    "tiny" 3d printer of high quality?
    1.5k
    • Qdeathstarundefined
      Qdeathstar
      If you want something that small with very high quality, look into getting a DLP resin printer printer…
      https://www.3dprintersonlinestore.com/wanhao-d7-resin-3d-printer?gclid=Cj0KCQiAnOzSBRDGARIsAL-mUB3e0HdJiB1Rv_k955hyU-eT7f8_FE73ZjW18RsPSbVG1LuqQ5PCH98aAq2kEALw_wcB
      https://www.aniwaa.com/product/3d-printers/formlabs-form-2/
      • tenajaundefined
        tenaja
        Thanks, but I already have a Form1+, and the resin strength does not seem to be there.
        • tenajaundefined
          tenaja
          To clarify my definition of quality, a "quality" FDM machine will not be sloppy, will not wear out fast (500 to 1k very small prints) and require lots of tuning. It should be repeatable, reliable, and predictable. The home positions will be the same place every time, and once the gcode is dialed in, it might only need slight tweaking if there are large variations between spools.
          My end goal is to set up a selector switch so the operator can turn it to the desired part (3-4 options), and hit start. I already have a "finicky" machine, and that is fine for one-offs, but this one is for low volume production of small parts so I don't have to spend time fiddling.
          • kraegarundefined
            kraegar
            Dice is a small FDM that can produce very high quality prints. http://www.instructables.com/id/DICE-a-Tiny-Rigid-and-Superfast-3D-printer/
            The build volume is smaller than you specified, though.
            You could scale down a railcore II perhaps: https://www.thingiverse.com/thing:2407174
            Though I've not looked too hard into going smaller - most people want it to be scaled up.
              I suggest a miniature delta using Nema 14 motors and magnetic/Delrin rods, although I don't know of an existing design for one that small. You could control it with a PanelDue modified so that it only allows the operator to run the predefined macros.
              • kraegarundefined
                kraegar
                The SeeMeCNC Eris is pretty small, too, but was discontinued. Might be able to find one used very cheap. With a duet added, the quality might be good enough.
                • DjDemonDundefined
                  DjDemonD
                  its just an idea but there is a microdelta design, magnetic rods would probably help, but at this size accuracy is easier to achieve so it works quite well with traxxas joints.
                  https://www.thingiverse.com/thing:1874766
                  www.precisionpiezo.co.uk
                    One other thought: with a larger printer, you could print several of the same parts simultaneously. For example, if you print 4 at a time, then only 1/4 as much operator intervention is needed to remove the completed prints and start a new set.
                    • stephencundefined
                      stephenc
                      I've built something small and good looking 🙂 though I wouldn't say my machine is operator friendly…
                      Stephen
                      https://github.com/stephenci/ZideX
                      • tenajaundefined
                        tenaja
                        @dc42:
                        That size I quoted IS big enough to print 4 at a time… 🙂 Probably big enough for 8 at a time with 2 print heads. They are small parts.
                        Actually, the qty is low enough that 2 print heads is not necessary, but it is what I am doing now. I just want a simple solution to make a few parts a week without tying up my big machine. It seems I always need to make parts when I want to use it for something else.
                        As for the kits and DIY machines, I am just too busy to tackle another project. I don't mind spending a little time to tune it and make it semi-automatic, but I don't have time for a build.
                        • DjDemonDundefined
                          DjDemonD
                          How about this system?
                          https://www.youtube.com/watch?v=lzYMd95iSsg&feature=youtu.be
                          It uses the 86duino printer, PLA only I suspect but can print quite a few items with the option build plate cassette.
                          • tenajaundefined
                            tenaja
                            I love that automation; unfortunately, these parts are too low volume for it to be practical. I would set something like that up if I was lacking in projects.
