    Publishing external/additional Inputs to ObjectModel
    DSF Development
    500
    • reroundefined
      rero
      Good Evening,
      we plan a setup with a Duet3 Mini5+ and a RPi-5 in SBC mode.
      We also want to use additional (most of them digital) inputs from an external uC-Board (we design/implement ourselves). These inputs/values will be used in different macros on the Duet-Board.
      As far as I understood, it is not possible to publish/modify global variables of the ObjectModel directly, if the systems runs in SPI (https://forum.duet3d.com/topic/31248/modify-a-global-variable-value).
      So possible ways to go are:
      a) write a C#/Python-Daemon who periodically pushes the input-states via a simple NC-command to the board ("set global.my_input=...")
      b) write a NC-filter-daemon to intercept user-defined M-Codes to query the inputs (not sure if this will work / if NC-macros can parse/handle the answers from the M-codes correctly).
      c) modify our uC-Board to support Duet's CAN-Bus (like the Sammy-C21) and publish relevant inputs over CAN
      I would prefer solution a) or b).
      May I run into other issues doing this or is there a better, more elegant solution for my problem?
      Thanks and regards,
      Reiner
        dc42 administrators @rero
        @rero global variables are already published in the Object Model. The current states of GpIn pins on the Duet are also published.
        reroundefined 1 Reply Last reply Reply Quote 0
        • reroundefined
          rero @dc42
          @dc42 thanks for your quick reply.
          The inputs I am referring to are not on the Duet, they are on an extra 'standalone' board.
          But I need to handle some of these inputs in Duet-Macros to execute axis-motions depending on the inputs(-states).
          So I would like to update the input-state via DSF (C#- or python), e.g. I would update their value twice per second with a call to 'perform_simple_code("set global.var_name=value")' for every input.
          Can this cause performance-issues when a nc-job is running?
          Regards,
          Reiner
          • chrishammundefined
            chrishamm administrators @rero
            @rero In SBC mode, it doesn't really make sense to use global variables to store SBC-specific data in the object model. Instead, consider defining a custom JSON object in the plugin.json manifest of your new plugin and define it using the data property:
              "data": {
                "myVal": 123
            and update it using the SetPluginData IPC command:
            conn/set_plugin_data("myVal", 456, <plugin ID if plugin is not started by DSF>)
            Then you can access it using plugins.<plugin ID>.data.myVal in meta G-code expressions.
            See also https://github.com/Duet3D/DuetSoftwareFramework/wiki/Third-Party-Plugins
            Duet software engineer
            • reroundefined
              rero @chrishamm
              @chrishamm perfect! That was the detail I was searching for 👍
              I will prepare a test-setup with an arduino and some buttons/LEDs to see how it works.
              Thanks for your quick help @dc42 and @chrishamm!
              • reroundefined
                rero @rero
                So with the usual fiddling around I was able to prepare a test-configuration.
                Everything works as expected except one thing: updating the plugin-data via "set_plugin_data".
                I declared 4 inputs and 4 outputs in the plugins plugin.json description file. After installing the plugin the object-model looks like this:
                Once I modified the plugins data for a single input with this code:
                if gOutputs[i]:
                  plugin_update_connection.set_plugin_data("IOExample", "output{0}".format(i),"1")
                else:
                  plugin_update_connection.set_plugin_data("IOExample", "output{0}".format(i),"0")
                All the data properties/values are lost and only the last one modified remains:
                I tried to lock/unlock the object-model and also to update all 4 inputs in a for-loops, didn't work too...
                @chrishamm any idea what is causing this?
                  @rero Are you using software version 3.5 or 3.6-beta?
                  reroundefined 2 Replies Last reply Reply Quote 0
                  • reroundefined
                    rero @chrishamm
                    @chrishamm I was using stable 3.5.4
                    Tried unstable 3.6.0-beta2 tonite and got a different behaviour, the connection was closed by the server with this error "Closing connection: Internal Server Exception" when calling set_plugin_data.
                    I tried to call the function with a wrong key-name and/or wrong plugin-id, but this didn't change anything.
