    Prusaslicer with Duet3D mini5 based printer profile
    • handyandyundefined
      handyandy
      I have a Prusa mk4 3D printer and also a printer that I designed and built myself.
      My background is aerospce tooling design so (I think) the printer design and build is pretty good and very robust. It is a typical bed slinger, it uses a bear frame, Duet3 mini5 controller, Revo Hemera print head and a Prusa heatbed, and all other components are high quality.
      It works fairly well using the Cura 5.9 slicer to produce code for printing models. However, I feel much more comfortable with Prusaslicer 2.9 and would very much like to use this for all future printing.
      Can anyone on the forum help me with achieving this goal. Does any one have any example code for profile settings, start and end codes etc. that would get me started?
        droftarts administrators @handyandy
        @handyandy I think you asked this previously https://forum.duet3d.com/topic/37922/duet-3-mini-5-vs-prusa-mk4
        Perhaps start with the same settings as the Mk4, and tune extrusion (temperature, extrusion steps per mm) and see if you get similar results.
