    HY VFD controlled by Duet 3 Mini
    CNC
    693
    • dhusoloundefined
      dhusolo @dc42
      My VFD is the 110v 2.2kw 80mm spindle purchased from Amazon and is supposedly a clone of this one.
      Closest thing I could find from HY is this one
      Otherwise the only thing I have from the seller is a paper manual.
      • dhusoloundefined
        dhusolo @dc42
        @dc42 From what I can see it's the HY02D211B VFD. I've got it kind of working. I can control the speed from S6000 to S7000 but it'll max out at 7000, even if I enter s24000.
        RRF version 3.5.4
        Wifi Server 2.2.0
        DWC 3.5.4
        I've got a jumper wire in between DCM and FOR on the VFD
        Out6_buff/VFD goes to pulse input +
        and VFD GND goes to pulse input -
        This is the one I'm using link text
        ; Configuration file for Duet WiFi (firmware version 3.4.6)
        ; generated by RepRapFirmware Configuration Tool v3.4.6 on Wed Oct 10 2023 (Central Standard Time)
        M552 S1                                     ; enable wifi
        G90                                         ; send absolute coordinates...
        M83                                         ; ...but relative extruder moves
        M550 P"CNC"                                 ; set printer name
        M453                                        ; configure CNC mode
        ; Kinematics
        M669 K0                                     ; configure Cartesian kinematics
        M569 P0.0 S0                          		; physical drive 0.0 goes forwards
        M569 P0.1 S1                          		; physical drive 0.1 goes backwards
        M569 P0.2 S0                          		; physical drive 0.2 goes backwards
        M584 X0 Y1 Z2                               ; set drive mapping
        M350 X16 Y16 Z16 I1               	    	; configure microstepping with interpolation
        M92 X800.00 Y800.00 Z400.00         	    ; set steps per mm
        M566 X500.00 Y500.00 Z200.00                ; set maximum instantaneous speed changes (mm/min)
        M203 X1500.00 Y1500.00 Z2000.00             ; set maximum speeds (mm/min)
        M201 X1000.00 Y1000.00 Z1500.00                ; set accelerations (mm/s^2)
        M906 X1800 Y1800 Z1700 I10                  ; set motor currents (mA) and motor idle factor in per cent
        M84 S100                               	    ; Set idle timeout
        M204 P1500 T3000
        M208 X0 Y0 Z0 S1                        	; set axis minima
        M208 X316 Y200 Z130 S0                       ; set axis maxima
        M574 X1 S1 P"!0.io3.in"                       ; configure active-high endstop for low end on X via pin
        M574 Y1 S1 P"0.io5.in"                       ; configure active-high endstop for low end on Y via pin
        M574 Z2 S1 P"!0.io6.in"                     ; configure active-high endstop for high end on Z via pin
        M950 F0 C"0.out5" Q200      	                          	; create fan 0 on pin out9 and set its frequency
        M106 P0 C"Board Fan1"                      ; set fan 0 value. Thermostatic control is turned off
        ; Spindle Control
        M950 R0 C"0.out6" Q70 L6000:24000                   ; configure spindle #0
        M950 P1 C"0.out3" Q500
        M42 P1 S0
        M950 P2 C"0.out4" Q500
        M42 P2 S0
        M563 R0 P0 S"Spindle"                                 ; create tool #0
        M453
        M568 P0 F0                                  ; set initial tool #0 active and standby temperatures to 0C
        G10 P0 X0 Y0 U0 Z0                          ; set tool 0 axis offsets
        G10 P0 R0 S0                                ; set initial tool 0 active and standby temperatures to 0C
        ; Mist Control
        ;M950 F0 C"0.out6" Q20000      	                          	; create fan 0 on pin out9 and set its frequency
        ;M106 P0 C"Mist Control" S0 L0.15 X0.85 H-1                     ; set fan 0 value. Thermostatic control is turned off
        M564 S0 H0								;Allow movement without homing (without axis maxima)
        ;T0                                          ; select first tool
        M575 P1 S1 B57600
        dhusoloundefined dc42undefined 2 Replies Last reply Reply Quote 0
        • dhusoloundefined
          dhusolo @dhusolo
          Any help would be greatly appreciated
            dc42 administrators @dhusolo
            @dhusolo you have a frequency to voltage converter, however what you need to interface the Duet spindle control to a VFD with 0-10V input is a PWM to voltage converter. See https://docs.duet3d.com/en/User_manual/Machine_configuration/Configuration_CNC#connecting-a-spindle.
