    Firmware 1.19 connection problems
    Firmware installation
    1.6k
      Have you tried the 1.20 release?
      • Michel000undefined
        Michel000
        Was there a bug in 1.19 that is fixed in 1.20 ?
        i read the thread about 1.20 some are also reporting connection problems,
        Maybe i try that one today.
          Michel000
          1.20 fixed the problem
            Michel000
            sorry it did not fixed the problem, i still get the AJAX errors.
            Im running :
            Duet wifi 1.) + Duex2
            firmware version 1.20
            wifi server version 1.20
            web interface version 1.19.3
            Is it possible to go back to the old firmware ? i didnt have this problem before.
            This is my M122 reply.
            M122
            Used output buffers: 4 of 32 (10 max)
            RepRapFirmware for Duet WiFi version 1.20 running on Duet WiFi 1.0 + DueX2
            Board ID: 08DAM-999TL-MQ4S8-6J9F2-3S06T-9497Z
            Static ram used: 15448
            Dynamic ram used: 99448
            Recycled dynamic ram: 3888
            Stack ram used: 1392 current, 8440 maximum
            Never used ram: 3848
            Last reset 00:12:23 ago, cause: power up
            Last software reset details not available
            Error status: 0
            Free file entries: 9
            SD card longest block write time: 203.5ms
            MCU temperature: min 16.8, current 30.8, max 31.1
            Supply voltage: min 24.0, current 24.0, max 24.5, under voltage events: 0, over voltage events: 0
            Driver 0: ok, SG min/max 0/140
            Driver 1: ok, SG min/max 0/173
            Driver 2: standstill, SG min/max 0/148
            Driver 3: ok, SG min/max 0/180
            Driver 4: ok, SG min/max 0/124
            Driver 5: ok, SG min/max 0/192
            Driver 6: ok, SG min/max 0/187
            Expansion motor(s) stall indication: yes
            Date/time: 2018-01-21 11:39:24
            Cache data hit count 2958946100
            Slowest main loop (seconds): 0.206642; fastest: 0.000045
            MaxReps: 5, StepErrors: 0, FreeDm: 145, MinFreeDm 105, MaxWait: 2930606083ms, Underruns: 0, 0
            Scheduled moves: 1515, completed moves: 1496
            Bed compensation in use: none
            Heater 0 is on, I-accum = 0.0
            Heater 1 is on, I-accum = 0.1
            Heater 2 is on, I-accum = 0.3
            Segments left: 1
            Movement lock held by null
            http is idle in state(s) 0
            telnet is idle in state(s) 0
            file is doing "G1 X70.409 Y135.981 E4.72573" in state(s) 0
            serial is idle in state(s) 0
            aux is idle in state(s) 0
            daemon is idle in state(s) 0
            queue is idle in state(s) 0
            Code queue is empty.
            Network state is running
            WiFi firmware version 1.20
            WiFi MAC address 5c:cf:7f:2c:25:2f
            WiFi Vcc 3.32, reset reason Turned on by main processor
            WiFi flash size 4194304, free heap 16416
            WiFi IP address 192.168.2.15
            WiFi signal strength -69dBm, reconnections 0, sleep mode modem
            HTTP sessions: 1 of 8
            Socket states: 0 2 2 0 0 0 0 0
            Responder states: HTTP(1) HTTP(1) HTTP(0) HTTP(0) FTP(0) Telnet(0)
              Michel000
              i see my wifi strength is not great -69dBm, but i dont think this has anything to do with it.
              For example if i upload file it just works fine even with really big ones,
                Michel000
                i missed the number of AJAX retries setting, it was set to 1, changed to 5 and it is a bit better,
                But i still get disconnects.
                Maybe i set it to a really high number.
                But it doesnt really fix the problem i think it just makes it workable
                  Michel000
                  oke with AJAX retries set to 50 i was connected for 5 minutes. but then i get the AJAx error
                  and i could not reconnect again it looks like web server is just down . My browser gives me this error : ERR_CONNECTION_RESET
                  When i send ping to the Duet it does reply so it does have a wifi connection.
                    Michel000
                    is there a special procedure to go back to the old firmware ?
                    i think the last working version (for me) was :
                    • DuetWifiFirmware-1.17e
                    • Duetwebcontrol-1.14a
                    • DuetWifiServer-1.03-ch
                      Have you tried both versions 1.20 and 1.20+1 of DuetWiFiFirmware?
                        Michel000
                        i download this version : https://github.com/dc42/RepRapFirmware/releases/
                        thats 1.20
                        Where can i get the 1.20+1 ?
                        I prefer to go for the latest version that didnt have the disconnect problems .
                        i see on this board users who have this 1.20+1 version and the are also reporting disconnects.
                        I dont have a panel due connected so my only option to print is with the webinterface.
                          Michel000
                          i will upload the old firmware today and hope it will work.
                            Michel000
                            i installed the old firmware, and untill now i didnt see any Ajax erros .
                            it looks like there is a bug in the 1.19 and later firmware. or my board is broken.
                            would be nice if this is fixed so i can also enjoy the new features.
                              Michel000
                              its running for 5 hours now and still no AJAX errors.
                              So im happy i can print again, but if its not fixed , im stuck with old firmware….
