    Weird issue PanelDue. I think it has a bad SB diode. Ideas?
    PanelDue
    2.7k
    • ddt154undefined
      ddt154
      David,
      Thanks for the TIP. LOL.. I did the M111 command, but had designated P15. P3 works much better 🙂
      So I uploaded new firmware and still the same. I then left it powered off for 4 hours and I hooked up Saleae Logic Pro analyzer. Upon power-on - it worked perfectly and I captured the data. I was even able to do a M115 and get back that data. So then powered everything off and on again.. and then the logic analyzer captured tons of framing errors and PanelDue upper right was stuck on "Connecting". I ordered replacement SB Diodes which will be arriving Monday. Hopefully that'll do the trick.
      Funny thing is.. I forgot I had the Logic Analyzer. Let's just say it's been a long week 🙂 I also checked the pins around the Atmel SAM chips and they appeared to be ok. I may hit those pin areas with an clean tipped iron this weekend. Who knows..
      TIA,
      Drew
        Were the framing errors in the data on the PanelDue DOUT pin, or on the DIN pin?
        If you let me know which size screen you have, I'll do you a firmware build from the latest unreleased source code.
        • ddt154undefined
          ddt154
          LOL - I should have noted that, before unplugged and put away the analyzer. I really want to redo the testing but not sure I have time today to work on it. I have stuff to do with wife & kids. One extra thing I did notice was that when it does work from being off for awhile, the display goes in sequence of "Starting Up", to "Connecting", then to "Idle". Then it seems to work for like a minute before something goes wrong and stops communicating. Also.. after unplugging it from that state or doing a reset. I noticed the display goes straight to "Connecting" and seems to skip "Starting Up". idk. maybe the comm lines need a reset or something. David - I greatly appreciate your help in this, but to be honest I feel a bit lazy. I can probably import your firmware code and run code in HW debug mode and see what is going on myself and just report back. I was able to get Marlin imported into AS7 and do HW debug with that with a RAMPS 1.4 board.. I only have one Atmel-ICE so could only do testing from PanelDue or DuetWiFi at a time. Would be neat to have both setup and running at same time 🙂 I'll keep you posted and thanks for such great work!
          TIA,
          Drew
            I plan to release a new PanelDue firmware beta tomorrow, so please try that one. I suspect that the issue you are seeing is caused by a firmware bug.
            PanelDue doesn't always see the "Starting up" state of the Duet when it connects.
            • ddt154undefined
              ddt154
              Hi David. So this time I connected 4 probes.
              Probe 0 @ PanelDue CONN_SD Din (was easy to connect probe here)
              Probe 1 @ PanelDue CONN_SD Dout (same as above)
              Probe 2 @ DuetWiFi CONN_SD Pin10 - UTXD0 (aka Din of Panel)
              Probe 3 @ DuetWiFi CONN_SD Pin09 - URXD0 (aka Dout of Panel)
              Upon cold boot, first communication started at 1.32s and was from panel. ~7.7ms later, Duet responded.. and they then communicated back and forth every 1s. First framing error occurred 52.8 seconds from power-on. After that framing errors were prevalent every second or so. Framing errors only showed on probe 0 & 3 which are the Dout. So from my standpoint data is corrupt before it reaches the SAM chip on the DuetWiFi board.
              I have 2 good data captures with Saleae Logic. 1st one is 4MB and 2nd one is 13MB. First session shows everything working as expected up until that 52.8s point. If you want, I can send you the files. Download of Saleae Logic is free and will work in simulation mode if you don't have the analzer probe, however you can open the capture data files and check out the data yourself.
              So IMHO I think the culprit is either that SB Diode or the SAM chip on the PanelDue board. I'm out of time now, but I could put older firmware back on the boards to see if something in new firmware is causing this. PM me if you would like for me to email or upload those capture files.
              Also, I have an order of SB Diodes arriving tomorrow, so I intend on doing a replacement sometime tomorrow.
              Best regards,
              Drew
              • ddt154undefined
                ddt154
                Ah - just saw your last post. Will hold off on the SB diode replacement until I try out your new beta code.
                Many thanks!