                    The log with debug enabled looks like:
                    Dec 09 23:44:01 duetpi DuetControlServer[725]: [debug] IPC#62: Granting full DSF permissions to external plugin
                    Dec 09 23:44:01 duetpi DuetControlServer[725]: [debug] Command processor added for IPC#62
                    Dec 09 23:44:01 duetpi DuetControlServer[725]: [debug] IPC#62: Received command WriteMessage
                    Dec 09 23:44:01 duetpi DuetControlServer[725]: [info] [IOExample]: IO [auto:True; inputs:True,False,False,True; outputs:True,False,False,False]
                    Dec 09 23:44:01 duetpi DuetControlServer[725]: [debug] Got new connection IPC#63, checking permissions...
                    Dec 09 23:44:01 duetpi DuetControlServer[725]: [debug] IPC#63: Granting full DSF permissions to external plugin
                    Dec 09 23:44:01 duetpi DuetControlServer[725]: [debug] IPC#62: Connection closed
                    Dec 09 23:44:01 duetpi DuetControlServer[725]: [debug] Command processor added for IPC#63
                    Dec 09 23:44:01 duetpi DuetControlServer[725]: [debug] IPC#63: Received command WriteMessage
                    Dec 09 23:44:01 duetpi DuetControlServer[725]: [info] [IOExample]: Closing connection:  Internal Server Exception
                    Dec 09 23:44:01 duetpi DuetControlServer[725]: [debug] IPC#63: Connection closed
                    Dec 09 23:44:01 duetpi DuetPluginService[1702]: [info] Plugin IOExample: Process has been stopped with exit code 0
                    Calling the function ('set_plugin_data("IOExample", "output0", 1)') with a non-string value gives a different error:
                    "Closing connection: value must be a string"
                    Anything else I can test ... ?
                    chrishammundefined AndyE3Dundefined 3 Replies Last reply Reply Quote 0
                      @rero The dsf-python library for v3.6 is being overhauled, because unfortunately it didn't fully adhere to the IPC protocol standard. A while ago I made a DSF plugin in C# for DSF 3.5 and that worked well with SetPluginData but I'm going to test it again to be sure.
                      Version 3.5.4 should work as expected, but note that I've never tested the Python set_plugin_data function myself.
                      • AndyE3Dundefined
                        AndyE3D @rero
                        @rero Hi, these errors should be fixed in dsf-python 3.6.0-b2.post3. Let me know if you have any further issues
                        AndyE3Dundefined 1 Reply Last reply Reply Quote 0
                        • AndyE3Dundefined
                          AndyE3D @AndyE3D
                          @rero regarding the issue where the data variables disappear from the OM, in my testing on 3.6-b2 the variables are still accessible with meta gcode but are not being displayed by the OM plugin correctly. This is likely a DWC issue which @chrishamm is looking into.
                          You can test if the variables still exist with
                          echo {plugins.IOExample.data.output0}
                          echo {plugins.IOExample.data.output1}
                          echo {plugins.IOExample.data.output2}
                          echo {plugins.IOExample.data.output3}
                            @rero I could confirm that there is a problem in DWC preventing the correct display of updated plugin data even though it's correct in DSF. I've got a fix ready for the next DWC beta. Thanks for reporting this!
                            • reroundefined
                              rero @chrishamm
                              @AndyE3D @chrishamm thanks for the investigations and the fixes.
                              Did a quick test, stayed with 3.6.0-beta2 and updated dsy-python to 3.6.0-b2.post3:
                              -> No exception/exit anymore
                              -> String-values are correctly set via set_plugin_data
                              -> Object model plugin variables disappear (only last one modified is visible), accessing them via 'echo ..." works
                              Reloading the OM-plugin page via browser reload also brings back all values.
                              Will test tomorrow if using non-string values also works for me and also test 3.5.4 again.
                              Thanks for your help, have a good evening!
                              reroundefined 1 Reply Last reply Reply Quote 1
                              • reroundefined
                                rero @rero
                                Final tests:
                                For 3.6.0-beta2(.post3) all relevant data-types (float,int,bool,string) worked as expected.
                                For 3.5.4 with dsf-python-3.5.0 setting string-data and accessing it via "echo ..." also works.
                                So issue solved for me - merci!
                                Thx @all for their support to answer questions and find/solve issues!
