    Need help changing an X or Y coordinate into a variable
    Gcode meta commands
    416
    • Strider007undefined
      Strider007 @fcwilt
      @fcwilt Yes, I send a "G38.2 X10 F100" command, the machine moves until the sensor is tripped and stops. I want that exact X coordinate where it stopped as a number to be used in in alignment calculations.
      zuoyanundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
      • zuoyanundefined
        zuoyan @Strider007
        @Strider007 You can search "duet object model", it should be move.axes[0-1].machinePosittion -- You can also explore the object model list in DWC
        Strider007undefined 1 Reply Last reply Reply Quote 0
        • fcwiltundefined
          fcwilt @Strider007
          @Strider007
          See if this will work:
          For the X:
          move.axes[0].machinePosition or move.axes[0].userPosition
          For the Y:
          move.axes[1].machinePosition or move.axes[1].userPosition
            Strider007 @fcwilt
            @fcwilt Thanks,
            Ok, tried all combinations of your suggestions and only got error messages as follows:
            Error: Bad command: move.axes[0].
            Error: Bad command: machinePosition
            I had hoped that would work and had tried it already. What am I missing here?
            I
              Strider007 @zuoyan
              @zuoyan
              Its a long list, and I've looked through it multiple times. I probably should have mentioned that. That's when I found the two suggestions that fcwilt gave me but no success so far. Thanks
                Strider007 @Strider007
                @Strider007 Ok, now studying M409, and I think I got this working.
                Thanks all
                • fcwiltundefined
                  fcwilt @Strider007
                  @Strider007
                  Those are not to be executed - they are merely variables holding those values.
                  To use such values, say, to move to a position, you would do something like
                  G1 X{move.axes[0].machinePosition} Y{move.axes[1].machinePosition}
                  The question is do those variables hold the values you desire. Compare them against what you see in the DWC, assuming the DWC is showing the values you seek.
                    Strider007 @fcwilt
                    @fcwilt
                    Yes, when I echo, that is the number I want to store as a temp variable then use in calculations of tool offsets.
                    echo "it is", move.axes[0].machinePosition
                    it is -118.088
                    Thank you for your guidance. I believe I 've got it from here.
                    • fcwiltundefined
                      fcwilt @Strider007
                      @Strider007
                      To save a value from the Object Model (OM) into a local variable you do something like:
                      var Xvalue = move.axes[0].machinePosition
                      var Yvalue = move.axes[1].machinePosition
                      Or it you want it to be persistent so you can use it later or in other code:
                      global Xvalue = move.axes[0].machinePosition
                      global Yvalue = move.axes[1].machinePosition
                      Good Luck.
                        Strider007 @fcwilt
                        @fcwilt Exactly what I needed to get past my mental roadblock. Some small code blocks doing just what I need. Now to refine the hardware to go with it. Most appreciated Gilly
