    Gcode upload with python and OpenAPI
    Third-party software
    560
    • cnc65undefined
      cnc65
      I am trying to write a Python program to control a Duet 3 mainboard 6HC via Ethernet. I am using the OpenAPI definition for standalone mode. Everything works well except for the file upload function.
      When I run my test program, I get this error message:
      File Path exists: True
      Exception when calling DefaultApi->rr_upload_post: (0)
      Reason: Cannot prepare a request message for provided arguments. Please check that your arguments match declared content type.
      Does anyone have any idea what I am doing wrong?
      Here is my test program:
      #! /usr/bin/python3
      # -*- coding: utf-8 -*-
      Duet file upload test
      from __future__ import print_function
      import os
      from datetime import datetime
      import swagger_client
      from swagger_client.rest import ApiException
      from pprint import pprint
      create an instance of the API class and connect Duet to
      fixed host address DUET_HOST
      configuration = swagger_client.Configuration()
      configuration.host = "http://192.168.2.1"
      # instance of the API class
      api_instance = swagger_client.DefaultApi(swagger_client.ApiClient(configuration))
      time = datetime.now()
      try:
          # new connection and log in
          duet_response = api_instance.rr_connect_get(password="", time=time)
      except ApiException as e:
          print("Exception when calling DefaultApi->rr_connect_get: %s\n" % e)
      # Upload a file
      file = "f:/temp/test.g"
      print("File Path exists: ", os.path.exists(file))
      try:
          duet_response = api_instance.rr_upload_post(file)
          print("Exception when calling DefaultApi->rr_upload_post: %s\n" % e)
      # Disconnect Duet
      try:
          duet_response = api_instance.rr_disconnect_get()
          # pprint(duet_response)
          print("Exception when calling DefaultApi->rr_disconnect_get: %s\n" % e)
        T3P3Tony administrators @cnc65
        @cnc65 which version of the firmware are you using? Are you using the same version of the api yaml file in swagger to generate the api code. e.g. 3.6 is here for stand alone mode:
        https://github.com/Duet3D/RepRapFirmware/blob/3.6-dev/Developer-documentation/OpenAPI.yaml
        • cnc65undefined
          cnc65
          RepRapFirmware: 3.5.4
          OpenAPI yaml: 3.6 and also tested with 3.4
            @cnc65 I am not a python expert but I used swagger to generate a python api using 3.6.0.
            Looking at that code for your error message i found it in "rest.py":
              def request(self, method, url, query_params=None, headers=None,
                            body=None, post_params=None, _preload_content=True,
                            _request_timeout=None):
                    """Perform requests.
                    :param method: http request method
                    :param url: http request url
                    :param query_params: query parameters in the url
                    :param headers: http request headers
                    :param body: request json body, for `application/json`
                    :param post_params: request post parameters,
                                        `application/x-www-form-urlencoded`
                                        and `multipart/form-data`
                    :param _preload_content: if False, the urllib3.HTTPResponse object will
                                             be returned without reading/decoding response
                                             data. Default is True.
                    :param _request_timeout: timeout setting for this request. If one
                                             number provided, it will be total request
                                             timeout. It can also be a pair (tuple) of
                                             (connection, read) timeouts.
                    method = method.upper()
                    assert method in ['GET', 'HEAD', 'DELETE', 'POST', 'PUT',
                                      'PATCH', 'OPTIONS']
                    if post_params and body:
                        raise ValueError(
                            "body parameter cannot be used with post_params parameter."
                    post_params = post_params or {}
                    headers = headers or {}
                    timeout = None
                    if _request_timeout:
                        if isinstance(_request_timeout, (int, ) if six.PY3 else (int, long)):  # noqa: E501,F821
                            timeout = urllib3.Timeout(total=_request_timeout)
                        elif (isinstance(_request_timeout, tuple) and
                              len(_request_timeout) == 2):
                                connect=_request_timeout[0], read=_request_timeout[1])
                    if 'Content-Type' not in headers:
                        headers['Content-Type'] = 'application/json'
                    try:
                        # For `POST`, `PUT`, `PATCH`, `OPTIONS`, `DELETE`
                        if method in ['POST', 'PUT', 'PATCH', 'OPTIONS', 'DELETE']:
                            if query_params:
                                url += '?' + urlencode(query_params)
                            if re.search('json', headers['Content-Type'], re.IGNORECASE):
                                request_body = '{}'
                                if body is not None:
                                    request_body = json.dumps(body)
                                r = self.pool_manager.request(
                                    method, url,
                                    body=request_body,
                                    preload_content=_preload_content,
                                    timeout=timeout,
                                    headers=headers)
                            elif headers['Content-Type'] == 'application/x-www-form-urlencoded':  # noqa: E501
                                    method, url,
                                    fields=post_params,
                                    encode_multipart=False,
                                    timeout=timeout,
                                    headers=headers)
                            elif headers['Content-Type'] == 'multipart/form-data':
                                # must del headers['Content-Type'], or the correct
                                # Content-Type which generated by urllib3 will be
                                # overwritten.
                                    method, url,
                                    fields=post_params,
                                    encode_multipart=True,
                                    timeout=timeout,
                                    headers=headers)
                            # Pass a `string` parameter directly in the body to support
                            # other content types than Json when `body` argument is
                            # provided in serialized form
                            elif isinstance(body, str):
                                request_body = body
                                    method, url,
                                    body=request_body,
                                    timeout=timeout,
                                    headers=headers)
                            else:
                                # Cannot generate the request from given parameters
                                msg = """Cannot prepare a request message for provided
                                         declared content type."""
