3.6.0B4 object model calibration final deviation value
in the new beta versions v6.3.0 the value displaying the final deviation value has changed from mm rounded to 3 decimal places to a scientific notation format , will it be like this in the future or is this a mistake?
v3.5.3
v3.60b2
v3.6.0b4
it would be nice to select the number of decimal places , but as it was was ok
undefined moth4017 referenced this topic
@moth4017 in RRF 3.5 and earlier, each floating point field in the object model is displayed to a set number of decimal places. This has some undesirable consequences, for example the C parameter in the thermistor configuration is reported as zero whereas in reality it has a small but very significant value. For this reason, RRF 3.6 reports very small values in scientific notation instead. What's happening here is that because of floating point rounding error, the final deviation is computed as a very small number instead of zero, which is why 3.6 reports it in scientific notation.
BTW if you use more probe points than leadscrews, the final deviation won't be zero, which is why we report it.
