[3.6.0-rc.2] Code 3 move error
The issue is also present in 3.6.0-rc.1
Error: Code 3 move error: new: start=651528999 overlap=5623 time now=651492690, existing: s=651491803 t=42819 d=20.46 u=8.0975e-4 a=-1.5504e-8 f=18
@MaxGyver please provide the GCode file that provokes these errors.
Here you go:
LARGE SOFIA LAMPSHADE.gcode -
@MaxGyver thanks, I'll try to reproduce it. We haven't had any other reports of Code 3 errors since we released RC4.
@MaxGyver not related to the Code 3 errors, but I noticed this in your config.g file:
M205 X8 Y8 Z2 E10 ; M205 X5 Y5 Z2 E3 P0 ; set jerk;M566 X125 Y125 Z60 P0 ;set jerk
M205 and M566 no longer do the same thing with different units in 3.6. M566 sets the machine limits (in mm/min) while M205 sets the limits for the current print, if they are lower than the M566 limits when converted to the same units. See https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x-RC#upgrade-notes-from-354.
@MaxGyver I believe I have identified the cause of these errors. If I am right, they only occur when the input shaping frequency is below about 12Hz, which would explain why nobody else has reported Code 3 errors since we released beta4.
Please try the new 3.6.0-rc.2+2 main board firmware binary from https://www.dropbox.com/scl/fo/nlkfneaas1osgtdw37s17/AIS_H0KSAKCmfYSjSRTSOAE?rlkey=ad4omnq36zkdz3wl8i7kthqqt&dl=0. You may keep your expansion board binaries at 3.6.0-rc.2 or upgrade them to rc.2+1 from https://www.dropbox.com/scl/fo/kj7gwwzxg5lhe26twph5z/AAdwkPCTYi6bcogLmIIIup4?rlkey=8oo6z5il7wzk2u5b7qpykf3qv&dl=0.
I finally had a chance to test the latest 3.6.0-rc.3. When the input shaping frequency is set below 12Hz I still have a code 3 movement error always at the same code line early in the first layer. When the IS frequency is >12Hz it is working. I have attached the test pot.gcode file that is causing the error.
Error: Code 3 move error: new: start=335135293 overlap=3753 time now=335099122, existing: s=335096227 t=42819 d=20.49 u=8.1090e-4 a=-1.5526e-8 f=18
M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.6.0-rc.3 (2025-04-30 14:43:53) running on Duet 3 MB6HC v1.01 (SBC mode) Board ID: 0JD2M-999AL-D25S4-7J1D2-3SJ6K-T51V3 Used output buffers: 1 of 40 (19 max) === RTOS === Static ram: 137420 Dynamic ram: 98720 of which 0 recycled Never used RAM 107844, free system stack 130 words Tasks: LASER(5,nWait 7,0.0%,235) SBC(2,nWait 7,1.1%,813) HEAT(3,nWait 6,0.0%,368) Move(4,nWait 6,0.0%,209) TMC(4,nWait 6,3.0%,377) CanReceiv(6,nWait 1,0.1%,792) CanSender(5,nWait 7,0.0%,329) CanClock(7,delaying,0.0%,350) MAIN(1,running,83.7%,500) IDLE(0,ready,12.1%,29) USBD(3,blocked,0.0%,149), total 100.0% Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:02:34 ago, cause: software Last software reset at 2025-05-12 11:06, reason: User, Gcodes spinning, available RAM 82500, slot 1 Software reset code 0x2003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a Error status: 0x00 MCU temperature: min 33.9, current 34.3, max 35.0 Supply voltage: min 23.4, current 23.5, max 23.6, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0 Heap OK, handles allocated/used 99/16, heap memory allocated/used/recyclable 2048/320/52, gc cycles 0 Events: 599 queued, 599 completed Date/time: 2025-05-12 11:08:41 Slowest loop: 1545.84ms; fastest: 0.07ms === Storage === Free file entries: 20 SD card 0 not detected, requested/actual speed: 0.0/37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === Segments created 3, maxWait 68608ms, bed comp in use: none, height map offset 0.000, hiccups added 0/0 (0.00/0.05ms), max steps late 0, ebfmin 0.00, ebfmax 0.00 Pos req/act/dcf: -464285.00/-463726/-0.50 0.00/0/0.00 804000.00/804000/0.00 Next step interrupt due in 22 ticks, disabled Driver 0: standstill, SG min n/a, mspos 8, reads 47118, writes 11 timeouts 0 Driver 1: standstill, SG min n/a, mspos 8, reads 47118, writes 11 timeouts 0 Driver 2: standstill, SG min n/a, mspos 8, reads 47118, writes 11 timeouts 0 Driver 3: standstill, SG min n/a, mspos 8, reads 47118, writes 11 timeouts 0 Driver 4: standstill, SG min n/a, mspos 8, reads 47118, writes 11 timeouts 0 Driver 5: standstill, SG min n/a, mspos 8, reads 47118, writes 11 timeouts 0 Phase step loop runtime (us): min=0, max=40, frequency (Hz): min=1744, max=2358 === DDARing 0 === Scheduled moves 6, completed 5, LaErrors 0, Underruns [0, 0, 0] Segments left 0, axes/extruders owned 0x80000007, drives owned 0x80000007 Code queue is empty === DDARing 1 === Scheduled moves 0, completed 0, LaErrors 0, Underruns [0, 0, 0] Segments left 0, axes/extruders owned 0x00000000, drives owned 0x00000000 Code queue is empty === Heat === Bed heaters -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters 2 -1 -1 -1 -1 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.0 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by Trigger, null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 2 0 5 0, running macro Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 === Filament sensors === Driver 31: no filament === CAN === Messages queued 1431, received 9757, lost 0, ignored 0, errs 0, boc 0 Longest wait 4ms for reply type 6061, peak Tx sync delay 379, free buffers 50 (min 49), ts 734/733/0 Tx timeouts 0,0,0,0,0,0 === SBC interface === Transfer state: 5, failed transfers: 0, checksum errors: 0 RX/TX seq numbers: 6084/6084 SPI underruns 0, overruns 0 State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x27a24 Buffer RX/TX: 208/256-0, open files: 0 === Duet Control Server === Duet Control Server version 3.6.0-rc.3 (2025-04-30 10:29:48, 64-bit) HTTP+Executed: > Executing M122 Trigger: Buffered code: G1 H1 X-1205 F{global.homingspeed/2} ; move slowly to X axis endstop once more (second pass) Buffered code: G90 ; absolute positioning Buffered codes: 96 bytes total >> Doing macro trigger2.g, started by system >>> Doing macro homeall.g, started by G28 >>> Suspended code: M98 P"homey.g" >>>> Doing macro homex.g, started by M98 P"homex.g" Code buffer space: 3840 Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0 Full transfers per second: 40.77, max time between full transfers: 1750.1ms, max pin wait times: 39.5ms/4.0ms Codes per second: 0.71 Maximum length of RX/TX data transfers: 4468/904
@MaxGyver thanks for your report. When that error was reported, did you still have input shaping set to 8.7Hz EI3 in config.g?
@dc42 Yes, Input shaping was Set to 8.7Hz EI3.
@MaxGyver thanks.
I found a bug in the previous fix. Please try the 6HC build from https://www.dropbox.com/scl/fo/dumsdufoej44q97ek9joo/AIBRnU-wtKfMrbWPzZwH_XY?rlkey=idmyinvvcuiwmycbb1l2obz38&dl=0.