                                raise ApiException(status=0, reason=msg)
                        # For `GET`, `HEAD`
            Does that shed any light on why its failing?
            Things to try:
            Use the CURL commands as a test in the documentation here;
            https://github.com/Duet3D/RepRapFirmware/wiki/HTTP-requests#post-rr_upload
            That proves the duet side of things
            Have thieving on the same version (preferably 3.6, so for RRF use 3.6beta4)
            • cnc65undefined
              cnc65
              @T3P3Tony Thank you for your help.
              What I have tried so far:
              1. Update RRF to 3.6beta4
              2. Test CURL commands:
              F:\temp>curl http://192.168.2.1/rr_connect?password=
              {"err":0,"sessionTimeout":8000,"boardType":"duet3mb6hc102","apiLevel":2,"sessionKey":0}
              F:\temp>curl --data-binary @"test.g" "http://192.168.2.1/rr_upload?name=/gcodes/test.g"
              {"err":0}
              F:\temp>
              No success with Python so far.
              What I dont understand is that the Python function generated from OpenAPI has only one parameter "name". The parameters "time" and "crc32" are optional. But at least two variables are required: source(path_and_filename.gcode) and destination(name) like in CURL.
              rr_upload_post
              Example
              import time
              # create an instance of the API class
              api_instance = swagger_client.DefaultApi()
              name = 'name_example' # str | Path to the file to upload
              time = '2013-10-20T19:20:30+01:00' # datetime | ISO8601-like represenation of the time the file was last modified (optional)
              crc32 = 'crc32_example' # str | CRC32 checksum of the file content as hex string *without* leading `0x`. Usage of this parameter is encouraged (optional)
              try:
                  # Upload a file
                  api_response = api_instance.rr_upload_post(name, time=time, crc32=crc32)
                  pprint(api_response)
              Parameters
              Name Type Description Notes
              name str Path to the file to upload
              time datetime ISO8601-like represenation of the time the file was last modified [optional]
              crc32 str CRC32 checksum of the file content as hex string without leading `0x`. Usage of this parameter is encouraged [optional]
                @cnc65 said in Gcode upload with python and OpenAPI:
                so curl is working, there is an issue with the python implementation or the API description in YAML file
                What I don't understand is that the Python function generated from OpenAPI has only one parameter "name". The parameters "time" and "crc32" are optional. But at least two variables are required: source(path_and_filename.gcode) and destination(name) like in CURL.
                I think the "name" parameter is the destination path & filename. however the comments in the YAML file imply its the source:
                parameters:
                               - name: 'name'
                                 in: query
                                 description: 'Path to the file to upload'
                                 required: true
                                 schema:
                                     type: string
                               - name: 'time'
                                 in: query
                                 description: 'ISO8601-like represenation of the time the file was last modified'
                                 required: false
                                 schema:
                                     type: string
                                     format: 'date-time'
                               - name: 'crc32'
                                 in: query
                                 description: 'CRC32 checksum of the file content as hex string *without* leading `0x`. Usage of this parameter is encouraged'
                                 required: false
                                 schema:
                                     type: string
                @chrishamm can you help?
                • cnc65undefined
                  cnc65
                  Is a solution to this problem in progress?
                  • cnc65undefined cnc65 marked this topic as a question
                  • chrishammundefined
                    chrishamm administrators @cnc65
                    @cnc65 @T3P3Tony is right. name specifies the target filename (e.g. /gcodes/foobar.gcode) and the body must contain the file content. I don't know why the generated API does not provide an extra parameter for the file content, though - it's there in the OpenAPI definition.
                    Duet software engineer
                      T3P3Tony administrators @chrishamm
                      @chrishamm can you point to where it is in the API definition? I.e. where is "body" is specified in the definition?
                        chrishamm administrators @T3P3Tony
                        @T3P3Tony Here: https://github.com/Duet3D/RepRapFirmware/blob/3.6-dev/Developer-documentation/OpenAPI.yaml#L174 and here: https://github.com/Duet3D/RepRapFirmware/wiki/HTTP-requests#post-rr_upload
                          @chrishamm thanks so this is some issue with swagger?
                            @T3P3Tony Perhaps it was the GET request, not the POST request? I'm not sure.
                              @chrishamm I looked at the swagger post code.
                              • cnc65undefined
                                cnc65
                                @chrishamm @T3P3Tony
                                I have changed the requestBody in the OpenAPI.yaml file so that a parameter body is generated in Python. This works for uploading gcode files. I have not tested other files.
                                requestBody:
                                	required: true
                                	description: 'File content'
                                		content:
                                			application/octet-stream:
                                			schema:
                                				type: string
                                				format: binary
                                The function call in Python then looks like this:
                                # Upload a file
                                name = "0:/gcodes/test-1.g"
                                try:
                                    body = open(file).read()
                                    duet_response = api_instance.rr_upload_post(body, name)
                                • cnc65undefined cnc65 has marked this topic as solved
