware
                                      deckingman
                                      @abitidi:
                                      Works for me. Maybe it got fixed between your post and mine?
                                      • abitidiundefined
                                        abitidi
                                        @deckingman:
                                        Weird…I still get a 404 when I try the link.
                                          I just tried it again (using the link in deckingman's post above) and it works for me.
                                          • Dougal1957undefined
                                            Dougal1957
                                            it also works for me with no issues (From the OP's original link)