            Note, when fed from the 10V supply on the VFD these devices can't supply as much as 10V output, so the full spindle speed is not available.
            With the frequency to PWM converter that you have, you would need to adjust the Q parameter in the M950 command that set up the port in order to vary the speed.
            In future we expect to support control of spindles via Modbus RTU. If your VFD supports the Modbus commands described in the manual you linked to then control over Modbus may be possible in future.
            dhusoloundefined 1 Reply Last reply Reply Quote 0
            • dhusoloundefined
              dhusolo @dc42
              @dc42 You sir are correct. I did get the wrong board. I installed an actual PWM to Voltage converter and wired it up. This is the one I'm using now
              Voltage output - (GND) goes to ACM
              Voltage output + (AO) goes to VI(I've also tried AI)
              I have a relay connected
              NO > DCM
              COM > FOR
              Right now I'm switching it with a macro but eventually I'll get it configured to automatically switch when the drive is working correctly. I know the relay is working because when I switch it on the FOR LED on the VFD goes to solid.
              I set:
              PD001 = 1
              PD002 = 1
              PD070 = 0
              I've moved the jumper to J1 enabling external potentiometer. I've tested the AO and GND and I am getting about 4.8v at 12k RPMs. But the VFD isn't recognizing the signal from the PWM converter
                @dhusolo how have you connected the converter to the VFD?
                • dhusoloundefined
                  dhusolo @dc42
                  @dc42 Yes I have. The connections are
                  PWM Input - > VFD GND Pin
                  PWM Input + > VFD(out6_buff) pin
                  Power Supply + > 12v+ next to VFD pins
                  Power Supply - > 12v- next to VFD pins
                  My config is
                  M950 R0 C"0.vfd+0.io4.out" Q3000 L24000                   ; create spindle #0 connected to vfd pin and 24k rpm at full PWM
                  M563 P1 S"Spindle" R0                                                      ; create tool #1 with spindle 0
                  M453        ; set cnc mode
                  M568 P1 F0
                  T1
                  M3 T1 S0
                  M5
                    @dhusolo where are you getting the 12V power from? It should be an isolated supply. Alternatively, use the 10V that the VFD provides for the pot.
                    dhusoloundefined 2 Replies Last reply Reply Quote 0
                    • dhusoloundefined
                      dhusolo @dc42
                      @dc42 12v power is coming from the 12v pins next to the VFD header.
                      • dhusoloundefined
                        dhusolo @dc42
                        @dc42 I confirmed the wiring is correct. I tested the voltage output at the PWM+/- pins and I can see the voltage changing when I adjust the speed in DWC.
                        This is the wiring
                        I have a relay connected to io4.out that shorts DCM to FOR when the spindle is turned on.
                        M453                                        ; set cnc mode
                        M568 P1 F0                                  ; set initial tool #0 active and standby temperatures to 0C
                        T1                                          ; select tool 1
                        M3 T1 S0
                        M5
                        I know this is working because when I turn the spindle I can hear the relay clicking and the numbers and the FOR LED on the VFD LCD go solid.
                        The jumper was moved from J2 to J1. I have the VFD configured for:
                        PD001 = 1
                        PD002 = 2
                        PD070 = 0
                          @dhusolo unfortunately you've purchased the non-isolated version of the converter. See https://docs.duet3d.com/en/User_manual/Machine_configuration/Configuration_CNC#connecting-a-spindle. I don't know whether your VFD will work using an external 12V supply, or whether you have you use the 10V output provided by the VFD. Do not try to feed the 10V output to that converter, it's not safe due to the lack of isolation.
                          You could try connecting a potentiometer to the 10V output of the VFD and the speed input, to check that the VFD is configured correctly to be controlled from that input.
                          • dhusoloundefined
                            dhusolo @dc42
                            @dc42 damn I'm an idiot. I see that now. I had some of those laying around and didn't realize those were the ones not to use. I'll have to order more green converter boards and see if I can get those to work.
                            I do have 1 of these 3.3v boards. https://www.amazon.com/dp/B08CRKRBX4?ref=ppx_yo2ov_dt_b_fed_asin_title
                            But would that work with a duet 3 mini?
                              @dhusolo yes that should work.
                              • dhusoloundefined dhusolo referenced this topic
