    Firmware 1.19 connection problems
    Firmware installation
    1.6k
    • Michel000undefined
      Michel000
      Was there a bug in 1.19 that is fixed in 1.20 ?
      i read the thread about 1.20 some are also reporting connection problems,
      Maybe i try that one today.
        Michel000
        1.20 fixed the problem
          Michel000
          sorry it did not fixed the problem, i still get the AJAX errors.
          Im running :
          Duet wifi 1.) + Duex2
          firmware version 1.20
          wifi server version 1.20
          web interface version 1.19.3
          Is it possible to go back to the old firmware ? i didnt have this problem before.
          This is my M122 reply.
          M122
          Used output buffers: 4 of 32 (10 max)
          RepRapFirmware for Duet WiFi version 1.20 running on Duet WiFi 1.0 + DueX2
          Board ID: 08DAM-999TL-MQ4S8-6J9F2-3S06T-9497Z
          Static ram used: 15448
          Dynamic ram used: 99448
          Recycled dynamic ram: 3888
          Stack ram used: 1392 current, 8440 maximum
          Never used ram: 3848
          Last reset 00:12:23 ago, cause: power up
          Last software reset details not available
          Error status: 0
          Free file entries: 9
          SD card longest block write time: 203.5ms
          MCU temperature: min 16.8, current 30.8, max 31.1
          Supply voltage: min 24.0, current 24.0, max 24.5, under voltage events: 0, over voltage events: 0
          Driver 0: ok, SG min/max 0/140
          Driver 1: ok, SG min/max 0/173
          Driver 2: standstill, SG min/max 0/148
          Driver 3: ok, SG min/max 0/180
          Driver 4: ok, SG min/max 0/124
          Driver 5: ok, SG min/max 0/192
          Driver 6: ok, SG min/max 0/187
          Expansion motor(s) stall indication: yes
          Date/time: 2018-01-21 11:39:24
          Cache data hit count 2958946100
          Slowest main loop (seconds): 0.206642; fastest: 0.000045
          MaxReps: 5, StepErrors: 0, FreeDm: 145, MinFreeDm 105, MaxWait: 2930606083ms, Underruns: 0, 0
          Scheduled moves: 1515, completed moves: 1496
          Bed compensation in use: none
          Heater 0 is on, I-accum = 0.0
          Heater 1 is on, I-accum = 0.1
          Heater 2 is on, I-accum = 0.3
          Segments left: 1
          Movement lock held by null
          http is idle in state(s) 0
          telnet is idle in state(s) 0
          file is doing "G1 X70.409 Y135.981 E4.72573" in state(s) 0
          serial is idle in state(s) 0
          aux is idle in state(s) 0
          daemon is idle in state(s) 0
          queue is idle in state(s) 0
          Code queue is empty.
          Network state is running
          WiFi firmware version 1.20
          WiFi MAC address 5c:cf:7f:2c:25:2f
          WiFi Vcc 3.32, reset reason Turned on by main processor
          WiFi flash size 4194304, free heap 16416
          WiFi IP address 192.168.2.15
          WiFi signal strength -69dBm, reconnections 0, sleep mode modem
          HTTP sessions: 1 of 8
          Socket states: 0 2 2 0 0 0 0 0
          Responder states: HTTP(1) HTTP(1) HTTP(0) HTTP(0) FTP(0) Telnet(0)
            Michel000
            i see my wifi strength is not great -69dBm, but i dont think this has anything to do with it.
            For example if i upload file it just works fine even with really big ones,
              Michel000
              i missed the number of AJAX retries setting, it was set to 1, changed to 5 and it is a bit better,
              But i still get disconnects.
              Maybe i set it to a really high number.
              But it doesnt really fix the problem i think it just makes it workable
                Michel000
                oke with AJAX retries set to 50 i was connected for 5 minutes. but then i get the AJAx error
                and i could not reconnect again it looks like web server is just down . My browser gives me this error : ERR_CONNECTION_RESET
                When i send ping to the Duet it does reply so it does have a wifi connection.
                  Michel000
                  is there a special procedure to go back to the old firmware ?
                  i think the last working version (for me) was :
                  • DuetWifiFirmware-1.17e
                  • Duetwebcontrol-1.14a
                  • DuetWifiServer-1.03-ch
                    Have you tried both versions 1.20 and 1.20+1 of DuetWiFiFirmware?
                      Michel000
                      i download this version : https://github.com/dc42/RepRapFirmware/releases/
                      thats 1.20
                      Where can i get the 1.20+1 ?
                      I prefer to go for the latest version that didnt have the disconnect problems .
                      i see on this board users who have this 1.20+1 version and the are also reporting disconnects.
                      I dont have a panel due connected so my only option to print is with the webinterface.
                        Michel000
                        i will upload the old firmware today and hope it will work.
                          Michel000
                          i installed the old firmware, and untill now i didnt see any Ajax erros .
                          it looks like there is a bug in the 1.19 and later firmware. or my board is broken.
                          would be nice if this is fixed so i can also enjoy the new features.
                            Michel000
                            its running for 5 hours now and still no AJAX errors.
                            So im happy i can print again, but if its not fixed , im stuck with old firmware….
