    HY VFD controlled by Duet 3 Mini
    CNC
    693
    • dhusoloundefined
      dhusolo @dhusolo
      Any help would be greatly appreciated
        dc42 administrators @dhusolo
        @dhusolo you have a frequency to voltage converter, however what you need to interface the Duet spindle control to a VFD with 0-10V input is a PWM to voltage converter. See https://docs.duet3d.com/en/User_manual/Machine_configuration/Configuration_CNC#connecting-a-spindle.
        Note, when fed from the 10V supply on the VFD these devices can't supply as much as 10V output, so the full spindle speed is not available.
        With the frequency to PWM converter that you have, you would need to adjust the Q parameter in the M950 command that set up the port in order to vary the speed.
        In future we expect to support control of spindles via Modbus RTU. If your VFD supports the Modbus commands described in the manual you linked to then control over Modbus may be possible in future.
        dhusoloundefined 1 Reply Last reply Reply Quote 0
        • dhusoloundefined
          dhusolo @dc42
          @dc42 You sir are correct. I did get the wrong board. I installed an actual PWM to Voltage converter and wired it up. This is the one I'm using now
          Voltage output - (GND) goes to ACM
          Voltage output + (AO) goes to VI(I've also tried AI)
          I have a relay connected
          NO > DCM
          COM > FOR
          Right now I'm switching it with a macro but eventually I'll get it configured to automatically switch when the drive is working correctly. I know the relay is working because when I switch it on the FOR LED on the VFD goes to solid.
          I set:
          PD001 = 1
          PD002 = 1
          PD070 = 0
          I've moved the jumper to J1 enabling external potentiometer. I've tested the AO and GND and I am getting about 4.8v at 12k RPMs. But the VFD isn't recognizing the signal from the PWM converter
            @dhusolo how have you connected the converter to the VFD?
            • dhusoloundefined
              dhusolo @dc42
              @dc42 Yes I have. The connections are
              PWM Input - > VFD GND Pin
              PWM Input + > VFD(out6_buff) pin
              Power Supply + > 12v+ next to VFD pins
              Power Supply - > 12v- next to VFD pins
              My config is
              M950 R0 C"0.vfd+0.io4.out" Q3000 L24000                   ; create spindle #0 connected to vfd pin and 24k rpm at full PWM
              M563 P1 S"Spindle" R0                                                      ; create tool #1 with spindle 0
              M453        ; set cnc mode
              M568 P1 F0
              T1
              M3 T1 S0
              M5
                @dhusolo where are you getting the 12V power from? It should be an isolated supply. Alternatively, use the 10V that the VFD provides for the pot.
                dhusoloundefined 2 Replies Last reply Reply Quote 0
                • dhusoloundefined
                  dhusolo @dc42
                  @dc42 12v power is coming from the 12v pins next to the VFD header.
                  • dhusoloundefined
                    dhusolo @dc42
                    @dc42 I confirmed the wiring is correct. I tested the voltage output at the PWM+/- pins and I can see the voltage changing when I adjust the speed in DWC.
                    This is the wiring
                    I have a relay connected to io4.out that shorts DCM to FOR when the spindle is turned on.
                    M453                                        ; set cnc mode
                    M568 P1 F0                                  ; set initial tool #0 active and standby temperatures to 0C
                    T1                                          ; select tool 1
                    M3 T1 S0
                    M5
                    I know this is working because when I turn the spindle I can hear the relay clicking and the numbers and the FOR LED on the VFD LCD go solid.
                    The jumper was moved from J2 to J1. I have the VFD configured for:
                    PD001 = 1
                    PD002 = 2
                    PD070 = 0
                      @dhusolo unfortunately you've purchased the non-isolated version of the converter. See https://docs.duet3d.com/en/User_manual/Machine_configuration/Configuration_CNC#connecting-a-spindle. I don't know whether your VFD will work using an external 12V supply, or whether you have you use the 10V output provided by the VFD. Do not try to feed the 10V output to that converter, it's not safe due to the lack of isolation.
                      You could try connecting a potentiometer to the 10V output of the VFD and the speed input, to check that the VFD is configured correctly to be controlled from that input.
                      • dhusoloundefined
                        dhusolo @dc42
                        @dc42 damn I'm an idiot. I see that now. I had some of those laying around and didn't realize those were the ones not to use. I'll have to order more green converter boards and see if I can get those to work.
                        I do have 1 of these 3.3v boards. https://www.amazon.com/dp/B08CRKRBX4?ref=ppx_yo2ov_dt_b_fed_asin_title
                        But would that work with a duet 3 mini?
                          @dhusolo yes that should work.
                          • dhusoloundefined dhusolo referenced this topic
