    Better rejection of unsupported files
    Firmware wishlist
    • GrodanBundefined
      GrodanB
      Made the mistake of uploading an STL instead of a .GCODE file.
      The duet rightly complained that this file made no sense.
      I then had to go to the printer and press STOP to get it to reset and made it possible for the web browser to connect.
      I would really like a more graceful version of error handling for the fault: "Stupid user"… ( 🙂 ) Since I will probably cause it again...
      • heathmancundefined
        heathmanc
        Amen.
        • DADIYundefined
          DADIY
          The newer versions of DWC by default limit the file you can upload unless you click 'All Files' in the upload window.
          • Juggeliundefined
            Juggeli
            Yep, made that mistake too. After upload the web interface just disconnected for no obvious reason and i couldn't connect back. Did a reset and uploaded again for like 5 times before realising that my slicer saved the gcode to different directory 😄