                -Drew
                  A framing error suggests to me that the ATSAM is no longer transmitting correctly. Assuming you have set your logic analyser to the correct parameters (57600 baud, 1 stop bit, no parity bit) that suggests to me a firmware error or a faulty microcontroller.
                  • ddt154undefined
                    ddt154
                    Probe settings confirmed. 57600, 1 stop bit, no parity. Also- you had asked what screen size I had. That would be 4.3".
                    I am thinking it's a bad chip and not firmware. But- It may be a "it depends". Some SAM chips have one HW SPI port whereas others may need to be setup as SW. idk.. just thinking aloud.
                      If you are brave, you can try the binary here: https://www.dropbox.com/s/ya3s46660yxvl1t/PanelDue-v3-4.3.bin?dl=0. I haven't tested it, but the 5" build from the same source code seems to work properly so far.
                      • ddt154undefined
                        ddt154
                        AH- that's not brave! Brave is what may come next.. SMD rework 🙂 I did try that binary and still a no-go 😞 . Going to try that SB Diode next and if that doesn't fix it.. then I'll order a few ATSAM4S4BA chips and.. see how it goes.
                        Keep you posted.
                        -dt
                          What happened when you tried the new binary: did it not work at all, or work but had the same issue?
                          The PanelDue board will work without that diode present. Its main purpose is to provide compatibility with 5V systems by limiting the voltage that can appear on the pins of the ATSAM.
                          • ddt154undefined
                            ddt154
                            I figured it was for that. Hmm.. I could setup some of those probes of Logic Analyzer to Analog mode an analyze voltage. Ah - I just checked the DuetWiFi. It doesn't have any protection. The DuetWiFi's URXD0 and UTXD0 pins plugs directly to pin 75 and 66 of the ATSAM4E8E. So in theory.. I could remote the diode and the 2.2K resistors on the PanelDue board. I just have to bridge over where the resistors were.
                            • ddt154undefined
                              ddt154
                              David - truly puzzling. I left the display disconnected for several days as I worked on other parts of the build. Today I reconnected it for cable length sizing, etc.. and it just works. Typically it would stop working after coming up on a minute of start-up, however it has been on for at least 10 mins and counting. For the record - running v1.21RC1 on DuetWiFi and 1.20b2 on DuePanel.
                              I'm trading in my CmpEn/Sci degree and going back for a degree voodoo/witch doctor.
                              -dt
                              • garyd9undefined
                                garyd9
                                @ddt154:
                                Many would say they are already one and the same.
                                • ddt154undefined
                                  ddt154
                                  LOL disregard. Stopped working a second ago.
                                  It apparently just does not like me and is messing with me.
                                  Will keep you updated. Should be received new PanelDue board in a week.
                                  -dt
                                    If the framing errors are on the PanelDue data out pin, then likely causes are:
                                    1. Intermittent short between that data out pin and something else, in the cable or at the Duet;
                                    2. The pin on the MCU that generates data out is not properly soldered down to the pad, or has a minute solder bridge to an adjacent pin.
                                    I guess there is also the possibility of the crystal oscillator on the PanelDue not running smoothly.
                                    • ddt154undefined
                                      ddt154
                                      interesting - I discovered panel can receive data from Duet. Using WiFi/Web interface I did a print and noticed on the panel that it is getting print status. Ie Temperature readings. But yet on the Panel, it shows I have 4x extruders, but on DuetWiFi.. it is programmed for 1. I'm going to hit the pins with soldering iron.. We'll see if that makes a difference.
                                      -dt
                                        Another way to test data reception by the Duet is to use M117 or M300 commands.
                                        • ddt154undefined
                                          ddt154
                                          Status Update: fixed
                                          So hit the R4 and R5 2k2 resistors, D3 sb diode, and output pins with soldering iron. Worked for awhile and then stopped transmitting again, like before. I then removed these resistors and diode and then bridged over where the 2k2 resistors were and voila, PanelDue is working.
                                          So I tested the 2k2 resistors and they are ok, however SB diode seems to be the culprit in this case.
                                          I'll keep you posted if this arises again.
                                          Many thanks for your help
                                          -Drew
